 Old 10-18-2019, 04:08 PM   #1
The big tuna's Avatar
Posts: 16   (View Stats)
The big tuna is an unknown quantity at this point
Default Stuck D/S Axle (In Transmission)
Hey guys hoping someone can lead me along the right path.
Trying to change the clutch on my 07 speed 3. I cannot for the life of me get the axle out of the transmission. Is there something holding it in or am I missing something? I have the transmission out of the car. Trying to pry the axle out has led me nowhere. I can see it moving up a tad when i pry upwards but then it drops right back down. There is a metal guard it seems that I have flared up. Looks like it just covers the seal. Is there any idea why it would be so stuck in the transmission? Am I going to have to pull the outer cover off and see why it's stuck in the diff?
This car has been a nightmare compared to my miata. Being a northern car probably hasn't helped lol. Any tips are appreciated!
The big tuna is offline   Reply With Quote
 Old 10-18-2019, 04:20 PM   #2
Db09ms3's Avatar
Posts: 536   (View Stats)
Groans: 105
On my '09 I wedged a pry bar in between the axle and transmission, pried until it was taut, then whacked the pry bar with my 3lbs sledge. Popped it right out.
My metal guard was a little mangled but I bent it back to what it was before popping it back in with a new axle clip.
Stockish
Db09ms3 is online now   Reply With Quote
 Old 10-18-2019, 04:23 PM   #3
Db09ms3's Avatar
Groans: 105
Whack where the red circle is.
Stockish
 Old 10-18-2019, 04:27 PM   #4
thanks for the reply! Guess i'm just being a bit of a pansy with it. Didn't want to break anything in the diff. I'll try giving it a good smack on the pry bar.
 Old 10-18-2019, 04:39 PM   #5
Db09ms3's Avatar
Groans: 105
Work that pry bar around every other smack. Should pop it out just fine and yeah, don't be a panty waist!
Stockish
 Old 10-18-2019, 05:46 PM   #6
Thanks! Any tips for seperating the P/S axle and the half shaft? The tip on the P/S axle is demolished. I've been smacking the shit out of it and no luck. So it will need replaced. Can you buy just the axle if the half shaft bearing is still good?
 Old 10-18-2019, 06:03 PM   #7
Db09ms3's Avatar
Groans: 105
Leave the PS axle in, the half shaft can be unbolted from the engine and then it just slides out from the tranny. Then take it to a shop to separate it for you.
Yes, you can replace just the axle.
Stockish
Last edited by Db09ms3; 10-18-2019 at 06:03 PM. Reason: MSF Database - Automerged Doublepost
Part number and info on axle seal (transmission). Pic inside. dsmluck MazdaSpeed 3 - Engine, Transmission & Driveline 34 09-30-2015 08:46 AM
Transmission getting stuck in 1st, 2nd and R TegRacer324 MazdaSpeed 3 - Engine, Transmission & Driveline 2 07-25-2013 08:23 AM
Stuck Axle... help! mczimer Mazdaspeed3/6 General Discussion 11 09-24-2012 01:57 PM
axle floating around in transmission mtnrunner MazdaSpeed 3 - Engine, Transmission & Driveline 2 06-29-2010 09:14 AM
Page generated in 0.26637 seconds with 22 queries
