![]() Join Date: Jul 2017 Location: Portland, OR
Rep Power: 0 ![]() Thanks: 0
Groaned at 7 Times in 2 Posts
![]() Join Date: Mar 2012 Location: Bend, Oregon
Rep Power: 670 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,489
Groans: 122
| Not Ranked : 0 score Why oh why have the speed forums turned into a ricer fuck fest and not about performance. Any bpv is plenty loud when you run any aftermarket air intake. You don't need an aftermarket bpv until your tuned to around 20ish psi on the stock turbo. Even then, it can hold. I ran stock bpv up to 22psi and had zero leaks. If your bpv is leaking, then sure spend the money.
__________________ 2006 BCM Mazdaspeed 6 GT w/navi SOLD Freektune: 400whp/387awtq Mods: Cobb AP, MSD Dashhawk, GT3076r, HTP 3" SRI, FMIC w/ tr8, Wiseco Pistons (9.5:1), Manely Rods, HPFP AutoTech Intenals, NJSPEED3 Ported Intake Manifold w/ VCTS Delete, Turbosmart BPV, Grimspeed 3-Port EBCS, NGK Iridium One Step Colder Plugs, 3.0" ATP Turbo Dowpipe w/ high flow cat, Devil's Own Stage 1 Methanol/Water Injection Kit, 50/50 Methanol, ACT 6 puck sprung w/ streetlite flywheel, Block8head vent pod, Prosport Performance Boost Gauge Amber/White, Cipher Auto Harness Bar, Cipher Auto 4-point Racing Harness, BC Racing Coilovers, CP-E rear diff mount, JBR RMM 80A, SPC Front Adjustable Ball Joints, Enkei Raijin Hypersilver 18x8 +45, 225/45/18 -Autocross Setup- 17x8 +38, BF Goodrich R1 225/45/17 Other Rides: 2006 Mazdaspeed6 GT BCM: 114k miles, never modded (Totaled March 2013) 1969 Ford Ranchero: 351 Windsor, Edelbrock 600cfm, fully re-done interior (w/ Grant steering wheel, '91 T-Bird SC racing bucket seats), C-6 Automatic Trans w/ shifter kit, First, body work, then drag racing and dumping money into it. 1969 Pontiac Firebird: 4:11 gears, 28x10 ET Streets (Middle of restoration with father) 1998 Toyota Tacoma 4x4: 174k miles, 5 speed, Fiberglass Baja Front clip, 2in body lift, 4in suspension lift, 33x10 BFG All-Terrains, Custom Smittybuilt Bumpers, Custom Intake (SOLD) |
| The Following User Says Thank You to rymanmazda For This Useful Post: | MSMS3 (11-11-2017) |
(Thread Starter) | Not Ranked : 0 score Yes i do realize its a little rice, It is for planning in the future where i plan to go BNR s4 or bigger. How about you get off your high tower and answer the question. |
| The Following 5 Users Say NO Thank You to jaller1999 For This Un-useful Post: | Djohns (11-11-2017), g00s3y (11-09-2017), MSMS3 (11-11-2017), rymanmazda (11-08-2017), tegxsi (11-09-2017) |
Groans: 122
BTW i basically answered. ANY other bpv will be good. But you don't need it. Apparently you also forgot to read your welcome PM. Post a new member thread. Aaand from looking at your profile you don't have HPFP internals. That should be your priority so you don't fuck up your engine.
__________________ 2006 BCM Mazdaspeed 6 GT w/navi SOLD Freektune: 400whp/387awtq Mods: Cobb AP, MSD Dashhawk, GT3076r, HTP 3" SRI, FMIC w/ tr8, Wiseco Pistons (9.5:1), Manely Rods, HPFP AutoTech Intenals, NJSPEED3 Ported Intake Manifold w/ VCTS Delete, Turbosmart BPV, Grimspeed 3-Port EBCS, NGK Iridium One Step Colder Plugs, 3.0" ATP Turbo Dowpipe w/ high flow cat, Devil's Own Stage 1 Methanol/Water Injection Kit, 50/50 Methanol, ACT 6 puck sprung w/ streetlite flywheel, Block8head vent pod, Prosport Performance Boost Gauge Amber/White, Cipher Auto Harness Bar, Cipher Auto 4-point Racing Harness, BC Racing Coilovers, CP-E rear diff mount, JBR RMM 80A, SPC Front Adjustable Ball Joints, Enkei Raijin Hypersilver 18x8 +45, 225/45/18 -Autocross Setup- 17x8 +38, BF Goodrich R1 225/45/17 Other Rides: 2006 Mazdaspeed6 GT BCM: 114k miles, never modded (Totaled March 2013) 1969 Ford Ranchero: 351 Windsor, Edelbrock 600cfm, fully re-done interior (w/ Grant steering wheel, '91 T-Bird SC racing bucket seats), C-6 Automatic Trans w/ shifter kit, First, body work, then drag racing and dumping money into it. 1969 Pontiac Firebird: 4:11 gears, 28x10 ET Streets (Middle of restoration with father) 1998 Toyota Tacoma 4x4: 174k miles, 5 speed, Fiberglass Baja Front clip, 2in body lift, 4in suspension lift, 33x10 BFG All-Terrains, Custom Smittybuilt Bumpers, Custom Intake (SOLD) Last edited by rymanmazda; 11-08-2017 at 10:14 PM. Reason: MSF Database - Automerged Doublepost | |
(Thread Starter) | Not Ranked : 0 score Alright yea I get that, Im Just wondering if anyone has some updated news on if any more Forge BPV have resurfaced since they aren't produced anymore, since im pretty interested in those. And I do have the corksport HPFP internals actually Last edited by jaller1999; 11-08-2017 at 10:15 PM. Reason: MSF Database - Automerged Doublepost |
Groans: 122
| Not Ranked : 0 score Just search!!! Literally took me 5 seconds. It's not a v1 because they are no longer made. Forge Motorsport Recirculation Valve SILVER Mazdaspeed 3 2007-2013 / Mazdaspeed 6 2006-2007 / Subaru WRX 2008-2014 Corksport, gofastbits, turbosmart. Just a few good bpvs.
| The Following User Says Thank You to rymanmazda For This Useful Post: | g00s3y (11-09-2017) |
Groans: 438
Unless your stock one doesn't work, you have a lot of other things to worry about, if you are actually going to do things to this car. A ricer BPV is not one of them.
__________________ All good things must come to an end... | |
| MSF's Punishing Member ![]() Join Date: Apr 2011
Rep Power: 2794 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,165
Groans: 546
| Not Ranked : 0 score when even stop at a bpv, just go vta
__________________ 94 M MS6 IS350 |
![]() Join Date: Jun 2009
| Not Ranked : 0 score OP just wants to make armpit fart sounds with his engine so he can turn ricer fanboi heads and impress pre-teen girls. A Forge bpv is not a power mod. In fact, years ago a prominent motorsport magazine (Grassroots Motorsport) tested it against the stock Mazdaspeed bpv on a gen 1 MS3 and the stock one held boost better under full power even with mods at the 18-19 psi level.
![]() Join Date: Oct 2014 Location: sudbury ON, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 82
| Not Ranked : 0 score IMO, if the man wants a bpv, all power to him. Obviously it's not a performance mod, and should be last on the list of things to buy. A bpv was the last thing I purchased, and it's one of my favourite mods. Call me a ricer, but I love hearing it. With that said, OP needs to read his welcome PM. Literally could have spent 2 seconds on google and found at least 5 sites that sell bpv's. |
![]() Join Date: Feb 2011 Location: Chicago
Rep Power: 365 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 183
Groans: 74
| Not Ranked : 0 score 1.Go VIP, get enough posts to post in for sale section. 2.Post WTB forge bpv. 3. I will sell you my forge bpv
__________________ 2007 TR MazdaSpeed3:Autotech FP inernals, CorkSport Turbo, TR8 Front Mount w/CX piping, JBR 3" intake, COBB EBCS, Cobb AP, Toyota Injector Seals, FR stud mod, Fidanza flywheel/LUK clutch, Forge BPV v2, cp-e xFlex stage 2 RMM, Wiseco .20 Pistons/Manley Rods/BSD, Dual DM catch cans, Koni Yellows/H&R springs, FD wheels, eBay downpipe, stock CBE 2005 Mazda 3 SP23: mods include rusty quarter panels and grinding 3rd gear. It does have a fusion motor, so I guess that's a mod too. |
Groans: 122
| Not Ranked : 0 score Then when your done with that. Buy my H&R sport springs.
Groans: 122
| Not Ranked : 0 score onefidy. check my forsale ad. they are for a MS6
| Forge "sword" valves FOUND | AustinK | CorkSport | 26 | 04-03-2013 11:10 AM |
| Report: Mitsubishi boss labels French minister a "retard" for "ruining the lives of motorists" | Haltech | Automotive News | 0 | 10-25-2012 06:00 PM |
| Lutz lays out his strategy for GM advertising: "Memorable," "clever," "viral" [w/VIDEO] | Haltech | Automotive News | 0 | 08-04-2009 09:40 AM |
| Saudi government bans "lewd" personalized license plates including: "SEX," "ASS," and "USA" | Haltech | Automotive News | 0 | 04-14-2009 01:40 PM |
