Like Tree22Likes
 Old 10-11-2012, 08:25 PM   #41
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
Originally Posted by MATT DAMOND View Post
I'm hoping to hit 20psi at or before 3k, with a GTX3071 EWG. T3 SS mani, and higher compression should help.
What CR?
In for "a van just pulled me"
MATT DAMOND (10-12-2012)
 Old 10-11-2012, 11:14 PM   #42
RayRay's Avatar
Posts: 3,120   (View Stats)
RayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the world
Groaned at 9 Times in 5 Posts
Hard for me to really say what boost I hit at low RPM. I very rarely roll out under 4k. But I am full boost by 4300. Hitting 25 and holding 24 to RL... But let me clarify. I almost Never go WOT under 4k, and if I do, I'm brake boosting! Lower gear and higher RPM = Less wheel spin!!!
But for the sake of this thread, I will go out and try and log a 4th gear pull from 3k this weekend!!
MS3
GTX3076
25psi 4300rpm
IWG
Stock Mani
Downmented likes this.
2009 MazdaSpeed 3
Spy Hunter Smoke Screen Mod
Cobb AP (Custom Tune), ATP GTX3076 28PSi, CP Forged Pistons .020 Over, Pauter Forged Rods, Bore and Hone Block .020 Over, CP-E DISI Injector Seals, ARP Head Studs, MZR Cometic Head Gasket, ACT Stage 2 Heavy Duty Clutch,Cobb SRI Intake, JBR TIG, JBR TB Gasket, JBR 88 Duro Transmission Mount, JBR EGR Delete , JBR TB Coolant Bypass, CP-E Big Turbo TIP, KMD HPFP Internals, Street Unit TurboSmart Dual Port BOV, CorkSport TMIC, CorkSport DP, CorkSport Test Pipe, CorkSport CBE, CPE Single Guage Pod, DashHawk, Prosport Boost Gauge, Devils Own Progressive Methanol Injection Kit 80/20 with D07 Nozzle, E85 Tune 50/50, JBR DogBone 88 Duro Rear Motor Mount, CorkSport Mid Chassis Brace, JBR Stage 2 Short Shift Plate, H&R Springs, 18x8 Drag DR38 +47, Eibach 5mm Spacers, 235/40 18 Brisgestone RE760.
RayRay is offline   Reply With Quote
The Following 2 Users Say Thank You to RayRay For This Useful Post:
Realgib3 (10-16-2012), rfinkle2 (10-15-2012)
 Old 10-12-2012, 12:32 AM   #43
I have candy in my van
MATT DAMOND's Avatar
Posts: 1,931   (View Stats)
Groans: 70
What CR?
I'm not doing anything too crazy, just prob 10:1
Current Fail:
 Old 10-12-2012, 03:55 AM   #44
Downmented's Avatar
Posts: 3,040   (View Stats)
Groans: 493
Originally Posted by duappleganger View Post
my first big-turbo mention whhhhhattttt uppppppp
unfortunately, the turbo goes on in two days so give me a little while to get it tuned and ill post logs
lol, i basically went through the BT build section and scrolled down to the name of whoever created the thread and the thread looked legit.
Get that damn turbo on and post results
700HP CLUB
11.479@124mph
#DIX
 Old 10-12-2012, 04:49 AM   #45
SarcasticOne's Avatar
Posts: 1,013   (View Stats)
Groaned at 8 Times in 4 Posts
MS3
Turbo- gt3071
Manifold- steedspeed
21PSI @3400 rpm
IWG
(See 20psi @ 3350rpm, based on @cld12pk2go s suggestion)
 Old 10-12-2012, 06:22 AM   #46
Will fuck up ur day
Chimmike's Avatar
Posts: 6,003   (View Stats)
Groans: 433
If you do I will be very surprised.........but impressed!
07 MS3
The original Genpoo Hater
Alpha (10-12-2012), Downmented (10-12-2012)
 Old 10-12-2012, 10:56 AM   #47
Tripple OG
NJSPEED3's Avatar
Posts: 5,703   (View Stats)
Groans: 113
08.5 ms3
t3 single scroll gt3076 .82hotside
custom t3 tubular mani
44mm ewg
29psi@4100rpms +/-
 Old 10-12-2012, 11:18 AM   #48
Downmented's Avatar
Groans: 493
08.5 ms3
44mm ewg
29psi@4100rpms +/-
Thanks Gerry, appreciated.
If everyone else has a small screen shot like what is posted here of their log, that would be amazing, if its something you do have, please edit your initial post with it or just post it up seperately, either way, doesnt really matter
700HP CLUB
11.479@124mph
#DIX
The Following 2 Users Say Thank You to Downmented For This Useful Post:
aggierandy (10-12-2012), NJSPEED3 (10-12-2012)
 Old 10-12-2012, 02:49 PM   #49
Captain
djuosnteisn's Avatar
Posts: 11,480   (View Stats)
As mentioned, this is good, but if we can make it better by having similar variables, ie 20psi @xxxx rpm starting at 2k rpm in 4th.
I will let you know, i figure this is still new and there are ALLOT more BT people to mention in here.
@djuosnteisn
Let me get an accurate MAP sensor installed, and i'll have some solid data for you.
500awhp 440awtq uncorrected
Check out the hair Salon:
www.permtuning.com
Downmented (10-12-2012), NJSPEED3 (10-12-2012), rfinkle2 (10-15-2012)
 Old 10-12-2012, 04:55 PM   #50
SilverDemon's Avatar
Posts: 3,034   (View Stats)
No N2O, 4th gear, seems to show a little wheel spin
07 MS3
T3 Single Scroll GT35r
.63 hot side (soon to be changed out)
Steed Speed Mani (soon to be changed out)
38MM EXWG
30 psi ~4500
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 3 Users Say Thank You to SilverDemon For This Useful Post:
Downmented (10-12-2012), EdgeAutosport.com (10-17-2012), NJSPEED3 (10-12-2012)
 Old 10-13-2012, 09:11 AM   #51
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
07 MS3
38MM EXWG
30 psi ~4500
What are your plans on the hotside? Why the changes?
SilverDemon (10-13-2012)
 Old 10-13-2012, 11:37 AM   #52
Winter project...all I am going to say for the moment....hehehehehe
EdgeAutosport.com likes this.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
Downmented (10-13-2012), EdgeAutosport.com (10-17-2012), helmetface (10-13-2012)
 Old 10-16-2012, 05:13 PM   #53
Downmented's Avatar
Groans: 493
Noone else? I would like to get a few more in here before we consider having it stickied.
700HP CLUB
11.479@124mph
#DIX
 Old 10-16-2012, 05:27 PM   #54
Realgib3's Avatar
Posts: 2,443   (View Stats)
Never had time to do much tuning, but is what I had with MBC.
08.5 MS3
Precision 6466 CEA
.82 Vband In/Out Hot side
CP-e mani
Precision 46mm Wg
~20psi by 4200
Downmented (10-16-2012)
 Old 10-16-2012, 05:30 PM   #55
aggierandy's Avatar
Posts: 2,241   (View Stats)
aggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the world
Groaned at 18 Times in 14 Posts
Still trying to get @S-hendrix over here to post up his BNR S3 stats
2010 MS3 Mica Black Tech
Cobb AP | JBR RMM 70 Duro | JBR SSP | CS SRI+TIP | CS Racepipe | NGK Plugs | KMD Internals
CS Interior LEDs | Custom Hatch LEDs | Rear Wiper Delete | Custom "Evil M" | Red Taillights | Resonator Delete | SWAS Switch
aggierandy is offline   Reply With Quote
 Old 10-16-2012, 05:42 PM   #56
DISIindahead's Avatar
Posts: 911   (View Stats)
DISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the worldDISIindahead is the leader of the world
Heres mine. Tune still in progress.
MS3
ATP GTX3071
Full Race Manifold
Grimmspeed 3 port EBCS
22 psi @ 3800rpms
IWG
rfinkle2 and Downmented like this.
2010 Mazdaspeed 3 - Built Motor - GTX3071: SOLD
2012 Jeep Wrangler Unlimited Sport: Current DD
DISIindahead is offline   Reply With Quote
The Following User Says Thank You to DISIindahead For This Useful Post:
rfinkle2 (10-16-2012)
 Old 10-17-2012, 12:26 PM   #57
aggierandy's Avatar
My turbos take forever to spool up!
The Following 4 Users Say Thank You to aggierandy For This Useful Post:
Downmented (10-17-2012), rfinkle2 (10-17-2012), S-hendrix (10-17-2012), sleepyspeed6 (10-17-2012)
 Old 10-17-2012, 12:31 PM   #58
BobtailedSnail's Avatar
Posts: 1,375   (View Stats)
Nice thread Chris can't wait to be added
Skreets be calling...
The Following User Says Thank You to BobtailedSnail For This Useful Post:
 Old 10-17-2012, 07:57 PM   #59
S-hendrix's Avatar
Posts: 1,410   (View Stats)
S-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the worldS-hendrix is the leader of the world
Sorry for the delay tapatalk doesn't show mentions. My tune from COBB prevents the turbo from spooling up as quickly as a perm tune would allow so keep that in mind but here's my dyno of the BNR S3.
MS3
BNR S3
Stock Manifold
20.75 psi @ 3500rpms
IWG
*Temp at time of DYNO 105*
BNR S3 . FREEKTUNED . COBB FMIC . COBB CBE . SURE full 3" . CPe Safe Seals . KMD Internals . Grimmspeed EBCS . Guardian Angel . TWM Short Shifter Replacement . MSD DashHawk V2 . Turbo XS DP+RP . Turbosmart Hybrid BOV (full recirc) . JBR SSP+Bushings+Knob/ Rear Sway Bar/ Rear Camber Arms . Sure PMM/TMM . JBR EGR Delete . AWR Adjustable Front/Rear Endlinks . TRZ Dogbone RMM . Denso ITV-22 . Eibach Sport Line . Koni Yellows
S-hendrix is offline   Reply With Quote
 Old 10-17-2012, 08:23 PM   #60
atvfreek's Avatar
Posts: 7,787   (View Stats)
MS3
BNR stage3
3 port ebcs
Stock intake and exhaust manifolds
22psi 3200 rpms
Freekn tappin
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 3 Users Say Thank You to atvfreek For This Useful Post:
Downmented (10-18-2012), rfinkle2 (10-18-2012), S-hendrix (10-17-2012)
 Old 12-04-2012, 06:16 AM   #61
Downmented's Avatar
Groans: 493
Bump for some new data please.
700HP CLUB
11.479@124mph
#DIX
 Old 12-04-2012, 07:04 PM   #62
MSP611's Avatar
Posts: 2,291   (View Stats)
Great thread... im lookin at similiar setups (gt35r t3 twinscroll) really want to see @djuousnteisn setup spools at. Im lookin at turbos similar to the 35r like HTA, GTX, BORG WARNER etc etc. Really interested in the borg warner spool times...
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
In progress:
The Following User Says Thank You to MSP611 For This Useful Post:
Downmented (12-04-2012)
 Old 12-04-2012, 07:34 PM   #63
BigRedSpecial's Avatar
Posts: 1,436   (View Stats)
Groans: 56
Just seeing this now... great idea. If everything goes according to plan I'll have something to contribute over Christmas
Needed: Driver mod
The Following User Says Thank You to BigRedSpecial For This Useful Post:
 Old 12-10-2012, 12:26 PM   #64
Tripple OG
NJSPEED3's Avatar
Groans: 113
Time out.
Did I just read on the op Finkle has a 3076?
The Following 2 Users Say Thank You to NJSPEED3 For This Useful Post:
BlueStreak (12-10-2012), rfinkle2 (12-10-2012)
 Old 12-10-2012, 01:44 PM   #65
Groans: 56
^^^ I believe he posted somewhere in this thread that it was a car he was tuning, not his personal car.
Needed: Driver mod
The Following 2 Users Say Thank You to BigRedSpecial For This Useful Post:
NJSPEED3 (12-10-2012), rfinkle2 (12-10-2012)
 Old 12-10-2012, 01:48 PM   #66
BlueStreak's Avatar
Posts: 1,467   (View Stats)
MS3
Turbo- ATP GT3071
Manifold- Stock
20 PSI @3100 rpm
ATP EWG /w 21PSI Spring
Fully PnP head.
'07 CWP MS3
Forged.
The Following 4 Users Say Thank You to BlueStreak For This Useful Post:
Bob-o (12-10-2012), Downmented (12-10-2012), helmetface (12-10-2012), rfinkle2 (12-10-2012)
 Old 12-10-2012, 01:49 PM   #67
Matrix311's Avatar
Posts: 2,133   (View Stats)
MS3
Turbo- ATP GT3071
Manifold- Stock
20 PSI @3100 rpm
Fully PnP head.
Wish mine spooled like that.
 Old 12-10-2012, 03:26 PM   #68
Downmented's Avatar
Groans: 493
Time out.
I didnt question it, he posted his stats, i update OP.
700HP CLUB
11.479@124mph
#DIX
The Following User Says Thank You to Downmented For This Useful Post:
 Old 12-10-2012, 04:11 PM   #69
It isn't my car (the data that I posted), but if you guys need data, I have some as far as what spools where etc.
I just wanted to participate @ a time where the 3076 wasn't as widely used to shot that it can spool pretty damn quick as well.
@Downmented; Gerry is poking me a bit besides wondering what I'm up to. LOL
 Old 12-10-2012, 04:25 PM   #70
helmetface's Avatar
Groans: 219
Fully PnP head.
Two things:
You sure you're running a 21lbs spring?
Secondly with a PnPed head you could probably benefit from a good aftermarket mani.
 Old 12-10-2012, 05:05 PM   #71
I might know where he can buy one very sooooooonn!!!
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 6 Users Say Thank You to SilverDemon For This Useful Post:
BigRedSpecial (12-10-2012), BlueStreak (12-10-2012), Downmented (12-10-2012), helmetface (12-10-2012), magicka (12-10-2012), mazdafreak (12-10-2012)
 Old 12-10-2012, 07:16 PM   #72
BlueStreak's Avatar
Two things:
Very sure. I'm running spring pressure right now and maintain 21-22PSI to redline. Boost comes on very very quick.
I had the SteedSpeed in there for quite a while then it decided to crack on me. Put back the stock one and picked up 50+g/s. I'll eventually throw a tubular on it and will likely go with CPe's cast ex mani to resist cracking at the welds. I have a wicked exhaust leak aversion after what I went through with the car over the last 10 months or so.
'07 CWP MS3
Forged.
The Following User Says Thank You to BlueStreak For This Useful Post:
 Old 12-10-2012, 07:18 PM   #73
helmetface's Avatar
Groans: 219
Boost controller?
Did you port the WG path on your ATP hotside?
 Old 12-10-2012, 07:22 PM   #74
XLT_66's Avatar
Posts: 850   (View Stats)
2009 MS3
GT3582r Twinscroll T3 .78 A/R
25 PSI @ 4000 RPM
Custom 1.25" Tubular Twinscroll Manifold
Teardrop Merged Single 44mm Tial MV-S
1 Bar Spring Pressure
COBB 3-Port
2009 CWP MS3 Sport
SOLD!
XLT_66 is offline   Reply With Quote
The Following 2 Users Say Thank You to XLT_66 For This Useful Post:
Downmented (12-10-2012), NJSPEED3 (12-13-2012)
 Old 12-10-2012, 07:42 PM   #75
Downmented's Avatar
Groans: 493
Thanks Evan, OP updated.
700HP CLUB
11.479@124mph
#DIX
 Old 12-10-2012, 08:13 PM   #76
BlueStreak's Avatar
Boost controller?
Yeah. Perrin EBCS but on spring pressure at the moment. Had to iron out my bouncy idle due to the JBR intake and will be turning it up to 24 or so in the next few days.
Didn't port anything. Just threw on the ATP EWG setup.
'07 CWP MS3
Forged.
 Old 12-12-2012, 03:02 PM   #77
XLT_66's Avatar
Car is running pretty good right now.
2009 CWP MS3 Sport
SOLD!
 Old 12-12-2012, 04:35 PM   #78
helmetface's Avatar
Groans: 219
Those with EWG should humor me and include what spring they are running.
 Old 12-12-2012, 04:39 PM   #79
Groans: 56
@cld12pk2go; you mentioned earlier that you spooled slower after porting your IM... why would that be?
Needed: Driver mod
 Old 12-12-2012, 05:00 PM   #80
Ziggo's Avatar
Posts: 3,843   (View Stats)
2008 MS3
BNR S3
18 PSI @ 3000 RPM
Stock Intake Manifold\Swaintech Coated DNP Exhaust Manifold & Hotside\COBB DP\MS CBE
JBR WP Intake (3.5")
Grimmspeed 3-Port
Its actually overrunning targets at 3500......
Ask Me About My:
himurax13 (12-12-2012)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/big-turbo-spool-characteristics-127115/
?????????? - ??????? (??????????, ???????, ??????) This thread Refback 04-07-2014 12:32 PM
For the big BIG turbo guys who complain about spool time... phate MazdaSpeed 3/6 - Turbo Induction 26 12-31-2014 08:35 AM
Faster spool turbo kit ? MazdaSpeedThree 2010 MS3 - Big Turbo Builds 17 10-11-2012 08:20 AM
Trouble shooting big turbo slow spool time Ckmazdaspeed3 2010 MS3 - Troubleshoot/Diagnostics 87 06-18-2011 10:58 AM
Page generated in 0.64180 seconds with 43 queries
