Like Tree8Likes
 Old 11-03-2013, 08:31 PM   #41
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Ill add them, I guess some peeps do still use them. I also have the correct timkin tob part number and the correct part numbers for some trans parts ill try to add this week.
2006 Mazdaspeed 6
 Old 11-06-2013, 12:15 PM   #42
bcmurphy87's Avatar
Posts: 1,435   (View Stats)
Rear Differential Axle Oil seals- M0A727238A
Head Studs (sold sep)- L3K910135A
06 Speed6 GT- Sold
The Following User Says Thank You to bcmurphy87 For This Useful Post:
06Speed6 (11-09-2013)
 Old 11-07-2013, 04:29 PM   #43
Axle Breaker
jmhinkle's Avatar
Posts: 4,639   (View Stats)
Groans: 162
tranny drain and fill crush washers are A60117117 (more specific gasket)
PTO drain and fill crush washers are 995621800 (used on a bunch of stuff)
The Following User Says Thank You to jmhinkle For This Useful Post:
 Old 05-09-2014, 06:16 PM   #44
aviator79's Avatar
Posts: 3,934   (View Stats)
M0A727238A leaking on cx7...78k
 Old 01-04-2015, 05:09 PM   #45
ihasmazda's Avatar
Posts: 1,011   (View Stats)
Looking for the pn on the 3 washers that the TMIC flanges sit on that go inside of the rubber washers. If anyone has a diagram that'd work...
2007 Mazdaspeed 6 GT
2003 Ford Ranger XLT
 Old 02-06-2016, 08:45 PM   #46
I_AINT_RICE's Avatar
Posts: 196   (View Stats)
I_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond reputeI_AINT_RICE has a reputation beyond repute
FYI, I got these right off the TSB for leaky CX-7 T-case. I assumed they were the same, but seam they are not due to the differences in the cases/shafts.
I am going to use these part #s :
2700B - FRONT DIFFERENTIALS. Fits: 2006 Mazda MazdaSpeed6 | Jim Ellis Mazda
I am just geting the RH ones as those are the ones I removed to get the big gear out of the case cover:
RH inner
27238 SEAL, OIL
ILLUST. NO.3
LN0127398
RH outer (I had this wrong)
27514
SEAL, OIL - IDLE GEAR
LN0127514
Not buying this one as it is $15 and I did not remove it.
LH inner:
27238 SEAL, OIL
ILLUST. NO.2
LN0127238
im not sure what this is eaither
27622A SEAL, OIL
A61027397
$23.21
But it is not a LH outer as there is not LH outer. I think it is a seal for the TC to the trans but I do not think it is needed. I do not think it is the Trans seal to axel. I was told to get one of those, but probably not going to as mine was fine.
As you can see by the parts lists you can adjust preload on the bearings by getting different thickness of the spacers 27-355 #2. It feals like mine has too much preload on it, but I cannot measure endplay or anything so I am just going to leave it as is. The case is tapered where the LH 27-350 bearing goes into and thats why they must use diff thickness of the spaces to adjust preload on the bearings. That gear is really stiff to turn but maybe that is the way it is suposed to be.
Sorry for the bump. Were there any other seals/gaskets that you needed? I'll be pulling the TC for cap install, and would like to change out anything that may give me a headache in the future.
I_AINT_RICE is offline   Reply With Quote
 Old 02-07-2016, 12:57 AM   #47
aviator79's Avatar
Never be sorry to bump thread. Better than making a new one.
Im sorry. my post has errors in it so I would not rely on it as i think that was from cx7 tsb.
I know what needs to be replaced as i just did another but dont have list on my phone.
can post later or there are other post that show all seals in another thread.
/drunk
I_AINT_RICE (02-07-2016)
 Old 02-07-2016, 01:34 AM   #48
/drunk
No worries man, I understand those feeels /alsodrunk I'll look around. If you remember tomorrow and have access to the part numbers, let me know. If not, have a fun/safe night!
Sent from my SAMSUNG-SM-G870A using Tapatalk
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f106/oem-mazdaspeed-6-engine-part-numbers-107606/
LN03-27-397 weight This thread Refback 05-15-2013 12:05 PM
Looking for part numbers help Necro_1015 Mazdaspeed3/6 General Discussion 1 03-28-2011 08:32 AM
Need help with part numbers Blackspeed MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 02-21-2011 03:39 PM
Someone Hit my car need part numbers!! KoleDeRacer MazdaSpeed 3/6 - Appearance 7 06-02-2010 09:56 AM
Fuel pump part numbers tburton101 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 04-03-2009 02:32 PM
Page generated in 0.30406 seconds with 26 queries
