Like Tree21Likes
 Old 04-18-2012, 02:17 PM   #41
Shit looks good ray
 Old 04-18-2012, 02:22 PM   #42
86AmishMs3's Avatar
Posts: 3,639   (View Stats)
Groans: 338
Originally Posted by RayRay (rg73gz) View Post
Just Installed...
GTX3076 / IWG
24psi
17* at RL
50/50 E85
100% Meth, D05
About 500 miles on current setup.
39k on Motor, And Beat the Shit out of it Daily!!
Dude wind that shit out to 7k. This aint no k04 anymore. Short shifting is a hard habbit to break after thousands of miles on the k04
Current: N54 135i
DCI, DP's, Exhaust, FMIC
12.3@122
2009 Mazdaspeed 3:
GT3076 - Corkey tuned
390whp/400wtq
12.8@114
Sold
 Old 04-18-2012, 02:38 PM   #43
RayRay's Avatar
Posts: 3,120   (View Stats)
RayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the worldRayRay is the leader of the world
Groaned at 9 Times in 5 Posts
LOL!! I usually do. I hit the button on the AP a little early!!
2009 MazdaSpeed 3
Spy Hunter Smoke Screen Mod
Cobb AP (Custom Tune), ATP GTX3076 28PSi, CP Forged Pistons .020 Over, Pauter Forged Rods, Bore and Hone Block .020 Over, CP-E DISI Injector Seals, ARP Head Studs, MZR Cometic Head Gasket, ACT Stage 2 Heavy Duty Clutch,Cobb SRI Intake, JBR TIG, JBR TB Gasket, JBR 88 Duro Transmission Mount, JBR EGR Delete , JBR TB Coolant Bypass, CP-E Big Turbo TIP, KMD HPFP Internals, Street Unit TurboSmart Dual Port BOV, CorkSport TMIC, CorkSport DP, CorkSport Test Pipe, CorkSport CBE, CPE Single Guage Pod, DashHawk, Prosport Boost Gauge, Devils Own Progressive Methanol Injection Kit 80/20 with D07 Nozzle, E85 Tune 50/50, JBR DogBone 88 Duro Rear Motor Mount, CorkSport Mid Chassis Brace, JBR Stage 2 Short Shift Plate, H&R Springs, 18x8 Drag DR38 +47, Eibach 5mm Spacers, 235/40 18 Brisgestone RE760.
RayRay is offline   Reply With Quote
The Following User Says Thank You to RayRay For This Useful Post:
86AmishMs3 (04-18-2012)
 Old 04-18-2012, 02:49 PM   #44
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
bumpin to stickies, thanks guys appreciate the knowledge!
The Following 3 Users Say Thank You to dooderek For This Useful Post:
86AmishMs3 (04-18-2012), EdgeAutosport.com (04-19-2012), RayRay (04-18-2012)
 Old 04-27-2012, 12:47 PM   #45
Broxer's Avatar
Posts: 875   (View Stats)
Broxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the worldBroxer is the leader of the world
Groans: 90
@Daddy Chinkus
We need you to take out the trash again
2012 Triumph Street Triple
SOLD -- 2010 Velocity Mica Red MS3
ATP GTX3071r - Cobb AP(Freek Permed) - CNT Catted DP - UR CBE - DO Stage 2 WMI(80/20) - cp-e TMIC - cp-e xcelXL - cp-e invicid inlet - Grimmspeed MBC - KMD v2.2 hpfp internals - Bosch 3bar MAP - H&R Springs - DDM 6k Raptor Kit - ITV22's - Forge v2 BPV - 225/40/18 Nitto Neogens - SURE RMM
Broxer is offline   Reply With Quote
 Old 05-30-2012, 11:16 AM   #46
2zz mr-s
dooderek's Avatar
Groans: 239
updated:
430 awhp 415 awtq @23.3 psi 6031
VVT 30 tapered to 0 by RL
19.50 degrees of timing by RL
91 + 3 gal e85
d07 pre tb
d02 pre turbo
68k miles
 Old 06-22-2012, 10:07 PM   #47
RaisedOnPunk's Avatar
Posts: 11   (View Stats)
RaisedOnPunk will become famous soon enough
Originally Posted by Daddy Chinkus View Post
updated:
91 + 3 gal e85
d07 pre tb
d02 pre turbo
68k miles
I may have missed it, but are you making this on stock internals?
RaisedOnPunk is offline   Reply With Quote
 Old 06-24-2012, 04:03 PM   #48
2zz mr-s
dooderek's Avatar
Groans: 239
This thread isn't called stock block for nothing
The Following User Says Thank You to dooderek For This Useful Post:
rigor (06-29-2012)
 Old 06-24-2012, 04:20 PM   #49
bwspeed's Avatar
Posts: 286   (View Stats)
bwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the worldbwspeed is the leader of the world
gtx3071
tmic fail
12.5deg
50/50 100octane/93
21.5psi
334whp 322wtq
Cobb AP, CNT TBE, Jbr intake CPE TMIC, JBR PMM & 88 Duro RMM, GTX 3071R turbo, Grimmspeed EBC, AEM methanol kit, 3 bar map sensor, Freektune
Moore Automotive 10/19/13
397whp 392wtq
bwspeed is offline   Reply With Quote
 Old 08-14-2012, 05:28 PM   #50
thehead's Avatar
Posts: 1,141   (View Stats)
thehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the worldthehead is the leader of the world
Groans: 143
GTX3071R
vvt 35 tapered to 0
19 degrees timing at rl
11.7 afr targeted
1808 hpfp desired fp
vd ~ 425-440hp / 420-430 lbftq 1.01 cf
4gal e-85/rest 93 oct (w/marvel mystery oil)
25psi
~4k miles on turbo, 51k on car, still trying to tune my spool quicker.
Edit: shot a rod/piston through the block last Sept
part of the piston was lodged into the crankshaft somehow.
2016 BMW M235i
[Dead] 2006 MS6 #367 Liquid Platinum 73,000 miles
Engine - Killah built -L19 Headstuds - Steedspeed T3 Twin Scroll top mount goodness - Twin Scroll .83 A/R hotside GTX3071R - JMF V1 IM - Perm 6th Port - CP-E FMIC - SURE 3.25 MAF housing - customized EBay DP - Magnaflow CBE - Autotech HPFP internals
Electrical - GS EBC - Cobb AP Richtune in progress
Drive train - Techna-fit Stainless Steel clutch and brake lines - stoptech rotors - CorkSport RMM - Corksport Trans inserts - SURE Juggernaught & Dreadnaught - E4 heavy knob & Jbarone's Short Shift plate - Tenzo DC-5 Bronze +45 wrapped in ExtremeContact DWS 235/40-18's
Fluids Transmission - Motorcraft synthetic. PTO and Rear diff - Conklin Gold Guard Plus synthetic 75W-90. Engine Oil - Rotella T6 5W-40.
thehead is offline   Reply With Quote
The Following 3 Users Say Thank You to thehead For This Useful Post:
atvfreek (08-14-2012), BPASPEED (08-14-2012), InFeXIoN (08-14-2012)
 Old 08-14-2012, 08:02 PM   #51
Voltwings's Avatar
Posts: 3,713   (View Stats)
As it sits:
ATP GT3071r
4 gal E85
23 psi
18.5* at redline
45k on car, ~3k on BT, gonna crank the bitch up once i get the 5th port sorted though.
Past:
-Sold-
-Sold-
Current:
2012 Loaded Speed3 - Stock
2001 Miata - Basically stock
 Old 08-28-2012, 08:12 PM   #52
Voltwings's Avatar
You guys running 2 and 2.5 gallon E85 blends, what are your fill ups like?? 1 gallon of e85 and 7 gallons of 93? half a gallon and 3.5 gallons? seems like thats barely any E85.
Past:
-Sold-
-Sold-
Current:
 Old 08-28-2012, 08:16 PM   #53
crazyp's Avatar
Posts: 1,093   (View Stats)
Groans: 68
You guys running 2 and 2.5 gallon E85 blends, what are your fill ups like?? 1 gallon of e85 and like 6 gallons of 93? half a gallon and 3 gallons?
Personally I just guess. If my light comes on 3 gallons of E and fill up the rest. If im at half of a quarter I put 2.5 of E. 1/4 tank I put 2 gallons and fill the rest. I just try to keep the ratio close I don't get to anal about it
zoom6zoom likes this.
The Following 3 Users Say Thank You to crazyp For This Useful Post:
atvfreek (08-28-2012), Voltwings (08-28-2012), x09MS3GT (09-04-2012)
 Old 08-28-2012, 09:26 PM   #54
Voltwings's Avatar
i guess its not enough e85 to really mess with the trims too much but guess work isnt gonna work for someone like me haha -_-
Past:
-Sold-
-Sold-
Current:
 Old 08-28-2012, 09:38 PM   #55
crazyp's Avatar
Groans: 68
well for me the e-85 is strictly for knock. The less e-85 I use the more fuel I have available. Plus I run 100% METH WITH A d07 NOZZLE i'M SURE THAT HELPS LOL.
at 25 psi I'm still at high 90 IDC
atvfreek (08-29-2012), Juyoung (01-21-2013), Voltwings (08-28-2012)
 Old 08-28-2012, 09:48 PM   #56
Voltwings's Avatar
The IDC is what im looking to lower by reducing my e85 as well. Thanks for the input. i started on 50/50, then went to a 4 gal blend and hoping i can run my 25 psi without the need for meth on a 2 gal blend. We'll see.
Past:
-Sold-
-Sold-
Current:
 Old 08-28-2012, 09:57 PM   #57
Black Metal's Avatar
Posts: 699   (View Stats)
Black Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the worldBlack Metal is the leader of the world
Groans: 78
ATP GT3071r
4 gal E85
22 psi
18.5* at redline
80k on car, ~3k on BT
- 2006 Black Mica MS6 -
- GT3071R - CP-e CAI - CP-e BT TIP - ATP Catted DP - JBR RMM - Corksport TMIC - Cobb AP -
- Autotech Internals - Turbo XS 50/50 - DSS Rear Axle - Sure Juggernaught & Dreadnaught -
- GS EBCS - H&R Springs - Sure TIG's - PNP'D Intake Manifold - EGR Delete -
12.89 @ 104.9 1.82 60' 4500' ASL on K04 20 PSI E30
12.01 @ 113.9 1.80 60' 4500' ASL on 3071 22 PSI E20
- 2004 Silver Sunlight Metallic RX-8 -
- 6MT - Stock -
Black Metal is offline   Reply With Quote
 Old 11-04-2012, 11:06 PM   #58
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
GTX3071
straight pump gas(93-94 octane)
25 PSI at red line (throttle reduction MAP limit set to 39.88psi/275kPa and fuel cut at 40.32psi/278kPa)
12 degrees of timing at red line, VVT set to 0 at RL
75k miles/121k km on the car, 18k km/11k miles on BT
blkspeed307 likes this.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 11-08-2012, 07:23 AM   #59
InFeXIoN's Avatar
Posts: 1,159   (View Stats)
InFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the world
Groaned at 42 Times in 15 Posts
As it sits:
ATP GT3071r
4 gal E85
23 psi
18.5* at redline
5th port? What happend with the meth?
GTX3071R EWG, DNP Tubular Manifold, SSP Ported/VTCS deleted intake manifold, DCR VVT Actuator, CP-E FMIC, Cobb AP, JBR 3.5" WP Intake ||| JBR 80 Duro RMM, JBR 80 Duro PSMM ||| CNT Racing Catless full 3" DP/TP, Speed Daddy 3" CBE ||| AEM Water/Methanol Kit, Autotech FP Internals, PTP Inj Seals, Synapse Engineering Bypass Valve, Matt Jackson map sensor harness, 3 Bar map sensor, Grimmspeed 3-port EBCS, NGK 1 Step Colder Plugs ||| Sure AGS 621G, Sure Shortcut, JBR Solid Base Bushings and Weight ||| AMR Engineering Coilovers, JBR Rear Sway, JBR Rear Camber Arms, XXR 527 18x8.75 +35 Chromium Black ||| CP-E Tow Plate, Rotella T6, FoMoCo XT-M5-QS, JBR OCC, JBR EGR Delete, JBR TB Gasket, JBR TIG and Coolant Bypass, EBC Redstuff.
Build Complete!!!!
InFeXIoN is offline   Reply With Quote
 Old 11-08-2012, 07:50 AM   #60
Lakespeed6's Avatar
Posts: 2,403   (View Stats)
Glad to finally be able to post here.
GTX3076 MS6
93 with D10 Meth
25psi
18*at redline
75k on the car
383HP 385TQ
Freektune
1990 Nissan Skyline GTR
1991 White BMW 325ic
The Following 3 Users Say Thank You to Lakespeed6 For This Useful Post:
atvfreek (11-08-2012), InFeXIoN (11-08-2012), Juyoung (01-21-2013)
 Old 11-08-2012, 09:40 AM   #61
Voltwings's Avatar
Look how long ago I posted that haha, that was before I picked this kit up
Past:
-Sold-
-Sold-
Current:
 Old 11-08-2012, 11:15 AM   #62
InFeXIoN's Avatar
Oh haha I didn't even think to look at the damn date, my bad.
Build Complete!!!!
The Following User Says Thank You to InFeXIoN For This Useful Post:
Voltwings (11-08-2012)
 Old 02-12-2013, 08:25 AM   #63
BlckMs3's Avatar
Posts: 769   (View Stats)
BlckMs3 is the leader of the worldBlckMs3 is the leader of the worldBlckMs3 is the leader of the worldBlckMs3 is the leader of the worldBlckMs3 is the leader of the worldBlckMs3 is the leader of the worldBlckMs3 is the leader of the worldBlckMs3 is the leader of the worldBlckMs3 is the leader of the worldBlckMs3 is the leader of the worldBlckMs3 is the leader of the world
Groans: 30
hate to be that guy buuuuut kinda of upset this thread stopped lol...
Stance will make her dance, but boost will make her sploosh
[12:57 PM] Enki: kim should sell her used tampons to msf as fresh teabags
2007 Mazdaspeed3 SOLD
2014 Mustang GT
BlckMs3 is offline   Reply With Quote
The Following User Says Thank You to BlckMs3 For This Useful Post:
Swinger13 (02-22-2013)
 Old 02-12-2013, 08:36 AM   #64
Eth Fiend
phate's Avatar
Posts: 6,947   (View Stats)
We have pretty well established power levels for what is safe, long term, and what is a time bomb.
-06 MS6
-Corn fed 07 MS3 - Sold
 Old 02-12-2013, 08:40 AM   #65
BlckMs3's Avatar
Groans: 30
lol all this i know, was just interesting to see how far people ride that line
2014 Mustang GT
 Old 02-12-2013, 09:20 AM   #66
Voltwings's Avatar
been on 27 psi, 435 whp 465 wtq for the past month. motors gettin built at the end of the month so i figured id get slightly more frisky in the mean time but i've turned it down now haha, no sense in sending a rod through the block before then.
Past:
-Sold-
-Sold-
Current:
The Following 4 Users Say Thank You to Voltwings For This Useful Post:
BlckMs3 (02-12-2013), bob^3 (04-23-2013), jracer (02-12-2013), lilred (02-12-2013)
 Old 02-12-2013, 11:37 AM   #67
atvfreek's Avatar
Posts: 7,787   (View Stats)
Is that vd or dyno numbers?
Sent from your couch
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
Voltwings (02-12-2013)
 Old 02-12-2013, 12:03 PM   #68
Voltwings's Avatar
They're "dont worry about it" numbers haha. Thats VD, so i do tend to take it with a grain of salt, but id imagine its somewhere in that ballpark.
Past:
-Sold-
-Sold-
Current:
atvfreek (02-12-2013)
 Old 02-22-2013, 08:36 AM   #69
Swinger13's Avatar
Posts: 3,480   (View Stats)
Groans: 53
I'm doing a turbo swap in a month or less. I can post here to bring this thread back to life.
Performance:
Stratified Tune in progress
The Following User Says Thank You to Swinger13 For This Useful Post:
BlckMs3 (02-22-2013)
 Old 04-23-2013, 09:34 AM   #70
Voltwings's Avatar
Speaking of which, did you forget?
Past:
-Sold-
-Sold-
Current:
 Old 04-23-2013, 01:48 PM   #71
BlckMs3's Avatar
Groans: 30
i got mine 71 in, gonna wait for dyno results to post up
2014 Mustang GT
Voltwings (04-23-2013)
 Old 06-02-2013, 02:51 AM   #72
ricardo_yen's Avatar
Posts: 27   (View Stats)
ricardo_yen will become famous soon enough
What about running a gtx28, with spool at 3300, would that be danagerous, like a high load low rpm situation.....
I have a stock block but I'm trying to match the right turbo for the 1/4mile....
ricardo_yen is offline   Reply With Quote
 Old 06-02-2013, 04:24 AM   #73
Swinger13's Avatar
Groans: 53
Neutral  +1 score
I guess I forgot to reply. I'm in the middle of the tuning process with Lex. I have a GT2871 now. We just upped the boost and timing slightly and it feels great. I will update.
I need to learn how to use V dyno correctly because my graphs are wonky looking and wavy. Just to get some idea.
Performance:
Voltwings (06-02-2013)
 Old 06-02-2013, 11:50 AM   #74
Police - Grammarhead
Vansquish's Avatar
Read . . . then donate . . . then read some more.
 Old 06-02-2013, 12:37 PM   #75
stlskater92's Avatar
Posts: 78   (View Stats)
stlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond reputestlskater92 has a reputation beyond repute
My black ms3 has a .5557 w/ t-4 hotside
running 17psi currently @16* timing on 93pump gas.
Gonna get the meth kit working and fix the most fucked up maf cal in history and run 22-25psi and 19ish* timing.
I'll get ligit dyno numbers up when I'm done with tuning.
motor only has 21.5k miles currently so fingers crossed she's a strong one
White 2009 MS3:
100k mile pig
HTP built
gt3076r powered
6th port fueled
Tuned by Nishan
Black 2008 MS3:
under construction
#700orbust
stlskater92 is offline   Reply With Quote
 Old 06-02-2013, 01:34 PM   #76
If the smoothing is set to 3 and they are still all over the place the logging must be done on a very smooth flat road.
Swinger13 (06-02-2013)
 Old 06-02-2013, 04:07 PM   #77
Swinger13's Avatar
Groans: 53
I had no clue what smoothing is but as soon as I hit smoothing 2 it flattened out nicely and didn't really change through smoothing 3,4,5,6
Performance:
 Old 06-02-2013, 04:50 PM   #78
kimura's Avatar
Posts: 170   (View Stats)
kimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the worldkimura is the leader of the world
since this thread is apparently back up and running I'll drop in my two cents
ATP gt3071r
3 gal E85 + 9 gal 93
load tune with reverse taper to ~22psi (when it's warm out)
17* at redline
turbo installed May 2012 at 69k miles. I'm at 81k now with good compression. crossing fingers
VD says 372hp 364tq w/ cf of 1.01
shits and giggles every time I drive it
09 CWP MS3 Sport - ATP GT3071r on ~E30, ACT 6-puck, TR8 FMIC, Bilsteins, etc... sold
kimura is offline   Reply With Quote
The Following User Says Thank You to kimura For This Useful Post:
 Old 07-07-2013, 04:00 PM   #79
Etipp98's Avatar
Posts: 1,947   (View Stats)
Groaned at 7 Times in 4 Posts
6266 w/6th port
3 gal e85/ 9 gal 93 mix
26 psi at redline with only 12* advance at 6500. (tune in progress by @Realgib3 )
99k on motor, great compression still. Was running a gt30 before this for about 10k miles on 390whp.
Have about 5k on this setup.
atvfreek and Roddiy like this.
The Following 4 Users Say Thank You to Etipp98 For This Useful Post:
atvfreek (07-07-2013), BlckMs3 (07-09-2013), Boost_creep (07-07-2013), Roddiy (07-08-2013)
 Old 07-08-2013, 06:04 AM   #80
Eth/Meth Junkie
cld12pk2go's Avatar
Posts: 2,998   (View Stats)
Originally Posted by Etipp98 View Post
6266 w/6th port
That is a lot of power for so little timing. Looking nice.
Realgib3 (07-08-2013)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/big-turbo-stock-block-thread-108396/
? View topic - getting 300WHP out of a KO4 in JHB This thread Refback 05-13-2013 09:59 AM
HOW TO GET 400WHP FROM YOUR SPEED 3 (the practical way) This thread Pingback 04-19-2012 03:02 PM
stock block big turbo dyno kmac MazdaSpeed 3/6 - Dyno Sheets/Discussions 178 06-24-2012 08:35 PM
Bad Turbo Results in New Block batman MazdaSpeed 3 - Engine, Transmission & Driveline 31 02-22-2010 08:32 AM
So...Turbo/motor limits on stock block & internals? 94jedi MazdaSpeed 3/6 - Turbo Induction 26 05-31-2008 08:01 AM
Page generated in 0.57536 seconds with 45 queries
