![]() Join Date: Mar 2017
Rep Power: 0 ![]() ![]() Thanks: 2
(Thread Starter) | Not Ranked : 0 score Anyone have a picture of their EBCS or know if the factory connector is suppose to be 2 wire or 1 wire? I have the Corksport EBCS installed in my speed3 and it comes with a 2 wire connector, but my factory harness is only 1 wire. I'm also getting a P0245 when I scan for codes, but the CEL isn't on. My tuner just recently turned up the WGDC to 25% to supposedly yield 20PSI of boost, but I'm only getting around 16-17 PSI on my Corksport Turbo, which is around wastegate spring pressure. Any help would be appreciated! I don't have pictures quite yet, but I'll try to get some soon. Also, if it suppose to be 2 wire on the factory harness, does someone have a wiring diagram/pinout for it? Thanks, Ian |
Groans: 60
| The Following User Says Thank You to SSinstaller For This Useful Post: | ian209 (12-07-2018) |
(Thread Starter) | Not Ranked : 0 score Just checking if I'm tripping balls or not. The EBCS has a switched +12V going to one pin from the main relay with a fuse "ENG BB 5A." The other pin is from the PCM to the solenoid with presumably an active low PWM signal. Am I correct? |
| Not Ranked : 0 score you mixed 2 connectors if the 1 remain for the ebcs has just 1 wire. In that car, i figured out Mazda made all connectors différents in the engine bay to avoid mixing them except these 2 and unfortunately both are at the same location to make it easy to be mixed... You probably put the wrong one to the capacitor bolted on top plate above the EGR valve. EBCS connector needs 2 wires. one is a constant +12v and the other one is the pulsed negative signal from the ECU.
| The Following User Says Thank You to Jeff23spl For This Useful Post: | ian209 (12-07-2018) |
(Thread Starter) | Not Ranked : 0 score Yep, you were right lol. The guys that installed my new Corksport Dankai 1 motor mixed up the connection for the EBCS and capacitor. What does that capacitor do btw? |
| Not Ranked : 0 score i bet it is a filtering cap to reduce some signal noise but idk
| Not Ranked : 0 score Be careful with your new tune now that the connector is fixed.
| Display Modes | |
| P0245 CEL | Flameninja00 | 2010 MS3 - Troubleshoot/Diagnostics | 10 | 01-26-2017 07:07 PM |
| p0401 and p0245 | cocoleveo7686 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 15 | 12-10-2013 01:55 PM |
| P0245 CEL | Zbrit00x | Gen2 MS3 General Discussion | 2 | 08-09-2012 09:46 PM |
| CLE P0245 | ms6ms6 | MazdaSpeed 6 - Engine, Transmission & Driveline | 1 | 09-20-2011 11:26 PM |
| P0245, with MBC? | 11cruzito11 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 3 | 12-20-2009 08:29 PM |
