 Old 07-02-2019, 11:18 PM   #1
Joedirt's Avatar
Posts: 6   (View Stats)
Joedirt is an unknown quantity at this point
Default Fuel pressure at RPM
Hi
I’m having a dilemma in figuring out wtf is going on with my 2012 cx7
Started misfiring and died one day
Plugs,intake gaskets,pcv valve etc etc are new
At startup it dies right away,only way to start it is to Disconnect MaF to get it idling but fluctuating 1000-750rpm untill hot then idles at 750rpm after that with maf connected
It passes the RV test ,At idle fuel pressure is around 1000psi at operating temps and initial start when cold
New O2 sensors but upstream is maxed at 25% at operating temps and open loop
Vac is 20 at idle,17 with ac on
Egr is clean
Car is undriveable, misfires and will not accelerate or even rev up
Joedirt is offline   Reply With Quote
 Old 07-03-2019, 06:21 AM   #2
Police - Grammarhead
Vansquish's Avatar
Originally Posted by Joedirt View Post
Hi
Egr is clean
I assume when you say that "upstream is maxed at 25%" that you're actually referring to fueling corrections.
What intake are you running? Does the new intake have a significantly larger-than-stock diameter MAF housing? Does it have an air-straightener?
Are all of the boost tubes, intercooler, and intake properly connected (no pinched, cut, or otherwise damaged or unsecured silicone tubes, etc.)
The reason I ask is that your symptoms sound like a classic massive vacuum leak.
 Old 07-03-2019, 09:18 AM   #3
Joedirt's Avatar
All stock
It dose sound like it but not by the vacuum numbers on the scanner and i’ve Checked for leaks
What are the fuel psi numbers supposed to be at idle and then at 2000 rpm
Plugs are not lean but rich
 Old 07-03-2019, 09:33 AM   #4
Vansquish's Avatar
All stock
At idle, your fuel pressure should be in the 400-500 range, if memory serves. I couldn't tell you what it should be at 2000rpm, as it really depends on the driving conditions, calculated load, etc.. Under high load, your fuel pressure should be around 1600-1650psi.
 Old 07-03-2019, 10:18 AM   #5
Posts: 2,233   (View Stats)
have you checked engine compression, it will tell a lot about engine bloc and timing health just in case.
if i get it right, it die quickly if you start it with the maf connected but it can keep running for a while if you disconnect it. just in case your in tank fuel pump isn t receiving proper voltage thru the relay and resistor but i think it would die in both case....
it sound like a leak as stated above and your vacuum get irrelevant if it is between tb and maf....you would need to do a boost leak test to check it.
 Old 07-03-2019, 10:46 AM   #6
Joedirt's Avatar
Done a pressure(boost) leak test on intake system
Fuel pressure is then very high if I’m 600psi above normal idle range
I’ve seen idle vids online at 1600-1660psi
In tank is fine 55-75psi prime pressure
 Old 07-03-2019, 11:00 AM   #7
Vansquish's Avatar
Not necessarily. Even the idle fuel pressure depends on what you're doing to maintain the idle. If you're having to add throttle to keep the motor on, you may be inadvertently causing the car to increase fuel rail pressure.
The symptoms you've described really do sound like a massive vacuum leak. However, given that the car won't start at all with the MAF hooked up, and will only maintain idle after the car is already warmed up with the MAF sensor connected, you may have a bad MAF sensor.
I would suggest that you see if you can find someone near you who would be willing to swap MAF sensors to test that theory. If you need to buy a new MAF sensor ONLY an OEM MAF sensor will work. The aftermarket ones are not calibrated correctly, and this has been proven time after time on this forum and elsewhere.
 Old 07-03-2019, 11:03 AM   #8
Joedirt's Avatar
MAF has been replaced and is reading good
This is not touching the throttle
 Old 07-03-2019, 11:07 AM   #9
Vansquish's Avatar
What were you doing when the car starting to misfire and died?
If it is misfiring, you should be throwing some codes. What are they?
 Old 07-03-2019, 11:15 AM   #10
Joedirt's Avatar
Car gas just being driven normally
No codes when it happens
The codes on it now are from disconnecting throttle body and replacing it,permanent codes that need to cycle off
Injectors have been replaced
It gets better when warm but no leak by injectors
Last edited by Joedirt; 07-03-2019 at 11:15 AM. Reason: MSF Database - Automerged Doublepost
 Old 07-03-2019, 11:50 AM   #11
Vansquish's Avatar
If there are no codes, then it probably isn't misfiring. I know my car throws misfire codes within about 4 engine revolutions if something is amiss with one of the cylinders.
As to your comment about the injectors, why don't you give us a full run-down of what was done to the vehicle *prior* to the problem happening, and what you have done since then.
So far, you've given piecemeal information and have been adding variable after variable as a result. It's hard enough to try and remotely diagnose something without being given all of the background information.
Additionally, can you take a datalog of the car running and/or trying to run?
 Old 07-03-2019, 12:09 PM   #12
Joedirt's Avatar
As the title states I’m looking for solid information on fuel pressure readings
All parts where replaced after problem started
No log possible at this time
 Old 07-03-2019, 12:13 PM   #13
Vansquish's Avatar
Well, you've been given that information (and you could've found it with about 5 minutes worth of searching of this very forum). Moreover, a comment that, "All parts where(sic) replaced after problem started" gives us nothing to go on at all. What parts were replaced? What is the full list of the parts that have been replaced? In any case, since you don't seem to want actual help with the diagnosis, I'll go ahead and bow out here and leave your questions to others with more time to burn on this than I have.
Good luck to you, sir.
 Old 07-03-2019, 02:19 PM   #14
Posts: 2,826   (View Stats)
Did you use an OEM Mazdaspeed 3/6 MAF sensor? While many aftermarket parts work well, the MAF sensor is not one of them.
If you installed a new OEM MAF, then, obviously this points to something else. But, if you bought aftermarket, or bought the one for the standard Mazda 3, this could well be all or a part of your problem.
0 Fuel Pressure/0.0 Volts HPFP Voltage...but I do have fuel pressure?? AFcadet MazdaSpeed 3/6 - Troubleshoot/Diagnostics 26 08-02-2019 11:09 PM
Help Please: Low Fuel Pressure CruZ_MS6 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 21 05-06-2017 06:09 AM
Anyone else have 80,000 psi of DI fuel pressure? mdd5148 MazdaSpeed 3/6 - ECU Computer Tuning 10 09-03-2011 10:04 AM
Fuel Pressure PID bewsted 2010 MS3 - ECU Computer Tuning 16 02-03-2011 10:45 AM
Fuel pressure dip myms3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 15 05-03-2008 12:37 PM
Page generated in 0.33173 seconds with 23 queries
