  • 1 Post By MSMS3
 Old 10-08-2017, 10:11 PM   #1
panaspeed3's Avatar
Posts: 68   (View Stats)
panaspeed3 is a splendid one to beholdpanaspeed3 is a splendid one to beholdpanaspeed3 is a splendid one to beholdpanaspeed3 is a splendid one to beholdpanaspeed3 is a splendid one to beholdpanaspeed3 is a splendid one to beholdpanaspeed3 is a splendid one to behold
Groaned at 23 Times in 11 Posts
Default anyone use turbo lab of america for k04 upgrade
any one know anything about there k04 turbo pgrade
panaspeed3 is offline   Reply With Quote
 Old 10-10-2017, 08:01 PM   #2
Posts: 2,826   (View Stats)
Stick with BNR. Several different power levels from stock with Garrett CHRA (same flow as stock but eliminates smoking turbo risk), through Stage 2 and Stage 3 for higher power levels.
Designed specifically for our manifold flange. Tried and true.
danb likes this.
 Old 11-07-2017, 06:25 PM   #3
Marcus's Avatar
Posts: 777   (View Stats)
Marcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the worldMarcus is the leader of the world
If you're looking to keep things stock, just buy a new k04. You can find them online for $500~. Doubt a rebuilt upgrade will be much cheaper with down time and shipping.
2006 Moist Metallica Silver Speed6 GT #6557 @ 267,000km
Leakdown results was 50% or more across all four. slow rebuild in progress
Corksport: Turb.IM.DP.OCC.3.5MAP.IC.RMM.TIP.FSB.Tubes.Strut Tower. JBR: 70a Sides.SSP.51r SURE: Full3Aeros.Dreadnaught.Juggernaught.Anchors.FlowM6 .Rad Hoses.
Stratified Custome Tune/APv3.Turbosmart DS BOV.Cobb EBCS.AT HPFP.Deatchsworks.CPe SafeSeals.H&R Coils.Moog Camber Arms. SPC Ball Joints.Whiteline Adj RSB.
SU Rear Interior Brace.StopTech Perf Pads.Centric X-D Rotors.TechnaFit Braided Clutch-Brake Lines.Damond PS Cooler.EGR. PeRM PCV Plate.
Michelin Pilot Sport AS3+ 235/40/18.Drag DR-38 +47. Gloss Black Blue Undercut. Pirelli Sottozero s2 240 215/45/18. MS6 OEMs.
To order: Fullrace Exhaust Mani. FMIC. Damond side mounts. New built motor. Still thinking about Flowmasters
Marcus is offline   Reply With Quote
MS6 turbo Upgrade mlamp89 MazdaSpeed 3/6 - Turbo Induction 20 04-06-2013 12:18 AM
Turbo upgrade - what else needs to be done j_dub99 MazdaSpeed 3/6 - Turbo Induction 4 12-15-2011 07:18 AM
Turbo Upgrade Reid Clark MazdaSpeed 3/6 - Turbo Induction 229 08-01-2011 08:29 PM
Turbo Upgrade ?? ludddwig MazdaSpeed 3/6 - Turbo Induction 5 11-04-2008 12:45 AM
Page generated in 0.24797 seconds with 22 queries
