 Old 09-20-2012, 05:44 PM   #1
Greekfreak's Avatar
Posts: 15   (View Stats)
Greekfreak can only hope to improve
Default Will a DIY clutch adjustment help a slipping clutch?
My 06 MS6 slips very bad under slightly heavy acceleration, and I noticed that the clutches disengagement point is very close to almost releasing the clutch completely. I was thinking the the DIY adjustment might help the clutch engage better but I don't want to try it without being sure, Thanks for any help in advance!
Greekfreak is offline   Reply With Quote
 Old 09-20-2012, 05:53 PM   #2
jm211's Avatar
Posts: 943   (View Stats)
your issue is you have run out of material on your clutch. delaying the repair will cause more part failure. I also think the adjustment would be pointless. FYI the speed6 has a higher engagement point anyways.
you can replace with stock (luk kit) and get a lightweight flywheel to save on costs
Could a slipping clutch cause KR? AntiStock MazdaSpeed 6 - Engine, Transmission & Driveline 2 07-01-2010 02:23 PM
My clutch is slipping ms3jake MazdaSpeed 3 - Engine, Transmission & Driveline 29 03-03-2009 05:37 PM
Page generated in 0.23015 seconds with 21 queries
