7Likes ![]() |
(Thread Starter) | Not Ranked : 0 score I was getting ready to have my cold pipe cut and welded out to open that neck up like this guy in the pic I posted below. Then my buddy brought me an 07+ cold pipe and the thing was WAY more opened up in the neck area. You can see that here. ![]() I found some measurements online of the 06 pipe vs. the 07 pipe. The 06 pipe is 5.28 sq inch at the intercooler gasket area and drops to 2.51 sq inch at the pinch area and 4.91 sq inch at the throttle body end of the pipe. The 07 pipe is 5.28 sq inch at the intercooler gasket area and drops to 3.11 sq inch at the pinch area and 4.91 sq inch at the throttle body end of the pipe. The 07 pipe has 20% larger area in that pinch area and the pipe is generally opened up quite a bit more throughout. I am guessing that Mazda knew the 06 cold pipe flowed like crap but didn't have time to revise it before early shipments and revised it as soon as possible. It's one thing to have the aftermarket fix a problem, but you know its a big deal when the OEM revised a part bigger. This tells me I'm onto something. I don't know how this extra flow will impact performance on a k04, but I am willing to bet it's going to make a good difference on my bnr, especially considering how opened up everything else is on my intake/exhaust. Wouldn't it be crazy if this stupid cold pipe has been holding my car back all along? I am using my buddies 07 cold pipe, I ordered some JBR cold tubes and a Snow meth tap for the silicone tube so I can swap the setup in place of my 06 cold pipe. I will definitely post up before/afters, but my gut says there will be gains above the noise floor. I don't know how many others with older 6 speed 6's knew this. I sure as shit didn't.
__________________ 2006 MS6 WWP Sport - 340whp/350wtq JBR 3"- BNRS3V2 - GS EBCS - CUSTOM FMIC - CS IM - LTR7IX - CMGS WMI & D07 GA - TURBOXS HEADER - FIDANZA FW - CP-E CATTED DP - 3" CATBACK BILSTEIN - H&R SPRINGS - 18x8.5 +48 ROTA SVN - 265/35R18 HTR ZIII MINI H1 6.0 - CAR LED TAILS SEE MORE USING !SHOUTTAG.COM - ENTER: !6SPEED6 Last edited by dale_gribble; 07-02-2014 at 10:37 PM. |
| The Following 10 Users Say Thank You to dale_gribble For This Useful Post: | blackmicamps6 (06-11-2014), Cheapspeed (10-03-2015), Chicagospeed6 (06-11-2014), Code Monkey (06-11-2014), Easter Bunny (06-16-2014), ItsNox (06-15-2014), speed23 (06-16-2014), Vader (06-11-2014), Vansquish (06-11-2014), WetzMS3 (06-11-2014) |
![]() Join Date: Sep 2013 Location: Valrico FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 475
Groans: 51
| Not Ranked : 0 score That's a good find. I wonder how hard it would be to get rid on the stock cast outlet and for someone to make an aluminum mandrel bent peice instead. I think that would help improve the flow coming out of the intercooler and would also eliminate that bottle neck.
__________________ 2006 TITANIUM GREY METALLIC MS6 SPORT Cobb AP v3 \\ Turbosmart Dual Port \\ Mazda Spin-On Conversion \\ Autotech HPFP \\ CP-E RDM \\ Turbine Tech FDM \\ CX Racing IC Piping \\ Treadstone TR8 Core \\ M2 Downpipe \\ JBR Power Path stage 2 \\ Denso ITV22 \\ JBR 80a Trilogy \\ JBR OCC \\ JBR TIGs \\ JBR EGR Delete \\ Corksport Springs |
(Thread Starter) | Not Ranked : 0 score Its not that easy with the stock intercooler flange, I.e. welding flange to mandrel pipe. The pipe hugs right up against the intake runners on the back side. There is room towards the front of the engine though to expand out. Corksport did experiment with a big cold pipe years ago but insisted their tmic was the bottleneck and that the pipe didn't matter; they didn't build it. I didn't think that spoke much for their tmic. There is room for something creative, I'm just not sure you can do tubing right off the flange without clearance issues. .
__________________ 2006 MS6 WWP Sport - 340whp/350wtq JBR 3"- BNRS3V2 - GS EBCS - CUSTOM FMIC - CS IM - LTR7IX - CMGS WMI & D07 GA - TURBOXS HEADER - FIDANZA FW - CP-E CATTED DP - 3" CATBACK BILSTEIN - H&R SPRINGS - 18x8.5 +48 ROTA SVN - 265/35R18 HTR ZIII MINI H1 6.0 - CAR LED TAILS SEE MORE USING !SHOUTTAG.COM - ENTER: !6SPEED6 |
Groans: 51
| Not Ranked : 0 score I did some searching and found out trz made a tmic, looks like they had the right idea for the cold side
| The Following 3 Users Say Thank You to Hargarbl For This Useful Post: |
![]() Join Date: Mar 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score Never knew that Mazda themselves revised the part, but think autoexe had an aftermarket version? Called it an air charger or similar. Keen to see what changes the switch will make, have a 2005 mps here in Aus so assume have the same bottleneck. |
Groans: 51
![]() Edit: found it http://www.nengun.com/autoexe/turbo-suction-kit
__________________ 2006 TITANIUM GREY METALLIC MS6 SPORT Cobb AP v3 \\ Turbosmart Dual Port \\ Mazda Spin-On Conversion \\ Autotech HPFP \\ CP-E RDM \\ Turbine Tech FDM \\ CX Racing IC Piping \\ Treadstone TR8 Core \\ M2 Downpipe \\ JBR Power Path stage 2 \\ Denso ITV22 \\ JBR 80a Trilogy \\ JBR OCC \\ JBR TIGs \\ JBR EGR Delete \\ Corksport Springs | |
![]() Join Date: Mar 2011 Location: Bethlehem, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,167
Groans: 70
| Not Ranked : 0 score Will be interested to see what kind of difference it makes! I remember working on one of the NATOR guys cars here in CT and at the time didn't realize there was a difference there!
__________________ 07' Speed6 Velocity Red Mica Go Faster: CorkSport SRI/TIP, SU Test Pipe, SU TMIC, Autotech Internals, ITV22's, Cobb AP Anti break stuff: Upper Rear Diff Brace, RMM Appearence: STRI DSD Boost Guage/Blockhead 60mm Guage Pod |
| Feline Führer ![]() Join Date: Feb 2013 Location: Jacksonville, FL
Rep Power: 2280 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,422
| Not Ranked : 0 score meth nozzle hole pre-drilled is a nice touch too. |
![]() Join Date: Aug 2012 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,823
__________________ |
![]() Join Date: Jun 2012 Location: Houston, Texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,245
| Not Ranked : 0 score I was actually working on opening up a 06 MS6 coldpipe that came with the TMIC I just picked up and noticed it was slightly smaller as I was having a hard time getting it all smoothed out. I also noticed that the opening in the flange both on the TMIC and the coldpipe are smaller then the gasket's opening so I ported the openings to match the gasket and smoothed out as much as I could. Not sure if this is going to help much if any but figured it shouldn't hurt either and it is a free mod. Guess I will be selling the MS6 cold pipe and using my Gen2 pipe.
__________________ 2012 Liquid Silver Metallic MazdaSpeed3 with Tech Package. South Bend Clutch Stage 3 Endurance | TWM Full Replacement Shifter | Synapse Engineering BPV | Autotech Internals | Grimmspeed EBCS - 3port | NGK 1 Step Colder Plugs | CNT Catless DP and CBE w/resonator deleted | COBB AP - E35 Tune | HTP 3.5" Intake w/ AMSOIL Dry Filter and Pre-Filter | HTP Battery Tray w/ Energizer 51R | CP-E TMIC | CorkSport DISI Silicone Boost Tubes | Damond Motorsports/Saikou Michi Co. Stage2 OCC | Damond Motorsports Short Shift Plate | Sure Countershift | BOSCH 3 Bar MAP w/MattJackson86 PnP Harness | JBR Rear Sway Bar | JBR EGR Block Off Kit | JBR Manifold - TIG | JBR Throttle Body TIG & Coolant Bypass | JBR 88a RMM | JBR 88a TMM | JBR 80a PMM |JBR DISI Bypass Valve Hose | Ported and Polished Intake Manifold DIY | RX8 Wheels w/ Nitto Motivo 235/40/18 Tires | CP-E Towplate | DIY Custom 600g Shift Knob | Redline Tuning Hood QuickLIFT | 30% / 15% Tint | Craven Speed Stubby Antenna | Broadway 400mm Rear View Mirror | Debadged Mazdaspeed 3 Waiting to be installed: Devil's Own Stage 2 DVC-30 Meth Injection | Damond Motorsports Meth Throttle Body Plate On Order: Coming Soon: DIY Projects: FYCN - TEAM LBN BEERS - FYCN-TEAM MUMFORD - FYCN |
| The Following User Says Thank You to SparkySparks For This Useful Post: | dale_gribble (06-13-2014) |
| Not Ranked : 0 score Oh and just encase anyone was wondering, the choke point on both versions is still smaller then 2.5"(4.9088"^2) piping used for most FMICs, even 2"(3.1416"^2) piping is slightly better then the revised cold pipe.
![]() Join Date: Sep 2011 Location: Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 213
__________________ - 2010 Mazdaspeed 3 Black Mica - - Cobb AP - Self Tuned - cpe HPFP - cpe DP - CS 3" SRI - cpe TMIC - Forge BPV v2 - Grimmspeed EBCS - Denso ITV22 - - SouthBend Stage 3 Daily Clutch - cpe RMM - CS TMM Insert - TWM SB - CS SSP & SW - CS RSB & Mid Chassis Brace - - CS Brake Pads - Michelin Pilot Super Sport - CS Boost Tubes - CS Fog, DRL and Interior LEDs - Horns - Grounds - 20% Tint - | |
![]() Join Date: May 2013 Location: Edmonton,AB
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 572
Groans: 46
Groaned at 37 Times in 19 Posts
fuck the 06 cold pipe. I knew it was a restriction just like that pos stock tip, but the cold end flange itself on all of the aftermarket tmic's would be the next issue as mentioned above if you only upgrade the cold pipe to ones like the autoexe. so what's the point? I don't think the cold pipe itself will make any difference unless on a BT, and the gains will still be negligible.
__________________ 06 Liquid Platinum GT COBB AP // 3" ID MAF // 3" HTP TIP // Ebay catless DP // Autotech FPI // DO DVC-30 w/D07 // Grimmspeed EBCS // FORGE V1 BPV // DM OCC // JBR SSP|TIGs|EGR- // SURE RMM|Juggernaught // CP-E TMIC|Rear Diff Mount // Whiteline RSB // ISC N1 Coilovers // 18x8 +45 TSW Nurburgring MisterSix Tuned.. vdyno: 287hp/335tq Uncorrected (2400ft ASL) 303hp/355tq Corrected | |
| Not Ranked : 0 score Yes, the cold pipe was only off by about a sharpie width while the CP-E TMIC was off by a bit more. The casting was also not all that great (smooth) on the inside of either end tank.
| Not Ranked : 0 score @kashbringer; I wonder if this was a possible limitation with how much you were pushing the K04.
(Thread Starter) | Not Ranked : 0 score Guys, just an update, this went nowhere after comparing before/after tests of 06 cold pipe vs. 07 cold pipe. No gains were had with the 07 cold tube FML. Kind of shocked, but it is what it is. It is a choke point, but as @CorkSport; previously reported on their cold tube research, the intercooler is a greater choke point so the cold tube isn't an issue. Definitely a case of mind/physics playing tricks on me.
Groans: 46
| Not Ranked : 0 score I wonder if the width of a tmic will make a difference in the case of it being less of a choke point since the air will go through less space. The problem is there isn't a way to test that.
| Not Ranked : 0 score is the 07 MS6 the same as the cold pipe used on all the MS3's could the later PU's also have a revision?
| Not Ranked : 0 score When you are pressurizing air choke points such as these have less of an effect. If you go too big on the piping you actually lose response. Good find and testing. On that TRZ TMIC, I would not get something that doesn't seal to the OEM shroud. The MS6 already has the hardest time (compared to an MS3) channelling air to the TMIC and cooling it.
![]() Join Date: Aug 2015 Location: Virginia Beach, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 138
Was thinking about this today since it seems to be a major restrictive point. Has any tried this aftermarket elbow? I know that you @dale_gribble; have done the 06 vs 07 comparison but they seem too similar to possibly have any significant differences. It seems like the autoexe would be much smoother, and have a noticeable difference. Anyone have any data on this? Sent from my SCH-I545 using Tapatalk
__________________ 06 MS6: Stocked out and trying to find her a new family. | |
![]() Join Date: Mar 2014 Location: Durham, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
| Not Ranked : 0 score Subbed for interest, I really doubt there will be any gains, if the 06 cold pipe with the smallest surface area wasn't choking going to an even bigger flange still wouldn't make an impact (there's no choke to "fix"). Maybe if you're on a turbo that's quite a bit bigger but unless it's a GTX30xx I don't think it would make any difference and the difference would probably be negligible.
__________________ 2006 Super Clean BCM MS6 Corksport Intake/TIP - Test Pipe - CS FMIC - Freektune - Autotech HPFP - 18x8 Wheels with Nitto NT05's 235/40/18 - H&R Coilovers - SPC Balljoints - CS RMM - Magnaflow CBE - DM Power Steering Cooler - CAR LED Tails - EBC Yellowstuff w/ Centric Blanks - Xcarlink w/ Bluetooth Module Waiting to be installed: Diff Braces - TMM Insert |
| Not Ranked : 0 score I agree that a larger turbo would magnify any flow enhancement from the autoexe unit, but it seems like it should do something even on a smaller turbo setup. The design is much different than the difference between an oem elbow. Sent from my SCH-I545 using Tapatalk
| Not Ranked : 0 score @Dat8687; do you still have this piece?
![]() | | #24 | ![]() |
![]() Join Date: Dec 2013 Location: Tampa, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 462
| Not Ranked : 0 score Corksport designed a bigger one that had no impact on flow. The intercooler was more of a restriction even upgraded
__________________ The line up: 2013 G37 loaded...not stock for long 2013 MS3...stock to midturbo back to stock (traded) 2009 Nissan Frontier LE loaded...big stereo system (traded) 2009 Cadillac CTS sport package...stock (blown and traded piece of shit) 1994 Integra RS built all motor (sold) 1990 Civic EF nitrous turbo motor swapped beast (sold) 1987 Dodge pick up...jacked up (sold) |
| The Following 2 Users Say Thank You to speedfreak44 For This Useful Post: | Easter Bunny (09-25-2015), SNOW_QN (09-25-2015) |
![]() | | #25 | ![]() |
| Not Ranked : 0 score You're crushing my dreams man. I'm hoping to find a way to avoid going fmic in the future, and was hoping this might help a little. Sent from my SCH-I545 using Tapatalk
![]() | | #26 | ![]() |
| Not Ranked : 0 score No dreams crushed. Let me break this down simple and sweet; Tr6 or 8: Rpm sale comes to about $210 Underoute piping (bnr does it) on sale $470 Tmic cpe $360 Boost tubes $60 Hood scoop for better cooling $250 They break down to being almost exactly the same cost and fmic is way more efficient
| The Following User Says Thank You to speedfreak44 For This Useful Post: | SNOW_QN (09-25-2015) |
![]() | | #27 | ![]() |
![]() Join Date: Jan 2015 Location: College Park, Maryland
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 202
| Not Ranked : 0 score The pressurized, "high" velocity air (as being pumped from the compressor) that is flowing at or below Mach 0.3-0.4 is not entirely sensitive to minor increases/decreases in flow area as opposed to air flowing with at 1 atmosphere (standard atmospheric pressure). Simply put, don't waste your money. Source: I am an Aerospace Engineer. |
| The Following 4 Users Say Thank You to RalliartRsX For This Useful Post: | Cheapspeed (10-03-2015), Easter Bunny (09-25-2015), redneck4Christ (10-02-2015), SNOW_QN (09-25-2015) |
![]() | | #28 | ![]() |
Lol thanks @RalliartRsX; I'm convinced now that beating the dead horse is going to continue resulting in the same thing. Sent from my SCH-I545 using Tapatalk
![]() | | #29 | ![]() |
| Not Ranked : 0 score Did not see the cpe in your sig. I would stay with it and get the Cs hood scoop.
![]() | | #30 | ![]() |
![]() | | #31 | ![]() |
| Not Ranked : 0 score Gah stop throwing me curve balls! Yea that's kinda hard to install on an ms6 lol. Fmic ftw
![]() | | #32 | ![]() |
| Unless you can make the Gen 2 hood fit on a MS6. It'll work awesome. Hood scoop is awesome for the TMIC. I also don't want to cut up my crash bar either. sent from my HTC One M9
![]() | | #33 | ![]() |
| Not Ranked : 0 score Tr6 flows 400whp. That's all our fueling does anyway and nobody really shoots past that anymore with supplemental fueling. I say go tr6 and call it a day. Treadstone shit is top notch
![]() | | #34 | ![]() |
| Not Ranked : 0 score Hood scoop would certainly help, but it would be out of place on the subtle sedan. I'll look more into the tr6. When the time comes to upgrade, maybe there will be another option or two out there. (Don't ruin my wishful thinking. I need something to hope for) Sent from my SCH-I545 using Tapatalk
| The Following User Says NO Thank You to SNOW_QN For This Un-useful Post: | mxlplx71 (09-25-2015) |
![]() | | #35 | ![]() |
![]() Join Date: Oct 2013
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 16
Groaned at 60 Times in 22 Posts
you can get it from around 375-450 from RHD japan What it all comes with This was it on my speed 6 several years ago | |
| The Following 3 Users Say Thank You to Dat8687 For This Useful Post: |
![]() | | #36 | ![]() |
![]() Join Date: Nov 2013 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 481
| Not Ranked : 0 score That's one stout cold pipe. Notice any gains?
__________________ 2010 speed w/tech//Freektune//Autotech hpfp//Cobb APv3-SRI-TIH--cold air box//Corksport--Axle back exhaust//adjustable shocks and springs//LED's//Damond RMM--PMM--TMM--OCC stage II--SSP with OEM weight//HKS SSQV recirc//Fomoco honey//JBR bsd and baffle--shift bushings--51R battery tray--STS--bypass hose--tig tb coolant bypass//M2 test pipe//NGK 6510 one step chilly//StopTech SS brake lines//ETS TMIC//Progress 32mm rear sway//UMBRA tint by Nino 35%//Hawk DTC-60 up front and HPplus pads in rear//Mazda5 oem+rear brake kit//TrackMasters hood struts// Coming up: Corksport injector seals |
![]() | | #37 | ![]() |
| Not Ranked : 0 score |
| The Following User Says Thank You to Dat8687 For This Useful Post: | macdiesel (10-05-2015) |
![]() | | #38 | ![]() |
![]() Join Date: Jun 2015 Location: SF, CA
Rep Power: 61 ![]() ![]() ![]() ![]() Thanks: 5
| Not Ranked : 0 score Anyone know where to find the Autoexe TMIC cold charge pipe kit? Specifically looking for the elbow. New or used, any info is greatly appreciated. Thanks! |
| The Following User Says NO Thank You to Federighi For This Un-useful Post: | Vansquish (03-09-2019) |
![]() | | #39 | ![]() |
Rep Power: 3746 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| Dude...5 years late to the party, and still can't use Google.
![]() | | #40 | ![]() |
| Not Ranked : 0 score Better late than never! ![]() If anyone has a used Autoexe turbo suction kit or knows where to find one, please let me know. Thanks in advance! |
| Cold pipe tube - does it need heat wrap? | mituc | MazdaSpeed 3/6 - Turbo Induction | 5 | 09-06-2011 07:15 AM |
