![]() Join Date: Aug 2013 Location: Grand Rapids, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3
![]() Join Date: Oct 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 39
| Not Ranked : 0 score Any air helping to cool your engine is a benefit. Not to mention it helps get cooler air to the intake as well.
__________________ 08 Speed 3 - BNR Stage 3, Cobb AP, CPE TMIC, Turbo XS DP, CNT CB, Cobb SRI, Cobb Turbo Inlet, Forge BPV, Autotech Internals, EGR Delete, and other stuff im sure I forgot to mention |
![]() Join Date: Feb 2011 Location: Aurora, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,094
Groans: 39
| Not Ranked : 0 score Good deed for the day: If you take it off, there is a port in the radiator support that can be opened (used for the regular 3 air ducting) that will allow air to flow to a SRI. Other than that, if you take it off, air flows around more redily then just on top of the motor, IMO.
__________________ 2008.5 Metropolitan Grey Mica: Sold 99 miata: sold 2011 Wicked White Evo X: built motor and efr7163 w/ full flex fuel TRex - "i dont care if it is a soccer mom in a mini van, if that whore launches on me im going at it like im racing a supra....just so i can bask in the sweet sweet tears of their defeat" |
Groans: 39
![]() Join Date: Jan 2013 Location: OC, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 633
| Not Ranked : 0 score Removed the ducting and the "directors" behind the grill to help give some more air to the radiator (Corksport sells some "directors" that help channel more to the radiator since the intercooler takes up most the air flow) and only kept the snorkel tube for the battery box. |
(Thread Starter) | Not Ranked : 0 score But the battery box tube isn't connected to anything now right? |
| Not Ranked : 0 score I think it has it's own "Christmas tree plugs" attached to it. Mines attached to the hood still, has some wiggle since it's not connected to the rest of the ducting but it's still attached. |
(Thread Starter) | Not Ranked : 0 score Sweet thx for the info. Ill be taking it off tonight |
| The Following User Says Thank You to Motocooney For This Useful Post: | He Hate Me (09-05-2013) |
![]() Join Date: Mar 2013 Location: Quebec
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 153
| Not Ranked : 0 score I think the best way is to drop the air flow behind/under the intercooler (Front/top). Less air pressure behind the FMIC = more air flow thru it remove air duct... |
