![]() | | #41 | ![]() |
![]() Join Date: Feb 2009 Location: Flanders, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 224
| Neutral : -1 score On a sidenote, have you looked into a supercharger kit? you'll get a shit load more power plus its providing more air into your engine which several people have suggested you do anyway. Supercharger kits are available MAD CHEAP on ebay and just like everything else for our car thats on ebay, its very reliable. I even read somewhere that the Hypertech has a code you can enter that unlocks maps for superchargers. left, left, right, right, up, down, enter.
__________________ 2008 Cosmic Blue Mazdaspeed 3 GT - COBB AP DIZZYTUNED for 30% E85//JBR Whale Penis//COBB TIP//COBB DP//COBB STS//COBB Knob//COBB shift weight//COBB Piping TR8L Core//Magnaflow CBE//Turbosmart BPV//PTP internals//SU RMM//TRZ tranny mount//Koni + H&R springs//Tinted 35% front, 20% rear//Lamin-X head-light & tail-light film//ASA GT1 18x8//Hankook Ventus V12 225/40// |
| The Following 3 Users Say Thank You to sallyspeed3 For This Useful Post: |
![]() | | #42 | ![]() |
![]() Join Date: Jul 2011 Location: graham, wa
Groaned at 8 Times in 3 Posts
| Not Ranked : 0 score If your a mechanic, i hope you go out of business damn fast, otherwise i worry for anyones vehicle you touch
__________________ PTP windage tray/ BSD|PTP CDFP|Cobb SRI| JBR RMM|JBR SSP|CS TIP|Cobb AP+OTS tune |
| The Following User Says Thank You to MS3kid08 For This Useful Post: | Tokay444 (12-18-2011) |
![]() | | #43 | ![]() |
![]() Join Date: Dec 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groaned at 312 Times in 89 Posts
(Thread Starter) | Not Ranked : 0 score So say fuel pump and dp then. As stated I aready have hypertech tune. I don't want it to be loud. I want to keep my stock cat back exhaust system. I want to be a sleeper car so I don't really want the noise from the intake. I realize there will be louder sound without the two cats as well.
Last edited by b4n30n3; 12-18-2011 at 01:04 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #44 | ![]() |
Groans: 793
| Not Ranked : 0 score Are you still posting?
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals |
| The Following User Says Thank You to Tokay444 For This Useful Post: | skiptowncat (12-18-2011) |
![]() | | #45 | ![]() |
Groans: 63
| Not Ranked : 0 score there are plenty of intakes for under $200. from a pure physics point of view, output cannot be greater than input so replacing the downpipe will have almost no effect. If you're worried about sound, performance cars are not for you.
![]() | | #46 | ![]() |
Groans: 793
| Not Ranked : 0 score Maybe on an n/a car. If you free up restrictions on the exhaust side, it should suck a little quicker on the intake side.
![]() | | #47 | ![]() |
![]() Join Date: Jun 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,505
| Not Ranked : 0 score OP: Just stop posting. EVERY answer you have received with any substance has consistently pointed out that you need to do the INTAKE before the dp. And yes, HT will work well with your damn downpipe, ONCE you get to that point, AFTER the intake. Get it? I tried to help. I really did.
![]() | | #48 | ![]() |
![]() Join Date: May 2009 Location: Little Neck, NY
Rep Power: 3771 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,108
Groans: 326
| Not Ranked : 0 score for a mechanic you sure are stupid as fuck why is he not being destroyed why are you all helping this forum has gotten so fucking soft its disgusting op go spend some time on m3f or 247 |
![]() | | #49 | ![]() |
Groans: 793
| Not Ranked : 0 score Fuck just do it. Car is invincible. Had direct injection. Some new space aged tech.
![]() | | #50 | ![]() |
![]() Join Date: Apr 2011 Location: Boynton Beach FL/Flanders, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,007
Groaned at 64 Times in 49 Posts
lolol
__________________ Badsnake 2003 Cobra: Ported Eaton, 2.93 upper, 4lb lower, Steeda intake, fuel system, LF Heat Excg, MGW Shifter, MM Coilovers, Billet Flow IRS Brace, Magnaflow O/R X Pipe/CBE, Fiore Clutch Quadrant/Adjuster, MT ET Street Radials 515rwhp/525rwtq. #HAR Hidden Agendas Racing Last edited by Payne Racing 67; 12-18-2011 at 01:38 PM. Reason: MSF Database - Automerged Doublepost | ||
| The Following User Says Thank You to Payne Racing 67 For This Useful Post: | vrspeed10 (12-18-2011) |
![]() | | #51 | ![]() |
![]() Join Date: Jun 2011 Location: Wilmington, Delaware
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 612
Groaned at 25 Times in 10 Posts
| Not Ranked : 0 score Lol
__________________ If your not first your last. ![]() 03 Speed Protege.. SOLD 10 Speed3 BT and getting my DRANK on!!! |
| The Following User Says Thank You to vrspeed10 For This Useful Post: | Payne Racing 67 (12-18-2011) |
![]() | | #52 | ![]() |
![]() Join Date: Jan 2010 Location: Downers Grove, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,309
Groans: 76
| Not Ranked : 0 score I feel like this is either someone off the pt cruiser website who found out we were trolling them, or a gen2 guys who is sick of all the noob gen 2 posts and wanted to make a gen1 post... either way TROLL
__________________ '12 speed 3 CWP w/tech: DIZZY Tuned by Phate!,cobb AP,Autotech internals, cp-e nano, cp-e TIP, JBR 88 dogbone, JBR SSP/bushings, JBR rear sway bar, UR test pipe RIP '08 speed 3 silver cp-e 75 duro RMM, cp-e intake, cp-e TIP, Jbarone SSP and bushings. |
![]() | | #53 | ![]() |
Groans: 793
| Not Ranked : 0 score Lol at colder plugs being step 5 and rmm being step 2. That whole list is 'tarded.
| The Following User Says NO Thank You to Tokay444 For This Un-useful Post: | vrspeed10 (12-18-2011) |
![]() | | #54 | ![]() |
![]() Join Date: Feb 2011 Location: Oshkosh, WI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,456
Groans: 398
| Not Ranked : 0 score No you're not. You suck at trolling. Sent from my DROIDX using Tapatalk
__________________ 2007 MS3 Silver. Intake bits, exhaust bits, FMIC bits, freektuned, loved, cherrished, SOLD!!! 2014 5.0 Gotta Have It Green w/Track Pack |
![]() | | #55 | ![]() |
![]() Join Date: Oct 2011 Location: Boca Raton, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,717
Groaned at 50 Times in 17 Posts
| Not Ranked : 0 score Who's more retarded??? The OP or the guys who expend more time answering questions???
__________________ 2012 LSM MS3 Some mods, No list, too much "zapos". |
![]() | | #56 | ![]() |
![]() Join Date: Nov 2010 Location: Chicago, IL
Rep Power: 466 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,591
Groans: 32
| Not Ranked : 0 score Haven't been on mazdaboards for years? Your join date is dec 2011. Stfu troll.
__________________ 2007 MS3 GT - Mazdaspeed CAI, Corksport Downpipe, Corksport Testpipe, HKS-CBE w/resonator delete, CP-E 75 RMM, Koni Yellows, H&R Springs, Greddy Type S Bov, Denso ITV 22s, Autotech Internals, Accessport Tuned (Thanks Phate!) ^^ - RIP 5/29/13, You will be missed <3 2013 MS3 - Mazdaspeed Intake, Turbo XS DP & TP, Ultimate Racing CBE, Greddy Type S Bov, Autotech Internals, AP OTS MAP ( Awaiting Tune ) |
![]() | | #57 | ![]() |
(Thread Starter) | Not Ranked : 0 score Maybe I should just assume no one knows the answer to my exact question. I don't get how everyone keeps saying I am making things up. I am a mechanic the work I do is good and no ones stuff doesn't work after I fix I always test drive and make sure it runs right. I have an 07 msp with a hypertech module so essentially no modifications. I do not own a gen2 or a pt cruiser. My thinking is that if I just want to put one single part on my car that is already tuned I would get more power with a dp than an intake or any other mod. Reducing exhaust gas temps in the manifold could only help the motor run safer. I really don't deserve to be flamed for that it is on topic for this subforum. |
| The Following 6 Users Say NO Thank You to b4n30n3 For This Un-useful Post: | BobbleHead (12-22-2011), KusteLokal (12-18-2011), skiptowncat (12-18-2011), speeed (12-18-2011), TexasSpeed3 (12-18-2011), Tokay444 (12-18-2011) |
![]() | | #58 | ![]() |
Groans: 433
| Not Ranked : 0 score Shut the fuck down. Noob. you have not done any reading, it's obvious. Don't fucking lie to us and tell us you have. What makes you think it's a great idea to get a downpipe on a motor that can barely suck in enough air via the stock intake? On stock cdfp, with no tune to compensate? Make another post like this without reading more, and you'll get a vacation. 34 groans in your short membership period is not a good start.
| The Following 12 Users Say Thank You to Chimmike For This Useful Post: | 8.5MS3 (12-18-2011), BobbleHead (12-22-2011), KusteLokal (12-18-2011), MSMS3 (12-18-2011), Payne Racing 67 (12-18-2011), sallyspeed3 (12-18-2011), speeed (12-18-2011), SWAY (12-18-2011), symkaz (12-18-2011), TexasSpeed3 (12-18-2011), Tokay444 (12-18-2011), Vinnie (12-18-2011) |
| weird tire wear pattern. stock tires. stock rim. stock suspention. stock tire pressure what's up with this? | labikesrcool | MazdaSpeed 3/6 - Wheels & Tires | 21 | 11-30-2015 03:32 PM |
