Like Tree3Likes
 Old 12-04-2013, 04:08 PM   #1
Axel907's Avatar
Posts: 231   (View Stats)
Axel907 is the leader of the worldAxel907 is the leader of the worldAxel907 is the leader of the worldAxel907 is the leader of the worldAxel907 is the leader of the worldAxel907 is the leader of the worldAxel907 is the leader of the worldAxel907 is the leader of the worldAxel907 is the leader of the worldAxel907 is the leader of the worldAxel907 is the leader of the world
Default NAPA remanufactured block
So I spun yet another bearing and instead of attempting another rebuild I decided to go with a NAPA block.
$3500 with a 3 year unlimited mile warranty(I decided to keep my core or it would have been $3000)
I realize this is probably not the highest quality option but I was on a budget.
Have any of you had any experience with these blocks?
2006 BCM MS6 GT Plasti-dipped Black
Current Mods:
BNR S3, HTP 3 inch TIP, Sure Shortcut, Sure RRM, Denzo One Step Colder, Autotech HPFP, KrankVents, Dashhawk, Water to Air Intercooler, HTP 3 Inch MAF Housing, MATT DAMON OCC, Block8Head Vent Pod, Prosport Electric Boost Guage, Napa remanufactured long block, Grimmspeed EBCS, 3 Bar Map with Matt Jackson Harness, JBR Intake Manifold TIG, ACT Clutch and Flywheel, JBR 70 duro PMM and TMM, Snow performance stage 2 meth setup to run off MAF signal, Kosmic motorsports full EGR delete, CPE injector seals, Oil filter conversion kit, AUX jack mod, Sure shift nob, HKS BOV W/recirc, M2 Downpipe And Ofcourse an AP... Tune in Progress
VVT and Timing Chain replaced under warranty at 69,000 miles
Spun rod bearing at 69,355 miles
Built Motor at 69,363 miles
Axel907 is offline   Reply With Quote
The Following 3 Users Say Thank You to Axel907 For This Useful Post:
jack_hammer (01-03-2014), obijack (12-05-2013), redboat (01-14-2014)
 Old 12-05-2013, 05:33 AM   #2
Mazdazilla6's Avatar
Posts: 3,657   (View Stats)
Probably not made by NAPA. Most likely OEM. That's a pretty good price for a new long block though.
VersaTuner = Versatune
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Autotech = HPFP Internals
Grimmspeed = EBCS
The Following 3 Users Say Thank You to Mazdazilla6 For This Useful Post:
Axel907 (12-05-2013), Koke382 (12-05-2013), rfinkle2 (12-05-2013)
 Old 12-05-2013, 08:32 AM   #3
r3d
r3d's Avatar
Posts: 182   (View Stats)
r3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond reputer3d has a reputation beyond repute
Awesome find!
This is the one you got?
NAPA AUTO PARTS
Building it from ground up:
r3d is offline   Reply With Quote
The Following User Says Thank You to r3d For This Useful Post:
 Old 12-05-2013, 10:40 AM   #4
Axel907's Avatar
I'm pretty sure it is made by iron clad. Also when I talked to napa about these they said they were pretty popular.
Beats $6500 for a new one hopefully it will hold together above stock power levels.
Originally Posted by r3d View Post
Awesome find!
NAPA AUTO PARTS
I'm actually out of town right now but I'll post the part number when I get back and keep this thread updated.
Current Mods:
Last edited by Axel907; 12-05-2013 at 10:40 AM. Reason: MSF Database - Automerged Doublepost
The Following 2 Users Say Thank You to Axel907 For This Useful Post:
rfinkle2 (12-05-2013), wolly6973 (12-05-2013)
 Old 12-05-2013, 10:44 AM   #5
Awesome find!
NAPA AUTO PARTS
That's an NA 2.3 motor.
breakfstincluded (12-20-2013)
 Old 12-05-2013, 10:53 AM   #6
obijack's Avatar
Posts: 1,830   (View Stats)
What about OP's? I wonder if he bought the NA version too?
2014 Honda Grom-Red
2014 Yamaha Grizzly 350- Blue
 Old 12-05-2013, 10:58 AM   #7
Deldran's Avatar
Posts: 3,139   (View Stats)
Groans: 118
Is this a long block? Bare block? Short block? Complete engine?
Damond Built Speed 6
 Old 12-05-2013, 11:05 AM   #8
Axel907's Avatar
Haha I've been wondering if it was a n/a motor but the one I got was specifically listed for the mazdaspeed3 and 6.
This is a fully assembled long block. Timing is set, crank pully is on, other than that I have to swap the valve cover off my original block.
Current Mods:
obijack (12-05-2013), wolly6973 (12-05-2013)
 Old 12-05-2013, 11:19 AM   #9
ArmanRus's Avatar
Posts: 1,566   (View Stats)
Groans: 42
He has the MS3/MS6, you can see the cam lobe for the HPFP.
The Following 6 Users Say Thank You to ArmanRus For This Useful Post:
ABolewski (01-03-2014), Axel907 (12-05-2013), Easter Bunny (12-20-2013), obijack (12-05-2013), rfinkle2 (12-05-2013), wolly6973 (12-05-2013)
 Old 12-05-2013, 11:20 AM   #10
obijack's Avatar
Then that is a fucking deal!
2014 Honda Grom-Red
The Following 2 Users Say Thank You to obijack For This Useful Post:
 Old 12-05-2013, 11:29 AM   #11
timjs's Avatar
Posts: 908   (View Stats)
timjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the world
Groaned at 16 Times in 7 Posts
I've installed quite a few remans from Napa, but not a DISI. Always work beautifully.
The last aftermarket reman engine I installed WAS a Disi, and was not a Napa engine. It was some company that the extended warranty people use.
The balance shaft assembly literally screamed while the engine was operating.
Clearly they did not shim it properly.. At any rate, the company did not want to help the customer, because the engine ran fine. I'm not sure what happened afterwards but I am trying to remember the name of the company.
'06 Mazdaspeed 6
timjs is offline   Reply With Quote
The Following 2 Users Say Thank You to timjs For This Useful Post:
 Old 12-05-2013, 11:34 AM   #12
Axel907's Avatar
Sounds like I should install my bsd delete. Thanks for the input
Current Mods:
 Old 12-05-2013, 11:36 AM   #13
timjs's Avatar
Yea man, I do trust Napa though.
'06 Mazdaspeed 6
The Following User Says Thank You to timjs For This Useful Post:
 Old 12-20-2013, 05:26 PM   #14
Axel907's Avatar
So I looked into this napa remaned block with a bore scope and it looks like there's pitting around cylinder 3
Current Mods:
The Following User Says Thank You to Axel907 For This Useful Post:
 Old 12-20-2013, 05:31 PM   #15
timjs's Avatar
Any other pics?
Was it just this one piston?
It doesn't look like they use OEM pistons as I don't see the little intake valve reliefs..
'06 Mazdaspeed 6
 Old 12-20-2013, 05:34 PM   #16
Axel907's Avatar
I just checked the other cylinders and found pitting on cylinder 4 also
Current Mods:
 Old 12-20-2013, 05:39 PM   #17
Axel907's Avatar
Originally Posted by timjs View Post
Any other pics?
They look like the oem pistons, and yes they do have the intake relief cuts. I found pitting on both cylinder 3 and 4. Here's another pic.
Current Mods:
 Old 12-20-2013, 05:48 PM   #18
timjs's Avatar
I see the reliefs now.
Wow. I don't even know what to say. That doesn't look good at all.
'06 Mazdaspeed 6
 Old 12-20-2013, 06:39 PM   #19
sheston's Avatar
Posts: 1,847   (View Stats)
Looks like crap on the piston, and you're seeing the reflection in the cylinder walls?
 Old 12-20-2013, 07:49 PM   #20
Axel907's Avatar
I wish it was just crap on the piston. I can get a glimpse of it with the flashlight on my phone and it is definately deep pitting
Current Mods:
 Old 12-20-2013, 08:17 PM   #21
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
But how can that even happen? You should talk to the supplier, but unless a valve bounced around in the combustion chamber before the reman, I don't really see what could cause something like that. It's most likely not caused by any of the machining operations, unless something was terribly wrong with a tool they were using.
 Old 12-20-2013, 08:27 PM   #22
glockman25's Avatar
Posts: 335   (View Stats)
glockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the worldglockman25 is the leader of the world
Groaned at 8 Times in 5 Posts
hash marks on walls of cylinders?
2010 Liquid Silver Metallic
JBR- SRI/TIP(powerpath intake)- RMM-TMM-PMM(88 DURO)- RSB(medium setting)
Swift springs/SenSen/ SPC camber arms (ACDELCO)
ETS TMIC-AUTOTECH INTERNALS
XS POWER TURBO MANIFOLD-EBAY M2 DP-MAGNAFLOW CBE
NGK LTR7IX-11
COBB AP-CURRENTLY BEING PERM'D
glockman25 is offline   Reply With Quote
 Old 12-20-2013, 09:35 PM   #23
Axel907's Avatar
I think since it's a remaned motor some parts are reused, like the pistons and possibly rods. It all depends on the state of the core that they get
Current Mods:
 Old 12-23-2013, 11:30 PM   #24
Was this resolved? Did you take it back?
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 12-23-2013, 11:41 PM   #25
Swinger13's Avatar
Posts: 3,480   (View Stats)
Groans: 53
Awesome find!
NAPA AUTO PARTS
Did anyone else notice that there was only 1 intake runner per cylinder? Foolish people
Performance:
Stratified Tune in progress
 Old 12-24-2013, 11:51 AM   #26
Axel907's Avatar
I decided to run it. As long as I can get this exhaust mani to seal to the head. I'm in the process of making some sort of pressure tester.
I looked into the warranty and it also states that ironclad will pay $50 per hour of the labor required to replace the motor if failure occurs.
Ha I'd end up makin more money at that than my regular job so I'm just goin to risk it
Current Mods:
 Old 12-24-2013, 04:48 PM   #27
Axel907's Avatar
I think your mistaken
Current Mods:
The Following User Says NO Thank You to Axel907 For This Un-useful Post:
Swinger13 (12-25-2013)
 Old 12-24-2013, 04:51 PM   #28
I think he was talking about what that other guy linked.
Did you ever get the part number for this?
PTE = JB 5862
Forge = V2 BPV
Tial = 44mm WG
Grimmspeed = EBCS
 Old 12-24-2013, 06:44 PM   #29
Axel907's Avatar
Ill post it ASAP
Current Mods:
 Old 01-02-2014, 06:33 PM   #30
dpost95's Avatar
Posts: 9   (View Stats)
dpost95 is an unknown quantity at this point
I'm also still looking for the part number
dpost95 is offline   Reply With Quote
 Old 01-03-2014, 07:52 AM   #31
93GTS's Avatar
Posts: 486   (View Stats)
93GTS is the leader of the world93GTS is the leader of the world93GTS is the leader of the world93GTS is the leader of the world93GTS is the leader of the world93GTS is the leader of the world93GTS is the leader of the world93GTS is the leader of the world93GTS is the leader of the world93GTS is the leader of the world93GTS is the leader of the world
I'm in basically the same boat as you, NAPA block costs more than the new Mazda short block (2500 with freight).
93GTS is offline   Reply With Quote
 Old 01-03-2014, 09:17 PM   #32
Axel907's Avatar
Sorry about the wait.
Here's that part number.
Current Mods:
 Old 01-03-2014, 09:21 PM   #33
Axel907's Avatar
You can't exactly make that comparison. We are talking about a napa long block and your talking about a OEM short block.
The difference is the long block comes fully assembled and ready to dump in. That means new timing components, a complete gasket set, etc.
Current Mods:
The Following 4 Users Say Thank You to Axel907 For This Useful Post:
Coaststarlight (03-12-2014), jack_hammer (01-03-2014), mzr0818 (01-21-2014), speed23 (01-03-2014)
 Old 01-04-2014, 05:29 AM   #34
timjs's Avatar
Also, a cylinder head!
'06 Mazdaspeed 6
The Following 3 Users Say Thank You to timjs For This Useful Post:
Axel907 (01-04-2014), btstarcher (01-21-2014), mzr0818 (01-21-2014)
 Old 01-04-2014, 04:16 PM   #35
93GTS's Avatar
No argument from me there, but short block, head, etc from mazda add up to about the same price. Sure, you'll need to do the head gasket and new timing set, just saying that new parts cost about the same if this is the kind of stuff we can expect to see from parts distributors.
Autozone has a long block for < $2500 with a good enough warranty as well.
jackalpupz likes this.
The Following User Says Thank You to 93GTS For This Useful Post:
rob ms6gt (01-11-2014)
 Old 01-21-2014, 12:40 AM   #36
Axel907's Avatar
Here's a little update for y'all
I got the new block yesterday and went to town on it.
Getting pretty close, but I have school for the rest of the week. Hopefully it will be running by Wednesday or Thursday
This thing makes the rest of the engine bay look like shit
Current Mods:
jack_hammer (01-21-2014), obijack (01-21-2014), sidekick (01-21-2014), tbcota25 (04-01-2014)
 Old 01-21-2014, 08:53 AM   #37
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
i hope this works for you. $3500k/$3000 for a long block seems like a pretty solid deal.
it's fun to do bad things
The Following User Says Thank You to jack_hammer For This Useful Post:
Axel907 (01-21-2014)
 Old 01-21-2014, 09:07 AM   #38
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
I went thru this with a local Nator member. there's no telling what internals are in that thing............who assembled it....if it's reman, did they hone the cylinders? If the cylinders are scored do they bore hone and use oversize pistons?
Too many questions to risk unless you're stocking out. Even then.........who knows the quality of parts used. $3500 is $3500. That's a lot of coin for a risk like this.
07 MS3
The original Genpoo Hater
The Following 4 Users Say Thank You to Chimmike For This Useful Post:
93GTS (01-21-2014), Axel907 (01-21-2014), Easter Bunny (01-21-2014), impossible (08-02-2017)
 Old 01-21-2014, 09:45 AM   #39
Matrix311's Avatar
Posts: 2,133   (View Stats)
Good luck man! I hope this works for you as well. Get rid of your headaches and such.
Did you let NAPA know of the pitting in #3 and #4 or did you just document the pitting and take photos of it just incase something happens?
 Old 01-21-2014, 12:19 PM   #40
Groans: 549
i think i know what you're saying. i've always been leery of engines sold at part stores, even when i worked at a part store.
i guess part of it has to do with my faith in napa. i don't usually shop there because they're overpriced, but i've always considered their parts to be really good quality.
also, i'm sure there is some fine print int here that it has be installed by a mechanic or the warranty is void.
all of your questions regarding the parts used should be things you could get answered.
and if they bored or not, used oversized pistons or not, i'm not following the concern there. i you bore, you get bigger pistons and rings. if you machine the crank, you get bigger bearings. what's the problem there? (or is the problem just the assumption that they know how to match pistons / bearings to a machined block / crank?
read the warranty:
if installed by a licensed repair facility, you get parts & labor covered
if installed by a DIY, you get parts but not labor
rob ms6gt likes this.
Last edited by jack_hammer; 01-21-2014 at 12:19 PM. Reason: MSF Database - Automerged Doublepost
Sp33dyGT (11-16-2014)
napa oil filter lopezsr20 MazdaSpeed 3 - Engine, Transmission & Driveline 2 03-17-2013 05:59 PM
Napa front Strut Mounting kit? Mouse MazdaSpeed 3/6 - Suspension & Brakes 2 04-16-2012 02:46 PM
WTF Napa Guy? reggiegsd Gen2 MS3 General Discussion 6 07-09-2011 04:28 PM
HP Remanufactured Photosmart C5280 Color Flatbed All-in-One $64.98 Haltech Hot Deals Section 0 04-03-2008 09:20 AM
Page generated in 0.56149 seconds with 37 queries
