Like Tree115Likes
 Old 04-22-2016, 07:51 AM   #721
sh4d0w's Avatar
Posts: 565   (View Stats)
sh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the worldsh4d0w is the leader of the world
Groans: 45
Groaned at 7 Times in 4 Posts
Hey Tokay glad to have you back haven't had a chance to say Hi yet. So HI
2010 Black MS3
Cobb AP // Cobb EBCS // Cobb Downpipe // Cobb RMM // JBR Tru 3.5'' Intake // JBR TMM // JBR PMM // JBR RSB // CP-E Cat Back // NGK One step colder plugs // GT 3071r // Azenis 615k // Bilstein PSS B14 Coilovers // Treadstone TR8 FMIC // Bully Stage 4 Clutch // Damon EGR Delete // Autotech HPFP // AEM V1 Meth Kit 50/50 // Freektuned 94 Oct
sh4d0w is offline   Reply With Quote
The Following User Says Thank You to sh4d0w For This Useful Post:
Tokay444 (04-22-2016)
 Old 04-22-2016, 08:34 AM   #722
Mazd1222's Avatar
Posts: 74   (View Stats)
Mazd1222 has a spectacular aura aboutMazd1222 has a spectacular aura about
Groaned at 16 Times in 7 Posts
Default gas leak
I did not install any injectors my car us leaking gas when cranked I'm suspecting something came loose with the fuel rail or injectors could the engine be flooded with gas
Mazd1222 is offline   Reply With Quote
 Old 04-22-2016, 08:59 AM   #723
Nel Mazdaspeed's Avatar
Posts: 407   (View Stats)
Nel Mazdaspeed is the leader of the worldNel Mazdaspeed is the leader of the worldNel Mazdaspeed is the leader of the worldNel Mazdaspeed is the leader of the worldNel Mazdaspeed is the leader of the worldNel Mazdaspeed is the leader of the worldNel Mazdaspeed is the leader of the worldNel Mazdaspeed is the leader of the worldNel Mazdaspeed is the leader of the worldNel Mazdaspeed is the leader of the worldNel Mazdaspeed is the leader of the world
have you traced the leak location?
Sent from my SAMSUNG-SM-N910A using Tapatalk
Nel Mazdaspeed is offline   Reply With Quote
 Old 04-22-2016, 11:11 AM   #724
Mazd1222's Avatar
Default fuel leaking from engine
I will be removing the intake manifold this Sunday to take a look at the fuel rail and injectors
This all took place after an overheat issue thermostat housing literally melted and lost a lot of coolant as well
 Old 04-22-2016, 11:26 AM   #725
see if the fuel system will pressurized without turning over the car to find the leak before you dismantle...
 Old 04-22-2016, 12:08 PM   #726
Mazd1222's Avatar
Default fuel leak
Well when the car broke down from overheating I touched the high pressure fuel line and I heard a surge of fuel from the line again gas leaking from the engine it smells real strong from the power steering pump side of the engine
 Old 04-22-2016, 12:21 PM   #727
Mazd1222's Avatar
Default fuel leak
 Old 04-22-2016, 12:54 PM   #728
stockms3's Avatar
Posts: 840   (View Stats)
Groans: 74
They round side faces the head, where the injectors go.
Um OK? Head is part of the long block so you are saying exactly same thing. Thanks for the correction man. You saved the day.
 Old 05-31-2016, 05:15 PM   #729
leo766's Avatar
Posts: 300   (View Stats)
leo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond reputeleo766 has a reputation beyond repute
Groaned at 93 Times in 33 Posts
Default These don't look the same....
So I ordered what seemed to be the same part number, only diff is on this toyota site it had an extra 71 on the end of it for some reason, both of these fit the injector snugly, any suggestions on which set i should use, they are both allegedly toyota diesel injector gaskets like OP gave part # for before, I took two detailed pics if anyone wants any other angles or shots plz let me know, thx
I also included the baggies they came in, both were like no more than 3$ a gasket from either company I believe
Fresh to High Rockies Colorado from VA DC area MS6 07 TiGray!
Cpe: FMIC, CAI, TIP, HPFP, bone engine mount
Cobb AP, Test pipe, turbosmart BPV, whitlenine swaybar
Turbine Tech: Extra front motor mount, both diff mounts +bushings
EGR Delete, mini 0803 Dash cam, Prosport Boost guage. Dash Hawk,
AWR: Trans mount with 88 duro bushings, End links front/rear(removed due to them being total garbage and got some moog stock ones for all around on rockauto.
17x7 Kosei K1 TS 15lb rims, goodyear 225/50r17 all season performance tires and RPM springs
Waiting to install: SPC Ball Joints, SS clutch line, lower engine mount bracket local car shop damaged during clutch install and thermal TB gasket and coolant inline plumbing line that can be turned on and off on demand
leo766 is offline   Reply With Quote
 Old 01-16-2017, 08:44 PM   #730
kbiz's Avatar
Posts: 1   (View Stats)
kbiz is an unknown quantity at this point
anyone ever try vw seals? just a thought
kbiz is offline   Reply With Quote
 Old 02-15-2017, 02:34 PM   #731
paraplan's Avatar
Posts: 20   (View Stats)
paraplan is on a distinguished road
I'm running complete stock Mazda CX-7 and need to replace injector seals. I was thinking about CP-E at first, but wanted to know your opinion if Toyota gaskets would do the work just fine for a stock car.
Also a few guys reported using hi-temp 400F max permatex with those seals. Does it improve anything? Isn't 400F sealant too low for such application?
It seems that 22ft-lbs is the golden ratio for the torque. Can someone also confirm this?
paraplan is offline   Reply With Quote
 Old 04-09-2017, 08:39 PM   #732
paraplan's Avatar
Guys, please help! I put those Toyota gaskets on my injectors and did a compression test on each cylinder and it came really low. I mean re-eally low, 60 psi at the most. The convex side of the gasket is facing the cylinder bore and the flat side - the injector. Torqued to 25 ft. lbs. Don't know what to do, thinking about going stock but wonder how come people have success with those gaskets. Need your advise!
 Old 04-09-2017, 09:52 PM   #733
stockms3's Avatar
Groans: 74
I have been running Toyota seals on a MS3 with the mods in my signature for about 10k miles now. No problems.
Did you clean out the old gaskets? Leak down test would help you identify where you are losing pressure.
 Old 04-10-2017, 01:16 AM   #734
paraplan's Avatar
Yes, I did very thorough cleaning of everything. I took the opportunity to clean intake valves with walnut shells while the manifold was off, so everything was very clean including the injector ports. I tried the leak test and it is clearly showing that there is a leak somewhere, possible injectors, but I cannot be 100% sure, I just hear quiet shss from that area. I did the leak and compression test before I attempted the repair and it was OK, so given that the only thing I did was servicing injectors and replacing seals, I have high reasons to suspect Toyota seals. I'm not sure though why they didn't work for me.
 Old 04-10-2017, 02:09 AM   #735
stockms3's Avatar
Groans: 74
Or you fucked something up during the valve cleaning if not pull the seals get the corksport ones.
Are you low on all 4 cylinders?
You sure you tested correctly (meaning intake/exhaust valves closed)?
 Old 04-10-2017, 10:32 AM   #736
paraplan's Avatar
I first did a compression test, which does not require finding TDC. For the leak test, yes everything was at TDC. All cylinders give similar result.
As for the valve cleaning - walnut shells blasting is a BMW approved procedure, which I've done before. Not sure how this can be fucked up unless you are cleaning valves with a hammer.
One though: I used permatex non-hardening sealant as was suggested on this forum to make sure rings don't get loose and fall out. I used very little of it just on the flat side of the seals. As a wild guess, could it dry out before I torqued everything down? And if it did, could that be the cause of a problem?
 Old 04-14-2017, 04:12 PM   #737
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
Do a leak down.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 04-14-2017, 04:21 PM   #738
paraplan's Avatar
Do a leak down.
I did it. See my post above.
 Old 04-14-2017, 07:25 PM   #739
Tokay444's Avatar
Groans: 793
So where are you leaking?
Demodded.
The Seals
 Old 04-14-2017, 07:44 PM   #740
paraplan's Avatar
I suspect through bad injector seal. The sound comes off that area. Results are very consistent on all 4 cylinders. Before I removed the injectors I did the same test and there were no leaks.
 Old 04-14-2017, 08:34 PM   #741
Tokay444's Avatar
Groans: 793
I guess that's your answer then.
Demodded.
The Seals
 Old 04-14-2017, 08:53 PM   #742
paraplan's Avatar
My original question was not where I have the leak but why. You ask me questions that I have already posted answers for. My main question: why Toyota gaskets did not provide good sealing when I did everything according to the info provided in this thread:
1) convex side to the bore, flat to the injector
2) used non-hardening hi-temp 400F permatex to secure gaskets to injector
3) torqued to exactly 25 ft. lbs.
Did I miss something?
 Old 04-15-2017, 02:31 PM   #743
Tokay444's Avatar
Groans: 793
You fucked it up.
Who told you 25ft/lbs?
Demodded.
The Seals
 Old 04-15-2017, 02:49 PM   #744
paraplan's Avatar
You fucked it up.
25ft lbs was suggested right here in this thread. This guy is also suggesting the same torque:
https://www.youtube.com/watch?v=-4IvGIbAgM4
 Old 04-15-2017, 03:06 PM   #745
Tokay444's Avatar
Groans: 793
You've over crushed the seal by that point.
17ft/lbs on the crow's foot.
Demodded.
The Seals
 Old 04-15-2017, 05:09 PM   #746
paraplan's Avatar
Interesting... 17ft lbs is a spec for OEM seals and people here said that it may not be enough to crush Toyota seals. I'll try this on new Toyota seals and report back.
 Old 04-29-2017, 04:41 PM   #747
paraplan's Avatar
OK, I got new seals and torqued everything to 17 ft lbs. No permatex used this time. Without reassembling everything back I measured compression in each cylinder. This time the results I got are much better:
Dry test
Cyl 1 - 120 psi
Cyl 2 - 120 psi
Cyl 3 - 120 psi
Cyl 4 - 160 psi
Wet test (added a little bit of oil)
Cyl 1 - 125 psi
Cyl 2 - 125 psi
Cyl 3 - 125 psi
Cyl 4 - 165 psi
The compression in cylinders 1 - 3 is still kind of low, but the test was done on the engine that was never started after cleaning the valves.
I have two possible theories:
1) Valves may not be fully closing because some debris after cleaning got stuck to the valves. This should improve after first run as debris should burn and let the valves sit correctly.
2) 17 ft lbs is still too low. The consensus based on the post #597 is 20-25 ft lbs
Any thoughts? Should I just go ahead and put everything back together and try starting the car or try experimenting further with the torques?
 Old 05-02-2017, 09:55 AM   #748
Tokay444's Avatar
Groans: 793
Increased compression when wet points to rings. Not injector seals.
Demodded.
The Seals
 Old 05-03-2017, 07:29 AM   #749
GroceryGtr's Avatar
Posts: 472   (View Stats)
I torqued mine to 20lbs and have no issues. I doubt 25 deformed the seals and instead lean more towards the permatex being the culprit. Using a TINY dab as a retaining mechanism is fine, but anything more and/or expecting it to magically fill in microscopic gaps and hold under extreme pressure is just unicorn land dreams.
I think you're going the right direction with doing a test run. The Walnut procedure is approved by bmw and vw/audi as a maintenance repair, and I can tell you most techs run the vehicle around the block to get all the debris out of the valves. It can certainly hang a valve enough to leak and regardless of how well you vac and air gun it afterwards you will still have some particles left over. Run it around the block and then rerun the tests. That should be enough flow to blow anything out of the valve areas.
 Old 05-03-2017, 08:45 AM   #750
Yatta's Avatar
Posts: 1,862   (View Stats)
Increased torque for stock or Toyota might be ok (or even a good idea) but I would expect the person that designed the 3rd option to have also accounted for expansion at torque... likely the parts are designed for optimal at OEM (17 ft/lbs) designation to prevent problems.... @Tokay444; I expect your seals (or the CS equivalent) state 17 ft/lbs? if so... why would anyone go above this *unless* they didn’t trust their torque wrench...
 Old 05-03-2017, 10:54 AM   #751
aackthpt's Avatar
Posts: 1,450   (View Stats)
Seriously? If you don't trust your torque wrench stop fucking around and get a trustworthy torque wrench. Setting things tighter because you don't trust a measuring tool is just asking for a failure that is a major pain in the ass to fix.
Yatta likes this.
2013 'speed3, silver
Stage Bro
 Old 05-03-2017, 10:56 AM   #752
Yatta's Avatar
preaching to the choir... but I have dropped one
 Old 05-05-2017, 12:48 AM   #753
paraplan's Avatar
Exactly! I put back the bare minimum parts to start the engine and ran it idle for about 15 minutes. Then repeated the compression test while the engine was still warm and ...
Cyl 1 - 180 psi
Cyl 2 - 175 psi
Cyl 3 - 162 psi
Cyl 4 - 185 psi
So definitely problem #1 was the permatex (actually it was mostly me letting it harden before torquing the injectors ), problem #2 compression test is not accurate after doing valve cleaning.
I hope that 17 ft lbs that I used this time is sufficient for Toyota seals...
BTW, after I cleaned the valves the compression is about 10% better than what it used to be before the cleaning. Cylinder 3 is a little low but still within the Mazda spec and the difference between 4 and 3 is within the spec as well.
 Old 05-05-2017, 01:14 AM   #754
paraplan's Avatar
Yes, I was also thinking about the expansion under high temps. Hopefully 17 ft lbs that I used second time will not result in injector leaking...
 Old 05-23-2017, 07:08 AM   #755
Titang9's Avatar
Posts: 6   (View Stats)
Titang9 has a little shameless behaviour in the past
So, the final consensus is 17ft/lb for Toyota seals?
Titang9 is offline   Reply With Quote
 Old 05-23-2017, 08:49 AM   #756
Atomic41's Avatar
Posts: 1,174   (View Stats)
Cyl 1 - 180 psi
Cyl 2 - 175 psi
Cyl 3 - 162 psi
Cyl 4 - 185 psi
So if I got these number :
Cyl 1 - 180 psi
Cyl 2 - 180 psi
Cyl 3 - 160 psi
Cyl 4 - 180 psi
I'm fine too ??? I'm around 11% difference between all my others cylinders
2008 MAZDASPEED3 Black
Stratified Tuned / Stage 2
 Old 05-23-2017, 10:38 AM   #757
paraplan's Avatar
Cyl 1 - 180 psi
Cyl 2 - 180 psi
Cyl 3 - 160 psi
Cyl 4 - 180 psi
According to the spec the maximum allowed difference between cylinders is 28.5 psi. You have 20 psi, which should be fine.
Mazda OEM spec is 15.9 - 18.8 ft lbs, so if I were to do it again, I'd pick the upper limit of 18.8
Last edited by paraplan; 05-23-2017 at 10:39 AM. Reason: MSF Database - Automerged Doublepost
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f106/injector-seals-solution-version-104815/
AP stage question - Page 4 - 2004 to 2014 Mazda 3 Forum and Mazdaspeed 3 Forums This thread Refback 04-13-2014 02:21 PM
2004 to 2014 Mazda 3 Forum and Mazdaspeed 3 Forums - View Single Post - AP stage question This thread Refback 03-14-2014 10:30 PM
<![CDATA[OzMPSclub - Australia's fastest growing Mazda MPS forum]]> This thread Refback 02-20-2014 04:36 PM
Injector seals, my woes, and apparently Toyota to the rescue? This thread Pingback 02-20-2014 07:32 AM
Thoughts on the Toyota Injector Seals This thread Refback 02-02-2014 03:27 AM
Injecteur Mazdaspeed 3 2007 et mécanicien - Mazda 3 Quebec This thread Refback 05-22-2013 11:22 AM
? View topic - wanted injector seals This thread Refback 01-23-2013 02:23 PM
Mazda MPS Owners Club • View topic - Thoughts on the Toyota Injector Seals This thread Refback 06-13-2012 04:02 PM
AP stage question - Page 4 - 2010 Mazda 3/Mazdaspeed 3 Forums This thread Pingback 04-29-2012 08:12 AM
Cheap Injector Solution? This thread Refback 03-26-2012 04:58 PM
CPE Safe Seal - Replacing Injectors - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 02-26-2012 09:55 AM
VersaTune • View topic - Knock issue This thread Refback 02-15-2012 03:39 AM
Possible Injector Seal Alternative? This thread Refback 02-10-2012 10:59 AM
Injector seals solution. paveltol 2010 MS3 - Fuel, Nitrous & Water Injection 404 11-22-2016 03:39 AM
Injector seals solution. Version B paveltol MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 463 11-12-2016 09:30 AM
Injector seals solution. paveltol 2010 MS3 - Engine, Transmission & Driveline 397 07-25-2014 08:34 PM
Injector seals solution - Gen 2 paveltol MSF KB - Mazdaspeed 3/6 - Engine, Transmission & Driveline 397 09-19-2012 02:50 PM
Injector seals solution. paveltol MSF KB - Mazdaspeed 3/6 - Fuel 401 09-19-2012 01:49 PM
Page generated in 0.58161 seconds with 33 queries
