![]() Join Date: Sep 2008 Location: Alaska
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score The discharge side and angle is perfect for the dump tube back into the intake. You would have to just get a new factory gasket from mitsu and install it after removing the oring on the stock setup. I had used a 1g dsm bov well into the 400whp area on my 1g when I had with no issues.
__________________ 08 Speed 3 GT -- Silver Cobb short ram, Cobb AP w/ stage2+sf 91 v102e map,CPE 3" turbo back w/ cat, 1g dsm BOV. Street Unit lower mount 268whp/300tq SAE Dynojet 03 Cobra -- Sonic Blue 10.45@134 Stock Motor + KB 2.4 @ 23psi - Slicks 644whp 625tq SAE Dyno whore mode 21psi + 75 dry shot 741whp/808tq SAE |
![]() Join Date: Mar 2008 Location: Pittsburgh, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,174
Groans: 45
| Not Ranked : 0 score works on my ms6 so i dont know why it wouldn't work on an ms3 |
![]() Join Date: Jun 2008 Location: lancaster, ca
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,297
Groans: 91
| Not Ranked : 0 score 08msbm3 or something uses one. he says its good.
__________________ "Go find your own enterprise, and get the fuck off my bridge!" 2008 Speed 3 GT- Cobb SRI, Cobb TIP, AQ Motorsports DP (Turboxs Adapter Plate), TurboXS FMIC, GReddy CBE, GReddy BPV, 3P Flange, GReddy TT, GReddy Boost Gauge, Vent Pod, GReddy Shift Knob, SU Shifter Bushings, AWR RMM, Cobb RSB, Cobb AP, Cobb Shifter Weight, Autotech FP Internals, Corksport Exhaust Hangers. "parked hard" 1996 200sx SE-R- Injen CAI, GReddy SP CBE, Tein Basic Coilovers, Progress FSB, Clutch Masters Flywheel, Progress RSB, Cusco FSTB, Progress LCAB, Prothane MM, JWT POP Program, JWT S4 Cams, Mishimoto Radiator, GoodRidge SS Brake Lines, Powerslot Rotors, Nismo CF Shift Knob. "back in action" |
| Not Ranked : 0 score i use one. its fine.
![]() Join Date: Mar 2008 Location: abc
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,081
Groans: 147
Groaned at 34 Times in 29 Posts
| Not Ranked : 0 score WOOOOOOOOOOOOOOT. i got one if anybody needs one
__________________ "08, I hate to break it to you, but if it gives kevin a boner, its porn" ![]() NATOR PERFORMANCE Nylon washer sponsered |
![]() Join Date: Mar 2008 Location: Baltimore Md.
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 59
| Not Ranked : 0 score Why does one use this?
__________________ [SIGPIC][/SIGPIC] Gotta Love The Turbocharged Wagon |
(Thread Starter) | Not Ranked : 0 score what type of gasket are you all using?
Groans: 147
| Not Ranked : 0 score This bov will hold more boost than stock. You use the mitsu gasket for the bov. They are really cheap and you can find them anywhere
![]() Join Date: May 2008 Location: Sayreville, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 168
| Not Ranked : 0 score I have confirmed that it can be used on speed3/6 from tests i did on couple test cars. The holes to mount it to the pipe will need to be enlarged. I cut some gasket material to make the gasket. -C
__________________ All content created by this user is for entertainment purposes only. Mods: Wouldn't you like to know |
Groans: 147
| Not Ranked : 0 score I have one for $30 plus shipping in very good condition. Anybody who needs it just let me know
| Not Ranked : 0 score How does it sound? I have the forge and its getting old to me
Groans: 147
| Not Ranked : 0 score There is some youtube vids of it. definately much better than the mario coin bullshit
| Not Ranked : 0 score So whats the deal with a crushed one it sounds good? very good All i would have to do is reem the holes?
I had leak tested mine to 45psi when I had a crushed one on my Talon with my boost leak tester. I'll try and get some vids of mine tonight when I get it installed if it doesnt snow again.
__________________ 08 Speed 3 GT -- Silver Cobb short ram, Cobb AP w/ stage2+sf 91 v102e map,CPE 3" turbo back w/ cat, 1g dsm BOV. Street Unit lower mount 268whp/300tq SAE Dynojet 03 Cobra -- Sonic Blue 10.45@134 Stock Motor + KB 2.4 @ 23psi - Slicks 644whp 625tq SAE Dyno whore mode 21psi + 75 dry shot 741whp/808tq SAE | |
| Not Ranked : 0 score How do u "Crush" it?
Groans: 147
| Not Ranked : 0 score [/HTML]I have seen some people put it in a vice. Mine is uncrushed, and in really good shape. If anybody wants it, PM me, as i have 1 left
(Thread Starter) | Not Ranked : 0 score Mine is on, sounds alot like the stock setup, lil louder, probably a tad stiffer, doesnt blow off as easy. Good cheap mod, I can try and get some vid if the snow melts anytime soon and the roads dry up.
| Not Ranked : 0 score So its quiet unlike the forge? like stock? Do you get alot of surge with it?
![]() Join Date: Jul 2008 Location: PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 30
Groaned at 16 Times in 8 Posts
than i noticed the location | |
(Thread Starter) | Not Ranked : 0 score btw...the stock tires suck in the snow and ice. I would suggest if your in a snow prone area to get some different tires. It is outright dangerous. I am gonna be running Hankook Ipikes over the winter.....
| Not Ranked : 0 score Vids?
| is cp-e working on a sri? | skeeter149 | Custom Performance Engineering (cp-e.com) | 38 | 10-11-2008 04:35 AM |
| 9ff already working on Porsche Panamera? | Haltech | Automotive News | 0 | 09-24-2008 11:50 AM |
| Map Clamp not working | oskinosmee | MazdaSpeed 3/6 - ECU Computer Tuning | 10 | 08-17-2008 11:37 AM |
| BMW working on M3 CSL with 470 hp | Haltech | Automotive News | 0 | 07-16-2008 11:00 AM |
