![]() | | #41 | ![]() |
![]() Join Date: Dec 2008 Location: Tempe, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13
| Not Ranked : 0 score Sent from my SCH-I535 using Tapatalk 2
__________________ Eric Schlaht - Arizona Phoenix Photographer http://www.esimaging.net - http://www.facebook.com/esimaging [SIGPIC][/SIGPIC] 2007 MS3 Sport, gtx3071r, Full-Race Exhaust Manifold, SP PNP Intake Manifold, SP 88mm Pistons 9:5:1, Manley H Beam Rods, 10mm H11 Head Studs, ARP Main Studs, 4" HTP TIP + Small Battery Tray, 3 Bar MAP, Grimmspeed ECBS, CP-E FMIC, CP-E DP, CP-E Nexus CBE, Tokay Injector Seals, CP-E RMM, SU PMM, TRZ TMM, PTP FP Internals, DCR VVT, JBrone Shift Plate, SU Shifter Bushings, HKS SSQV, ITV22, DIY Perm Plate with dual OCC, Corksport Radiator Shroud, Southbend Stage 3 Clutch, DO Stage 2 Meth D10, Evo X Wheels, 245/40-18 Nitto NT05, Koni Sports + H&R Springs **463whp/409lb-ft via Mustang Dyno as of 3/28/14** **9/19/13** Zoom Zoom Boom ** Currently Rebuilding with goal of 475whp **11/19/13** Forged engine built and started up the car for the first time, success! **3/28/14** Dyno results from build 463whp / 409lb-ft Mustang Dyno **6/24/15** Sold the Mazdaspeed 3 **7/4/15** Purchased 2015 F150 Ecoboost Lariat FX4 with Sport Package |
![]() | | #42 | ![]() |
![]() Join Date: Aug 2013 Location: Grand Rapids, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3
(Thread Starter) | Not Ranked : 0 score Okay, that's what I thought. Is that the ONLY thing it could be is the pump itself? Can it be rebuilt? It's less than 2 years old. I mean I realize the proof is in the log but is there any way to test the pump to make sure its not a bad connection, fuel pressure regulator, in tank pump or injectors or something else. If not, I'll be ordering a pump. Thanks!!! Last edited by Motocooney; 08-27-2013 at 04:22 AM. |
![]() | | #43 | ![]() |
(Thread Starter) | Not Ranked : 0 score So I need to buy a stock HPFP and Autotech(or equivalent) internals correct. thanks |
![]() | | #44 | ![]() |
![]() Join Date: Sep 2011 Location: Stockholm Sweden
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,687
Groans: 33
| Not Ranked : 0 score You need to take the pump out and take a look at the internals and the inside of the pump. Take pics and post. How sure are you that you in fact have aftermarket internals installed now?
__________________ Mazdaspeed6 -06 Tuned with by Alex@StratifiedCP-E Atmosphere Kit GTX3076 Tial 0.82AR / EWG / 3,25" MAF / Catless DP Simons 3" Catback CP-E Diff Mount HDI FMIC HTP Battery Relocation Corksport: Rear Brace Bar - Front Strut Bar - Stubby Antenna - Interior + Underhood LED Kit JBR: TMM+PMM+RMM - Short Shift Kit /w Bushings - TIG Throttle - Coolant Bypass - EGR Delete - JBR OCC Stage 2 Whiteline Rear Swaybar SPC Camber Joints Turbosmart BPV Autotech Internals SURE Juggernaught Stratified Guardian Angel & Boost Dial NGK IX @ 0.025 Bosch 3 bar MAP w/ PNP Harness Block8Head Dual Gauge Pod Defi Racer Boost & Oil Pressure & Oil Temp Techna-Fit Clutch Line + Brake Lines ATE Super Blue Racing ProSport Oil Filter Adapter Mazda Spin-On Conversion + NPT/BSPT adapter Not installed yet: SP63 longblock, FreekTune 4" Intake, JBR TIG IM, DM Meth Spacer 290 AWHP / K04 370 AWHP / GTX3076 @ 23 psi |
![]() | | #45 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thx for the quick reply. I wanna get whatever I need ordered. I have documentation from Ptuning for the install. Could it be possible that I just need to install new autotech internals or do you think the pump itself is done. It's just mechanical right? Could it be the spill valve or a connection? Is it normal for the internals to fail and the pump itself be fine? I will do what you say. I will take it out and post pics. Thanks |
![]() | | #46 | ![]() |
![]() Join Date: Nov 2010 Location: Albuquerque NM
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 358
| Not Ranked : 0 score You could have all the documentation in the world but not have whats documented in the car. The prev owner could of taken the internals out (why? IDK)..... Just a wild thought. Im not sure what your income is and if money is a problem but like the other guys said, remove the pump, inspect and then spend your money.
__________________ [SIGPIC][/SIGPIC] "That Other's May Live" SELF TUNED 380WHP/372WTQ Dyno Jet @SL E85 mix ENGINE GTX3071r // CUSTOM exMANI // CUSTOM DP // TAIL 38mm WG // NGK 1 STEP COLDER PLUGS (6510) // HTP 3.5" WP+BATT TRAY // GRIMSPEED 3 PORT EBCS // BOSCH 3 BAR+HARNESS // JBR BYPASS HOSE // GUARDIAN ANGEL // CX PIPING+TR8 CORE // V3 ACCESSPORT // JBR 88a RMM // JBR 88 duro TRANNY // JBR OCC Stg 2 // SYNAPSE DV SUSPENSION CorkSport Coils // SPC REAR CAMBER ARMS @-1.5 // 17x9 RPF01's- 255/40/18 FEDERAL RS-R // 5mm(front) EIBACH SPACERS+STUDS OTHER SHIT JBR SSP // RALCO RZ SS // DEFI RED RACER BOOST GUAGE // BLOCK8HEAD VENT POD // KENWOOD DDX419 // KICKER ZX300.1 // DX200.4 // KICKER CVR 12" IN PORTED BOX // KICKER MIDS+HIGHS |
![]() | | #47 | ![]() |
(Thread Starter) | Not Ranked : 0 score Money isn't an issue as much as time is. If I'm gonna pull the pump out and apart, I'd like to have internals on hand to replace with ya know. I've been searching but what components can fail on the pump itself? Seals. If I order autotech internals, do they come with all that's needed to make the pump like new again. I can't tell from the photos. Thx |
![]() | | #48 | ![]() |
(Thread Starter) | Not Ranked : 0 score Previous owner says its a PT Performance HPFP with "basic upgrade" internals. |
![]() | | #49 | ![]() |
![]() Join Date: Jul 2011 Location: Fayetteville, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,655
@phate; has my v2 and i believe they are still running strong.
__________________ [SIGPIC][/SIGPIC] | |
| The Following User Says Thank You to StayBroke For This Useful Post: | rfinkle2 (08-27-2013) |
![]() | | #50 | ![]() |
No one is going to really know untill you cover the basic stuff I.E. remove yo shitzz to rule out a few possibilities so you can have your car back.
__________________ [SIGPIC][/SIGPIC] "That Other's May Live" SELF TUNED 380WHP/372WTQ Dyno Jet @SL E85 mix ENGINE GTX3071r // CUSTOM exMANI // CUSTOM DP // TAIL 38mm WG // NGK 1 STEP COLDER PLUGS (6510) // HTP 3.5" WP+BATT TRAY // GRIMSPEED 3 PORT EBCS // BOSCH 3 BAR+HARNESS // JBR BYPASS HOSE // GUARDIAN ANGEL // CX PIPING+TR8 CORE // V3 ACCESSPORT // JBR 88a RMM // JBR 88 duro TRANNY // JBR OCC Stg 2 // SYNAPSE DV SUSPENSION CorkSport Coils // SPC REAR CAMBER ARMS @-1.5 // 17x9 RPF01's- 255/40/18 FEDERAL RS-R // 5mm(front) EIBACH SPACERS+STUDS OTHER SHIT JBR SSP // RALCO RZ SS // DEFI RED RACER BOOST GUAGE // BLOCK8HEAD VENT POD // KENWOOD DDX419 // KICKER ZX300.1 // DX200.4 // KICKER CVR 12" IN PORTED BOX // KICKER MIDS+HIGHS | |
![]() | | #51 | ![]() |
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. | |
| The Following User Says Thank You to phate For This Useful Post: | StayBroke (08-27-2013) |
![]() | | #52 | ![]() |
| Not Ranked : 0 score I've been running ptp internals in my car since 2009 and still running strong with my big turbo. Rarely do they fall below 1700 @ wot. I've been happy with mine. Sent from my SCH-I535 using Tapatalk 2
![]() | | #53 | ![]() |
Wow oh wow
![]() | | #54 | ![]() |
| Not Ranked : 0 score lol, yeah. I couldn't get the piston out of the barrel (they were completely seized), so I had to destroy the piston retainer to get them out of the nut. Luckily, I had another pump lying around so I had donor parts.
| The Following User Says Thank You to phate For This Useful Post: | rfinkle2 (08-27-2013) |
![]() | | #55 | ![]() |
| Not Ranked : 0 score Damn i would have called him and got ANOTHER set lmao.
![]() | | #56 | ![]() |
(Thread Starter) | Not Ranked : 0 score Cool thanks dudes I'm gonna pull it tonight and post pics. What exactly am I looking for? Scored walls? I think pressure is fine at idle (400ish) and its fine while cruising. Ill log it tonight. Idle I mean. No more wot. Lol. |
![]() | | #57 | ![]() |
| Daily Driver ![]() ![]() Join Date: Dec 2008 Location: Tampa, Fl
Rep Power: 880 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 576
| Not Ranked : 0 score I love how everyone's answer is get an etune instead of troubleshooting. Does the turbo grind when you sign wheel by hand |
![]() | | #58 | ![]() |
(Thread Starter) | Not Ranked : 0 score Ill be checking shaft play tonight as well. Only had the car since Friday. Haven't had a chance to really dig into it. My guess is the turbo is fine. Part throttle feels great. I think the turbo want to boost but there isn't enough fuel for the engine to make it boost |
![]() | | #59 | ![]() |
(Thread Starter) | Not Ranked : 0 score As far as recommendations for an Etune.....the original tune couldve been amazing (not likely) but it was 2.5 years ago. In my experience these types if cars aren't "set it and forget it" Tunes need to be touched up here and there. Of course I know I'm preaching to choir. Lol. You guys know your shit it seems. Which is a refreshing change of pace from the Evo world. So as soon às its running right, it will be tuned properly Last edited by Motocooney; 08-27-2013 at 12:29 PM. |
![]() | | #60 | ![]() |
| Not Ranked : 0 score BTW, you can get the pump out in about 30min. You really dont have to remove all the shit in the how-to's. You seem like you have common sense so you will figure it out.
![]() | | #61 | ![]() |
| Not Ranked : 0 score I highly recommend removing battery box when taking hard line off especially for installing the pump out cost me hours once because I did not want to remove the battery can be done in 3 minutes |
![]() | | #62 | ![]() |
![]() Join Date: Feb 2010 Location: SLC, UT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,720
| Not Ranked : 0 score it just makes it easier taking out the battery and tip but i usually just leave it all in place
__________________ GTX 2867/ JBR OG 3.5 WP/ Snail Ported IM/ ITV-22/ DAMOND RMM EBAY DP wCAT/ HKS BPV/ CP-E FP/ COBB EBCS/ PG FMIC W/ TR8 STOPTECH/ EBC YELLOW/ GOODRIDGE LINES/ MOTUL RBF 600 [443/409]SAE CORRECTED -------------245 DZ102 / 245 NT01 |
![]() | | #63 | ![]() |
(Thread Starter) | Not Ranked : 0 score . Last edited by Motocooney; 08-27-2013 at 09:26 PM. |
![]() | | #64 | ![]() |
(Thread Starter) | Not Ranked : 0 score Pics soon Last edited by Motocooney; 08-27-2013 at 09:28 PM. |
![]() | | #65 | ![]() |
(Thread Starter) | Not Ranked : 0 score Got it Last edited by Motocooney; 08-27-2013 at 09:25 PM. |
![]() | | #66 | ![]() |
(Thread Starter) | Not Ranked : 0 score Alright. Got the pump out, took it apart, put it back together and put it back in. lol Things to note....The internals were dirty as fuck. I cant think of a reason they would get so sludged up...I only took one pic of this. The button retainer that PTP uses was loose as hell Like a mm of play. I cant imagine thats good. They state in their internals installation instructions that the button retainer must have no play. This is a hpfp built by them, assembled by them and sent out by them. And the retainer was loose. Im guessing its been loose ever since it was installed on the car. I've talked further with the previous owner and he says that he's always noticed a bit of hesitation under wot, low/rough idle and irratic accleration. HMMM i wonder what was causing that? Well, here are the pics. Let me know what you guys think I should do. The pump itself seemed fine, I didnt notice any damage at all, I mean the internals are the only moving parts except for the spring which is... a spring. It seemed springy enough to me. [IMG] [IMG] [IMG] I couldnt get any good pics of the inside bore of the other internal piece(dont know what its called, the thing the shaft slides in and out of lol) but it was scored in the same way as the shaft/plunger. Do you thing the loose retainer button is to blame? It was basically being rattled back and forth by the cam instead of a steady, solid motion ya know? [IMG] The previous owner seems to think he can get the pump warrantied or at least the internals replaced. I doubt it but I will certainly let him try. This pump was bought in late 2010. There are a string of threads about failed PTP HPFPs from this time. Either way, I just want to get the car running how its supposed to. Thanks for the help |
![]() | | #67 | ![]() |
![]() Join Date: Feb 2012 Location: davenport, iowa
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,201
Groans: 128
| Not Ranked : 0 score your shaft looks fucked like .... no its just fucked
__________________ 09 Speed3 ,sold 2012= k04@18lbs, k&n intake, race pipe, selftune13.00@109.76 2013= BNRs2@20lbs E30 FreekedBuilt & Bolted12.63@113.75 full weight, nitto dr's 2014 06 ms6 gt3076 built bolted 2015 06 ms6 parted 2016 07 cosmic MS3 SOLDforged pistons/rods, bsd baffle, cs turbo, fmic, occ, spin on conv, catless long dp, e30, sri, cpe hpfp, rmm, ported im. |
![]() | | #68 | ![]() |
![]() | | #69 | ![]() |
| Not Ranked : 0 score Clean everything in the pump body. Break it down completely and blast it with brake parts cleaner. Throw in a new set of internals and you should be set.
![]() | | #70 | ![]() |
I was gonna clean the spill valve but after I saw the condition of the internals I figured I had found the culprit. Or do you mean disassemble same as I did tonight? Thanks man | |
![]() | | #71 | ![]() |
Groans: 128
__________________ 09 Speed3 ,sold 2012= k04@18lbs, k&n intake, race pipe, selftune13.00@109.76 2013= BNRs2@20lbs E30 FreekedBuilt & Bolted12.63@113.75 full weight, nitto dr's 2014 06 ms6 gt3076 built bolted 2015 06 ms6 parted 2016 07 cosmic MS3 SOLDforged pistons/rods, bsd baffle, cs turbo, fmic, occ, spin on conv, catless long dp, e30, sri, cpe hpfp, rmm, ported im. | |
![]() | | #72 | ![]() |
| Not Ranked : 0 score what phate says. lots of scoring on the shaft es no bueno
![]() | | #73 | ![]() |
![]() Join Date: Apr 2012 Location: irving,tx
| Not Ranked : 0 score Where are you located?This way others can see where you are from an get iin touch with your fellow Nator bbrothers/ sisters. Look for the Nator national section |
![]() | | #74 | ![]() |
Groans: 128
| Not Ranked : 0 score donate and change your avatar, PLEASE
![]() | | #75 | ![]() |
![]() | | #76 | ![]() |
Groans: 128
| Not Ranked : 0 score cool, you could also maybe edit your location
![]() | | #77 | ![]() |
(Thread Starter) | Not Ranked : 0 score I forgot to add that when I started the car after re-installing the hpfp, I had a CEL P0091. Low pressure regulator circuit or something. I cleared it and it didnt come back. I let the car idle for about 10 minutes and went for a 10 minute easy cruise and it hasnt come back. The clip connector is secure on the spill valve. I was logging fuel pressure for the first 10 minutes of idle and it finally settled right around 375psi. Don't worry about it? I pulled the coil packs for the first 10 or so cranks to build fuel pressure (I know realize I couldve just put the pedal to the floor) |
| The Following User Says Thank You to Motocooney For This Useful Post: | mxlplx71 (08-28-2013) |
![]() | | #78 | ![]() |
(Thread Starter) | Not Ranked : 0 score Autotech internals ordered from CTS ![]() I'm extremely excited to see what this car can do with proper fueling. Assuming that's what the problem is. I sure hope so. Thanks so much for helping the new guy out. Great first impression from mazdaspeedforums. |
![]() | | #79 | ![]() |
![]() Join Date: Jul 2008 Location: Imperial MO
Rep Power: 582 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 127
| Not Ranked : 0 score And who said check your fuel pump and I was told it was ok....lulz. Glad you found your issue.
__________________ 2008 MazdaSpeed 3 AWD big turbo...blah blah blah |
![]() | | #80 | ![]() |
I was using th AP to monitor FP pressure (not logging just realtime) I didn't have the cable and hasn't yet downloaded ATR or ap manager. The ap has a max value on whatever you are monitoring. So I selected hpfp actual pressure and did a pull. After, I looked and it said the max I had hit was 1700psi. I just assumed that max was hit during wot. Oops. Obviously after I really logged it, the only time it hits 1700psi is right before it starts making boost. Right before it drops to fucking 600psi. Stupid. That's my excuse. Yes, you were all right about the pump from the start | |
| Help just put on a turbo inletpipe car not running | 609speed6 | Mazdaspeed3/6 General Discussion | 12 | 02-19-2011 10:12 AM |
| What are the Built Motor guys running? | FamiliaGT | MazdaSpeed 3 - Engine, Transmission & Driveline | 4 | 02-07-2011 11:04 PM |
| Anyone running a precision turbo on MS3 | origjdm3 | MazdaSpeed 3/6 - Big Turbo Builds | 37 | 07-08-2010 04:04 PM |
| Running open turbo! | nutsac76 | Mazdaspeed3/6 General Discussion | 52 | 04-20-2009 12:02 AM |
