 Old 08-03-2010, 03:54 PM   #1
Chriscote's Avatar
Posts: 913   (View Stats)
Chriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the worldChriscote is the leader of the world
Groans: 137
Default idle smoke getting serious
just installed my cpe tbe about 2 weeks back and now i am starting to smoke... badly. only at idle when reversing out of the driveway or sitting in traffic. i leave for college in 10 days so i need to try something. Any input would be greatly appriciated
Thanks and regards
Chris (GA)
Chriscote is offline   Reply With Quote
 Old 08-03-2010, 04:10 PM   #2
Kdawg207's Avatar
Posts: 2,389   (View Stats)
Kdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the worldKdawg207 is the leader of the world
Search would be step 1
And yur not fixin that in 10 days
Change yur oil to 5/40. Bnoon bolt. Catch can.
Cross fingers it goes away after that.
~~~NJ Nator OG~~~Then AND Now, Just Better~~~
Kdawg207 is offline   Reply With Quote
The Following 2 Users Say Thank You to Kdawg207 For This Useful Post:
Chriscote (08-03-2010), dougefresh_ (08-04-2010)
 Old 08-04-2010, 12:56 PM   #3
dougefresh_'s Avatar
Posts: 4,489   (View Stats)
Go into ATR, and bump your idle to 950. I did that to get rid of some idle vibs from my mounts, and it made a HUGE difference if reducing smoke. In ATR, go to 'Idle Speeds' A & B, and increase 140, 176, and 212F values to 950. Do this to both tables, and change your oil to 10w/40 as already suggested. I started getting a lot of smoke after I put my TP in, and all I've done is raise the idle and it helped a LOT. I'll probably switch to 5w/40 at my next oil change. A lot of people bump their idle (amongst other things) to help w/ the smoke. You can do both of these in a half hour, and it should help a lot.
GL
 Old 08-04-2010, 12:58 PM   #4
ms3brendan's Avatar
Posts: 1,017   (View Stats)
ms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the worldms3brendan is the leader of the world
Yeah. it's been about 2ish weeks for me too and yesterday I noticed sitting at a light for about a minute I started smoking. 5w40 for my next oil change and OCC in the next month or so..
2012 BMW 135i //M-Sport
ms3brendan is offline   Reply With Quote
 Old 08-04-2010, 01:21 PM   #5
Try bumping your idle... My car did the same thing at sets of lights. It was getting so bad I'd kill the engine if I was at a long light. Just bumping the idle cured that. Not completely, but I've left my car idling for 5 minutes w/ no smoke. Sometimes it will but it's so much better. Well worth it, and won't affect your tune, etc...
 Old 08-04-2010, 01:23 PM   #6
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
is your TBE catless?
 Old 08-04-2010, 01:39 PM   #7
ms3brendan's Avatar
It's true. And easy enough to do.
And I've got the CPE catted DP.. thought the cat would help with smoking.. Not sure if the OP's DP is catted or not..
 Old 08-04-2010, 01:43 PM   #8
m4tic's Avatar
Posts: 4,928   (View Stats)
this just shows how much smoke your stock cat was hiding... its like mazda put the second cat to hide the smoke :/
2017 Daytona 392
STOLEN//2015 BMW S1000R
2007 MS6 w/ Cheez
 Old 08-04-2010, 01:47 PM   #9
MattJackson86's Avatar
Posts: 1,407   (View Stats)
MattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the worldMattJackson86 is the leader of the world
Bumping the idle is the only "fix" for me. I don't have an AP so I just hold the gas a little...yes it sux. Having the AC on bumps the idle too and that helps.
GTX3071 - SURE 3.25" Full3 Aeros - CP-E FMIC - CP-E Catted Downpipe - CNT Catback Exhaust - HKS SSQV BPV - James Barone 88 Trilogy - KMD CDFP Internals - CP-E Injector Seals - Cobb EBCS - ITV22 at .025 - 3 Bar MAP
Bitwise Motorsports http://www.bitwise-motorsports.com -
Mazdaspeed 3 BAR MAP Harness, Torque Plugins for Android, and 3-Port EBCS (coming soon!)
MattJackson86 is offline   Reply With Quote
The Following User Says Thank You to MattJackson86 For This Useful Post:
kgb (11-07-2010)
 Old 08-04-2010, 01:52 PM   #10
treyclash's Avatar
Posts: 592   (View Stats)
treyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond repute
Groaned at 321 Times in 98 Posts
is it bad for the car to be smoking like this at idle or is it just an annoyance he is trying to fix?
2010 Mazdaspeed 3 Liquid Silver.
Performance: -K&N SRI. -CP TP. -Forge BPV.
Interior: -DashDaq.
Exterior: -Rally Armor Mud Flaps. - Xenon 35w 6000.
treyclash is offline   Reply With Quote
 Old 08-04-2010, 02:08 PM   #11
silentwolf8's Avatar
Posts: 1,986   (View Stats)
silentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the worldsilentwolf8 is the leader of the world
Groans: 44
i had that issue as well when at idle.. did u install the tbe urself??? if so you may have not gotten the seals fully down. or something may be leaking.. i had to take to dealer when i had issues, not cause of the smoking nor did i tell them it was doing that.. but they did tell me that my seals werent fully connected even though it sure as hell felt like it when i put bk on..
just a thought.
silentwolf8 is offline   Reply With Quote
 Old 08-04-2010, 02:11 PM   #12
ms3brendan's Avatar
just a thought.
I did the cat-back myself and the DP I had a mechanic do because I couldn't for the life of me reach that bolt on the bottom of the DP lol, now I think I can reach it with the CPE on there, the reach is much easier but.. before.. not a chance.
 Old 11-03-2010, 12:52 AM   #13
Chriscote's Avatar
Groans: 137
i guess ill update because we lost 60 days... why the hell not. bnoon bolt and w50 stopped my smoking!
 Old 11-03-2010, 11:47 AM   #14
Cool. You meant 5w40 right?
 Old 11-03-2010, 12:22 PM   #15
DSIT995's Avatar
Posts: 1,768   (View Stats)
I hope he meant 5w40! lol
Bumping up idle to 900-950 also worked for my very occasional smoking, have had zero probs since
99 Miata NB - Stock for now
 Old 11-03-2010, 12:46 PM   #16
m4tic's Avatar
1100 rpm idle ftw
2017 Daytona 392
2007 MS6 w/ Cheez
 Old 11-03-2010, 01:43 PM   #17
Chriscote's Avatar
Groans: 137
why?
smoke on idle? kraz3y MazdaSpeed 3/6 - Turbo Induction 20 01-09-2013 03:26 AM
Smoke at idle sleeper329 MazdaSpeed 3 - Engine, Transmission & Driveline 8 06-13-2010 01:56 PM
smoke at idle ms3-87 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 12 05-31-2008 01:15 PM
Page generated in 0.37392 seconds with 29 queries
