 Old 06-22-2009, 08:22 AM   #1
TenaciousBoost's Avatar
Posts: 245   (View Stats)
TenaciousBoost is the leader of the worldTenaciousBoost is the leader of the worldTenaciousBoost is the leader of the worldTenaciousBoost is the leader of the worldTenaciousBoost is the leader of the worldTenaciousBoost is the leader of the worldTenaciousBoost is the leader of the worldTenaciousBoost is the leader of the worldTenaciousBoost is the leader of the worldTenaciousBoost is the leader of the worldTenaciousBoost is the leader of the world
Groaned at 12 Times in 3 Posts
Default 13psi sucks
I can't seem to hold steady boost pressure, anywhere from 12-14 PSI while WOT. I see boost spikes up to 18 psi or so but only for a fraction of a second, not holding 17.5 like I'm supposed to be with an accessport stage 1+sf.. Am I experiencing symptoms of a leaky bypass valve, or do I have a boost leak elsewhere?
I have heard of loose connections between TIP and turbo, but will this really cause me to not hit my boost targets? Only thing I could think of was my BPV being a leaker, but wanted to know if anyone else had resolved this issue by scrapping the stocker...
TenaciousBoost is offline   Reply With Quote
 Old 06-22-2009, 10:26 AM   #2
Crossbow's Avatar
Posts: 709   (View Stats)
Crossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the worldCrossbow is the leader of the world
So you spike to 18, then immediately drop to 14/12? Or do you spike to 18, hit 17/16, then slowly taper down to 13-14?
Crossbow is offline   Reply With Quote
 Old 06-22-2009, 11:14 AM   #3
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
datarog prease
 Old 06-22-2009, 11:35 AM   #4
clos561's Avatar
Posts: 1,172   (View Stats)
clos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the world
change your valve
7-Inch Jensen Flip Out Touch Screen, HKS SSQ, MS CAI, Prosport Premium Amber/White Boost Gauge,2nd Cat Gutted, Delrin TRZ MM,16 inch FD rims,TWM shifter Bushings,COBB Turbo Inlet, 28psi, rebuilt stock block, custom rods and piston heads/gaskets, underdrive pulleys, big cams, big oil filter, stage4 clutch, stage4 DISI injectors, Fuel Pump, 4inch Catless TBE with screamer pipe, external wastegate spring modification,Methanol direct twin port duty cycle injection. Tuned by Nator Performance
clos561 is offline   Reply With Quote
 Old 06-23-2009, 06:59 AM   #5
I will spike for a split second and immediately drop to 13ish psi, no tapering whatsoever, can't even hold stock boost levels. Infact I wont even spike that high unless I suddenly floor it, if I ease into it I'll only get 13
datarog prease
I think i've smoken to many pots and cant friggin figuire out how to view the datalogs, i fail with computers.. Little help?
Originally Posted by clos561 View Post
change your valve
That's what my brother told me also, but I wanted to see if anyone else had a similar problem and remedied it by switching to a better valve. I figuired it would at least hold stock boost levels, but I guess not
 Old 06-23-2009, 08:36 AM   #6
slyter485's Avatar
Posts: 42   (View Stats)
slyter485 has a spectacular aura aboutslyter485 has a spectacular aura about
I haven't loaded a log on this site yet, but this is how I've done it on other sites..
If you have your logs open up in Microsoft Excel, take a screenshot of what you have open (hit the print screen button on keyboard). Save picture, and host picture on a site (or just upload it). Walla, datarog, bery nice!
slyter485 is offline   Reply With Quote
The Following User Says Thank You to slyter485 For This Useful Post:
TenaciousBoost (06-24-2009)
 Old 06-23-2009, 11:25 AM   #7
SuperVillain's Avatar
Posts: 898   (View Stats)
SuperVillain is the leader of the worldSuperVillain is the leader of the worldSuperVillain is the leader of the worldSuperVillain is the leader of the worldSuperVillain is the leader of the worldSuperVillain is the leader of the worldSuperVillain is the leader of the worldSuperVillain is the leader of the worldSuperVillain is the leader of the worldSuperVillain is the leader of the worldSuperVillain is the leader of the world
Sounds like a boost leak since you cant even hold 17psi, I spike to 18 or 19 and taper the closer I get to readline. Maybe its time for HKS?
2009 Crystal White Pearl MazdaSpeed 3:
Cobb SF intake, HKS ver 2 BOV (Recirc), Cpe 70 Duro RMM (Removed), Hid Kit, 18 Inch Flat Blk, Tenzo Cuzco's... ver 2, Cobb Springs and the Cobb AP Stage 2... Coming Soon... Koni Yellows, 60 Duro, ?mm wheel spacers, FMIC, and im currently waiting for my FP to go out
BEAST MODE
2007 Alabastar Silver Honda Civic SI:
Injen SRI, Greddy Evo 2 CB, P2R Throttle Body Spacer, Buddy Club Race header.
KIA
I
SuperVillain is offline   Reply With Quote
 Old 06-23-2009, 11:29 AM   #8
clos561's Avatar
got anyone local that would let you put on their valve to see if you get diff boost levels?
 Old 06-24-2009, 07:28 AM   #9
But is my bpv the origin of the boost leak?
That would definitely answer my question above.. I've heard good stuff about the hks, I think I'm just gonna bite the bullet and get one. Also thinking about replacing the turbo inlet with the one from pg, since I heard that can be another source of boost leak, even though pre-turbo, just from loose clamps. And if I got to get in there anyway I might as well upgrade...
So I view datalogs through MS Excel? I thought I was supposed to view them through the accessport manager or ATR.. Probably why I couldn't figuire out how to view them
 Old 06-24-2009, 11:37 AM   #10
ToledoSpeed3's Avatar
Posts: 244   (View Stats)
ToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the worldToledoSpeed3 is the leader of the world
Yeah, Excel is a good viewer to use. Go into the AP Manager while your AP is connected and choose the View|Advanced menu (or something like this). It will then pop a dialog where you can download the logs from the AP to your hard disk. Then, navigate to that folder and open the CSV files with Excel. For ATR it will log to a folder on your laptop.
Mike
ToledoSpeed3
09 MazdaSpeed3 GT, True Red
ToledoSpeed3 is offline   Reply With Quote
The Following User Says Thank You to ToledoSpeed3 For This Useful Post:
TenaciousBoost (06-25-2009)
 Old 06-24-2009, 06:09 PM   #11
Docnox's Avatar
Posts: 1,435   (View Stats)
Docnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the worldDocnox is the leader of the world
Groans: 35
Mine used to do the same and it was from a boost leak on the intercooler hoses.
'06 Speed 6
Black Mica
Mazdaspeed SRI, Medieval inlet, Eibach Springs, Magnaflow cbe,
3 ebay catless dp, SU rmm, HKS ssqv, JBR stage 2 ssp
Altered Customs fmic, Autotech fp internals
Cobb AP, Stage 2+ 93 tweaked
Centric blanks, EBC red pads
Lotek center gauge pod: AEM wideband, Autometer boost and volts
Tints, blacked emblems, spec-v front lip, Shark fin
Redline MT-90, ITV-22s, Matt Damond OCC
13.66@102 Lebanon Valley 4/10/11 (sri, tp, rmm, ap)
DO Meth kit waiting on install
Docnox is offline   Reply With Quote
The Following User Says Thank You to Docnox For This Useful Post:
 Old 06-25-2009, 07:14 AM   #12
Dang, I'll go check those asap, that would be a super easy fix. There are a total of four clamps to check between the hot and cold pipe right? Was it obvious they were loose, I took a glance at them this weekend but nothing looked unsecured, maybe I should go tighten them all down anyway
 Old 06-25-2009, 05:08 PM   #13
Docnox's Avatar
Groans: 35
Not obvious by looking at them. My loose ones were on the hot pipe. I was installing my turbo inlet and figured why not tighten the clamps on my intercooler. Went to tighten them and they were pretty loose. You might as well double check anyway, only takes a few minutes.
'06 Speed 6
Black Mica
 Old 06-27-2009, 06:07 AM   #14
Well, I tightened down all of the clamps on intake, inlet and intercooler hoses and still no luck with my boost problem.. Maybe its the bpv afterall. Would watching wg duty cycle help to clue me in if I actually have a leak or if its possibly tune related? Would my wastegate be maxed trying to make up for the leak? I also remember hearing something about a loose connection on throttle body being a problem, wasn't sure what to look for when tightening the other clamps. How do I find the throttle body, is it near the intake manifold?
 Old 06-27-2009, 08:03 AM   #15
clos561's Avatar
watchign wg duty cycle would probably not do anything. since the boost is leaking the wg would not have to work to keep the pressure below "safe" (im just guessing but it seems right) remove your valve, take the seal off and then put it back together and install your valve again. its gona come down to you buying a new valve i think.
The Following User Says Thank You to clos561 For This Useful Post:
TenaciousBoost (06-27-2009)
 Old 06-28-2009, 07:03 PM   #16
gsrtype1's Avatar
Posts: 7,514   (View Stats)
Groans: 102
TenaciousBoost hey bro im haven the same issue maybe we can figure this out. I did a boost leak test with an air compressor and I do not have a leak.
 Old 06-29-2009, 07:29 AM   #17
Weird, I really don't know what the problem is. I'm hesitant to drop cash on more parts hoping to fix this supposed boost leak. Do you have your standback hooked up or are you just using the stock ecu?
I might try switching back to the stock map on my accessport to see if the boost levels change at all.. Not really sure what else to try
 Old 06-29-2009, 08:38 AM   #18
gsrtype1's Avatar
Groans: 102
I had to send in the Standback for a minor usb issue so im stock boost. Witht he SB on boost is normal what ever I set it too. Yours may be a Cobb issue try going back to stock and see what you get.
 Old 06-29-2009, 10:02 PM   #19
ms3077's Avatar
Posts: 4,024   (View Stats)
ms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the worldms3077 is the leader of the world
Groans: 974
Groaned at 738 Times in 373 Posts
Shit I'm stock and my 2nd gear holds 12-12.5 PSI from 3000-5800.
ms3077 is offline   Reply With Quote
 Old 06-29-2009, 10:20 PM   #20
gsrtype1's Avatar
Groans: 102
where u at? whats the temp?
 Old 06-29-2009, 10:23 PM   #21
ms3077's Avatar
Groans: 974
Central Florida - 80F / Just did a 2 gear datalog about 1hr ago.
 Old 06-29-2009, 10:24 PM   #22
gsrtype1's Avatar
Groans: 102
yeah see 80 is diff then 105 here. your prob still high boost just sayen,
 Old 06-29-2009, 10:28 PM   #23
ms3077's Avatar
Groans: 974
Yes I've noticed ambient temps/ humidity can make a big difference +/-
Radio Reception sucks acehigh MazdaSpeed 3/6 - Car Audio & Electronics 1 02-26-2009 09:49 AM
Boom this shit sucks speed_3 MazdaSpeed 3 - Engine, Transmission & Driveline 124 02-04-2009 12:54 PM
OMG, this sucks for all of us. ptperformance MazdaSpeed 3 - Engine, Transmission & Driveline 59 06-13-2008 01:14 AM
Page generated in 0.41337 seconds with 29 queries
