7Likes ![]() |
![]() Join Date: Feb 2018
Rep Power: 0 ![]() Thanks: 0
(Thread Starter) | Not Ranked : 0 score Well only put 30 miles on it since purchase and after getting on it noticed a whine from the turbo and no power. I've had/built many turbo cars over the years and I though meh, boost/vacuum leak. The hose off the turbo inlet had broken so I ordered a corksport and mended the stocker for now (youll see in the video). Went around the block and the noise was still there. Took a video and once I heard it its definitely the turbo, you can hear the fan blades bouncing off the housing lol. Pulled the inlet and took a second video of the shaft play. I am keeping the car at stock power levels so I was looking at having it re manufactured by the guys at BNR. Anyone have any other recommendations? videos for your viewing pleasure. https://youtu.be/lMnWFsgB-WI Shaft play: https://youtu.be/S3OYuaNlHNw |
![]() Join Date: Dec 2017 Location: Idaho
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 84
| Not Ranked : 0 score Just buy a bnr v1, reman of yours is a tall task
__________________ 2011 MS3 Tech - 2008 Jeep Grand Cherokee CRD - 1989 Crown Vic LTD LX - 1985 Lincoln Town Car Signature The key to happiness is owning a car ridiculously slower than your 'fast' car. |
(Thread Starter) | Not Ranked : 0 score You mean an s1? BNR will do a full remanufacture for 400 vs 900 for the s1. |
| Not Ranked : 0 score Yes S1 sorry. It would just be worth it to me to have a brand new turbo instead of a reman... It may be in worse shape then you know by just seeing what you can in the video.
(Thread Starter) | Not Ranked : 0 score Ah, so the 400 bucks is just a baseline rebuild and could end up costing more depending on the extent? I do like the idea of the "hybrid" s1. |
![]() Join Date: Sep 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 60
| Not Ranked : 0 score Everyone I have read who has had this issue seems to run into similar advice regarding rebuilding the stock turbo. I would be reluctant to do so. OEM is not the most reliable design and the BNR OEM replacement is cheap in terms of peace of mind. That is the direction I would head in with that mileage. I suspect these engines can clock a lot of miles if the oil is changed out ahead of MFG specs.
__________________ 13 MS3 Eibach Pro kit Springs, Koni Ylw. F and R, Tanabe strut tower brace, 25 MM rear bar,CPE R mount, ETS TMIC, Autotech HPFP, ITV-22, CS: CAI, Cold Air Box, Boost tubes, Race Pipe, front spoiler. Forge BPV, Hypertech tune, Amsoil fluids,Philips DV H-11's and 9505's, Traklite RPM 18x8 +45 offset rims, 15mm Ichiba spacers(F&R) Rolled fenders w 235-40 Y rubber, Tint, Remix Rear Lip, Radar detector. |
(Thread Starter) | Not Ranked : 0 score Ok I im going to go with the BNR OEM remanufacture. Is there anyone that has experience with them? |
![]() Join Date: Jun 2009
| Not Ranked : 0 score Yes. Did both. Got a BNR reman to address "smoking turbo". My OEM also had shaft wear and was getting vane strikes. The reman also started smoking after about 50,000 miles. Not BNR's fault. K04 seals just can't handle crankcase pressure. So, I got BNR stage 1. It uses a Garrett G28 series CHRA in the K04 shell. This is a permanent solution to the seal failure smoking. It has the same flow (actually a little bit better) than the K04, so you can run it on stock tune or your present K04 tune with no change. Just go BNR Stage 1. A reman, regardless of who does it, will just smoke eventually.
![]() Join Date: Nov 2015 Location: Rochester Hills, MI
| Not Ranked : 0 score I disagree. a good quality rebuild will be just fine. Turbos are wearable items, so when someone complains they only got 50K out of their rebuild I just shake my head. A decent quality rebuilt unit can be had for $200-350. I would go this route as they dont require a core in the event yours is truly trashed. I do agree a S1 is superior, but if you plan on staying stock a rebuilt K04 would meet your requirements and save you some coin. I will warn you there are a ton of cheap ebay special rebuilds you want to stay away from. Look for one that comes from a reputable rebuilder and/or has a warranty.
__________________ "Sarcasm and shit talking are two different things. MSF offers the best advice, just delivered by sarcastic pricks, with your best interest in mind." -ThePedigree13 Silver 06 MS6 - DD stealth build - no show, all go.... '12 Abarth Challenge Car - very loud, very fast, very inconvenient to drive on the street... |
| The Following User Says Thank You to MSMS3 For This Useful Post: | kTaLgsTo (02-07-2018) |
| Not Ranked : 0 score rebuilt turbo is just as good as how it is done. It is like rebuilding an engine, if the cylinder wall is deeply grooved or worn out and you just put new rings it will blow-by again.... If your turbo fail and you just put another one in without looking at the reason why the first one fail, just expect to put a third one in too and so on... If you look for a low price more than anything else, you can buy a brand new K04 CHRA for about 200$ and put it back into your hot and cold side yourself....I just don't know about the quality of these CHRA
Groans: 111
| Not Ranked : 0 score Instead of rebuilding it for $400 you can buy a Chinese replacement off of ebay which are pretty decent quality. If it was my car and didn't want to go bigger I'd go with the BNR S1 or S2, but that's just me. Personally I've been there and the teenager in me decided to go big turbo even the factory turbo was still good. The grown-up in me couldn't resist and gave up arguing the teenager decision. Long story short it may be a good thing that your turbo shit the seals. So act accordingly. And a personal advice: act recklessly. Fuck grown-ups opinions!
![]() Join Date: Aug 2009 Location: Hershey, PA
Rep Power: 265 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 84
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score Definition of "a lot of miles" is subjective. Many are hitting the 120-130k mile mark and are requiring rebuilds due to low compression in cylinder 3. That's with routine oil changes every 3k miles. I'm seeing more and more posts from owners buying these cars with this mileage on the clock and just starting their performance builds (just bolt ons). IMO they're wasting their $$ if they're not financially planning for a engine rebuild/replacement in the near future.
__________________ '06 MS6: BNR S3//CP-E FMIC//Forge V3/CP-E Nano Intake//TIP//DNP Swain Tech Coated Exhaust Mani//CP-E Catted Swain Tech Coated DP//Magnaflow CBE//CP-E RMM & TT Rear Diff Mount//PnP & Coated Intake Mani// VCTS and EGR delete//GS EBCS//3 Bar MAP//RMM//SafeSeals//PT-P FP Internals//TWM Stage II STS//SSP//Saikou Michi OCC//Snow Stage 2 WMI w/ D07 nozzle//Cobb AP V3//RICH TUNE!//Stoptech Slotted Rotors and EBC RedStuff Pads//H&R springs w/spacers//Bilsteins//SPC Balljoints//AeroForce ScanGauge & WideBand//Snow Performance WMI Failsafe & Guardian Angel//Morimoto HID Projector Upgrade//Hella HID Fogs |
To your point, I'll be picking up my block from the machine shop very soon. Once it's built, the original engine will go into storage as a working back-up if I manage to screw something up with the forged build.
__________________ '06 MS6 GT-167k Miles(Forged@157,116) Manley Pistons & Rods, King Bearings Stock Head/Cams, Stock Int/Exh Manifolds Versatuner, 3-bar MAP, ITV22, CP-e TMIC CS Turbo/DP/RP/HPFP/BPV/R-DiffMount White Widow F-DiffMount, Whiteline RSB Rear Russian Bushings, Poly FSB Bushings Magnaflow CBE, ACT 6-puck/Streetlite JBR Tru-3.5/3-port EBCS/EGR-D Damond RMM/PMM/OCC/PCV Plate Other rides: 2014 F-150 XLT SuperCrew Ecoboost 2002 Tacoma ExtCab 2.4L 5spd 2WD 2004 Olds Alero ECOtec 2.2 - Broken History: 2008 GSX-R 1000 - Stolen 1988 RX-7 TII - Sold (13.467 @ 105.44) 1985 Camaro - Sold (est. 265bhp 5.7 swap, Edelbrock intake & Hooker headers) | |
I hear what you are saying, though. Ring land issues can emerge at any time. Buyers of our cars with higher mileage need to confirm static compression and do a leak down test before closing the deal, and if a K04 is still in place, expect it to smoke.
Groans: 111
| Not Ranked : 0 score If the compression is solid at that mileage I'd rather expect the exhaust valve seals to be a bit cooked than the rings to be gone. If rings are gone it always reflects into compression, and sometimes low compression engines do not even smoke yet until they get below 100PSI on at least two cylinders.
| The Following User Says Thank You to mituc For This Useful Post: | Thor Hammer (02-21-2018) |
![]() Join Date: Apr 2013 Location: Somersworth, NH
Rep Power: 878 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,570
| Not Ranked : 0 score PTE 6466 or bust!
__________________ 2012 NASA Spaceship Gray MS3 BNR S3 - JBR Tru 3.0" - CP-E TMIC - Corksport catless DP - Corksport catted race pipe - Forge V2 - Autotech internals + AP v3 - Swift springs - Enkei RPF1 17x9 + 45 (5mm JBR spacers in the front) - Freektune 320/346 |
I wasn't seeing it between oil change. The oil ring was still intact....In fact, my rebuild use more oil than my original low compression engine! (I went a bit far with ring gap ) My valves were a lot dirty and the injector seal was gone too.... I don't really think it is a matter of mileage because i know exactly when and why mine broke. IMO there is more risks for rods bearing or VVT/timing on an stock or slightly modded engine with high mileage....
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... Last edited by Jeff23spl; 02-08-2018 at 09:18 AM. | |
I have never kept a Speed past 70 k miles (have had 3 of them) and compression was always even with no apparent wear that I could discern, However I do de-carbon every 30K miles and run Gas which has a decarbon-fuel system lubricant in it.
__________________ 13 MS3 Eibach Pro kit Springs, Koni Ylw. F and R, Tanabe strut tower brace, 25 MM rear bar,CPE R mount, ETS TMIC, Autotech HPFP, ITV-22, CS: CAI, Cold Air Box, Boost tubes, Race Pipe, front spoiler. Forge BPV, Hypertech tune, Amsoil fluids,Philips DV H-11's and 9505's, Traklite RPM 18x8 +45 offset rims, 15mm Ichiba spacers(F&R) Rolled fenders w 235-40 Y rubber, Tint, Remix Rear Lip, Radar detector. | |
Groans: 111
So if you do WMI prior to getting significant wear and decreased compression you may save the engine and run it for quite long.
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI | |
I may be leaving 10 whp on the table with the HT tune on stock turbo and pump gas compared to a custom tune with Versatune or AP, but maybe the super rich philosophy of Mazda and Hypertech, is helping save my pistons. Just don't know. On the other hand if that unburned fuel gets past the rings it contaminates the oil. Gasoline is a poor lubricant. Oil analysis does indicate some fuel contamination, which all of us experience to greater or lesser degrees, but it is actually quite low for me, especially at this mileage.
| The Following User Says Thank You to MSMS3 For This Useful Post: | dp3 (02-20-2018) |
Groans: 111
Also Hypertech was made responsible over time for damaging a few engines. With those pig rich AFRs up top and long high speed cruising on the german autobahn a lot of drivers ended up with shattered spark plugs (no, not all of them were Densos from that shitty batch that was released on the market back in 2010), butted rings and cracked cylinder walls especially on #3, and so on. The rich AFRs at relatively low RPM and high load are usually meant to give more control over ignition, and they're used sometimes to promote turbo spool (along with more VVT timing and less ignition timing). As a result there's going to be more soot clogging the oil rings over time. So considering the way I saw over these last few years how you take care of your car (I'm thinking about both the actual maintenance and how you drive it) your engine will be healthy for even longer with a proper tune. Another reason why your engine is still so good after so many miles is that you added proper breathing mods which promote the heat dissipation while the tune is not squeezing too much power out of the engine. That threshold of power/torque which would result in faster wear is impossible to predict and depends quite a lot on how the owner maintains the car and how the car is driven. In your case all things that add up simply result in lower figures than whatever the threshold would be in your case.
| The Following 3 Users Say Thank You to mituc For This Useful Post: |
![]() | | #24 | ![]() |
| Not Ranked : 0 score I guess being anal-retentive and OCD about maintenance has its rewards! Good breathing on intake and exhaust side, modest, but effective tune, and short oil change intervals (typically 3,000 miles, never more than 3,500), may have helped. Yes, we don't have any autobahns here. No opportunities to drive long distances at or near redline in 6th! I've only been above 150 mph twice in the ten years of ownership, and those were very short duration events. Never any opportunity to cruise for extended time at high rpm. I've always run NGK plugs, so I was never exposed to the Denso problems others had. I guess I've been a bit lucky. Maybe stumbled upon some good, compatible mod choices along the way and taken care of what I have. Even the blind squirrel occasionally finds an acorn.
| The Following User Says Thank You to MSMS3 For This Useful Post: | dp3 (02-23-2018) |
| Blown turbo | acidhalo | 2010 MS3 - Turbo Induction | 24 | 10-16-2013 03:08 PM |
| Blown Turbo? | finalems3 | MazdaSpeed 3 - Engine, Transmission & Driveline | 7 | 07-24-2013 09:37 AM |
| Another Blown Turbo... | dcamp2 | Gen2 MS3 General Discussion | 75 | 06-29-2012 11:35 AM |
| Blown Turbo????? | sacredmonkey | Mazdaspeed3/6 General Discussion | 10 | 02-15-2012 01:56 PM |
| Blown Turbo | JD80 | Gen2 MS3 General Discussion | 23 | 07-27-2011 09:23 PM |
