 Old 07-27-2019, 07:09 PM   #1
Whoha1638's Avatar
Posts: 17   (View Stats)
Whoha1638 is an unknown quantity at this point
Default Mazdaspeed 6 brakes overheating?? HELP
So my my 2006 MS6 passenger side rear brakes are overheating, just replaced the caliper, pads, caliper bracket, bled the brakes, and that one wheel is still overheating.. any suggestions??
Sent from my SM-G973U using Tapatalk
Whoha1638 is offline   Reply With Quote
 Old 07-27-2019, 07:41 PM   #2
Whoha1638's Avatar
And just to note, the other 3 wheels are warm to touch after an hour drive, the passenger side rear I could cook an egg on it's so hot you can barely touch the wheel itself.
 Old 07-29-2019, 04:38 PM   #3
-Six-'s Avatar
Posts: 14   (View Stats)
-Six- has a little shameless behaviour in the past
Make sure none of your brake lines are twisted or bound up in some way. How did the new pads fit? Did they slide freely or are they frozen in place? When you compressed the older calipers, did they move smoothly or did they fight you? Lots of old rusty parts on these cars in most cases given their age. I've already been through a few seized calipers myself after 13 years and 120k+ miles. I wouldn't think bleeding the brakes is the issue, usually a soft pedal is the result if that wasn't done properly.
-Six- is offline   Reply With Quote
Bigger Brakes for the Mazdaspeed 6 CorkSport CorkSport 2 09-25-2018 08:30 AM
Corksport Brakes Pads - Mazdaspeed 3 Haltech Mazdaspeed Forums Performance Parts Reviews 61 08-08-2017 04:59 PM
Overheating OEM Brakes...options? cnote308 Auto-X / Road Racing / Time Attack 5 07-13-2016 03:16 PM
2006 Mazdaspeed 6 brakes questions... ~100K Ashy Larry MazdaSpeed 3/6 - Suspension & Brakes 7 09-19-2011 09:30 PM
Page generated in 0.24128 seconds with 21 queries
