![]() Join Date: May 2011 Location: copperas cove, tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 0
Groaned at 23 Times in 11 Posts
(Thread Starter) | Not Ranked : 0 score any one know anything about there k04 turbo pgrade |
![]() Join Date: Jun 2009
| Not Ranked : 0 score Stick with BNR. Several different power levels from stock with Garrett CHRA (same flow as stock but eliminates smoking turbo risk), through Stage 2 and Stage 3 for higher power levels. Designed specifically for our manifold flange. Tried and true.
![]() Join Date: Jan 2011 Location: Vancouver BC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 130
| Not Ranked : 0 score If you're looking to keep things stock, just buy a new k04. You can find them online for $500~. Doubt a rebuilt upgrade will be much cheaper with down time and shipping.
__________________ 2006 Moist Metallica Silver Speed6 GT #6557 @ 267,000km Leakdown results was 50% or more across all four. slow rebuild in progress Corksport: Turb.IM.DP.OCC.3.5MAP.IC.RMM.TIP.FSB.Tubes.Strut Tower. JBR: 70a Sides.SSP.51r SURE: Full3Aeros.Dreadnaught.Juggernaught.Anchors.FlowM6 .Rad Hoses. Stratified Custome Tune/APv3.Turbosmart DS BOV.Cobb EBCS.AT HPFP.Deatchsworks.CPe SafeSeals.H&R Coils.Moog Camber Arms. SPC Ball Joints.Whiteline Adj RSB. SU Rear Interior Brace.StopTech Perf Pads.Centric X-D Rotors.TechnaFit Braided Clutch-Brake Lines.Damond PS Cooler.EGR. PeRM PCV Plate. Michelin Pilot Sport AS3+ 235/40/18.Drag DR-38 +47. Gloss Black Blue Undercut. Pirelli Sottozero s2 240 215/45/18. MS6 OEMs. To order: Fullrace Exhaust Mani. FMIC. Damond side mounts. New built motor. Still thinking about Flowmasters |
| MS6 turbo Upgrade | mlamp89 | MazdaSpeed 3/6 - Turbo Induction | 20 | 04-06-2013 12:18 AM |
| Turbo upgrade - what else needs to be done | j_dub99 | MazdaSpeed 3/6 - Turbo Induction | 4 | 12-15-2011 07:18 AM |
| Turbo Upgrade | Reid Clark | MazdaSpeed 3/6 - Turbo Induction | 229 | 08-01-2011 08:29 PM |
| Turbo Upgrade ?? | ludddwig | MazdaSpeed 3/6 - Turbo Induction | 5 | 11-04-2008 12:45 AM |
