 Old 01-13-2014, 09:05 PM   #1
Boltz's Avatar
Posts: 19   (View Stats)
Boltz has disabled reputation
Default MS6 AWD trans bearings / preload question
I have my transmission out replacing the clutch, and standard inspection I check the input shaft for play and feel for rotation issues. I find that there is (Aprox 8 to 10 thou) play which to me most trans shouldn't have any because of taper bearing preloads on both ends of the shaft. However from reading over the trans manual The input shaft has a roller bearing at the bell housing side and a ball bearing at the driver axle side. The instructions only talk about preloads on the differential taper bearings and secondary shaft (No2)
So what I am looking for an answer to is if this play is normal or not. I haven't disassembled the trans to know fully how it works. I dont want to do unnecessary work or parts if this is normal.
I will be having the Bulk buy shifting forks installed, but i dont want to set bearings.
Thanks
Boltz is offline   Reply With Quote
 Old 01-17-2014, 09:37 AM   #2
93GTS's Avatar
Posts: 486   (View Stats)
93GTS is the leader of the world93GTS is the leader of the world93GTS is the leader of the world93GTS is the leader of the world93GTS is the leader of the world93GTS is the leader of the world93GTS is the leader of the world93GTS is the leader of the world93GTS is the leader of the world93GTS is the leader of the world93GTS is the leader of the world
I can't say for our trans, but other transmissions (T5, G5M, etc) have play when they have been used at all. The RWD T5 input shaft can literally flop from side-to-side as well as in and out on some of the transmissions I've seen last 100,000 miles. Of the FWD G5M's that I've torn apart, all of them have at least 1 shim... and all of them have had shaft play. I have a brand spanking new one on a pallet in my garage right now that has shaft play.
93GTS is offline   Reply With Quote
 Old 01-17-2014, 12:53 PM   #3
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Its pretty normal, if the trans was making noise, you can check the ball bearings by hand and replace any that dont turn smoothly.
2006 Mazdaspeed 6
 Old 01-17-2014, 10:53 PM   #4
Boltz's Avatar
Thanks. I was prety upset when I found it. I am used to all shafts having taper bearings shimmed to no play. As far as i know there are no issues internally
 Old 01-18-2014, 02:25 AM   #5
93GTS's Avatar
If you're concerned, a shop probably wouldn't charge much to strip off gears and change the bearing.
If you're doing it yourself, you'll need bearing/gear separators and a lightweight (cheap 10-12 ton) press with a tall stand (36") as well as a few punches, shop manual (clearances), a dial indicator, and hand tools.
If it is any consolation, those tapered bearings are generally the same part number as wheel bearings on other vehicles... so they are tough.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
 Old 01-18-2014, 10:11 AM   #6
Speeeeeed
06Speed6's Avatar
Pfft I swapped bearings on my trans with a bearing seperator, a small sledgehammer, and a 6" section of pipe lol. Took like 20mins
Ive never opened a ms3/6 trans that didnt have bad ball bearings. They arent made to handle thrust loading so they tend to have short lives.
2006 Mazdaspeed 6
 Old 01-18-2014, 10:14 AM   #7
93GTS's Avatar
On some trans, the input shaft bearing is first, on others you have to strip all of the gears off of the shaft. Thw only reason for tall stand on press would be long shafts like a rwd t5 or t56
Was it inly the input shaft bearing or did you do diff bearing and others?
If op os worried about pre-load theb dial indicator and base aren't optional tools either. There's probably shim-selection sst to help.
 Old 01-18-2014, 10:24 AM   #8
Speeeeeed
06Speed6's Avatar
The diff has tapered roller bearings that are just about indestructible. I just swapped a roller bearing on the input shaft and three ball bearings. No shims on those shafts.
EDIT: I swapped a gear and input shafts too because mine was trashed and the gear was rocking on the shaft.
2006 Mazdaspeed 6
 Old 01-18-2014, 10:28 AM   #9
93GTS's Avatar
Yeah, that was kind of what I was trying to get across in my first response. Tolerances aren't usually as tight as the shop manual makes them out to be.
I swapped several front cases off a enough four cylinder g5m transmissions to fit kl engines now to know that if preload was that important I'd have had a failure. Lol, with them, the diff usually explodes.
 Old 01-18-2014, 12:40 PM   #10
93GTS's Avatar
Didn't see your edit. Were you able to strip the gears off if the input shaft with just hand gear puller? Usually, press-fit is pretty snug!
 Old 01-18-2014, 03:19 PM   #11
Speeeeeed
06Speed6's Avatar
I just put the separator under the gear, hung the separator in my bench vice, and hit (I think) a 1/2" socket extension on the shaft with a small sledgehammer. The bearings and gears are all press fit. The c-clip on the ends of the shafts is just for decoration I think.
Initially I used a separator with a 3 arm pulley puller and that was fine for the bearings but it didnt have enough reach for the gears
2006 Mazdaspeed 6
 Old 01-23-2014, 10:32 PM   #12
Boltz's Avatar
Ugh... so these trans bearings are problematic with our cars then? When it is appart do you recommend replacing the ball bearings any way then?
I know it would be hard to shim all the shafts but it really makes sense to have put taper bearings on them all.
The Following User Says Thank You to Boltz For This Useful Post:
06Speed6 (01-24-2014)
 Old 01-24-2014, 04:49 AM   #13
Speeeeeed
06Speed6's Avatar
Yeah tapered roller bearings would be way better.
Those ball bearings are ~$50/ea so they add up fast. I just replaced two of them along with the roller bearing on the input shaft. Ide just replace bearings that are rough when you spin them.
2006 Mazdaspeed 6
 Old 01-24-2014, 05:44 AM   #14
93GTS's Avatar
Is there not a timken or skf interchange# for the roller bearing yet? If you post up the mazda # I might be able to find it today if it exists.
 Old 01-24-2014, 11:07 PM   #15
Boltz's Avatar
Bearings are easily cross referenced by style ID and OD. I dont know them though.
 Old 01-25-2014, 04:25 AM   #16
93GTS's Avatar
I have a friend who works for a bearing distributor. That's exactly what I was going to do.
Adjusting preload IWG shawn. MazdaSpeed 3/6 - Big Turbo Builds 7 08-05-2013 09:02 AM
rod bearings help. please!! Jimblu MazdaSpeed 6 - Engine, Transmission & Driveline 1 11-23-2012 11:48 AM
Adjusting WG spring preload on turbo? p057 MazdaSpeed 3/6 - Turbo Induction 10 10-30-2012 05:55 PM
New MS3 Owner Here - Is This Normal Trans Question UnamusedPunk MazdaSpeed 3 - Engine, Transmission & Driveline 12 04-11-2012 06:06 PM
Rod and Main Bearings 06Speed6 MazdaSpeed 6 - Engine, Transmission & Driveline 10 02-26-2009 02:22 AM
Page generated in 0.36380 seconds with 22 queries
