Like Tree7Likes
  • 1 Post By mituc
  • 2 Post By MazdaspeedKills
  • 1 Post By mituc
  • 1 Post By MSMS3
  • 1 Post By mituc
  • 1 Post By MSMS3
 Old 02-03-2018, 12:03 PM   #1
jaynick1's Avatar
Posts: 6   (View Stats)
jaynick1 is an unknown quantity at this point
Default Another blown turbo
Hey guys unfortunately my intro/first post is a negative one. Recently purchased an 08 speed 3 that needed a little TLC. 112k miles, a little beat up but I got it for a steal. Wanted a fun daily run about car so looking to stay at stock power levels.
Well only put 30 miles on it since purchase and after getting on it noticed a whine from the turbo and no power. I've had/built many turbo cars over the years and I though meh, boost/vacuum leak. The hose off the turbo inlet had broken so I ordered a corksport and mended the stocker for now (youll see in the video). Went around the block and the noise was still there. Took a video and once I heard it its definitely the turbo, you can hear the fan blades bouncing off the housing lol. Pulled the inlet and took a second video of the shaft play.
I am keeping the car at stock power levels so I was looking at having it re manufactured by the guys at BNR. Anyone have any other recommendations?
videos for your viewing pleasure.
https://youtu.be/lMnWFsgB-WI
Shaft play:
https://youtu.be/S3OYuaNlHNw
jaynick1 is offline   Reply With Quote
 Old 02-03-2018, 12:21 PM   #2
kTaLgsTo's Avatar
Posts: 566   (View Stats)
Just buy a bnr v1, reman of yours is a tall task
 Old 02-03-2018, 12:24 PM   #3
jaynick1's Avatar
You mean an s1? BNR will do a full remanufacture for 400 vs 900 for the s1.
 Old 02-03-2018, 12:27 PM   #4
kTaLgsTo's Avatar
Yes S1 sorry. It would just be worth it to me to have a brand new turbo instead of a reman... It may be in worse shape then you know by just seeing what you can in the video.
 Old 02-03-2018, 12:29 PM   #5
jaynick1's Avatar
Ah, so the 400 bucks is just a baseline rebuild and could end up costing more depending on the extent? I do like the idea of the "hybrid" s1.
 Old 02-03-2018, 01:46 PM   #6
dp3
dp3's Avatar
Posts: 82   (View Stats)
dp3 is a splendid one to beholddp3 is a splendid one to beholddp3 is a splendid one to beholddp3 is a splendid one to beholddp3 is a splendid one to beholddp3 is a splendid one to beholddp3 is a splendid one to beholddp3 is a splendid one to behold
Everyone I have read who has had this issue seems to run into similar advice regarding rebuilding the stock turbo. I would be reluctant to do so. OEM is not the most reliable design and the BNR OEM replacement is cheap in terms of peace of mind. That is the direction I would head in with that mileage. I suspect these engines can clock a lot of miles if the oil is changed out ahead of MFG specs.
13 MS3 Eibach Pro kit Springs, Koni Ylw. F and R, Tanabe strut tower brace, 25 MM rear bar,CPE R mount, ETS TMIC, Autotech HPFP, ITV-22, CS: CAI, Cold Air Box, Boost tubes, Race Pipe, front spoiler. Forge BPV, Hypertech tune, Amsoil fluids,Philips DV H-11's and 9505's, Traklite RPM 18x8 +45 offset rims, 15mm Ichiba spacers(F&R) Rolled fenders w 235-40 Y rubber, Tint, Remix Rear Lip, Radar detector.
dp3 is offline   Reply With Quote
 Old 02-03-2018, 06:28 PM   #7
jaynick1's Avatar
Ok I im going to go with the BNR OEM remanufacture. Is there anyone that has experience with them?
 Old 02-06-2018, 07:03 AM   #8
Posts: 2,826   (View Stats)
Yes. Did both. Got a BNR reman to address "smoking turbo". My OEM also had shaft wear and was getting vane strikes. The reman also started smoking after about 50,000 miles. Not BNR's fault. K04 seals just can't handle crankcase pressure.
So, I got BNR stage 1. It uses a Garrett G28 series CHRA in the K04 shell. This is a permanent solution to the seal failure smoking. It has the same flow (actually a little bit better) than the K04, so you can run it on stock tune or your present K04 tune with no change.
Just go BNR Stage 1. A reman, regardless of who does it, will just smoke eventually.
 Old 02-06-2018, 11:50 AM   #9
GroceryGtr's Avatar
Posts: 472   (View Stats)
I disagree. a good quality rebuild will be just fine. Turbos are wearable items, so when someone complains they only got 50K out of their rebuild I just shake my head. A decent quality rebuilt unit can be had for $200-350. I would go this route as they dont require a core in the event yours is truly trashed. I do agree a S1 is superior, but if you plan on staying stock a rebuilt K04 would meet your requirements and save you some coin.
I will warn you there are a ton of cheap ebay special rebuilds you want to stay away from. Look for one that comes from a reputable rebuilder and/or has a warranty.
 Old 02-07-2018, 02:34 AM   #10
It will just smoke again. Turbos on other platforms I've owned (Volvos and Saabs) have all lasted more than 100,000 miles. Those have been tuned engines, too. The K03 on Audi and VW 2.0T engines is holding up to the 100,000 mile mark or better. We have a crankcase ventillation problem that is killing the seals in our K04s. This is a design defect.
kTaLgsTo (02-07-2018)
 Old 02-07-2018, 06:50 AM   #11
Posts: 2,233   (View Stats)
rebuilt turbo is just as good as how it is done. It is like rebuilding an engine, if the cylinder wall is deeply grooved or worn out and you just put new rings it will blow-by again....
If your turbo fail and you just put another one in without looking at the reason why the first one fail, just expect to put a third one in too and so on...
If you look for a low price more than anything else, you can buy a brand new K04 CHRA for about 200$ and put it back into your hot and cold side yourself....I just don't know about the quality of these CHRA
 Old 02-07-2018, 09:36 AM   #12
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Instead of rebuilding it for $400 you can buy a Chinese replacement off of ebay which are pretty decent quality.
If it was my car and didn't want to go bigger I'd go with the BNR S1 or S2, but that's just me.
Personally I've been there and the teenager in me decided to go big turbo even the factory turbo was still good. The grown-up in me couldn't resist and gave up arguing the teenager decision.
Long story short it may be a good thing that your turbo shit the seals. So act accordingly. And a personal advice: act recklessly. Fuck grown-ups opinions!
Jeff23spl likes this.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
The Following 3 Users Say Thank You to mituc For This Useful Post:
aackthpt (02-07-2018), kTaLgsTo (02-07-2018), MSMS3 (02-07-2018)
 Old 02-07-2018, 12:26 PM   #13
MazdaspeedKills's Avatar
Posts: 443   (View Stats)
MazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the world
Groaned at 7 Times in 4 Posts
Definition of "a lot of miles" is subjective. Many are hitting the 120-130k mile mark and are requiring rebuilds due to low compression in cylinder 3. That's with routine oil changes every 3k miles. I'm seeing more and more posts from owners buying these cars with this mileage on the clock and just starting their performance builds (just bolt ons). IMO they're wasting their $$ if they're not financially planning for a engine rebuild/replacement in the near future.
dp3 and Jeff23spl like this.
'06 MS6: BNR S3//CP-E FMIC//Forge V3/CP-E Nano Intake//TIP//DNP Swain Tech Coated Exhaust Mani//CP-E Catted Swain Tech Coated DP//Magnaflow CBE//CP-E RMM & TT Rear Diff Mount//PnP & Coated Intake Mani// VCTS and EGR delete//GS EBCS//3 Bar MAP//RMM//SafeSeals//PT-P FP Internals//TWM Stage II STS//SSP//Saikou Michi OCC//Snow Stage 2 WMI w/ D07 nozzle//Cobb AP V3//RICH TUNE!//Stoptech Slotted Rotors and EBC RedStuff Pads//H&R springs w/spacers//Bilsteins//SPC Balljoints//AeroForce ScanGauge & WideBand//Snow Performance WMI Failsafe & Guardian Angel//Morimoto HID Projector Upgrade//Hella HID Fogs
MazdaspeedKills is offline   Reply With Quote
 Old 02-07-2018, 02:26 PM   #14
Fstrnyou's Avatar
Posts: 2,498   (View Stats)
My 149k mile original engine started seeing mods at 120k (sooner if the PO stocked it out). Compression is solid...but it smokes a tad when I give it some beans. I suspect rings. Currently equipped with intake, TBE, CS turbo, HPFP, 18psi in the summer heat.
To your point, I'll be picking up my block from the machine shop very soon. Once it's built, the original engine will go into storage as a working back-up if I manage to screw something up with the forged build.
JBR Tru-3.5/3-port EBCS/EGR-D
Damond RMM/PMM/OCC/PCV Plate
Other rides:
History:
2008 GSX-R 1000 - Stolen
 Old 02-07-2018, 09:07 PM   #15
Your observations are right, but for every one that drops compression on one or more cylinders, there are two or three, if well-maintained, that are fine. I guess, at 140,000 miles, at least 120,000 of which have been with the mods below (except for recently added BNR S1), I am one of the lucky ones. Static compression is 185-190 across the board. No leak down losses of any significance.
I hear what you are saying, though. Ring land issues can emerge at any time. Buyers of our cars with higher mileage need to confirm static compression and do a leak down test before closing the deal, and if a K04 is still in place, expect it to smoke.
 Old 02-07-2018, 10:22 PM   #16
mituc's Avatar
Groans: 111
If the compression is solid at that mileage I'd rather expect the exhaust valve seals to be a bit cooked than the rings to be gone. If rings are gone it always reflects into compression, and sometimes low compression engines do not even smoke yet until they get below 100PSI on at least two cylinders.
Thor Hammer (02-21-2018)
 Old 02-08-2018, 08:23 AM   #17
KiwiFlavor's Avatar
Posts: 2,447   (View Stats)
PTE 6466 or bust!
2012 NASA Spaceship Gray MS3
 Old 02-08-2018, 09:07 AM   #18
Exactly, my blown broken ringland engine ran 1 year with something like 110-120psi on #3 . it wasn't smoking but smelling oil a little bit under wot when someone get close behind...
I wasn't seeing it between oil change. The oil ring was still intact....In fact, my rebuild use more oil than my original low compression engine! (I went a bit far with ring gap )
My valves were a lot dirty and the injector seal was gone too....
I don't really think it is a matter of mileage because i know exactly when and why mine broke. IMO there is more risks for rods bearing or VVT/timing on an stock or slightly modded engine with high mileage....
mituc (02-08-2018), MSMS3 (02-12-2018)
 Old 02-15-2018, 02:53 PM   #19
dp3
dp3's Avatar
I totally agree. One thing I had wondered about with regard to the cylinder3 compression drop was whether that was due to carbonning up the valve train and carbon being hammered down the cylinder walls.
I have never kept a Speed past 70 k miles (have had 3 of them) and compression was always even with no apparent wear that I could discern, However I do de-carbon every 30K miles and run Gas which has a decarbon-fuel system lubricant in it.
 Old 02-16-2018, 02:49 AM   #20
mituc's Avatar
Groans: 111
It's a combination of several things. the carbon build-up on the oil rings affects all cylinders. Then it's the 2nd and 3rd cylinders which take in more air (intake manifold flow imbalance) and dissipate heat less, especially #3 which is in the middle of the block with more reinforcements around, so the piston rings come in contact sooner than for the other cylinders which eventually lead to both ring and cylinder wear, and in worse cases to piston damage (ringlands).
So if you do WMI prior to getting significant wear and decreased compression you may save the engine and run it for quite long.
dp3 likes this.
dp3 (02-16-2018), MSMS3 (02-20-2018)
 Old 02-20-2018, 04:31 PM   #21
I'm wondering if the OEM tuning strategy of using pig rich AFR under high rpm, high load conditions to promote cylinder cooling and help prevent detonation at higher timing may have also been protective of cylinder 3? Just speculating. My "can-o-tune" Hypertech tune carries forward that same super rich AFR philosophy, making it even richer above 5,500 rpm under load, but with more timing, as much as 18-19 degrees at redline. At a bit over 140,000 miles of pretty aggressive, "spirited" driving I still have 185-190 compression across the board.
I may be leaving 10 whp on the table with the HT tune on stock turbo and pump gas compared to a custom tune with Versatune or AP, but maybe the super rich philosophy of Mazda and Hypertech, is helping save my pistons. Just don't know.
On the other hand if that unburned fuel gets past the rings it contaminates the oil. Gasoline is a poor lubricant. Oil analysis does indicate some fuel contamination, which all of us experience to greater or lesser degrees, but it is actually quite low for me, especially at this mileage.
dp3 likes this.
dp3 (02-20-2018)
 Old 02-20-2018, 04:47 PM   #22
dp3
dp3's Avatar
I have the Hypertech tune as well, and had wondered the same thing. One thing I noticed is that the oil had less fuel dilution of the oil w the Hypertech tune than when I checked the oil on the OEM ECU tune.
 Old 02-21-2018, 03:09 PM   #23
mituc's Avatar
Groans: 111
The cylinder #3 issue is present on the bone stock cars as well. Actually the more aggressive VVT and slower open loop/closed loop transitions makes it worse.
Also Hypertech was made responsible over time for damaging a few engines. With those pig rich AFRs up top and long high speed cruising on the german autobahn a lot of drivers ended up with shattered spark plugs (no, not all of them were Densos from that shitty batch that was released on the market back in 2010), butted rings and cracked cylinder walls especially on #3, and so on.
The rich AFRs at relatively low RPM and high load are usually meant to give more control over ignition, and they're used sometimes to promote turbo spool (along with more VVT timing and less ignition timing). As a result there's going to be more soot clogging the oil rings over time.
So considering the way I saw over these last few years how you take care of your car (I'm thinking about both the actual maintenance and how you drive it) your engine will be healthy for even longer with a proper tune.
Another reason why your engine is still so good after so many miles is that you added proper breathing mods which promote the heat dissipation while the tune is not squeezing too much power out of the engine. That threshold of power/torque which would result in faster wear is impossible to predict and depends quite a lot on how the owner maintains the car and how the car is driven. In your case all things that add up simply result in lower figures than whatever the threshold would be in your case.
dp3 likes this.
dp3 (02-21-2018), MSMS3 (02-23-2018), Thor Hammer (02-21-2018)
 Old 02-23-2018, 02:31 PM   #24
I guess being anal-retentive and OCD about maintenance has its rewards! Good breathing on intake and exhaust side, modest, but effective tune, and short oil change intervals (typically 3,000 miles, never more than 3,500), may have helped.
Yes, we don't have any autobahns here. No opportunities to drive long distances at or near redline in 6th! I've only been above 150 mph twice in the ten years of ownership, and those were very short duration events. Never any opportunity to cruise for extended time at high rpm.
I've always run NGK plugs, so I was never exposed to the Denso problems others had.
I guess I've been a bit lucky. Maybe stumbled upon some good, compatible mod choices along the way and taken care of what I have. Even the blind squirrel occasionally finds an acorn.
dp3 likes this.
dp3 (02-23-2018)
Blown turbo acidhalo 2010 MS3 - Turbo Induction 24 10-16-2013 03:08 PM
Blown Turbo? finalems3 MazdaSpeed 3 - Engine, Transmission & Driveline 7 07-24-2013 09:37 AM
Another Blown Turbo... dcamp2 Gen2 MS3 General Discussion 75 06-29-2012 11:35 AM
Blown Turbo????? sacredmonkey Mazdaspeed3/6 General Discussion 10 02-15-2012 01:56 PM
Blown Turbo JD80 Gen2 MS3 General Discussion 23 07-27-2011 09:23 PM
Page generated in 0.47667 seconds with 29 queries
