  • 1 Post By YokiMazoku
  • 1 Post By Chimmike
 Old 02-24-2012, 01:39 PM   #1
YokiMazoku's Avatar
Posts: 320   (View Stats)
YokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the world
Default 12psi boost
Okay maybe someone can help me out or at least point me in the right direction. I have a MS3 2007 that will only hit about 12psi of boost. I thought originally i damaged my TIP but it turns out that is not the case. I did a boost leak awhile back and didn't find anything im gonna try again but i dont think its that. Here is a log i took. Any help would be much appreciated. This started right after i updated to the latest OTS map.
Boobs.....because you can't motorboat a personality.
YokiMazoku is offline   Reply With Quote
 Old 02-24-2012, 01:47 PM   #2
abiezerf's Avatar
Posts: 725   (View Stats)
abiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the world
Groans: 46
Does it happen with only one map? or all of them?
Edit: Dude, there is no RPM column on your log. Makes it hard to determine stuffs.
Current Build:
Liquid Silver Metallic Pu - JBR Shifter Bushings, Cobb AP, JBR Chome Molly
JBR SSP, ProSport Premium Boost Gauge, 25% e85 Tune
PTP HPFP Internals, CorkSport Intake/TIP, Cobb Sport Springs
Sold:
2008.5 Black Mica GenWon - Fully Bolted
abiezerf is offline   Reply With Quote
 Old 02-24-2012, 01:53 PM   #3
COCKSTRONG
SofaKingAwesome's Avatar
Posts: 8,447   (View Stats)
Groans: 890
yikes. Practice datalogging and do a MAF Cal.
HOW TO CALIBRATE YOUR MAF! With An Example
select default logging preferences or whatever it says on your AP and it should set you up decent.
Last edited by SofaKingAwesome; 02-24-2012 at 01:53 PM. Reason: MSF Database - Automerged Doublepost
rfinkle2 (02-24-2012)
 Old 02-24-2012, 02:13 PM   #4
YokiMazoku's Avatar
I was trying different maps sorry i will do another log later today. I haven't calibrated the MAF on the new map yet bc of the boost problems.
 Old 02-24-2012, 02:22 PM   #5
You have either a bad boost control solenoid, or a wastegate actuator problem.
If you look @ the logs, your car is running 0 wgdc for some reason.
Edit: Actually I cannot tell from your logs that the above is your problem for sure. (I looked @ it too quickly the first time)
Most of your log is not WOT operation.
Can you catch a log from 2500 rpm - redline?
As Sofaking said, reset the default logging parameters on your AP when you get a chance, and hit us with that log.
SofaKingAwesome (02-24-2012)
 Old 02-24-2012, 02:25 PM   #6
patrick failman
karl-hungus's Avatar
Posts: 4,635   (View Stats)
Groans: 74
yellow no shims.
 Old 02-24-2012, 02:29 PM   #7
POWERED BY POLSKA
themytb's Avatar
Posts: 762   (View Stats)
themytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the world
Groans: 38
maf=first
BNR S3---GS 3PORT---3bar map---COBB SRI & TIP---PG/GODSPEED FMIC ---DNP MANI--- CNT catted TBE--CP-E HPFP-- DIY P&P'd intake mani---SURE TIG(mani & tb)---DIY EGR delete---DIY VCTS delete--- DIY OCC/PCV reroute(through old egr port)---CP-E S2 RMM---JBR 80 PMM---TS BPV--- SURE ANCHORS---JBR shift weight---Whiteline RSB
25%E85FREEKPERMED
themytb is offline   Reply With Quote
 Old 02-24-2012, 02:57 PM   #8
YokiMazoku's Avatar
Ok i took another log 3rd thru 4th. I did turn on my logging options for a better log. If i need to add something else let me know ill try again thanks guys! ops wrong log ap didnt catch one of my log but this one should work.
 Old 02-24-2012, 03:04 PM   #9
COCKSTRONG
Groans: 890
ya gonna post the damn thing?
 Old 02-24-2012, 03:04 PM   #10
Police - Grammarhead
Vansquish's Avatar
WTF is that?
Your log shows NOTHING useful.
If you're doing a MAF calibration log, you should be using low throttle, basically staying out of boost and running from about 3k RPM to redline.
If you're doing a WOT log, you actually have to log from about 3k RPM to redline while you've got the pedal to the floor.
The log you gave us shows nothing of the sort. The only thing I can say conclusively is that your MAF is not calibrated well, as you're definitely not within (abs)2 of 0 for your LTFTs.
 Old 02-24-2012, 03:04 PM   #11
YokiMazoku's Avatar
changed sorry posted wrong log. The previous log i started then i saw a cop and had to try somewhere else sorry again.
 Old 02-24-2012, 03:14 PM   #12
Vansquish's Avatar
OK...so here's my own experience with the latest (Boost-tuning) OTS maps from Cobb.
I should preface this by saying that my car is a 2006 MS6.
Because they were the newest thing from Cobb, I downloaded and installed a Boost-Tuning OTS map when Cobb made them available. I noticed that I was hitting lower boost than stock levels and that the car felt significantly down on power relative to my previous Load-Tuning map.
I fiddled with everything from load targets to boost targets to WGDC to Ignition and even dabbled a little in VVT. No matter what I did (granted, I was making small adjustments), I couldn't get back to the 17.5-18psi of boost that I'd been running on my previous Load-map, and the car was noticeably more sluggish (VD said I'd lost about 30hp and 40tq on the Boost map).
On the Boost map, I was only hitting about 13.5-14.5psi, and was unable to do any better despite the map's target of 17.5psi.
I switched back, revised my most recent Load map with some things that I'd learned, and the car is back to its old self...but even faster (tweaked a few things).
rfinkle2 (02-24-2012), YokiMazoku (03-01-2012)
 Old 02-24-2012, 03:21 PM   #13
YokiMazoku's Avatar
I still have my old map that worked great i will try switching back to that later today and give it a try.
 Old 02-24-2012, 03:23 PM   #14
abiezerf's Avatar
Groans: 46
Looks like you can't pass 14 psi. That is the wastegate spring pressure. Might be your solenoid or your wastegate that is messed up.
Current Build:
Sold:
 Old 02-24-2012, 03:42 PM   #15
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Your WGDC is very low
 Old 02-24-2012, 03:56 PM   #16
Are you on the stock turbo?
Your MAF is reading very high for a stock turbo and 13psi. The high reading of the MAF means your calculated load is high - so the ECU is running all the boost it needs to hit those load targets.
I am suspecting a leak between the turbo outlet and the motor. The turbo is pulling the air through the MAF causing it to read high but the boost pressure is lost before it gets to the manifold.
If you are on a larger turbo then indeed you might be flowing that much air in which case you have to target higher load values to increase boost.
rfinkle2 (02-24-2012), YokiMazoku (03-02-2012)
 Old 02-26-2012, 01:24 AM   #17
YokiMazoku's Avatar
Thanks everyone for all the help! I did another boost leak test it seems my TIP is messed up like i originally thought. Looks like it has just gotten worse. Managed to get a hold of Mark at street unit everyone seems to love this guy now i know why he hooked me up after the huge ordeal i had a few weeks back. I should have it wednesday or thursday this week. Thanks Mark!
The Following User Says Thank You to YokiMazoku For This Useful Post:
rfinkle2 (02-26-2012)
 Old 03-01-2012, 05:40 PM   #18
YokiMazoku's Avatar
So i ran another boot leak test since lex suspected i had another leak after the TIP. Which he was correct. However im still stuck at 12psi. So i finally got a chance to load up my old map "load base tuning" and now 16-17 psi boost. WTF is going on why is that? I tried different new boost base tuning maps and they all get me stuck at about 12-13 psi.
Azspeed likes this.
 Old 03-01-2012, 05:58 PM   #19
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Leak after the TIP? dude, the TIP doesn't EVER see boost.
it sounds like you're not checking the box for boost based tuning or something
07 MS3
The original Genpoo Hater
rfinkle2 (03-02-2012)
 Old 03-01-2012, 07:22 PM   #20
YokiMazoku's Avatar
box is checked. Thats not it.
 Old 03-01-2012, 08:07 PM   #21
abiezerf's Avatar
Groans: 46
Odd, I'm having a similar problem. Can you post one of your load based maps so I can try and see what happens?
Sent from my HTC Evo 3D using Tapatalk
Current Build:
Sold:
 Old 03-01-2012, 09:16 PM   #22
YokiMazoku's Avatar
Ok so i did a quick pull in fourth gear and noticed some kr so i got off of it can anyone shine some light on this? The maps i have are the 1.08 but they are modified some. Ill post one later. This i the new log i just did.
 Old 03-02-2012, 07:59 AM   #23
abiezerf's Avatar
Groans: 46
Please post the map when you can, I'd like to try it. Thanks!
Current Build:
Sold:
 Old 03-02-2012, 09:35 AM   #24
Miembro
nighthawk358's Avatar
nighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the worldnighthawk358 is the leader of the world
Groans: 27
what box do you have to check?
2008.5 MS3 Metro Gray...slow
nighthawk358 is offline   Reply With Quote
 Old 03-02-2012, 03:23 PM   #25
COCKSTRONG
Groans: 890
READ
http://www.cobbtuning.com/v/vspfiles...MAZDASPEED.pdf
 Old 03-02-2012, 03:38 PM   #26
timjs's Avatar
Posts: 908   (View Stats)
timjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the worldtimjs is the leader of the world
Groaned at 16 Times in 7 Posts
When I first flashed to one of Cobb's stage 1 OTS maps..I had the 12 psi/ 0% WGDC issue too. Reflashed to stock, and flashed it AGAIN to the stage 1 map and it was fine.
I have NOOO idea what changed from the first try to the second.
timjs is offline   Reply With Quote
 Old 03-02-2012, 03:40 PM   #27
COCKSTRONG
Groans: 890
You can try the "Open map in ATR, save in ATR, push to AP, and reflash car trick"
Can't hurt.
 Old 03-02-2012, 05:47 PM   #28
BrianB6's Avatar
Posts: 400   (View Stats)
^^^ totally agree, also double check AP firmware and ATR version
have you tried to contact anyone at Cobb? could be some kind of known issue???
2016 - WRX -Cobb AP - Perrin Shift Stop - Perrin Trans Mount - Whiteline Positive Shift Bushings
2006 - MS6 - Dead RIP
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/12psi-boost-106167/
MazdaSpeed Forums This thread Refback 02-26-2012 03:01 AM
Only running 12psi- spring pressure speed23 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 21 02-25-2012 06:52 AM
wont boost past 12psi kachow22 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 12 07-23-2009 05:45 PM
Stand Back only boosting 12psi? steven88 MazdaSpeed 3/6 - ECU Computer Tuning 4 07-18-2009 08:24 AM
Page generated in 0.43927 seconds with 33 queries
