 Old 05-19-2008, 04:14 PM   #1
Default Spark Plug Database - Colder Than Stock ( Stage 1&2 )
This is a compiled database for spark plugs who's heat range is 1 and 2 stages colder than stock. Please add your plugs and we will update this thread.
Mazdaspeed Forums Spark Plug Index Database
Gap size - 0.26 - 0.32 | Preferred gap is between 0.26 to 0.28
Type and Specs on DISI 2.3l Spark Plugs: 14mm; 5/8 hex; 25mm reach; projected tip; resistor plug
Heat Range Conversion Chart
Code:
HKS 25 30 35 40 45 50 52.5 55
DENSO 16 20 22 24 27 31 32 34
NGK 5 6 7 8 9 10 10.5 11
Spark Plug Manf & Part Numbers
  • Denso Iridium
  • itv-20 - Stock heat range
  • itv-22 - 1 stage colder heat range
  • itv-24 - 2 stage colder heat range
  • itv-27 - 3.5 stage colder heat range
  • HKS
  • 50003-M35LF *Mazda MZR Engine* ; Mazda 3, Mazda 6, MX-5 '06 7 $22.97ea. - 1 Stage Colder Heat Range
  • 50003-M40LF *Mazda MZR Engine* ; Mazda 3, Mazda 6, MX-5 '06 8 $22.97ea. - 2 Stage Colder Heat Range
  • NGK IX Iridium
  • NGK LTR7IX-11 (6510) - 1 Stage Colder Heat Range
  • NGK ILTR6A-8G (3787) - Stock Heat Range
  • Torque Master Spark Plugs
  • SVTP8BR Stock Heat Range
  • SVTP7YR 1 Stage Colder Heat Range
  • Autolite Iridium
  • Autolite Iridiums XP5364 - Stock Heatrange
  • Autolite Iridiums XP5263 - 1 Step Colder
NGK Copper Plugs
LZTR4A-11 (5306)
LZTR5A-13 (4306)
The Following 7 Users Say Thank You to Haltech For This Useful Post:
ELiTeNeSs (12-06-2011), labikesrcool (08-27-2011), Lost hawaiian (10-28-2011), meeker13 (05-31-2010), OXXIDO (09-25-2009), phate (09-04-2015), slickety (01-23-2016)
 Old 03-11-2009, 03:19 PM   #2
Alladin's Avatar
Posts: 2   (View Stats)
Alladin is an unknown quantity at this point
So I read all the post about plugs and have a question.
Is there any plug that is better for a stock engine? Will I notice any difference or should I keep what is in there now?
If I do change them, what should the gap be on a stock motor?
Thanks
And I apologize if I missed the answer in a thread somewhere.
Alladin is offline   Reply With Quote
 Old 03-12-2009, 02:51 PM   #3
Alladin's Avatar
Anyone?
 Old 03-12-2009, 07:50 PM   #4
bykeryder4life's Avatar
Posts: 1,032   (View Stats)
bykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the worldbykeryder4life is the leader of the world
Groans: 38
gap size is listed above just read. stock motor=stock plugs
bykeryder4life is offline   Reply With Quote
The Following User Says Thank You to bykeryder4life For This Useful Post:
I<3MazdaSpeed (04-20-2009)
 Old 03-14-2009, 02:46 PM   #5
egbertnr's Avatar
Posts: 186   (View Stats)
egbertnr is a name known to allegbertnr is a name known to allegbertnr is a name known to allegbertnr is a name known to allegbertnr is a name known to allegbertnr is a name known to all
Neutral  :  -1 score
IN the Focus community which have similar engines most all the guys that have turbo cars run copper core plugs, which in the ford world equates to Motorcraft copper cores, Copper is the best conductor and I can't see any gains being made from any high dollar plug. Correct me if I am wrong but I doubt anyone here has seen gains with any overpriced plug. IF so I would be happy to see the dyno.
2011 FX4 TT'd V6 SuperCREW F150 Blue Flame Metallic
egbertnr is offline   Reply With Quote
 Old 03-14-2009, 03:03 PM   #6
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
the problem is no one has found any copper plugs.
If so i would be using some for sure
 Old 03-14-2009, 03:56 PM   #7
MZRDISI4's Avatar
Posts: 1,430   (View Stats)
MZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the worldMZRDISI4 is the leader of the world
Groans: 94
Groaned at 38 Times in 19 Posts
Would a step colder help with pre-ignition?
"We already have the Speed6 replacement" "It's just called the CX-7 now"
back at http://www.mcx7.com bitches, spam free
MZRDISI4 is offline   Reply With Quote
 Old 03-15-2009, 04:30 PM   #8
phantomspeed3's Avatar
Posts: 559   (View Stats)
phantomspeed3 has much to be proud ofphantomspeed3 has much to be proud ofphantomspeed3 has much to be proud ofphantomspeed3 has much to be proud ofphantomspeed3 has much to be proud ofphantomspeed3 has much to be proud ofphantomspeed3 has much to be proud ofphantomspeed3 has much to be proud ofphantomspeed3 has much to be proud of
So I'm running a CAI, Catless TBE, and BOV what kinda plugs should I run? I live in Utah
2007 MS3: HKS Hi-Power CBE with muffler cut-out, HKS CAI, TurboXS RP, Forge BPV, PTP Air Straightener, OCC, MBC(not hooked up der), Cobb AP, Denso Iridium ITV22 Spark Plugs, PG Turbo Inlet
phantomspeed3 is offline   Reply With Quote
 Old 03-23-2009, 10:40 AM   #9
MSF Punished Member
FWD=WWD's Avatar
Posts: 200   (View Stats)
FWD=WWD is a name known to allFWD=WWD is a name known to allFWD=WWD is a name known to allFWD=WWD is a name known to allFWD=WWD is a name known to allFWD=WWD is a name known to all
gap sizing listed taken from which car? speed3 or speed6 (yes i know same engine.)
SU lists their plugs for the speed6 (under Mazdaspeed 6) with gap sizes of .44, .32, and a few are unlisted...
FWD=WWD is offline   Reply With Quote
 Old 03-23-2009, 04:14 PM   #10
ONLYA6's Avatar
Posts: 52   (View Stats)
ONLYA6 has a spectacular aura aboutONLYA6 has a spectacular aura aboutONLYA6 has a spectacular aura about
I'm going to switch my plugs out again here in a few months (coming on 15k).. is anyone running 2 steps colder? Any better results? Deciding whether I should stick with 1 step or go to 2
stupidslow_ms3 likes this.
ONLYA6 is offline   Reply With Quote
 Old 03-23-2009, 04:42 PM   #11
What are your mods? If you have every bolt on known to man and 20 psi+, i would go 2 stage colder.
LED_Vera (08-30-2014)
 Old 03-23-2009, 07:46 PM   #12
no one wants to answer me
 Old 04-09-2009, 07:33 PM   #13
Scottybones's Avatar
Posts: 10   (View Stats)
Scottybones will become famous soon enough
, Copper is the best conductor and I can't see any gains being made from any high dollar plug. Correct me if I am wrong but I doubt anyone here has seen gains with any overpriced plug. IF so I would be happy to see the dyno.[/QUOTE]
Actually, copper conducts well, but there are definitely better conducting metals out there. Copper is the cheapest out of them all. Gold and platinum, and iridium come to mind. Iridium plugs actually outperform copper and last a hell of a lot longer.
Dustin likes this.
Scottybones is offline   Reply With Quote
 Old 04-18-2009, 04:59 PM   #14
Clean Baldy's Avatar
Posts: 14   (View Stats)
Clean Baldy is an unknown quantity at this point
I found a set of six(6) ITV22 spark plugs on ebay for only $58 with free shipping. They're labeled for an '08 Chevy Equinox Sport, however, one ITV22 plug is the same as another.
Just wanted to toss a heads up for anyone wanting them, worried about breaking one oin a set of 4 when they re-gap. Now, you get two extras... just gap them and install
I haven't seen them cheaper anywhere else. If you have, post up.
Clean Baldy is offline   Reply With Quote
 Old 04-28-2009, 03:24 PM   #15
Decepticon's Avatar
Posts: 1,221   (View Stats)
Decepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the worldDecepticon is the leader of the world
Groaned at 43 Times in 28 Posts
do you need to flash the ap or reset the ecu after installing a set of upgraded spark plugs?
06 MS6, Cobb AP, -TUNED on corn mix, KMD v2 fp internals, NGK Iridium IX sp, Cp-e Xcel NANO, PG tip, SU bpv, AWR rear MM, Jbarone shifter plate and bushings, ATP catted dp, Corksport catback, Altered Custom fmic, H&R springs...
R.I.P. 08.5 MS3, Cobb Ap, KMD v2 fp internals, Denso ITV22 sp, Cobb Sri, TurboXS bpv, SU rear mm, SU shifter bushings, ETS TMIC, SU boost tubes, Cp-e catted dp, Enkei EKM3.
Decepticon is offline   Reply With Quote
 Old 07-09-2009, 10:53 AM   #16
jkunze's Avatar
Posts: 45   (View Stats)
jkunze will become famous soon enoughjkunze will become famous soon enough
No
2006 Mazdaspeed 6
Cobb AP 2.0 with 1.01 stage 2 93 octane SF map
Cobb Turbo Inlet, Cobb SF Intake
ATP 3inch downpipe with metal spun High-Flo Cat
jkunze is offline   Reply With Quote
 Old 07-14-2010, 02:56 PM   #17
morgan2112's Avatar
Posts: 29   (View Stats)
morgan2112 is on a distinguished road
Groaned at 7 Times in 4 Posts
I am putting a set of ITV22 in my 06 Speed6.
I am almost fully bolted except no DP. Anyway COBB and my AccessPort recommends .25 to .28 for GAP..NOt .31 & .44 What is correct???? Does anyone know what these ITV22's come gapped at?? THX
morgan2112 is offline   Reply With Quote
 Old 02-04-2011, 08:28 AM   #18
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
few more for the list-
-not meant to indicate the best or favorite, it's just a list.
based on US dollars
- from various on-line parts stores, prices will vary widely
Colder Heat Ranges
generally accepted gap, where adjustable, .028 (range .028 to .032)
>Autolite Single Platinum Spark Plug
Part No. AP5263
$2.50
>Autolite Double Platinum Spark Plug
Part No. APP5263
$4.00
>Autolite Xp (Xtreme Performance) Iridium Enhanced Fine Wire Spark Plug
**Cross-references the Denso ITV-22**
Part No. XP5263
$6.50
>NGK IX Iridium
Part No. LTR71X-11
$8.00 ea.
>Denso Iridium Spark Plugs
Part No. ITV22 - one step colder
$11.99 (streetunit price)
Part No. ITV24 - two steps colder
Factory Heat Range
generally accepted gap, where adjustable, .032 (range .028 to .032)
Part No. APP5364
$3.99
>Champion Double Platinum Spark Plug
Part No. 7437
$4.29
>Motorcraft Original Equipment Finewire Single Platinum Spark Plug
Part No. SP432
$4.69
>Motorcraft Original Equipment Finewire Double Platinum Spark Plug
Part No. SP478
$4.69
>Bosch Platinum+2 Spark Plug
Part No. 4315
$4.99
>Bosch Platinum Ir Fusion
Part No. 4515
$5.71
>Bosch Platinum+4 Spark Plug
Part No. 4488
$5.99
>Pulstar Platinum Pulse Plug
Part No. EF1P
$9.99
>ACDelco Professional Platinum Spark Plug
Part No. 41-814
$6.49
>Champion Iridium
Part No. 9901
$5.74
>NGK Premium Iridium
Part No. ILTR6A8G
$9.94
Part No. XP5364
$6.59
>Pulstar Iridium Pulse Plug
Part No. EF1I
$12.99
>E3 Premium Special Electrode Automotive Spark Plug
**reports of exceedingly poor performance in the MS6**
Part No. E3.66
$5.99
340hp / 371tq
Arnie1229 (02-09-2015), doubleflusher (04-09-2012)
 Old 02-26-2011, 10:16 AM   #19
Amazon's Avatar
Posts: 2,679   (View Stats)
Groans: 214
I know most of us have, or plan on going with the Denso ITV-22's. The NGK's are problematic to gap correctly as they come preset at .44, a member fought with trying to gap them before giving up.
I got my densos from http://www.sparkplugauto.com/denso/i...park-plug.html for $7.44 a piece.
Amazon is offline   Reply With Quote
The Following 2 Users Say Thank You to Amazon For This Useful Post:
Juyoung (08-11-2013), myt_tuf1 (02-26-2011)
 Old 02-26-2011, 04:28 PM   #20
myt_tuf1's Avatar
Posts: 256   (View Stats)
myt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the worldmyt_tuf1 is the leader of the world
Here's a great article on why and when you should go "colder": NGK.com
Prosport Mech Boost Gauge|Jbarone SSP/Bushings|CS SRI/TIP/RSB/RP|H&R Springs|Koni Yellows|Cobb FMIC/AP|Denso ITV22|Torque Solutions RMM|SPC Camber Links|Enkie RPF1 17x9 +45 w/Continental DWS Extreme Contact 235/45-17|SURE IM/TB TIG|CP-e HPFP|Grimspeed ECBS|DO Stage 2 w/100% Meth|MD OCC
myt_tuf1 is offline   Reply With Quote
The Following User Says Thank You to myt_tuf1 For This Useful Post:
flappypaddles (11-21-2013)
 Old 04-03-2011, 03:40 PM   #21
bozzben's Avatar
Posts: 305   (View Stats)
bozzben is the leader of the worldbozzben is the leader of the worldbozzben is the leader of the worldbozzben is the leader of the worldbozzben is the leader of the worldbozzben is the leader of the worldbozzben is the leader of the worldbozzben is the leader of the worldbozzben is the leader of the worldbozzben is the leader of the worldbozzben is the leader of the world
I got my densos from Denso Iridium Power ITV22 Spark Plug for $7.44 a piece.
Tx for the link!
bozzben is offline   Reply With Quote
 Old 04-05-2011, 06:38 PM   #22
Jkelley's Avatar
Posts: 218   (View Stats)
Jkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the worldJkelley is the leader of the world
with my mods currently and the future mods i plan to get in the near future.. what plugs should I get? ITV22 or ITV24?? or even itv27?
2008 Mazda Mazdaspeed3 GT (True Red) SOLD
~Mods: ATP GTX3071r IWG, JBR Tru 3.5" WP, UR V2 3" catless DP & TP, Tr8+JBR FMIC, Turbosmart BPV, CP-e HPFP, NGK 6510, Bosch 3bar MAP, Cobb 3-port EBCS, PERM PCV Plate, Damond OCC (1sealed, 1 VTA), Kozmic 1°/Damond 2° EGR Delete, Corksport seals, CP-e RMM 75A, JBR side MM 80A, Cobb AP V2, spin-on oil conversion, KSport Coilovers, SPC Performance Camber Arms, JBR IM/TB TIG, SURE Anchors
~~332whp @5300rpm / 354wtq @4800rpm @ 21psi on 91oct FREEKTUNED
~~380whp @6500rpm / 367wtq @4800rpm @ 20psi on e33 FREEKTUNED
2007 Mazda CX-7 (Burgundy Wine) SOLD
Jkelley is offline   Reply With Quote
 Old 04-05-2011, 06:59 PM   #23
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
^^^ itv49s all the way.
 Old 04-05-2011, 08:59 PM   #24
Jkelley's Avatar
Seriously..
 Old 07-04-2011, 11:56 AM   #25
Downmented's Avatar
Posts: 3,040   (View Stats)
Groans: 493
Originally Posted by Jkelley View Post
Seriously..
Read the article posted above and make your own decision. Its not something thats going to make a drastic difference so using one over the others isnt going to be better or worse for you. You have to make your decision on your own, its a spark plug not a turbo.
 Old 07-13-2011, 09:38 PM   #26
Jammer's Avatar
Posts: 4   (View Stats)
Jammer is an unknown quantity at this point
Default Denso IRL01-27 vs. ITV22 or ITV20?
I am confused. I have had both of these types of plugs recommended for
my 2006 Mazdaspeed 6. I am having difficulty justifying the 250% higher price for the
racing plug. Does anyone know why the Denso site http://www.densoiridium.com/find_part.php recommends IRL01-27 only for my car, when it recommends the other plug (ITV20) for the same engine in a different year?
2006 Velocity Red MS6, ASA AR1 Silver w/machined lip 225/45/18, EBC Red Stuff Front Brake Pads, StopTech Slotted Front Rotors
Jammer is offline   Reply With Quote
 Old 07-19-2011, 08:19 PM   #27
BlueDmnSpeed's Avatar
Posts: 1,129   (View Stats)
i was told that if you go 1 or 2 step colder heat range then you gotta tune for it. from what i am reading in hear as long as you just gap them to the stock recommended gap then you should be good.
is my assumption right or is what i heard correct? i need to change my plugs mods are below. trying to decide if i wanna get the NGK's Denso's or just install the new Autolite iridiums i have in the glove box. what is y'alls opinion?
RichTuned
BlueDmnSpeed is offline   Reply With Quote
 Old 10-13-2011, 12:58 PM   #28
oh_yeams6's Avatar
Posts: 104   (View Stats)
oh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond reputeoh_yeams6 has a reputation beyond repute
Groaned at 9 Times in 7 Posts
On the COBB 1.08 BETA testing, Christian and the team are asking for us to
"install new Denso ITV22 spark plugs gapped at .025".
oh_yeams6 is offline   Reply With Quote
 Old 11-06-2011, 12:11 PM   #29
theurgy's Avatar
Posts: 2,580   (View Stats)
People on this page have to be VERY clear when they mention gap sizes.
0.28" DOES NOT EQUAL 0.028".
Also to note, if you're measuring gap sizes, use feeler gauges and not those circle gapping gauges, they might damage Iridium plugs.
 Old 11-06-2011, 12:34 PM   #30
theurgy's Avatar
Finally... people use mm and inches interchangeably.
What is the real value?
 Old 06-20-2012, 03:20 PM   #31
aggierandy's Avatar
Posts: 2,241   (View Stats)
aggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the world
Groaned at 18 Times in 14 Posts
Additional manufacturers chart
Source in picture
2010 MS3 Mica Black Tech
Cobb AP | JBR RMM 70 Duro | JBR SSP | CS SRI+TIP | CS Racepipe | NGK Plugs | KMD Internals
CS Interior LEDs | Custom Hatch LEDs | Rear Wiper Delete | Custom "Evil M" | Red Taillights | Resonator Delete | SWAS Switch
aggierandy is offline   Reply With Quote
The Following User Says Thank You to aggierandy For This Useful Post:
 Old 06-20-2013, 11:11 PM   #32
dgiannitakis's Avatar
Posts: 31   (View Stats)
dgiannitakis is a glorious beacon of lightdgiannitakis is a glorious beacon of lightdgiannitakis is a glorious beacon of lightdgiannitakis is a glorious beacon of lightdgiannitakis is a glorious beacon of light
Nice info
http://​www.linkedin.com/in/​dgiannitakis
dgiannitakis is offline   Reply With Quote
 Old 11-14-2013, 09:32 PM   #33
redboat's Avatar
Posts: 634   (View Stats)
redboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the worldredboat is the leader of the world
Haltech,
I've seen in a few threads, you recommend people to NOT use Denso plugs. May I ask why since a lot of people use them?
I need new plugs (1 step colder).....
Also anyone use XP5263's? How do you like them? I found some, but they aren't listed for any Mazda's or even Ford's.
redboat is offline   Reply With Quote
 Old 12-12-2013, 01:58 AM   #34
nickpratt's Avatar
Posts: 40   (View Stats)
nickpratt is a jewel in the roughnickpratt is a jewel in the roughnickpratt is a jewel in the roughnickpratt is a jewel in the rough
So I hate to be that guy but here we go...why would you go colder and not hotter? I read this whole thread and nobody said hotter. And what mods justifies going up a step or down a step?
nickpratt is offline   Reply With Quote
 Old 12-12-2013, 06:57 AM   #35
A minute in Google, a lifetime on the brain.
More performance = more heat
When a plug heats up, after a certain point it can trigger a combustion event without spark. Colder plug transfers that extra heat more efficiently, preventing that stray combustion event and all the other problems & symptoms that come along with an overheated plug, such as shorter plug life.
Hotter plugs would only exacerbate the problems.
As a general rule, for every 50-100 HP added, go one step colder, but temper that with your driving style. You may not benefit from 2 step colder plugs if you spend your time in rush hour traffic as they may not get hot enough to burn off the deposits. If you have the power for it, but not the environment, then it's worth it to have two sets- one for daily driving and a colder set for the track.
340hp / 371tq
 Old 12-12-2013, 07:49 AM   #36
jm211's Avatar
Posts: 943   (View Stats)
Nicely put.
Also note that you want to run the hottest plugs you can without experiencing pre detonation from the plug.
jm211 is online now   Reply With Quote
 Old 08-08-2014, 12:32 PM   #37
razerer's Avatar
Posts: 168   (View Stats)
razerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond reputerazerer has a reputation beyond repute
Groaned at 8 Times in 4 Posts
I'm only getting confused by this. Cobb says gap needs to be 0.028 inches gap which translates to ~0.7 mm gap.. This says 0.28 gap, since I'm guessing that's in inches, 0.28 is much higher than 0.028. Can somebody confirm the actual gap for step colder plugs?
razerer is offline   Reply With Quote
 Old 08-08-2014, 12:36 PM   #38
0.028 - 0.026, tighter as HP increases.
This is covered in the thread, have to read more than just the first post.
340hp / 371tq
razerer (08-08-2014)
 Old 08-08-2014, 03:16 PM   #39
theurgy's Avatar
Yeah that's a big pet peeve of mine when people say 0.28"
That 0 makes a HUGE difference.
 Old 08-10-2014, 08:55 PM   #40
razerer's Avatar
I know! My gapping tool is in mm so I gapped it to 0.7mm car rubs fine on stage 2 so I'm guessing it was all good.. If it blows up I'll keep y'all posted
Cobb AP V3 // Cp-e HPFP // Cobb SRI TIP // Cobb DP // Cobb FMIC // Denso ITV22 // Cp-e Triton Cat-Back // Forge V2 BPV // JBR 88 Duro RMM
Cobb SoCal tuned
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f106/spark-plug-database-colder-than-stock-stage-5693/
Misfire!!!!! This thread Refback 01-12-2015 05:59 PM
How To: Spark Plug Replacement - Page 14 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 11-14-2013 09:20 PM
Свечи зажигания - MAZDA Club Belarus - Белорусский Клуб MAZDA - Форум This thread Refback 08-21-2013 04:32 AM
Свечи зажигания - MAZDA Club Belarus - Белорусский Клуб MAZDA - Форум This thread Refback 04-27-2013 12:34 PM
? View topic - MPS Sparkplugs This thread Refback 04-23-2013 08:15 AM
- MAZDA Club Belarus - MAZDA - This thread Refback 06-14-2012 12:16 PM
- 15 - MAZDA Club Belarus - MAZDA - This thread Refback 02-17-2012 09:25 AM
Stutter really isn't This thread Refback 06-01-2009 10:52 AM
Gainesville, FL - Page 13 - StreetUnitForum.com This thread Refback 04-20-2009 09:17 AM
Zndkerzen, welche und wann wechseln? - mazda-mps.net This thread Refback 07-26-2008 03:56 PM
Spark Plug Database - Colder Than Stock ( Stage 1&2 ) Haltech MazdaSpeed 3/6 - ECU Computer Tuning 74 08-02-2019 08:18 AM
Spark Plug Database - Colder Than Stock ( Stage 1&2 ) Haltech MazdaSpeed 3 - Engine, Transmission & Driveline 205 09-22-2015 06:52 PM
4 or 6 puck stage 3 clutch ? occschemguy MazdaSpeed 6 - Engine, Transmission & Driveline 17 02-16-2009 06:18 PM
Spark plug gap Jesse MS3GT MazdaSpeed 3 - Engine, Transmission & Driveline 6 03-16-2008 04:53 PM
Page generated in 0.58187 seconds with 50 queries
