 Old 03-13-2008, 09:18 AM   #41
Laloosh's Avatar
Posts: 5,166   (View Stats)
Laloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the worldLaloosh is the leader of the world
Groans: 57
Either way, blowing 5k and trapping 6 mph higher....makes you wonder whats the point.
Laloosh is offline   Reply With Quote
 Old 03-13-2008, 09:36 AM   #42
mrlilguy157's Avatar
Posts: 606   (View Stats)
mrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the world
quick update kids:
i gotta get the vac. line on the wastegate, which means i have to get under the car, because I can squeeze my hands back to it, due to coolant lines running right next to it. Look for an update this afternoon. I know I'm lame.
Its fixing car time, then nice alone time at the car wash.
ps - hott date was fun - but im nixxing her.
Black Mica '07 Mazdaspeed3
Mods:CP-E FMIC - ProtegeGarage Tubular Exhaust Manifold - TurboXS Hybrid BOV, Downpipe, and Custom Catted Racepipe - mrlilguyCDFP - ATP 3" Turbo Inlet - ATP Boost Cut Killer Module - CP-E Rear MM - WelderWerkz Short Shifter - AEM UEGO Wideband - ProSport Blue Boost/EGT/Oil Pressure Gauges - GReddy Full Auto Turbo Timer - PimpWheels Black/Red Edition - Falken Azenis RT-615 - Yakima Roof Rack w/ Fairing
Reppin' ProtegeGarage for life!
mrlilguy157 is offline   Reply With Quote
 Old 03-13-2008, 11:43 AM   #43
clos561's Avatar
Posts: 1,172   (View Stats)
clos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the worldclos561 is the leader of the world
post up some videos or something
7-Inch Jensen Flip Out Touch Screen, HKS SSQ, MS CAI, Prosport Premium Amber/White Boost Gauge,2nd Cat Gutted, Delrin TRZ MM,16 inch FD rims,TWM shifter Bushings,COBB Turbo Inlet, 28psi, rebuilt stock block, custom rods and piston heads/gaskets, underdrive pulleys, big cams, big oil filter, stage4 clutch, stage4 DISI injectors, Fuel Pump, 4inch Catless TBE with screamer pipe, external wastegate spring modification,Methanol direct twin port duty cycle injection. Tuned by Nator Performance
clos561 is offline   Reply With Quote
 Old 03-13-2008, 07:21 PM   #44
TRU-BOOST's Avatar
Posts: 801   (View Stats)
TRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the world
wait a min..... back to the 3" MAF again....
wouldnt a 3" MAF lean the car out more ?? by increasing the ID of the MAF housing you are giving the air more room to travel through and slowing it down as it crosses the sensor. the slower the air goes, the less fuel you will get.
TRU-BOOST is offline   Reply With Quote
 Old 03-13-2008, 07:23 PM   #45
phailerider's Avatar
Posts: 4,639   (View Stats)
agreed... but I just got off the phone with Jon... car is now boosting 15psi. hes scared. and a/fs are in the 10/s-11/s.
I think hes got a 3inch maf... idont get it either.
 Old 03-13-2008, 07:27 PM   #46
i do have a 3" maf, its part of a txs unit, not cut. I bought it from 'craighjr'. it is NOT 3" I.D.
Its dark out now, but I'll be in the car driving tomorrow for a good 3-4 hours. I'll film videos on the way home for sure. I'm sorry guys. I've been swamped this week and honestly, I'm exhausted from the install. Its great to see the car running and it feels amazing, but I'm so sore, and I've had less sleep this past week than I have in the past 6 months.
I'll snap some pictures late tonight. I know I don't have anything proving the turbo is on, but it is. I promise
The Following User Says Thank You to mrlilguy157 For This Useful Post:
Laloosh (03-14-2008)
 Old 03-13-2008, 07:29 PM   #47
If the MAF is properly designed, the car will NOT lean out because your inlet diameter has increased. Remember, as long as the sample tube within the MAF is properly calibrated to the inside diameter of the larger pipe, lean conditions will NOT exist.
If Jon is seeing 10-11's with 15psi, i would say it is working just as it was designed.
 Old 03-13-2008, 07:59 PM   #48
driver311's Avatar
Posts: 1,769   (View Stats)
I have a turbo xs intake on the way. Ill post my results of 3inch vs. 2.6inch.
Mazdaspeed
The Following User Says Thank You to driver311 For This Useful Post:
 Old 03-14-2008, 04:05 AM   #49
Laloosh's Avatar
Groans: 57
all i know that the cs 3 in maf housing runs like shit....the inner diameter of it is 2.8x i think
 Old 03-14-2008, 04:11 AM   #50
Even a cunt hair, aka, 1 micron, can throw a sensor off. It may be that CS didnt make the sample tube long enough to compensate for the diameter of the pipe they used, OR the actual housing the meter sits in, needs cnc machining.
 Old 03-14-2008, 04:13 AM   #51
Laloosh's Avatar
Groans: 57
well i doubt my silicone coupler glued in there there and edged with a knife is any smoother but the car runs great. Maybe i just got lucky but my cruising long term fuel trims are now at 3.9 lol.
 Old 03-14-2008, 04:27 AM   #52
Well thats better than what they were before.
 Old 03-14-2008, 06:04 AM   #53
Boostedfamily's Avatar
Posts: 278   (View Stats)
Boostedfamily is the leader of the worldBoostedfamily is the leader of the worldBoostedfamily is the leader of the worldBoostedfamily is the leader of the worldBoostedfamily is the leader of the worldBoostedfamily is the leader of the worldBoostedfamily is the leader of the worldBoostedfamily is the leader of the worldBoostedfamily is the leader of the worldBoostedfamily is the leader of the worldBoostedfamily is the leader of the world
I have so much trouble staying ahead of this forum in Korea but I love it. I want to say good luck and keep up the work cause my SRT has been out of production for almosr 5 years and it is still the king of the heep. I love my wifes Speed3 but it will take some time to catch up.
Boostedfamily is offline   Reply With Quote
 Old 03-14-2008, 06:12 AM   #54
Well keep in mind that Dodge knew the car would be a hit, thats why they made it easy to tap the ecu for tuning and released warrantied stage kits. It was just a matter of time. Before they released the CSRT, they contacted the aftermarket, gave them cars before they were being sold just to get the parts ready.
Mazda, being in bed with Ford, its not a surprise to see them lock this car down. Company's like Diablosport who do chips have a very hard time coming to market releasing tunes for Fords, unlike SCT who have a lot of friends at ford directly and get the rom's handed to them for $10K by the insiders.
Just give it time. Mazda will be releasing the Mazdaspeed Miata with the same engine, which should pull more interest into the DISI market.
 Old 03-14-2008, 06:59 AM   #55
Ok, so I dont want to be a troube maker cause I want to hepl out but, the PCM on the SRT-4 was cracked less then a year ago. Piggy back are not the way that has been proven so lets see if SCT or some other company gets tunes out there soon. With out tunes there will be no BIG mile stones.
 Old 03-14-2008, 10:20 AM   #56
Laloosh's Avatar
Groans: 57
link to vertify the 2.3 miata cause i smell trade in
 Old 03-14-2008, 10:55 AM   #57
No link, i heard it from the regional mazda vp yesterday when i was looking for information on a CX9.
Im looking to get an Audi Q7 for an additonal ride. Im not to impressed with the CX's for the money they want. By the time you option them out, youre in the german territory.
Besides, a Miata is a queer's car, even though its RWD, we will make fun of you!
whoosh@Realtune (03-14-2008)
 Old 03-14-2008, 11:03 AM   #58
Laloosh's Avatar
Groans: 57
im a autox whore at heart...corky romano style baby
 Old 03-14-2008, 11:06 AM   #59
Ill make sure Neo gets me a Disneyland hat to mail to you, pink at that.. He had a Disney event today. It will go perfect with your shiny, baby blue mazdaspeed miata!
AutoX or not, its not you bro! I cant let you do it!
 Old 03-14-2008, 11:12 AM   #60
whoosh@Realtune's Avatar
Posts: 1,459   (View Stats)
whoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the worldwhoosh@Realtune is the leader of the world
Groaned at 39 Times in 23 Posts
thank goodness you said it
I wanted to but starting shit with Laloosh is like standing up to the bully at school
I want to keep my lunch money bitches
Miata =
whoosh@Realtune is offline   Reply With Quote
 Old 03-14-2008, 11:12 AM   #61
Laloosh's Avatar
Groans: 57
First off i have to make sure that i fit, but if i do...hate to bust your bubble but i will most likly swing it depending ont how the aftermarket goes
What sounds gayer to you...260hp fwd 5 door wagon
or a 260 hp rwd 2 seater......hmmmm
 Old 03-14-2008, 11:50 AM   #62
Dude, hatches are cool... Convertible, 2 door Miata's are for mid life crisis peeps and queerbates!
Pink Disneyland hat FTW!
DISI or not, its still a Miata and wont look cool at all.
 Old 03-14-2008, 11:54 AM   #63
Laloosh's Avatar
Groans: 57
sigh go watch american idol with a box of tissues
 Old 03-14-2008, 11:55 AM   #64
when I bought the Odessey for my wife there was a marked down s2000 in the showroom. I went to sit in it and I couldnt even get in with the damn roof down.
The top of the windshield was eyelevel(im 6'6"). The Miatas are even worse.
Those cars are only for little people.
Now you guys are saying that the queers and the gays and the nancypancys...oh my. Not for me...lol
 Old 03-14-2008, 11:59 AM   #65
Laloosh's Avatar
Groans: 57
im 6'5ish so i guess there goes that
 Old 03-14-2008, 12:05 PM   #66
i think a miata/s2000 would be fun as hell to build and race... but I was actually STUNNED to discover how small they were. It wasnt even close.
Put it out of head. Actually dont... go sit in one. You'll crack up.
 Old 03-14-2008, 12:25 PM   #67
winniep's Avatar
Posts: 333   (View Stats)
winniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the worldwinniep is the leader of the world
A friend of mine actually let me drive his S2000 for a day. I let him drive my SRT-4. In the end, when we traded back we both loathed the Honda and loved the Dodge. I am 5'11" and the S2000 was still barely manageable as far as my size vs comfort. I have also driven a Miata around the dealership and they are even smaller. Like Pontiac Solstice small (which is like stuffing yourself into a go-cart with a shell around it). I would have to agree with the statement that the Miata (or any convertible roadster type with a 4 banger) is gay as hell. DON'T DO IT!!!!! If you were to trade this car for anything, at least make the trade worthwhile. The new STIs are sure starting to look good.........
winniep is offline   Reply With Quote
 Old 03-14-2008, 12:37 PM   #68
shucky's Avatar
Posts: 198   (View Stats)
shucky is a name known to allshucky is a name known to allshucky is a name known to allshucky is a name known to allshucky is a name known to allshucky is a name known to all
Groaned at 9 Times in 7 Posts
Yep bitches, little 4 banger Miata's are gay ... but isn't that part of the big fun when you mob past 'bigger' bitches in their Mustangs, Vettes, Evo's, WRX's, etc ?? It sure as hell was for me!! I laughed my ass off every time I ran someone and they got ass raped by a "Miata" ...bitches used to actually get mad at me because they got dusted by a Miata. I sold it a few years back, regret it and miss it ... '93 1.6 bone stock block w/custom Bell Eng. system 4 turbo, HKS Super Dragger, racer intercooler, Hahn Racecraft custom fuel system (4 addt'l inj), etc, etc ... drag radials + 110 octane = huge fun in 2100 lb car. Gay or not, it was one of my favorite cars to drive/drag...
I had no shame to drive a girls car outfitted like this! Bitches ... ha ha ha
shucky is offline   Reply With Quote
 Old 03-14-2008, 12:45 PM   #69
So what did the little bitch run in the 1/4 than being that light?
 Old 03-14-2008, 12:51 PM   #70
shucky's Avatar
13.2 @ 105 on drag radials, not a rocket ship, but being such a small car the sensation of speed and torque was pretty incredible. Plus 4-5 years ago, cars out of the box were a bit slower than today.
 Old 03-14-2008, 12:55 PM   #71
Theres a guy who shows up to my local strip religiously, each week with a shit tan colored dodge omni turbo.. it runs 11.7's all day long.
 Old 03-14-2008, 01:01 PM   #72
shucky's Avatar
I believe it, there is a hillbilly in S.Wisconsin that transplanted the turbo Omni motor into a shit bag Dodge Caravan with wooden side trim that runs low 12's high 11's. I mean this thing looks like a total barn find shit box but it goes like hell. He runs it a Union Grove, WI from time to time.
 Old 03-14-2008, 01:03 PM   #73
yup24z's Avatar
Posts: 56   (View Stats)
yup24z is a jewel in the roughyup24z is a jewel in the roughyup24z is a jewel in the roughyup24z is a jewel in the rough
Man....we got some big dudes that drive these things....good to know I'm not the only one who looks doofy getting in/out of my car.
6'6 260lbs
2008 Black Mica MS3--Corksport DP, Turbo XS Racepipe, Custom 3inch Catback, Cobb SRI, Turbosmart Mbc @ 18psi, ATP BCD, Prosport Boost Gauge, Dashhawk, 6000k HID's, 5% tint
Stock Dyno: 227hp/241tq
Dyno w/ Cobb SRI/Corksport DP/TXS RP/MBC @ 18psi- 279hp/315tq
yup24z is offline   Reply With Quote
 Old 03-14-2008, 03:41 PM   #74
digitaljedi's Avatar
Posts: 1,222   (View Stats)
digitaljedi is the leader of the worlddigitaljedi is the leader of the worlddigitaljedi is the leader of the worlddigitaljedi is the leader of the worlddigitaljedi is the leader of the worlddigitaljedi is the leader of the worlddigitaljedi is the leader of the worlddigitaljedi is the leader of the worlddigitaljedi is the leader of the worlddigitaljedi is the leader of the worlddigitaljedi is the leader of the world
Groaned at 51 Times in 34 Posts
Anyone that thinks small roadsters are gay must have insecurities about their own sexuality. It's actually the purest way to drive and the most fun you will ever have in four wheels. Ever heard of Lotus? I would hardly call the old Elan's gay, and the Elise is far from gay. Sorry to get all serious, but I hate when people call miatas gay.
(but they do look pretty fruity, lol).
2008 speed3- FOR SALE!!!!!!!!!!!!!!!!!! SEE HERE!
http://www.mazdaspeedforum.org/forum/forum/f665/2008-speed-3-sale-177096/
2000 Honda S2000(track car)
digitaljedi is offline   Reply With Quote
 Old 03-14-2008, 03:56 PM   #75
alot of you guys know me, and know i'm not one to lie or disguise the truth. i have no reason to. this is the internet, i don't even REALLY KNOW half of you guys, although I consider 3 or 4 of you guys close friends.
anywho.... i was driving back to dallas today from stillwater, its spring break (woohoo!!!!). I've been staying out of boost and letting the car do its adaptation (maybe its in my head?). I had 2 CEL's this morning, 1 for system lean at idle, some leak somewhere, very minor because my wideband shows 14.6-14.8 at idle - and another for no catylitic converter. no biggy. i went to autozone and got those scanned and cleared, and hit the road. About 150miles later..,...
just south of norman, ok - i downshifted to what I thought was 4th, from 6th, at about 65-70mph, just cruising. I don't want to PUSH the car too much until I am extremely comfy and all CEL's and quirks are non existant. Unfortunately, I believe I was in 2nd gear instead of 4th. (dumbass). Before I could truly react, I wrapped up almost instanenously to 5k and 6k, whcih is the highest I saw the tach go. POP. I coasted into the left grass shoulder and popped the hood, after turning off the car. I looked around, nothing seemed out of the ordinary. No oil or coolant tracks through the grass from the highway, nor was there fluids collecting under the car whatsoever. I have a bit of coolant, less than maybe 1/2 a cup, dispersed at the bottom of the front of the plastic undertray below the motor. Its actually near the front near the radiator, as shown in the pictures.
To be honest, I flipped. I have an oil light on, as well as coolant IIRC, and of course a CEL. Oddly enough, for experimentation, I attempted to start the car, and did. The car would not rev at all, but it would idle just fine, and wideband was reading proper a/f. After many discussions with Randy, JohnDavid (best friend from home) and William (another great friend from home) - I have decided to conclude that I blew the transmission. I don't have the keys to my car right now, I'm actually sitting in the dealership lounge area, so I can't check for which lights are on, nor can I scan codes... (I DONT HAVE BUT AM BUYING A DASHHAWK TODAY), so I don't know what all lights are on nor do I have conclusive evidence of exactly what went wrong, nor the side effects.
I was driving completely out of boost at the time, AFR was spot on, and EGT's were about 1200degrees. After long thought, not seeing the tach show past 7k, I think i may have blown the transmission. My buddy william is convinced at 98% that thats what happened. JohnDavid's good friend from high school blew a cobra transmission shifting from 4th to 1st, not 3rd, and nothing else.
I don't know what to say. I'm really in shock at the moment, and know that this was directly related between my hand and the shifter, furthermore to the transmission, not the big turbo upgrade. I was in shock today, and explained all the new mods to mom and pap - but assured them that under the circumstances, the new turbo and exhaust have nothing to do with the turbo upgrade. They are driving up as we speak to pick me up from the dealership. I think I may bring up the extra motor, trans and head tomorrow to the dealership and set in the corner in case they need them - I'll be out of town all throughout this next week.
In all honesty, the turbo wasn't the cause of this. I was out of boost, and I've been getting on the car underboost for 3 straight days, probably over 15 2nd-4th/5th pulls.
I'll update the thread when i have more information. Here are some pictures for you guys.... start the discussion. If you wanna call me an idiot for misshifting, go ahead, that is the only thing that happened, and I know it sucks. My debate within myself is.... "Did I blow the motor and smack a piston to the head?" or "Did I blow up 2nd gear in the transmission?" or, "Did I do both?"
Either way, I thankfully have all necessary replacement parts for everything, so the cost will stay somewhat low. The dealer is going to take care of all of the labor, and I'm providing all of the parts, very very cool. I may go ahead, since everything will be separated, order a clutch and get the dealer to put that in as well - if its just the trans. Decisions decisions.
Once again, here is pics, start the discussion. There can be no 'I told you so's' until I know exactly what is wrong with the ride....
KusteLokal (02-13-2013)
 Old 03-14-2008, 04:05 PM   #76
ms3guy22's Avatar
Posts: 530   (View Stats)
ms3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond reputems3guy22 has a reputation beyond repute
i've got the txs sri, here is my a/f with a complete bolt on fmic,sri, tbe, standback unit.
ms3guy22 is offline   Reply With Quote
 Old 03-14-2008, 04:12 PM   #77
Derek88's Avatar
Posts: 773   (View Stats)
Derek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the worldDerek88 is the leader of the world
This sucks. Good luck with it all.
-Derek
No longer in the Mazdaspeed Family
Derek88 is offline   Reply With Quote
 Old 03-14-2008, 04:24 PM   #78
After all our discussion, Im convinced more than ever, it has something to do....
with the weight of the stock wheels. They simply are to heavy for this setup.
The Following User Says Thank You to phailerider For This Useful Post:
Derek88 (03-14-2008)
 Old 03-14-2008, 04:39 PM   #79
driver311's Avatar
Ive done the same thing bro. Back iin 95 i went from full redline 3rd gear to 2nd. Boom, tranny, motor, starter, all of it. 3200 later.
Mazdaspeed
 Old 03-14-2008, 04:48 PM   #80
thanks for the support. Updates monday evening after they look at the car.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/big-turbo-anyone-3071r-installed-175/
YouTube - 2007 ms3 built and big turbo drive This thread Refback 08-15-2008 08:36 PM
Mazda Speed Forums: Mazdaspeed High Performance Forum with Gallery, Specs, discussion & more This thread Refback 03-27-2008 07:39 PM
PTP race mount installed Death-From-A-Mile MazdaSpeed 3 - Engine, Transmission & Driveline 22 01-08-2011 05:36 PM
GT35R turbo installed whoosh@Realtune MazdaSpeed 3/6 - Turbo Induction 45 04-30-2008 08:45 AM
Installed the Turbo xs DP and let it smoke! speed3 MazdaSpeed 3/6 - Turbo Induction 38 04-15-2008 06:20 PM
PG Manifold installed SLS MS3 MazdaSpeed 3 - Engine, Transmission & Driveline 25 04-04-2008 12:53 PM
Page generated in 0.58901 seconds with 35 queries
