 Old 08-02-2012, 11:13 AM   #1
5000lbs of voiceless fury
Caligula's Avatar
Posts: 3,140   (View Stats)
Caligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the world
Groans: 185
Groaned at 124 Times in 81 Posts
Thumbs down Is this the proper part that I need?
So my serp belt tensioner is going bad. The unit that I need to replace looks like it would be easy enough to do myself, but I need to know if I am about to order the proper part or not.
So far, this is what I found over @ RockAuto:
2007 MAZDA 6 Belt Tensioner
Is this the proper unit? And out of the 3, which one do I need or should buy?
Thanks in advance!
-Joe
2015 Telsa Model S 85D - Delivered 10/21/2015 FYEN!
SOLD!!! 2007 Mazda MS6 - //AWD//BNR S3//cp-e TMIC//cp-e CDFP//Cobb AP//Cobb TIH//Cobb EBCS//Bosch 845 3 Bar//MS-CAI//Custom DP//TS Kompact BPV//Magnaflow CBE//AWR RMM//JBR Stage 3 SSP Kit//JBR EGR Delete//H&R Springs//
Caligula is offline   Reply With Quote
 Old 08-02-2012, 12:39 PM   #2
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
I think they are probably all correct, I think the tensioner is the same for all 2.3 Mazdas.
The Gates are AC Delco are both correct, I didnt check the other.
2006 Mazdaspeed 6
Caligula (08-02-2012)
 Old 08-17-2012, 05:07 PM   #3
I know napa has a universal that works, need to search for part #...
 Old 08-17-2012, 05:49 PM   #4
Caligula's Avatar
Groans: 185
Update. Got the part. Works great and solved my issues.
Proper oil temp and pressure? vbt101 MazdaSpeed 6 - Engine, Transmission & Driveline 12 05-09-2014 01:47 PM
What you need for a proper build Hamilton69 2010 MS3 - Big Turbo Builds 2 01-04-2012 12:15 AM
Proper wastegate? TheNewGuy MazdaSpeed 3/6 - Turbo Induction 8 11-08-2010 07:08 AM
What is proper AFR for MS3? Matrix311 MazdaSpeed 3/6 - ECU Computer Tuning 13 12-08-2008 10:06 AM
Page generated in 0.24767 seconds with 22 queries
