Like Tree103Likes
 Old 09-06-2012, 04:09 PM   #41
@chimmike, I'm down to throw down some cash towards the $250 in small claims.
I thing Garrett is to blame...they made the CHRA which is where the failure occurred. ATP only adds a hotside, drain line and coupler to the mix so they never touch the CHRA oil feed.
I have a GTX3071 on the way and will compare the CHRA to my GT28.
AFAIK absolutely no restrictor needed and in-fact will likely destroy the CHRA.
Where did you read that? (I know there is definitely conflict)... This is from Garrett's site..
We really need to know the oil feed line pressure.
Q. Does my turbo require an oil restrictor?
A. Oil requirements depend on the turbo's bearing system type. Garrett has two types of bearing systems; traditional journal bearing; and ball bearing. The journal bearing system in a turbo functions very similarly to the rod or crank bearings in an engine. These bearings require enough oil pressure to keep the components separated by a hydrodynamic film. If the oil pressure is too low, the metal components will come in contact causing premature wear and ultimately failure. If the oil pressure is too high, leakage may occur from the turbocharger seals. With that as background, an oil restrictor is generally not needed for a journal-bearing turbocharger except for those applications with oil-pressure-induced seal leakage. Remember to address all other potential causes of leakage first (e.g., inadequate/improper oil drain out of the turbocharger, excessive crankcase pressure, turbocharger past its useful service life, etc.) and use a restrictor as a last resort. Garrett distributors can tell you the recommended range of acceptable oil pressures for your particular turbo. Restrictor size will always depend on how much oil pressure your engine is generating-there is no single restrictor size suited for all engines. Ball-bearing turbochargers can benefit from the addition of an oil restrictor, as most engines deliver more pressure than a ball bearing turbo requires. The benefit is seen in improved boost response due to less windage of oil in the bearing. In addition, lower oil flow further reduces the risk of oil leakage compared to journal-bearing turbochargers. Oil pressure entering a ball-bearing turbocharger needs to be between 40 psi and 45 psi at the maximum engine operating speed. For many common passenger vehicle engines, this generally translates into a restrictor with a minimum of 0.040" diameter orifice upstream of the oil inlet on the turbocharger center section. Again, it is imperative that the restrictor be sized according to the oil pressure characteristics of the engine to which the turbo is attached. Always verify that the appropriate oil pressure is reaching the turbo. The use of an oil restrictor can (but not always) help ensure that you have the proper oil flow/pressure entering the turbocharger, as well as extract the maximum performance.
Last edited by rfinkle2; 09-06-2012 at 04:12 PM. Reason: MSF Database - Automerged Doublepost
The Following 16 Users Say Thank You to rfinkle2 For This Useful Post:
atvfreek (09-06-2012), BlueStreak (09-06-2012), Dano (09-06-2012), doubleflusher (09-07-2012), Easter Bunny (09-06-2012), Fail_6 (01-30-2015), Fobio (09-06-2012), helmetface (09-06-2012), NJSPEED3 (09-06-2012), RichieRichness (11-06-2013), Rokusek (09-10-2012), SofaKingAwesome (09-07-2012), Speed3eak (09-07-2012), SPEED6 KILLAH (09-06-2012), SpeedSixxx (09-07-2012), xdm88 (09-06-2012)
 Old 09-06-2012, 04:14 PM   #42
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
Like I said, I had a long conversation with ATP about oil feed on this turbo and this car in particular, and they swear that no restrictor is best, that if you are getting a leak at the seals merely use a restrictor and the leak will stop, but they say this car does not need a restrictor.
I will be swapping to a -4 line and run the FP filter WITHOUT the restrictor. And I'll check the filter every oil change.
I'd rather you throw down some cash towards my new CHRA, lol
07 MS3
The original Genpoo Hater
Last edited by Chimmike; 09-06-2012 at 04:14 PM. Reason: MSF Database - Automerged Doublepost
The Following 3 Users Say Thank You to Chimmike For This Useful Post:
atvfreek (09-06-2012), helmetface (09-06-2012), rfinkle2 (09-06-2012)
 Old 09-06-2012, 04:19 PM   #43
If it is allowed, it will be inbound.
 Old 09-06-2012, 04:20 PM   #44
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
I call b.s. if they can't show you the "restriction."
The Following 2 Users Say Thank You to Mizzle For This Useful Post:
Easter Bunny (09-06-2012), themytb (09-06-2012)
 Old 09-06-2012, 04:21 PM   #45
BlueStreak's Avatar
Posts: 1,467   (View Stats)
I believe Bluestreak thinks the excessively long drain line they supply with the kit is the culprit.
Yep. My line was kinked and I'm sure it caused the oil to back up. At this point, I'm kinda nervous about my second one failing so I ordered this oil restrictor for testing. Nuts to ATP saying we don't need one.
Turbo Oil Feed Banjo Bolt Kit Garrett GT2871R GT2876R GT3071R Ball Bearing | eBay
'07 CWP MS3
Forged.
 Old 09-06-2012, 04:23 PM   #46
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Well, donation threads aren't allowed but I don't see why that isn't.
This is the filter I'm going to use. Earl's Performance 230304ERL - Earl's Performance Screen-Type Inline Oil Filters - Overview - SummitRacing.com
07 MS3
Last edited by Chimmike; 09-06-2012 at 04:23 PM. Reason: MSF Database - Automerged Doublepost
 Old 09-06-2012, 04:25 PM   #47
silvapain's Avatar
Posts: 6,665   (View Stats)
Groans: 136
Just rolling over and paying for a new part isn't the MSF way. We fuck couches.
I'm down to donate for a small claims filing.
Tapadatass
rfinkle2 and kritz like this.
The Following 11 Users Say Thank You to silvapain For This Useful Post:
802MS3 (09-06-2012), atvfreek (09-06-2012), Dano (09-06-2012), Keko (09-06-2012), Micha (09-07-2012), Monotonous ONE (09-06-2012), Pointless (11-11-2012), rfinkle2 (09-06-2012), Rokusek (09-10-2012), SpeedSixxx (09-07-2012), Tokay444 (09-06-2012)
 Old 09-06-2012, 04:27 PM   #48
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
Let Ye Royal Couch Fornication commenceith!
Nator is what it does.
The Following 9 Users Say Thank You to kritz For This Useful Post:
Easter Bunny (09-06-2012), Micha (09-07-2012), rfinkle2 (09-06-2012), Rokusek (09-10-2012), silvapain (09-06-2012), SLOWHATCH (09-07-2012), SpeedSixxx (09-07-2012), Tokay444 (09-06-2012), TWOptSL0W (09-06-2012)
 Old 09-06-2012, 04:30 PM   #49
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Tapadatass
dude, I can't take the time off work for that shit. I don't have time.
07 MS3
 Old 09-06-2012, 04:38 PM   #50
Mizzle's Avatar
Groans: 324
Either they show you the restriction so you can get it tested to find out if it was something in your oil or a piece of ATP's line that broke off inside (or something else,) or else ATP fixes it. If Garrett found any issue to cause the problem, they're not liable, but then ATP is unless they can prove it was something on your car that did it.
Easter Bunny (09-06-2012), Tokay444 (09-06-2012)
 Old 09-06-2012, 04:59 PM   #51
aviator79's Avatar
Posts: 3,934   (View Stats)
Well I was going to buy an GTX3076 (non ATP), but I think I am better off going with something else. Are all the failures ATP failures or are there any strait Garrett failures?
 Old 09-06-2012, 05:02 PM   #52
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
All ATP does it put a hotside on the turbo, the failures have nothing to do with ATP unless it is there return or feed kits fucking up.
860whp/677wtq
2.7 V6 Ecoboost
86AmishMs3 (09-09-2012), Dano (09-06-2012), Rokusek (09-10-2012)
 Old 09-06-2012, 05:06 PM   #53
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
So when smart people disagree I get confused:
@SPEED6 KILLAH @Tomas
What is the consensus with these ball-bearing bitches?
Oil restrictor, Yay or Nay?
Oil Filter in-line to turbo, Yay or Nay?
 Old 09-06-2012, 05:10 PM   #54
Will fuck up ur day
Chimmike's Avatar
Groans: 433
An oil restrictor, improperly sized, is more likely to fry your turbo that not. ATP's saying was "you can't have too much oil, and when you do, use a big restrictor, not a small one, to minimize flow just a little bit"
ATP did not discourage the in line oil filter.
07 MS3
 Old 09-06-2012, 05:10 PM   #55
SPEED6 KILLAH's Avatar
Posts: 1,176   (View Stats)
SPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the worldSPEED6 KILLAH is the leader of the world
Don't use that filter it a waste of money the screen are too big ...
SPEED6 KILLAH is offline   Reply With Quote
 Old 09-06-2012, 05:18 PM   #56
I will go with a oil restrictor. What I like about my turbo it came with one already on it. Also go with inline filter to be on the safe side
 Old 09-06-2012, 05:22 PM   #57
Will fuck up ur day
Chimmike's Avatar
Groans: 433
140 microns is pretty small. It's not the best, but it's definitely better than nothing.
you can bet your ass I'll be checking it frequently too. There's really no explanation for what happened to me other than I got fucked. hard. I do regular oil changes and use good filters, not those shit fram filters. Did the spin on conversion.......shit I should almost get a sandwich adapter and set up a SECOND filter.
07 MS3
 Old 09-06-2012, 05:25 PM   #58
crazyp's Avatar
Posts: 1,093   (View Stats)
Groans: 68
@RayRay had a similar issue.
@cld12pk2go, @NJSPEED3, @atvfreek, @ everyone interested....
The more I read about the gtx ball bearing turbos, the more I think we need to be running an oil restrictor.
Garrett recommends it.
@chimmike, we can get enough people together in this thread to show ATP how much business they do through this forum.
TBH, we don't need them considering their "drop in" oil and water feed kits are not correctly sized anyway.
I don't understand? I've been running a restrictor since I installed my GTX? The same restricor I use to run on my GT3071, was I not supposed to? I figured since they made the claim that its was drop in interchangeable that meant it needed it?
The Following User Says Thank You to crazyp For This Useful Post:
rfinkle2 (09-07-2012)
 Old 09-06-2012, 05:29 PM   #59
Look at the differences from earl and FP
That small shit will catch anything. Have your ever seen the oil feed whole for the ball bearing?
Also Im running a FP filter had no problem running it..
The Following 7 Users Say Thank You to SPEED6 KILLAH For This Useful Post:
atvfreek (09-06-2012), ms3blackmica (04-27-2013), PapaSmurf (09-06-2012), rfinkle2 (09-07-2012), Rokusek (09-10-2012), TWOptSL0W (09-06-2012), uncorked11 (09-08-2012)
 Old 09-06-2012, 05:29 PM   #60
aviator79's Avatar
I understand, that is why I do not think I can go with a GTX anymore. Just stating that me not getting one isnt like "Ha! see ATP, your lossing my bussiness cause I dont want to buy you POS nig rig turbo kit".
But now what can I get that will compare to a TS T3 GTX3076?. Have to start from scratch on that I guess...
 Old 09-06-2012, 05:30 PM   #61
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
The ATP/GT kits have been out for 5+ years and only maybe a handfull of failures that I know of and very few guys use a restrictor. That is all I was going by. nothing scientific..lol
I do however know of a guy running Precision turbos on a TT setup that toasted his turbos in a month due to using their recommended sized restrictor. It does require some measurements of oil pressure and then choose a size...not using a chart or someones recommendations...even if they are from the vendor.
So I am in ATPs camp with no restrictor unless you begin to have smoking issues. If you want to put a gauge on the feed line and measure that would be the only way to tell for sure.
FWIW I have 20K on my GT28, no pill and no shaft play. *knocks on wood*
oh and this does suck for Chimmike, bluestreak and the others that have had issues. Fucking Garrett could hand them a free turbo or hell even a CHRA and never feel the loss.
86AmishMs3 (09-09-2012), Ezekiel81923 (09-06-2012), PapaSmurf (09-06-2012)
 Old 09-06-2012, 05:34 PM   #62
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
I have no restriction other than the ~0.090'' orifice in my banjo...
So far so good...
The Following 4 Users Say Thank You to cld12pk2go For This Useful Post:
86AmishMs3 (09-09-2012), atvfreek (09-06-2012), Chimmike (09-06-2012), Dano (09-06-2012)
 Old 09-06-2012, 05:39 PM   #63
crazyp's Avatar
Groans: 68
-4 size Oil inlet fitting for GT28/30/35R with built-in restrictor : atpturbo.com
Thats the restrictor I'm using, is that right or not?
I bought it last november an havent had any issues
 Old 09-06-2012, 05:48 PM   #64
PapaSmurf's Avatar
Running the same one on my 35r and havent had any issues. I beat the fuck out of my car also. lol
860whp/677wtq
2.7 V6 Ecoboost
crazyp (09-06-2012)
 Old 09-06-2012, 05:52 PM   #65
RayRay's Avatar
Posts: 3,120   (View Stats)
RayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the world
Groaned at 9 Times in 5 Posts
I have definitely had similar issues with my gtx. First time I had a metal burr left on the inside of my housing. This supposedly caused excessive heat. This caused the seals to go bad. From there I sent the turbo in and they rebuilt it.sent it back and I am having the same issues. My oil return line from them had a mountain range inside of it. They sent me a new one, 1 in shorter. (I let them know the one in their kit was too long). I am still having issues. Everything is pointing to the seals again. I am actually pulling the gtx this weekend and putting the stock k04 in. ATP had told me I will have first priority when I.. send it back to get looked at. We will see what they say but I have very little faith right now. I am hoping they will take care of it!
jracer likes this.
2009 MazdaSpeed 3
Spy Hunter Smoke Screen Mod
Cobb AP (Custom Tune), ATP GTX3076 28PSi, CP Forged Pistons .020 Over, Pauter Forged Rods, Bore and Hone Block .020 Over, CP-E DISI Injector Seals, ARP Head Studs, MZR Cometic Head Gasket, ACT Stage 2 Heavy Duty Clutch,Cobb SRI Intake, JBR TIG, JBR TB Gasket, JBR 88 Duro Transmission Mount, JBR EGR Delete , JBR TB Coolant Bypass, CP-E Big Turbo TIP, KMD HPFP Internals, Street Unit TurboSmart Dual Port BOV, CorkSport TMIC, CorkSport DP, CorkSport Test Pipe, CorkSport CBE, CPE Single Guage Pod, DashHawk, Prosport Boost Gauge, Devils Own Progressive Methanol Injection Kit 80/20 with D07 Nozzle, E85 Tune 50/50, JBR DogBone 88 Duro Rear Motor Mount, CorkSport Mid Chassis Brace, JBR Stage 2 Short Shift Plate, H&R Springs, 18x8 Drag DR38 +47, Eibach 5mm Spacers, 235/40 18 Brisgestone RE760.
RayRay is offline   Reply With Quote
The Following 9 Users Say Thank You to RayRay For This Useful Post:
802MS3 (09-06-2012), atvfreek (09-06-2012), Dano (09-06-2012), doubleflusher (09-07-2012), Easter Bunny (09-06-2012), PapaSmurf (09-06-2012), rfinkle2 (09-07-2012), SPEED6 KILLAH (09-06-2012), uncorked11 (09-08-2012)
 Old 09-06-2012, 05:57 PM   #66
Will fuck up ur day
Chimmike's Avatar
Groans: 433
yeah. I'm interested to hear what they say.
07 MS3
RayRay (09-06-2012)
 Old 09-06-2012, 06:07 PM   #67
POWERED BY POLSKA
themytb's Avatar
Posts: 762   (View Stats)
themytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the worldthemytb is the leader of the world
Groans: 38
I'm just a journal bearing bnr having little turbo guy lol, but don't the gt30's have some sort of restriction built into the oil inlet port of the chra? or is it really a gaping 1/4 inch or so hole for the oil to flow through?
If there is a built in restriction- would you not want to just go with something .005 to .01 smaller just to cut the flow a tiny bit?
Also a kinked drain line is on the installer, no extra parts will help that. And IF there was a blockage in the feed line thats some bad fucking luck man-shitty. do you still have the feed line or did you send it to them?
BNR S3---GS 3PORT---3bar map---COBB SRI & TIP---PG/GODSPEED FMIC ---DNP MANI--- CNT catted TBE--CP-E HPFP-- DIY P&P'd intake mani---SURE TIG(mani & tb)---DIY EGR delete---DIY VCTS delete--- DIY OCC/PCV reroute(through old egr port)---CP-E S2 RMM---JBR 80 PMM---TS BPV--- SURE ANCHORS---JBR shift weight---Whiteline RSB
25%E85FREEKPERMED
themytb is offline   Reply With Quote
 Old 09-06-2012, 06:11 PM   #68
Ezekiel81923's Avatar
Posts: 535   (View Stats)
Ezekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the world
Not to threadjack, but how old was the turbo? My CEA 5858 has a restrictor built in. Was he using an additional one that was smaller or did his not have a restrictor built in?
2011 VMR Mazdaspeed 3
Cp-e | Cobb | JBR | Freektune
Ezekiel81923 is offline   Reply With Quote
 Old 09-06-2012, 06:20 PM   #69
Trail of Fail
Dano's Avatar
new turbos as of 6 months ago.
 Old 09-06-2012, 06:41 PM   #70
Mizzle's Avatar
Groans: 324
I realize this wasn't my turbo, but seriously what the fuck caused the problem? Magic oil globs that only exist inside this line?
If ATP provided the lines and the lining came loose and clogged or pinched, then they're liable...
Again, this isn't my money, but I wouldn't pay for shit until someone showed me what the fuck happened and we'd be in small claims if not.
The Following 4 Users Say Thank You to Mizzle For This Useful Post:
Easter Bunny (09-06-2012), Erich (09-06-2012), rfinkle2 (09-07-2012), Tokay444 (09-06-2012)
 Old 09-06-2012, 06:56 PM   #71
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,719   (View Stats)
Groans: 70
We need more options!
The Following User Says Thank You to forcedinduktion For This Useful Post:
 Old 09-06-2012, 07:08 PM   #72
Trail of Fail
Dano's Avatar
we need a failed GT turbo thread...here lemee get one started.
Failed ATP/Garrett Turbo Thread
Easter Bunny (09-06-2012), RayRay (09-06-2012), silvapain (09-06-2012)
 Old 09-06-2012, 07:11 PM   #73
There are options. Not a lot of options, but enough that you can run almost any turbo you want if you're willing to put a little extra work into it
 Old 09-06-2012, 07:13 PM   #74
Trail of Fail
Dano's Avatar
if you are just getting started, ie. no DP, no EM, no turbo...make the move and go T3 and get away from the mazda flange and your options are almost limitless.
but alas a DP is an an early mod and one that is hard to eat.
 Old 09-06-2012, 08:06 PM   #75
Ziggo's Avatar
Posts: 3,843   (View Stats)
How would the filter have fixed this issue? I am thinking an inline filter would be more likely to starve the turbo than anything else. If whatever was stopping it up was bad enough to block the line it would have clogged the filter for sure.
Its bullshit that this is not covered.
Ask Me About My:
Chimmike (09-07-2012), Dano (09-06-2012)
 Old 09-06-2012, 08:48 PM   #76
rabble rabble
802MS3's Avatar
Posts: 5,318   (View Stats)
Groans: 221
first, bullshit that its not covered.
what banjo bolt were you running and what oil. no problems yet, with me.
I'm using their "low profile" banjo for GT BB turbos. figures their site is not working right now. Rotella T6. I'll post of a pic of my drain when I get a sec, photobucket isn't loading either.
'08 CWP MS3 w/ T3 3071r
 Old 09-06-2012, 09:05 PM   #77
aviator79's Avatar
Are there any failed non atp turbos, garretts that is
 Old 09-06-2012, 10:19 PM   #78
Trail of Fail
Dano's Avatar
Yes.
I think one of crazyps was a T3 flanged but had ATP oil feed
Info in db thread.
Tappin
 Old 09-06-2012, 10:34 PM   #79
SFWD 1934's Avatar
Posts: 973   (View Stats)
SFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the world
I can forward a couple guys I race with that work there to this thread. I obviously cannot promise or guarantee any change in the outcome, but maybe it will be of help with this situation and any future ones that may arise.
Jason
JRL Tuning 510-459-7229
www.full-race.com
SFWD 1934 is offline   Reply With Quote
The Following 13 Users Say Thank You to SFWD 1934 For This Useful Post:
ArcticSpeed3 (09-08-2012), Chimmike (09-07-2012), Don06speed6 (09-06-2012), Easter Bunny (09-07-2012), Erich (09-06-2012), helmetface (09-07-2012), Micha (09-07-2012), Mizzle (09-06-2012), silvapain (09-06-2012), SLOWHATCH (09-07-2012), triplejumper18 (09-06-2012), uncorked11 (09-08-2012), Vader (09-07-2012)
 Old 09-06-2012, 11:06 PM   #80
Ur moms boyfriend
Groans: 70
Well duh..anything can be done if you really want it. I am aware you can get a different flange. I was stating we need more option on Mazda flange. It is kind of a hassle and you will be at a loss if you already have a DP and/or ex mani to switch for a different flange.
LakeSpeed6 GTX3076 Build Lakespeed6 MazdaSpeed 3/6 - Big Turbo Builds 60 04-12-2013 08:09 AM
Realgib3 - GTX3076 - 400whp Realgib3 MazdaSpeed 3/6 - Dyno Sheets/Discussions 63 10-13-2011 02:57 PM
Finally let my balls drop! - GTX3076 Realgib3 MazdaSpeed 3/6 - Big Turbo Builds 109 10-04-2011 01:51 PM
Page generated in 0.64259 seconds with 40 queries
