![]() Join Date: Mar 2010
Rep Power: 227 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
(Thread Starter) | Not Ranked : 0 score Has anyone done anything like this before? It sits almost exactly where the old airbox went but there's plenty of room for the hot pipe to go back to the turbo and the cold pipe lines up perfectly with the TB (well a few inches lower, but I'm sure I can get it to line up better). Anyone see any potential problems in doing this? I would have to move the drain cap to the upper part of that reservoir since it's sitting on the lower side right now, I'd also have to weld that hot side pipe straight up a good 6", and also weld on a BOV bracket onto the cold side. Personally I love this idea because it doesn't require hacking up ANYTHING, it doesn't sit on TOP of the dumb engine and it's a very short tube length!
__________________ 2006 Mazdaspeed6 | SNR S3 | Stratified Tune | Corksport DP | Corksport TP | Cobb AP | SU TMIC | HTP 3" intake | HTP battery tray | 3 bar MAP | HPFP | Whiteline rear sway bar | SU Rear engine mount | SU rear diff mount | Forge BPV Last edited by timjustindodd; 10-02-2013 at 03:27 PM. |
![]() Join Date: Dec 2009 Location: Minneapolis, MN
Rep Power: 390 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,607
| Not Ranked : 0 score If you made the pictures bigger I could maybe figure out what you are talking about...
__________________ 2006 BCM MS6 GT CS SRI/TIP Jbarone SSP/bushings cp-e RMM, TMIC, Stiff Diff AP KMD V2.whatever Ebay Catless DP Grom Ipod |
| The Following 2 Users Say Thank You to BigjohnB20 For This Useful Post: | breakfstincluded (10-02-2013), skiptowncat (10-02-2013) |
![]() Join Date: Jun 2012 Location: Wheaton, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 73
Groaned at 7 Times in 3 Posts
| Not Ranked : 0 score holy fucking pictures |
(Thread Starter) | Not Ranked : 0 score haha sorry is that better?
__________________ 2006 Mazdaspeed6 | SNR S3 | Stratified Tune | Corksport DP | Corksport TP | Cobb AP | SU TMIC | HTP 3" intake | HTP battery tray | 3 bar MAP | HPFP | Whiteline rear sway bar | SU Rear engine mount | SU rear diff mount | Forge BPV |
| Not Ranked : 0 score perfect is this meant to be a reservoir? or a IC relocation? |
(Thread Starter) | Not Ranked : 0 score That would be where the IC sits. That IS the actual IC (with a built in reservoir). So I guess, yes to both.
| Not Ranked : 0 score so the stock tmic mount would be bye bye? is there places to securely mount the IC setup? i imagine itd be pretty heavy |
| Daily Driver ![]() ![]() Join Date: Dec 2008 Location: Tampa, Fl
Rep Power: 880 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 576
| Not Ranked : 0 score I already beat you to that location a few months ago ill try to get pics later, i got my core veritcal feeding directly into throttle body and the other port just above it with a very very short pipe going directly to turbo, my intercooler pipes are only like 18 inches total |
![]() Join Date: Oct 2012 Location: Colorado Springs, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 757
| Not Ranked : 0 score Location isn't bad, but I would place it higher and as close to inline (between turbo outlet and coldpipe/throttle in) and as high as possible, over the engine or above your intake (might even put the filter below the exchanger). If you are seriously considering AWIC, keep the following in mind; how much water will you have in this system? too much and your carrying a lot of unneeded weight on the nose of your car, too little and you will have issues with heat soak, once water gets hot the same thing that makes it great will make it suck, you will have more thermal energy stored to displace; how big will your radiator be (or are you planning on using the engine cooling system for this?) AWIC is great for situations where you would use a LARGE FMIC but want short boost plumbing (better throttle, less potential air leaks) it is also great at avoiding heat soak, most of your thermal mass/water is in the plumbing and radiator; or drag racing where you want to chill the water with ice or dry ice between runs. With this location you will want the radiator and pump to be below the fill cap and that might create other technical problems to solve. I have a AWIC on a supercharged VW rabbit, I used a PWR exchanger (essentially a fat boost tube). and re-tasked the AC condenser for water; it works well and was a great solution to a space problem as I used nearly all open frontal area on a large aluminum radiator using the AC condenser allowed me to use a 'stock' solution for a secondary radiator.
__________________ mods: \\// AT HPFP // AccessPort // CS S2 TIP, SRI and TMIC // CPe S2 RMM // Synapse BPV // Mazda gutted secondary cat // S-OTS+ 91S2 // HKS TP DLi II // Wilwood DP6 13” brakes // TCE 2 piece rear rotors // Maxwell SuperCap/LiFePO4 cell \\// waiting for install: \\// CPE Catted DP // CS Battery Box // Devils Own Meth kit // H&R Coilovers \\// |
![]() Join Date: Sep 2012 Location: Elizabeth, NJ
Rep Power: 3180 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,265
Groans: 665
| Not Ranked : 0 score Where is your heat exchanger mounted? |
So... The main thing here is I want a good streetable car, and I occasionally drag race. I've thought about a FMIC but quite frankly a WTA is much more thermally effecient. I plan to put as big of a radiator in front of the car's radiator as I can fit with out being higher than where the reservoir cap sits. I'm not too worried about the additional weight of water in a car that weighs 3600 pounds and that I mostly drive on the streets. A passenger will change that weight in a second anyway. I also have a smaller battery which is a good 8 pounds off right there... so I'm honestly not too concerned about weight. Not one of my priorities. I've looked into the boost tubes and stuff but I don't want the exchanger to sit on top of the engine at all.. I want it to be away from the engine. I'm sick of heat soak and want the system to be removed from the engine/turbo heat as much as possible. This seems like a valid solution.
__________________ 2006 Mazdaspeed6 | SNR S3 | Stratified Tune | Corksport DP | Corksport TP | Cobb AP | SU TMIC | HTP 3" intake | HTP battery tray | 3 bar MAP | HPFP | Whiteline rear sway bar | SU Rear engine mount | SU rear diff mount | Forge BPV | |
Groans: 665
| Not Ranked : 0 score Don't know if you've seen this thread but it shows some good setups / ideas: LTA Intercooler Concept Thread The key to these systems is HE efficiency and pumping. |
| The Following User Says Thank You to Agent_Orange For This Useful Post: | chuckms6 (11-17-2013) |
![]() Join Date: Jul 2010 Location: Philadelphia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,201
| Not Ranked : 0 score Fill the intercooler with crushed dryice and 91% isopropyl alcohol. Then enjoy freezing cold BAT. Make sure to put a hose that vents the gas away from the intake.
__________________ 2010 Mica Black RMM/RSB/SRI+TIP |
Groans: 793
| Not Ranked : 0 score I've been curious lately about filling an lta system with methanol.
__________________ ![]() Inb4 85% silicone core. It's better than aluminum. What's you buddy's ex wife trap? I <3 SP63, but that port job though... "The coolant must be evaporating." Bye Felicia "Exclusivity" - CP-enis Demodded. The Seals |
![]() Join Date: Jun 2008 Location: Harrison, AR Heart of the Ozarks
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32,768
| Not Ranked : 0 score Prolly not a good idea unless you have a really really large fire extinguisher.
__________________ "I only do what the voices in my wife’s head tell her to tell me to do" |
![]() Join Date: Nov 2010 Location: Lido Beach,NY
Rep Power: 8624 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 17,845
Groans: 95
| Not Ranked : 0 score Nitromethane would be better Brock. But ammonia might be a better heat transfer liquid. Sent from fastest Ko4 Pu.
__________________ Nator is what it does. |
| The Following User Says Thank You to kritz For This Useful Post: | Tokay444 (11-17-2013) |
Groans: 665
Water beats out methanol (and many others) in terms of thermal conductivity, specific heat capacity, and thermal conductance. The best way to improve an LTA system is heat exchanger efficiency and capacity. | |
Groans: 95
| Not Ranked : 0 score Lol I was being silly sarcastic, deionized would do the trick. @Agent_Orange; Sent from fastest Ko4 Pu.
| The Following User Says Thank You to kritz For This Useful Post: | Agent_Orange (11-17-2013) |
Groans: 665
| Not Ranked : 0 score |
| The Following User Says Thank You to Agent_Orange For This Useful Post: | kritz (11-17-2013) |
![]() Join Date: Jun 2011 Location: australia
Rep Power: 1125 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,310
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score Could always just point the fire extinguisher at the intercooler :p Sent from my Nexus 5 using Tapatalk
__________________ OLD: GT3071 IWG | Autotech HPFP | Cobb AP | tune | Catted DP |HDi FMIC | CPE 4" TIP + 3.25" MAF | Grimmspeed EBCS | RX8 S2 Rims | JBR 80a Trilogy | Forge V2 BPVNEW: HTP full 3" | catted DP | Autotech HPFP | COBB AP |
| The Following User Says Thank You to SarcasticOne For This Useful Post: | kritz (11-17-2013) |
Groans: 95
| Not Ranked : 0 score Hey liquid nitrogen would work right? @Agent_Orange; (sarcasm button depressed) Sent from fastest Ko4 Pu.
![]() ![]() Join Date: Jul 2008 Location: Old Bridge NJ
Rep Power: 22834 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 31,276
Groans: 309
| Not Ranked : 0 score Um....move north, far north?
__________________ Dash08: I don't see the whole pedophile thing, But Predapio is a dirty old bastard. So, I wouldn't rule it out entirely. That's also why he fits in here. We're all a bunch of filthy, perverted, arrogant, pessimistic, self-righteous assholes who find entertainment at other peoples expense. What a lovable bunch we are!! |
| Any idea what this could be? Please Help. | mike w | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 5 | 06-03-2013 03:15 PM |
| Any idea what this is? | HIhello | MazdaSpeed 3/6 - Suspension & Brakes | 3 | 05-18-2013 11:33 AM |
| A 458 Italia-powered Fiat 500 is not a good idea, it's the best idea | Haltech | Automotive News | 0 | 06-22-2012 12:10 PM |
| Just an idea... | Fagwagon | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 12 | 11-13-2009 05:11 PM |
