 Old 06-24-2010, 02:29 AM   #1
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Default Now this is a catch can!
Universal Aluminum Valve Cover Breather Tank
This tank is a Must for High Boost Applications, Valve Cover oil normally leaks out, this tank collects the oil and also return back to the engine.
Overall Size: 11" (L) x6.5" (W) x5.5" (H)
Full Aluminum Construction
6 x AN10 Fitting
4 x Air filters
Fit Standard size Battery Tray
2006 Mazdaspeed 6
 Old 06-24-2010, 03:10 AM   #2
Huligan's Avatar
Posts: 142   (View Stats)
Huligan has much to be proud ofHuligan has much to be proud ofHuligan has much to be proud ofHuligan has much to be proud ofHuligan has much to be proud ofHuligan has much to be proud ofHuligan has much to be proud ofHuligan has much to be proud of
what the fuck
yes it's modded.
Huligan is offline   Reply With Quote
 Old 06-24-2010, 09:30 AM   #3
I<3Groceries's Avatar
Posts: 1,990   (View Stats)
Frankencan.
The Following 2 Users Say Thank You to I<3Groceries For This Useful Post:
06Speed6 (06-24-2010), cocoanton (06-27-2010)
 Old 06-24-2010, 09:31 AM   #4
BUNGEEZZ's Avatar
Posts: 426   (View Stats)
BUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the worldBUNGEEZZ is the leader of the world
Groaned at 49 Times in 36 Posts
where?? how??
Mazdaspeed6,2006, 46k miles.
COBB AP*
Gt3076, 19psi. CPE dp (catless), Dnp Mani 38-EWG, CorkSport Dual CB, CPE BIG MAF SRI, Big Turbo Inlet, CPE Fuel Pump, HKS SSQ Black out edition, Ported stock intake Mani, Intake mani spacer (PT), 2 step colder plugs, FMIC Custom 3.5 inch core, Meth (PT), OCC, BSD, TTFMM, CPE Rear Diff, CPE engine Mount, H&R Springs, Whiteline Rear Sway Bar, Stage 1 short shifter kit Base+bushings, Rotora Break Rotors All 4 (Slotted), Techna fit Brake Lines, Ebc red Stuff pads All 4, Enkei PF01 18's Wrapped in 245/40/18 Falkanzzzz ... Stock clutch until i get some funds.
I HAZ THE FASTEZ CAR ALIVE!!!!!!!!!!!! REDBULL FTW
BUNGEEZZ is offline   Reply With Quote
 Old 06-24-2010, 07:52 PM   #5
kgb
kgb's Avatar
Posts: 808   (View Stats)
Groans: 88
4 air filiters...I got a CC when PG was selling them with 1 filter and got +20 LTFTS.....so ricer math = (fill in here)
FAST & FURIOUS... MazdaSpeed CBE - CNT Downpipe (diode trick) - Cp-e Nano - Autotech Internals - AMSOIL Signature Series 5W-30 Motor Oil - NGK 1-Step Colder Plugs
WHEEL HOP...........Cp-e RMM (75) - Cobb SS - TMW Shifter Brushings - Cobb Shifter Weight - H&R Springs - Hawk HPS Pads (Front) - CS Pads (Rear) - JBR Rear Cambers - JBR 5mm Wheel Spacers - JBR Rear Sway Bar - NATOR Clutch By-Pass - Nitto NT05s
AL GORE...............EGR Block, Valve Delete - JBR TB Coolant Bypass - NATOR Air Reroute to SRI
MMMM BRAINS.....Dashhawk (Mounted) - Hypertech Tune - SWAStika Oppression Defeated[SIGPIC][/SIGPIC] - DSC LED Reroute
JAM SESSION........US Amps (in Series w/ Stock Amp) using
OEM Speakers for Mids & Highs Only - Bazooka 8" Amplified (Got my trunk back)
RICE.................. NATOR Interior Red LEDs - NATOR Engine Blue LEDs - Advanced Film Solutions Tint - NATOR Gun Metal Stock Wheels - Ventshade Deflectors
- Acne Rear Bumper LED Reflectors
 Old 06-24-2010, 08:49 PM   #6
bova's Avatar
Posts: 3,820   (View Stats)
Groans: 45
you got +20 LTFT because it was essentially a big vacuum leak.
 Old 06-28-2010, 03:09 PM   #7
onyx5's Avatar
Posts: 8   (View Stats)
onyx5 is a jewel in the roughonyx5 is a jewel in the roughonyx5 is a jewel in the rough
huge, ugly, in France at mazda club we did a group buy Saikou Michi Stage 2 OCC
MFT : Mazda French Touch
onyx5 is offline   Reply With Quote
 Old 06-28-2010, 03:15 PM   #8
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
Groans: 105
wow, COOL.
on msf we have a member that sells saiko michi occ's with custom fit lines.
 Old 06-28-2010, 03:19 PM   #9
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
It looks like decent construction / design, but i wouldn't want it in my engine bay lol.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
 Old 06-28-2010, 03:30 PM   #10
onyx5's Avatar
pass the fingers to change a light bulb is then put this galley equipment must remove the engine
The Following 3 Users Say Thank You to onyx5 For This Useful Post:
djuosnteisn (06-28-2010), wankular (06-28-2010), xcoldricex (06-28-2010)
 Old 06-28-2010, 03:32 PM   #11
ILL3ST
xcoldricex's Avatar
Groans: 105
what the fuck?
 Old 06-28-2010, 03:23 PM   #12
The Great NY's Avatar
Posts: 360   (View Stats)
wow, that is freaking huge. someone with a civic probably has it, lol
 Old 06-28-2010, 03:37 PM   #13
Captain
I dunno but i thanked it cause he quoted me hahahaha.
www.permtuning.com
 Old 06-28-2010, 03:39 PM   #14
onyx5's Avatar
ok cool bye
The Following User Says Thank You to onyx5 For This Useful Post:
 Old 06-28-2010, 03:41 PM   #15
Captain
See you around!
www.permtuning.com
 Old 06-28-2010, 03:43 PM   #16
TRex's Avatar
Posts: 3,139   (View Stats)
what the fuck is that guy saying.....and what the fuck......that box would really fuck up your airflow....
catch can... and nothing etant333 MazdaSpeed 3 - Engine, Transmission & Driveline 28 09-02-2012 02:12 AM
Oil Catch Can Kit PDXImportRacer MazdaSpeed 3 - Engine, Transmission & Driveline 48 09-16-2009 09:18 PM
oil catch can? nyghtryder MazdaSpeed 3 - Engine, Transmission & Driveline 10 06-07-2009 07:17 PM
Oil Catch Can? bova Mazdaspeed3/6 General Discussion 11 12-06-2008 09:04 PM
Page generated in 0.35388 seconds with 30 queries
