 Old 05-09-2009, 05:04 PM   #1
18psiWhiteMS3
Lurkers
18psiWhiteMS3's Avatar
Posts: n/a
Default 28mm samco hose review
So i wanted to change my stock bpv hose with something more flexable for a better fit with my cobb fmic with hks bov along with cobb inlet and sri. anyway i ordered the samco 28 mm silicone hose witch looks like this as it comes in 39 inch lenght.
It is very solid and doesnt want to be bent the slightest without kinking.
trying to make a lot of bends and you have one kinky ass tube.
so my conclusion is that it makes a great blue rake handle witch is soft and confertable
The Following 5 Users Say Thank You to For This Useful Post:
aaronc7 (05-11-2009), bioevolve (05-11-2009), Doc (05-17-2009), phillyb (05-10-2009), Zeya (06-05-2009)
 Old 05-09-2009, 05:29 PM   #2
Scatt Nasty's Avatar
Posts: 1,204   (View Stats)
Scatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the worldScatt Nasty is the leader of the world
Groans: 94
Groaned at 43 Times in 33 Posts
fmic fail.
321 HP/348TQ-- 13.940 @ 106 /3kft ASL
Scatt Nasty is offline   Reply With Quote
 Old 05-09-2009, 05:40 PM   #3
ms3boost's Avatar
Posts: 400   (View Stats)
ms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to beholdms3boost is a splendid one to behold
i bought a recirc tube from su and cut it to length and it works great
2008 TR MS3 Sport[/B]:Cobb Sri,AP/Corksport Dp/Vibrant Dp Back/Pg HF CDFP/SU Boost Tubes/TRZ Poly MM/TWM STS, Shifter bushings/DashHawk/Turbosmart DualPort BOV/15,35% Tints/AutoExe Shift Knob/ Redline Shifter,E-brake Boot
Future Mods[/B]auter Rods/CP pistons/PTP SST K04/PG Tubular Manifold EWG/Turbo XS Dp/Cobb TIP/HKS Plugs/Perrin OCC/Devils Own WM Injection/BC Racing Coilovers/Hotchkis H&R Sway Bars/Rotora F&R slotted Rotors/EBC Red stuff Pads/Goodridge Stainless Brake Lines/ACT Street clutch and flywheel/Cobb FMIC/Tial 38mm v-band and screamer pipe/SU Side Mounts/8000k HIDs/PTP BS delete,WT/rx8 wheels/samco silicone hoses/235-40-18 Falken Azenis RT-615/P&L Motorsports ATP or ATR tune we will see though although 350whp is the goal!
ms3boost is offline   Reply With Quote
 Old 05-09-2009, 05:42 PM   #4
18psiWhiteMS3
Lurkers
Posts: n/a
my stock hose workes way better then this cause the stocker has a factory bend to it
 Old 05-09-2009, 11:17 PM   #5
aaronc7's Avatar
Posts: 8,057   (View Stats)
Groans: 370
what you need is the samsco sport superflex hose.
 Old 05-10-2009, 12:26 AM   #6
18psiWhiteMS3
Lurkers
Posts: n/a
superflex hose was 60 bucks vs this at 14 bucks.
 Old 05-10-2009, 09:44 AM   #7
ElBartoRex's Avatar
Posts: 1,186   (View Stats)
ElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the worldElBartoRex is the leader of the world
I used a 2 inch section of home depot copper piping, a razor and 2 home depot hose clamps to fix mine. Works perfect.
2007 Mazdaspeed3 Sport, True Red
ElBartoRex is offline   Reply With Quote
The Following User Says Thank You to ElBartoRex For This Useful Post:
 Old 05-10-2009, 11:02 PM   #8
phillyb's Avatar
Posts: 14,702   (View Stats)
Groans: 1,940
fucking fail 18. fail fail fail.
i'm with elbarto over here (WHO IS STILL NOT A VENDOR ON THIS SITE), mine's not copper, but i have a fitting between two pieces of tube
 Old 05-11-2009, 01:09 AM   #9
babcockxmx's Avatar
Posts: 539   (View Stats)
babcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the worldbabcockxmx is the leader of the world
u failed to mention how much hp this will add.
gb?
2007 BM MS3
babcockxmx is offline   Reply With Quote
The Following User Says Thank You to babcockxmx For This Useful Post:
phillyb (05-11-2009)
 Old 05-11-2009, 08:07 AM   #10
aaronc7's Avatar
Groans: 370
18psi:
the superflex hose is 30 some dollar on summitracing.com.
They tend to be out of the stock, so keep checking. thats where i got mine.
size is 1 1/8"
 Old 05-11-2009, 04:36 PM   #11
ElBartoRex's Avatar
What can I say..I love msf but unfortunately I am not the one who gets to make those decisions
phillyb (05-12-2009)
 Old 05-12-2009, 02:23 AM   #12
TRU-BOOST's Avatar
Posts: 801   (View Stats)
TRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the world
I cant find the product on their site at the moment but i got exactly what you need from FORGE. I have a 1 of a kind TRZ intercooler with an all new cold pipe that relocates the BPV. Forge is partners with siliconehoses.com. Visit either website and look around or give them a call if you dont see it. Mine came in a 3 meter length and has the 1.25" ID to fit the BPV outlet. It is thick silicone that has a spring core to prevent it from getting kinked. It also has grooves cut around the outer layer to help it bend with ease. Check it out man... It will do what you need.
Turbo boost + Nitrous boost = TRU-BOOST
TRU-BOOST is offline   Reply With Quote
impressions on samco 28mm hose 18psiWhiteMS3 Mazdaspeed Forums User Reviews 19 06-14-2009 11:04 PM
HI! MS3 recirc. hose Jasnall Mazdaspeed3/6 General Discussion 9 06-09-2008 09:46 PM
Page generated in 0.31731 seconds with 26 queries
