Like Tree103Likes
 Old 09-06-2012, 11:50 PM   #81
The only way you can have a large piece float into the oil feed is that it either came from the line itself or was there prior to install or the motor is blown and it's a piece of motor.
Otherwise, the oil going into the turbo not only passes through the car's oil filter but it also passes through bearings. So that's a little odd to get large pieces at the feed.
On the restriction comment, I am surprised no one has mentioned pressure. Oil pressure and therefore flow at the oil feed from the motor should determine the requirements and size of the restrictor if one is needed at all. All a restrictor does is drop pressure across it and regulate flow into the turbo.
On the bottom side the turbo must freely be able to evacuate oil.
The symptoms of too much oil are usually smoke and oil consumption.
The symptoms of too little oil are fried bearings.
rfinkle2, kritz and Caligula like this.
The Following 12 Users Say Thank You to Lex For This Useful Post:
atvfreek (09-07-2012), Caligula (09-07-2012), Dano (09-07-2012), Easter Bunny (09-07-2012), easy (09-07-2012), helmetface (09-07-2012), kritz (09-07-2012), Nliiitend1 (09-10-2012), rfinkle2 (09-07-2012), SLOWHATCH (09-07-2012), speed14 (09-07-2012), Zbrit00x (09-07-2012)
 Old 09-06-2012, 11:53 PM   #82
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
My vote is that the oil line degraded, fell apart, fucked the turbo and ATP is playing stupid.
The Following 4 Users Say Thank You to Mizzle For This Useful Post:
Easter Bunny (09-07-2012), kritz (09-07-2012), rfinkle2 (09-07-2012), SLOWHATCH (09-07-2012)
 Old 09-06-2012, 11:56 PM   #83
Manny's Avatar
Posts: 1,185   (View Stats)
Groans: 320
@paulwalll
The Following 2 Users Say Thank You to Manny For This Useful Post:
rfinkle2 (09-07-2012), Rokusek (09-10-2012)
 Old 09-07-2012, 01:14 AM   #84
I agree 100%, but I don't know that anyone knows what the feed line pressure actually is on our car, although there are Garrett specific recommendations.
@chimmike, I realize this may not be part of your issue, although I do feel this is a question that needs to be addressed (restrictor, need for filter etc). Again, I would definitely help you and RayRay in any way possible. I'm down for whatever direction this thread goes. (boycott atp / small claims donation... whatever)
@Dano, understood that the history of the gt turbos is that they are reliable, but it seems that the gtx may have brought a new issue to the table based on recent events.
@Ziggo, @cld12pk2go @Lex ... does it make sense from an engineering standpoint that using the same CHRA in a GTX vs a GT may require different oil demands OR stress the bearings in a different way? I don't know enough about intertia or metalurgy to make an educated statement, but my gut makes me think that using the same chra on a compressor that spins faster / accelerates quicker would be under different demands bearing wise.
I'd let it go if it weren't for members like Bluestreak, Chimmike, RayRay etc suddenly having an issue.
^^^^****No offense to any members, but if guys with what are probably well maintained, well installed turbos are having issues, what chance do some of the other members have with either less mechanical skill or whom practice less frequent routine maintenance.
kritz, Rokusek and ASHMS3 like this.
The Following 9 Users Say Thank You to rfinkle2 For This Useful Post:
ASHMS3 (10-12-2012), atvfreek (09-07-2012), BlueStreak (09-07-2012), Easter Bunny (09-07-2012), exentix (09-07-2012), kritz (09-07-2012), Monotonous ONE (09-07-2012), Rokusek (09-10-2012), SLOWHATCH (09-07-2012)
 Old 09-07-2012, 05:31 AM   #85
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
That's the thing. I totally agree that I cannot explain how the 'debris' clogged the inlet. ATP's best explanation was that it could've been there since I installed the turbo and just wedged itself in at some point or another, who knows. Using Rotella this change, used Total before, and I use good oil filters.
I don't think an oil prefilter would harm flow enough to cause a starvation issue. I had a conversation with the guy at ATP on basically how I could prevent this from happening again, and he's like "I don't want you to feel like you have to go overboard with this, this was not a common failure, more like a one in a million deal", and I reiterated, then why won't garrett choke it and cover it? And he just repeated, the best they'll do is the core exchange.
07 MS3
The original Genpoo Hater
 Old 09-07-2012, 05:36 AM   #86
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
I know this has probably been brought up..
But I'm assuming they've cut open the line to find this so-called "clog"
Can you simply call up and ask for a picture of said clog?
 Old 09-07-2012, 05:38 AM   #87
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
Custom bent hard line?^
Nator is what it does.
The Following 2 Users Say Thank You to kritz For This Useful Post:
rfinkle2 (09-07-2012), trf5000 (09-08-2012)
 Old 09-07-2012, 05:54 AM   #88
Will fuck up ur day
Chimmike's Avatar
Groans: 433
I don't think you're understanding. The clog wasn't in the oil feed line. The oil feed line is still reliably bolted to my block. That thing has never been removed from the motor.
They're saying the clog is inside the oil feed in the turbo, that it's in some portion we can't see, and the way they know this is they plugged in an oil feed and no oil was able to pass through to the bearings.
07 MS3
helmetface (09-07-2012), rfinkle2 (09-07-2012)
 Old 09-07-2012, 05:56 AM   #89
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
I think the oil pressure and flow are high enough on that line to wash away any debris that may be in there and prevent any clog from building up. And if there was any clog/debris just after the install I think the turbo would have failed within the next few hundred miles.
Also, we're talking about oil restrictors and stuff to lower the oil flow while the blown bearings are a result of poor oiling.
Just think how damaging cooked/burnt oil can be for a turbo: guy comes home with a hot turbo, does not let the turbo cool down, oil cooks on the shaft and makes a solid film, guy starts car next cold morning and bam!, it smokes slightly already. Repeat the process a week in a row and you have a blown bearing and possibly seals on that turbo. While mike and others used these turbo's for a while before they let go.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
The Following 3 Users Say Thank You to mituc For This Useful Post:
Chimmike (09-07-2012), rfinkle2 (09-07-2012), Rokusek (09-10-2012)
 Old 09-07-2012, 06:02 AM   #90
helmetface's Avatar
Groans: 219
Thanks for clearing that up. Even more convenient for them.
I may have missed it, but did you push for proof?
 Old 09-07-2012, 06:03 AM   #91
Will fuck up ur day
Chimmike's Avatar
Groans: 433
funny thing was, there was NO SMOKE. None.
Anyways. If anyone feels like shooting me some help, my paypal is chimmike at hotmail dot com.
07 MS3
The Following 3 Users Say Thank You to Chimmike For This Useful Post:
irishking03 (09-07-2012), LittleredMPS (09-07-2012), rfinkle2 (09-07-2012)
 Old 09-07-2012, 06:30 AM   #92
irishking03's Avatar
Posts: 2,136   (View Stats)
irishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the worldirishking03 is the leader of the world
I maybe able to throw a donation.
DROID RAZR tapatalking2
2009 Metro Grey Numbers Fully Bolted.
Nator Pa Dyno Day: 311HP 328TQ Pump 93
Nator Pa Dyno Day: 310HP 329TQ Pump 93
End of Drive 9/24/2013
2012 Liquid Silver
Cobb AP
irishking03 is offline   Reply With Quote
The Following 3 Users Say Thank You to irishking03 For This Useful Post:
 Old 09-07-2012, 06:55 AM   #93
atvfreek's Avatar
Posts: 7,787   (View Stats)
Such B.S. and it certainly sounds like internal failure. Have you asked to escalate and speak to a manager? I know all this is time consuming, but seeing it's still in warranty, they don't have much to stand on.
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 5 Users Say Thank You to atvfreek For This Useful Post:
Easter Bunny (09-07-2012), helmetface (09-07-2012), MSFer87 (09-07-2012), NJSPEED3 (09-07-2012), rfinkle2 (09-07-2012)
 Old 09-07-2012, 07:05 AM   #94
greg08's Avatar
Posts: 480   (View Stats)
greg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond reputegreg08 has a reputation beyond repute
Groaned at 22 Times in 15 Posts
FUCK ATP BABY!
i like there downpipe though, just because there is no chance of them fucking me over
are they going to replace the turbo for you? its bs it went out on u.
Last edited by greg08; 09-07-2012 at 07:05 AM. Reason: MSF Database - Automerged Doublepost
greg08 is offline   Reply With Quote
 Old 09-07-2012, 07:18 AM   #95
atvfreek's Avatar
I believe they were also quick to tell @RayRay that his initial smoke issue was a PCV problem, then when they did further investigating, they found the bur in the turbo.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
The Following 3 Users Say Thank You to atvfreek For This Useful Post:
helmetface (09-07-2012), RayRay (09-07-2012), rfinkle2 (09-07-2012)
 Old 09-07-2012, 07:22 AM   #96
Will fuck up ur day
Chimmike's Avatar
Groans: 433
@greg08, no they're not replacing it for me.
07 MS3
 Old 09-07-2012, 07:38 AM   #97
@chimmike
ATP Turbo - Hayward, CA
ATP Business Review in Hayward, CA - San Francisco, Oakland, San Mateo, and Northern Coastal California BBB
Entity Name: ADVANCED TUNING PRODUCTS, INC.
Entity Number: C2516744
Date Filed: 06/02/2003
Status: ACTIVE
Jurisdiction: CALIFORNIA
Entity Address: 28988 HOPKINS ST
Entity City, State, Zip: HAYWARD CA 94545
Agent for Service of Process: QUI LE
Agent Address: 38851 HELEN WAY
Agent City, State, Zip: FREMONT CA 94536
Rokusek likes this.
 Old 09-07-2012, 07:52 AM   #98
Ezekiel81923's Avatar
Posts: 535   (View Stats)
Ezekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the worldEzekiel81923 is the leader of the world
Originally Posted by forcedinduktion View Post
Well duh..anything can be done if you really want it. I am aware you can get a different flange. I was stating we need more option on Mazda flange. It is kind of a hassle and you will be at a loss if you already have a DP and/or ex mani to switch for a different flange.
Well my point was just that if you're doing a BT build I think most are changing out the exhaust mani and swapping the flange gives you plenty of otions
If you're sticking with the stock flange, which is pretty restrictive but I digress, then yes you're kind of screwed. It'd be nice if someone like Precision or Turbonetics offered stock Mazda flanged hot sides so you could ditch Garrett altogether if you wanted to. Both are cheaper than Garrett turbo's and you don't give up anything from a performance standpoint.
2011 VMR Mazdaspeed 3
Cp-e | Cobb | JBR | Freektune
Ezekiel81923 is offline   Reply With Quote
The Following 2 Users Say Thank You to Ezekiel81923 For This Useful Post:
 Old 09-07-2012, 08:37 AM   #99
robry's Avatar
Posts: 862   (View Stats)
Groans: 27
Groaned at 9 Times in 7 Posts
mike, such a shitty thing to have to go through, "warranty" lol. anyhow, I threw you a few bucks to hopefully help easy the pain of paying the 750$ for the replacement. Curious to hear if anything further happens with ATP.
Chimmike likes this.
The Following 3 Users Say Thank You to robry For This Useful Post:
Chimmike (09-07-2012), RayRay (09-07-2012), rfinkle2 (09-07-2012)
 Old 09-07-2012, 09:36 AM   #100
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
My engineering SWAG is that the oil demands would be similar and the stresses in the same ballpark.
However, I certainly am not a turbo bearing guru by any stretch, and thus I could be off by a mile...
 Old 09-07-2012, 10:03 AM   #101
greg08's Avatar
dude i fuckin hate when companies dont cover warranty's on their products.
The Following 2 Users Say Thank You to greg08 For This Useful Post:
Chimmike (09-07-2012), Rokusek (09-10-2012)
 Old 09-07-2012, 10:13 AM   #102
You would need to know what the changes to the CHRA and bearings are. Oil passages on the inside of the CHRA make up the meat and potatoes of the situation and that determines what oil pressure and therefore flow you need through there. This should be covered in Garrett technical papers on the turbo and not by ATP.
So just so I'm understanding this correctly. Are all the failures from poor oiling or is there something else? Metal burrs are just assembly/manufacturing issues.
 Old 09-07-2012, 10:37 AM   #103
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
I'm pretty sure the CHRA is the same, it's only the blades that change. @jmhinkle should be putting his GTX3076 on soon and he will be running the same restrictor he was running on his normal GT3076 and the same one I run on my GT3582, neither of us have had problems.
Sent from my flying tapadildo
860whp/677wtq
2.7 V6 Ecoboost
 Old 09-07-2012, 10:50 AM   #104
Payne Racing 67's Avatar
Posts: 4,483   (View Stats)
Payne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the worldPayne Racing 67 is the leader of the world
Groaned at 64 Times in 49 Posts
Cool glad to know I have a ticking time bomb in my car @rfinkle2 since Im not having any problems YET, any suggestions? Im not running a restrictor. Simply the one line ATP provided and the other stock aluminum line. Maybe I should just abort my GTX and go with a custom set up?
Badsnake 2003 Cobra: Ported Eaton, 2.93 upper, 4lb lower, Steeda intake, fuel system, LF Heat Excg, MGW Shifter, MM Coilovers, Billet Flow IRS Brace, Magnaflow O/R X Pipe/CBE, Fiore Clutch Quadrant/Adjuster, MT ET Street Radials 515rwhp/525rwtq.
#HAR Hidden Agendas Racing
Payne Racing 67 is offline   Reply With Quote
 Old 09-07-2012, 11:01 AM   #105
Tabasco69's Avatar
Posts: 554   (View Stats)
Tabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the worldTabasco69 is the leader of the world
2 failures with properly maintained cars is suspect.
In any case, their kits are poop, imo..
And if poop, they should @ least stand behind them.
Technically it is not ATP's kit failing it is garrett's chra that failed, all atp does is slap their bolt on turbine housing onto it ....IDK I think it should be garret who eats the loss.
Most definitely not you.....what exactly could have caused the feed to plug?
FYI the gtx uses the same exact bearing/shaft set-up as the gt series, the billet wheel distinguishes the 2 apart, being the case every bb garret tc I have used required a restrictor, they need/use minimal oil...........but this failure doesn't sound like it has anything to do with having too much......more like not enough.
To the best of my knowledge the seals are exactly like a piston ring, they are designed to weep to relieve pressure beyond something like 40psi, but that doesn't mean they have failed, usually something like a pinched oil return line causes back pressure.
425whp/395ftlbs - GTX3071R .82a/r- 20psi- 92 octane pump fuel
Tabasco69 is offline   Reply With Quote
The Following 5 Users Say Thank You to Tabasco69 For This Useful Post:
802MS3 (09-07-2012), 86AmishMs3 (09-09-2012), Chimmike (09-07-2012), Easter Bunny (09-07-2012), rfinkle2 (09-07-2012)
 Old 09-07-2012, 11:06 AM   #106
I would stick with the set-up you have now, and just make sure that your return line has a straight shot to the block, i.e., no bends or kinks that are even the tiniest bit suspect.
Otherwise, there is no sense in worrying about it.
Easter Bunny (09-07-2012), Payne Racing 67 (09-07-2012)
 Old 09-07-2012, 11:29 AM   #107
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
holy shitstorm of conflicting information batman!
Garratt says use a restrictor..but only if you are under 40PSI
ATP says..do not use one.
some guys use them
some guys dont
has anyone actually measured oil pressure at the feed line in the upper RPMs?
edit: I see that Garrett wants pressure at least 40-45PSI if lower then the restrictor will increase said pressure in the CHRA.
This may be the same source @rfinkle2 quoted
Ball Bearing Turbo
"An oil restrictor is recommended for optimal performance with ball bearing turbochargers. Oil pressure of 40 - 45 psi at maximum engine speed is recommended to prevent damage to the turbocharger's internals. In order to achieve this pressure, a restrictor with a 0.040' orifice will normally suffice, but you should always verify the oil pressure entering the turbo after the restrictor in insure that the components are functioning properly. Recommended oil feed is -3AN or -4AN line or hose/tubing with a similar ID. As always, use an oil filter that meets or exceeds the OEM specifications. "
http://www.turbobygarrett.com/turbob...il_water_lines
Chimmike (09-07-2012), helmetface (09-07-2012), rfinkle2 (09-07-2012)
 Old 09-07-2012, 12:01 PM   #108
some guys use them
some guys dont
Oil & Water Lines | Turbobygarrett
I think there's a misunderstanding here. The restrictor in the feed will lower the pressure at the turbo since it causes a pressure drop. What they meant is that if you have above 40-45psi oil pressure coming from the block, use a restrictor. Not below.
Another note in here - if the oil feed is so large that pressure drops way low and the CHRA is not enough of a restriction, a restrictor may be needed since too much oil volume will pass through the turbo.
Oil pressure at the relief valve is probably around 70-80psi on our cars and its riding the relief at 3500 RPM and above. Someone check this in the manual. When oil passes through any passage some of that pressure drops, eventually dropping to zero as it return to the oil pan. The main bearings are fed first, then oil works its way up the block and into the head. I suspect the turbo feed to be between the main bearings and head.
I should add, more viscous oil increases pressure, and as the engine wears and bearings wear down/passages open up, pressure drops.
802MS3 (09-07-2012), Chimmike (09-07-2012), Dano (09-07-2012), helmetface (09-07-2012), mituc (09-07-2012), rfinkle2 (09-07-2012)
 Old 09-07-2012, 12:05 PM   #109
Trail of Fail
Dano's Avatar
O I C,
I guess I was thinking a restrictor would INCREASE pressure/lower volume...place finger over garden hose pressure goes up.
my head hurts....
 Old 09-07-2012, 12:11 PM   #110
Tabasco69's Avatar
WOT I had oil pressure in excess of 120psi, this is from a aem oil pressure gauge/sender, my tc oil feed is plumbed directly to the oil filter plate (non disi mzr), I absolutley have to run a restrictor.
you got to remember the whole premises behind oil pressure/volume has to do with hydro suspension of the older journal bearing which ride in a suspension of oil film, ball bearing only require a small amount of oil in comparison for general lubrication.
yeah restrictor decreases pressure, the hole is close to the diameter of a pencil lead
Dano and rfinkle2 like this.
The Following 2 Users Say Thank You to Tabasco69 For This Useful Post:
Dano (09-07-2012), rfinkle2 (09-07-2012)
 Old 09-07-2012, 12:26 PM   #111
865ms3's Avatar
Posts: 2,602   (View Stats)
@chimmike
this may be totally off topic and irrelevant but here goes.
ill start off by saying i think atp/garrett should be helping you out in this situation.
i work in the construction equipment industry. recently we had a machine that had a turbo go down. installed a new turbo and boom...turbo down again with an hour. we removed all the oil feed/drain lines and cleaned them. once again boom another turbo down. after days of scratching our heads we decided to investigate more. did a compression test. on this 3 cylinder engine cylinder #2 was WAYYYY down on compression. turns out blow by was causing the oil to get nasty and sludge up the feed line causing the turbo to fail.
not saying you have this problem, but if it was my money....id make 100% damn sure the turbo is getting sufficient oil.
do any of the gurus know if it is possible to get a reading on what pressure the oil pump is putting out? i know on our particular engine we where able to hook a gauge to the oil sending unit and see the oil pressure. but even in doing this....we did not realize the problem until it was too late. maybe there is a way to throw a pressure gauge on the feed line and check it. i didnt read ALL of the post, but did you pull the feed line and inspect it?
once again this may be un related....but figured i would throw this out to try to help. good luck with whatever you do.
Brent
-Built Block-5858-Meth
Dragon Slayer Setup
FreekTuned
jracer (09-08-2012), rfinkle2 (09-07-2012)
 Old 09-07-2012, 12:32 PM   #112
greg08's Avatar
yeas
u have so many JBR parts on ur gen pu 865 :p
Last edited by greg08; 09-07-2012 at 12:32 PM. Reason: MSF Database - Automerged Doublepost
 Old 09-07-2012, 12:34 PM   #113
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Oh, the motor is/was fine, as was the oil pump. If anything was wrong with the motor/oil supply, other shit would've failed too, or i'd have spun a bearing or something.
07 MS3
 Old 09-07-2012, 12:43 PM   #114
I should add to my comment regarding the oil pressure discussion. The oil pressure in the motor is regulated by the oil pressure relief valve at the pump.
The pump spins up and and starts flowing. At low engine speeds it can't flow enough volume to really increase pressure in the engine but at around 3000 RPM it should get to the maximum pressure allowed in the engine. At this point the relief valve is open and pressure is maintained in the system.
Everywhere the oil flows, it will drop pressure from what the pressure is held at by the oil pump relief valve. The head thus has less oil pressure than the bottom end.
The CHRA is a restriction to the flow of oil, so it will see X pressure at the top and basically zero pressure at the bottom. That X pressure at the top is maintained by the oil pressure relief valve at the oil pump and the many passages before the CHRA.
If the oil feed is very large and the oiling system is not designed for a turbo, the oil pump may not be able to flow enough to hit the oil pump PRV. This will starve the motor of oil and it's very bad news. So this is when a restrictor is needed and it's usually in cars where you T off another oil passage such as from the head.
If the oil pump can maintain X pressure at the CHRA, say 40psi and you add a flow restriction, then the oil pump relief valve will potentially bleed more oil since it now sees extra pressure in the system overall. So now the restrictor will see 40psi but the CHRA will see less.
Dano, you're right that putting your finger over a hose will create a higher pressure coming out, but it also increases the pressure upstream. If that upstream pressure is regulated, it will drop, and you will see less flow from the nozzle. The key here is that the overall system pressure is regulated.
The Following 10 Users Say Thank You to Lex For This Useful Post:
865ms3 (09-07-2012), anavrinIV (09-09-2012), atvfreek (09-07-2012), Chimmike (09-07-2012), Dano (09-07-2012), doubleflusher (09-07-2012), Ezekiel81923 (09-07-2012), mituc (09-07-2012), rfinkle2 (09-07-2012), Rokusek (09-10-2012)
 Old 09-07-2012, 12:59 PM   #115
You guys should all collaborate on a detailed paper, with pictures and everything else. I will publish it for you.
True, Garrett is the resp party of the CHRA.. However, you have an ATP modified turbo.. Therefore, they are ultimately responsible for the turbo as the reseller. ATP should be accepting these turbos back under warranty provisions and providing you a replacement. Its ATP's responsibility an an OEM distributor to deal with garrett on getting the warranty done.
None of this should be blown off. No one should be required to shell out another $750.. Its someones responsibility and thats ultimately Garrett.. I bet, if you collaborated with enough forums on the subject, you could easily get a class action lawsuit filed on Garrett.
Rokusek likes this.
The Following 5 Users Say Thank You to Haltech For This Useful Post:
atvfreek (09-07-2012), helmetface (09-07-2012), rfinkle2 (09-07-2012), Rokusek (09-10-2012), SpeedSixxx (09-07-2012)
 Old 09-07-2012, 01:11 PM   #116
Has anyone tried contacting Garrett directly?
If someone does get a hold of them, tell them one of their distributors (ATP) is jerking around a forum with members nearing 30,000 which has in the 100's of members with Garrett turbos.
(drop in the bucket for Garrett, yeah, but worth a try)
 Old 09-07-2012, 01:54 PM   #117
I would think a little more investigation is needed regarding the failure mode and what actually failed as well as the numbers of failures. Danos resource thread is a good start.
Then contact them and explain the situation and get some technical answers regarding the failure. Ie, are we doing something wrong or are the turbos bad?
 Old 09-07-2012, 04:25 PM   #118
SFWD 1934's Avatar
Posts: 973   (View Stats)
SFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the world
I forwarded the thread to one of my racing buddies that works for ATP. Hopefully it will help.
Jason
JRL Tuning 510-459-7229
www.full-race.com
SFWD 1934 is offline   Reply With Quote
The Following 6 Users Say Thank You to SFWD 1934 For This Useful Post:
atvfreek (09-07-2012), Chimmike (09-07-2012), forcedinduktion (09-07-2012), RayRay (09-07-2012), Rokusek (09-10-2012), SarcasticOne (09-08-2012)
 Old 09-07-2012, 04:31 PM   #119
Will fuck up ur day
Chimmike's Avatar
Groans: 433
Jason
Let me know what happens!
07 MS3
 Old 09-07-2012, 05:12 PM   #120
5000lbs of voiceless fury
Caligula's Avatar
Posts: 3,140   (View Stats)
Caligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the worldCaligula is the leader of the world
Groans: 185
Groaned at 124 Times in 81 Posts
In for win. Lets hope this gets sorted.
2015 Telsa Model S 85D - Delivered 10/21/2015 FYEN!
SOLD!!! 2007 Mazda MS6 - //AWD//BNR S3//cp-e TMIC//cp-e CDFP//Cobb AP//Cobb TIH//Cobb EBCS//Bosch 845 3 Bar//MS-CAI//Custom DP//TS Kompact BPV//Magnaflow CBE//AWR RMM//JBR Stage 3 SSP Kit//JBR EGR Delete//H&R Springs//
Caligula is offline   Reply With Quote
The Following User Says Thank You to Caligula For This Useful Post:
LakeSpeed6 GTX3076 Build Lakespeed6 MazdaSpeed 3/6 - Big Turbo Builds 60 04-12-2013 08:09 AM
Realgib3 - GTX3076 - 400whp Realgib3 MazdaSpeed 3/6 - Dyno Sheets/Discussions 63 10-13-2011 02:57 PM
Finally let my balls drop! - GTX3076 Realgib3 MazdaSpeed 3/6 - Big Turbo Builds 109 10-04-2011 01:51 PM
Page generated in 0.63756 seconds with 43 queries
