| Approved MSF Vendor ![]() Join Date: Sep 2011 Location: Denver Colorado
Rep Power: 5796 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,830
| Not Ranked : 0 score Shit looks good ray |
Groans: 239
(Thread Starter) | Not Ranked : 0 score bumpin to stickies, thanks guys appreciate the knowledge!
__________________ [07:25 PM] Pu Manchu: the second rule is "don't tell anyone" [07:25 PM] Pu Manchu: the first rule of tranny fucking is "don't do it" |
| The Following 3 Users Say Thank You to dooderek For This Useful Post: |
![]() Join Date: Feb 2011 Location: Cleveland TN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,751
Groans: 90
__________________ 2012 Triumph Street Triple SOLD -- 2010 Velocity Mica Red MS3 ATP GTX3071r - Cobb AP(Freek Permed) - CNT Catted DP - UR CBE - DO Stage 2 WMI(80/20) - cp-e TMIC - cp-e xcelXL - cp-e invicid inlet - Grimmspeed MBC - KMD v2.2 hpfp internals - Bosch 3bar MAP - H&R Springs - DDM 6k Raptor Kit - ITV22's - Forge v2 BPV - 225/40/18 Nitto Neogens - SURE RMM |
Groans: 239
(Thread Starter) | Not Ranked : 0 score updated: 430 awhp 415 awtq @23.3 psi 6031 VVT 30 tapered to 0 by RL 19.50 degrees of timing by RL 91 + 3 gal e85 d07 pre tb d02 pre turbo 68k miles
__________________ [07:25 PM] Pu Manchu: the second rule is "don't tell anyone" [07:25 PM] Pu Manchu: the first rule of tranny fucking is "don't do it" Last edited by dooderek; 05-30-2012 at 12:17 PM. |
![]() Join Date: Jun 2012 Location: Savannah, GA.
Rep Power: 0 ![]() Thanks: 3
| Not Ranked : 0 score |
Groans: 239
(Thread Starter) | Not Ranked : 0 score This thread isn't called stock block for nothing
| The Following User Says Thank You to dooderek For This Useful Post: | rigor (06-29-2012) |
![]() Join Date: Nov 2010 Location: Salisbury, NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 716
| Not Ranked : 0 score gtx3071 tmic fail 12.5deg 50/50 100octane/93 21.5psi 334whp 322wtq
__________________ Cobb AP, CNT TBE, Jbr intake CPE TMIC, JBR PMM & 88 Duro RMM, GTX 3071R turbo, Grimmspeed EBC, AEM methanol kit, 3 bar map sensor, Freektune Moore Automotive 10/19/13 397whp 392wtq |
![]() Join Date: Jul 2009 Location: Key West, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,273
Groans: 143
| Not Ranked : 0 score GTX3071R vvt 35 tapered to 0 19 degrees timing at rl 11.7 afr targeted 1808 hpfp desired fp vd ~ 425-440hp / 420-430 lbftq 1.01 cf 4gal e-85/rest 93 oct (w/marvel mystery oil) 25psi ~4k miles on turbo, 51k on car, still trying to tune my spool quicker. Edit: shot a rod/piston through the block last Sept part of the piston was lodged into the crankshaft somehow.
__________________ 2016 BMW M235i [Dead] 2006 MS6 #367 Liquid Platinum 73,000 miles Engine - Killah built -L19 Headstuds - Steedspeed T3 Twin Scroll top mount goodness - Twin Scroll .83 A/R hotside GTX3071R - JMF V1 IM - Perm 6th Port - CP-E FMIC - SURE 3.25 MAF housing - customized EBay DP - Magnaflow CBE - Autotech HPFP internals Electrical - GS EBC - Cobb AP Richtune in progress Drive train - Techna-fit Stainless Steel clutch and brake lines - stoptech rotors - CorkSport RMM - Corksport Trans inserts - SURE Juggernaught & Dreadnaught - E4 heavy knob & Jbarone's Short Shift plate - Tenzo DC-5 Bronze +45 wrapped in ExtremeContact DWS 235/40-18's Fluids Transmission - Motorcraft synthetic. PTO and Rear diff - Conklin Gold Guard Plus synthetic 75W-90. Engine Oil - Rotella T6 5W-40. Last edited by thehead; 06-02-2013 at 02:59 AM. |
![]() Join Date: Nov 2010 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,489
| Not Ranked : 0 score As it sits: ATP GT3071r 4 gal E85 23 psi 18.5* at redline 45k on car, ~3k on BT, gonna crank the bitch up once i get the 5th port sorted though.
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. |
| Not Ranked : 0 score You guys running 2 and 2.5 gallon E85 blends, what are your fill ups like?? 1 gallon of e85 and 7 gallons of 93? half a gallon and 3.5 gallons? seems like thats barely any E85.
![]() Join Date: Jun 2010 Location: corpus christ, tx
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,316
Groans: 68
Personally I just guess. If my light comes on 3 gallons of E and fill up the rest. If im at half of a quarter I put 2.5 of E. 1/4 tank I put 2 gallons and fill the rest. I just try to keep the ratio close I don't get to anal about it
__________________ 2006 MS6 -GTX3076 .82 AR-Steedspeed Topmount mani-DJ/PERM Top mount Kit with PERM tune-CXracing FMIC-Tial .44mm WG - KMD Internals- Sure RDM, Turbine tech FDM and FMM=JBR trilogy MM- Whiteline rear sway- eibach prosport springs-jbarone SSP-COBB AP-ACT 6PUCK- ITV22-Prosport Spin On Conversion-Snow Performance stg 2 Meth-CPE Injector seals-Matt Damon OCC | |
| Not Ranked : 0 score i guess its not enough e85 to really mess with the trims too much but guess work isnt gonna work for someone like me haha -_-
![]() Join Date: Feb 2011 Location: Utah
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,098
Groans: 78
| Not Ranked : 0 score ATP GT3071r 4 gal E85 22 psi 18.5* at redline 80k on car, ~3k on BT
__________________ - 2006 Black Mica MS6 - - GT3071R - CP-e CAI - CP-e BT TIP - ATP Catted DP - JBR RMM - Corksport TMIC - Cobb AP - - Autotech Internals - Turbo XS 50/50 - DSS Rear Axle - Sure Juggernaught & Dreadnaught - - GS EBCS - H&R Springs - Sure TIG's - PNP'D Intake Manifold - EGR Delete - 12.89 @ 104.9 1.82 60' 4500' ASL on K04 20 PSI E30 12.01 @ 113.9 1.80 60' 4500' ASL on 3071 22 PSI E20 - 2004 Silver Sunlight Metallic RX-8 - - 6MT - Stock - |
Groans: 111
| Not Ranked : 0 score GTX3071 straight pump gas(93-94 octane) 25 PSI at red line (throttle reduction MAP limit set to 39.88psi/275kPa and fuel cut at 40.32psi/278kPa) 12 degrees of timing at red line, VVT set to 0 at RL 75k miles/121k km on the car, 18k km/11k miles on BT
![]() Join Date: Jun 2011 Location: Conroe, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,698
Groaned at 42 Times in 15 Posts
__________________ GTX3071R EWG, DNP Tubular Manifold, SSP Ported/VTCS deleted intake manifold, DCR VVT Actuator, CP-E FMIC, Cobb AP, JBR 3.5" WP Intake ||| JBR 80 Duro RMM, JBR 80 Duro PSMM ||| CNT Racing Catless full 3" DP/TP, Speed Daddy 3" CBE ||| AEM Water/Methanol Kit, Autotech FP Internals, PTP Inj Seals, Synapse Engineering Bypass Valve, Matt Jackson map sensor harness, 3 Bar map sensor, Grimmspeed 3-port EBCS, NGK 1 Step Colder Plugs ||| Sure AGS 621G, Sure Shortcut, JBR Solid Base Bushings and Weight ||| AMR Engineering Coilovers, JBR Rear Sway, JBR Rear Camber Arms, XXR 527 18x8.75 +35 Chromium Black ||| CP-E Tow Plate, Rotella T6, FoMoCo XT-M5-QS, JBR OCC, JBR EGR Delete, JBR TB Gasket, JBR TIG and Coolant Bypass, EBC Redstuff. Build Complete!!!! | |
| Not Ranked : 0 score Look how long ago I posted that haha, that was before I picked this kit up
![]() Join Date: Jul 2010 Location: Lunenburg Mass
Rep Power: 2310 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,516
| Not Ranked : 0 score Glad to finally be able to post here. GTX3076 MS6 93 with D10 Meth 25psi 18*at redline 75k on the car 383HP 385TQ Freektune
__________________ 2006 Black MS6 531HP 486TQ FREEKBUILT -- FreekTune BW S300sx 62mm -- Twin TIAL 38mm EWG -- Perm Top Mount Twin Scroll Turbo Manifold -- Perm 4" Intake TR1035FMIC -- JBR TB and IM thermal spacers -- JBR OCC -- Bosch 3.5 Bar MAP -- Greddy BOV-- CP-E Injector seals Perm Downpipe -- 3" Magnaflow CBE -- Autotech Fuel Pump Internals -- Grimmspeed EBCS -- NGK Iridium Ported Head and Intake Manifold -- Snow Performance Meth Injection D10 and D12 -- balance shaft delete -- EGR delete ACT 6 Puck -- ISC Coilovers -- Sure Torq R6 -- Sure Juggernaught -- Sure Dreadnaught -- Sure Anchors -- Sure Shift Knob 2006 CWP MS6 313HP 319TQ FreekTune ATP GTX3076r -- TIAL 38mm EWG -- HTP 3" Intake System -- CPE Single Exit Exhaust-- ATP Catless Down Pipe CPE Differential Mount -- CPE Top Mount Intercooler -- JBR 80D Trilogy Mount Package -- Grimmspeed EBCS Autotech Internals -- Bosch 3 Bar Map Sensor -- Bit Wise Plug n Play -- GFB Hybrid BOV Bilstein Struts -- H&R Sport Lowering Springs -- Cobb v3 -- e85 1990 Nissan Skyline GTR ![]() 1991 White BMW 325ic Scorpion catback -- Short shifter -- Bilstein HD -- HR Springs -- Intake -- NRG Wheel -- Chassis and strut tower brace -- Sway bars |
| The Following User Says Thank You to InFeXIoN For This Useful Post: | Voltwings (11-08-2012) |
![]() Join Date: Dec 2011 Location: Virginia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 715
Groans: 30
| Not Ranked : 0 score hate to be that guy buuuuut kinda of upset this thread stopped lol...
__________________ Stance will make her dance, but boost will make her sploosh
2014 Mustang GT | |
| The Following User Says Thank You to BlckMs3 For This Useful Post: | Swinger13 (02-22-2013) |
| Not Ranked : 0 score We have pretty well established power levels for what is safe, long term, and what is a time bomb.
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. |
Groans: 30
| Not Ranked : 0 score lol all this i know, was just interesting to see how far people ride that line
2014 Mustang GT | |
but i've turned it down now haha, no sense in sending a rod through the block before then.
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. | |
![]() Join Date: Nov 2010 Location: Manchester, NH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 25,797
Sent from your couch
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 | |
| The Following User Says Thank You to atvfreek For This Useful Post: | Voltwings (02-12-2013) |
![]() | | #24 | ![]() |
| Not Ranked : 0 score They're "dont worry about it" numbers haha. Thats VD, so i do tend to take it with a grain of salt, but id imagine its somewhere in that ballpark.
| The Following User Says Thank You to Voltwings For This Useful Post: | atvfreek (02-12-2013) |
![]() | | #25 | ![]() |
![]() Join Date: Jan 2012 Location: Edmonton, Alberta, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,581
Groans: 53
| Not Ranked : 0 score I'm doing a turbo swap in a month or less. I can post here to bring this thread back to life.
__________________ 06 Speed 6 rock chipped n' shit Performance: Stratified Tune in progress Old Set-up: CS Ram air intake with 3" HTP inlet + "sig" Vdyno 323 awhp 349 awtq uncorrected Current Set up: JBR 3.5" WP, Perm PCV w/dual catch cans, trunk battery Vdyno 343 awhp 374 awtq uncorrected Corksport CBE ~ Ebay DP ~ Autotech Internals ~ COBB AP ~ BC Racing Coilovers ~ SURE shortcut ~ SURE countershift ~ SURE anchors ~ heavy sphere shift knob by maisonvi (MSF member) ~ CP-E seals ~ BSD ~ baffle pan ~ Dual Corksport OCC ~ CP-E Rear Diff Mount ~ SURE Juggernaught ~ Dashhawk ~ AWR 88 duro trilogy ~ EGR delete ~ 3 bar ~ JBR TIG's ~ Grimmspeed 3 port ~ GT2871R w/ported hotside ~ JBR 3.5 inch intake ~ Perm Tuning PCV Plate ~ Forge V1 BPV ~ ITV22's @ .026" ~ CP-E Helihose |
| The Following User Says Thank You to Swinger13 For This Useful Post: | BlckMs3 (02-22-2013) |
![]() | | #26 | ![]() |
| Not Ranked : 0 score Speaking of which, did you forget?
![]() | | #27 | ![]() |
Groans: 53
| Neutral : +1 score I guess I forgot to reply. I'm in the middle of the tuning process with Lex. I have a GT2871 now. We just upped the boost and timing slightly and it feels great. I will update. I need to learn how to use V dyno correctly because my graphs are wonky looking and wavy. Just to get some idea.
| The Following User Says Thank You to Swinger13 For This Useful Post: | Voltwings (06-02-2013) |
![]() | | #28 | ![]() |
| The Following User Says Thank You to Lex For This Useful Post: | Swinger13 (06-02-2013) |
![]() | | #29 | ![]() |
Groans: 53
| Not Ranked : 0 score I had no clue what smoothing is but as soon as I hit smoothing 2 it flattened out nicely and didn't really change through smoothing 3,4,5,6
![]() | | #30 | ![]() |
Groans: 30
| Not Ranked : 0 score i got mine 71 in, gonna wait for dyno results to post up
2014 Mustang GT | |
| The Following User Says Thank You to BlckMs3 For This Useful Post: | Voltwings (04-23-2013) |
![]() | | #31 | ![]() |
![]() Join Date: Apr 2011 Location: South Africa
| Not Ranked : 0 score What about running a gtx28, with spool at 3300, would that be danagerous, like a high load low rpm situation..... I have a stock block but I'm trying to match the right turbo for the 1/4mile.... |
![]() | | #32 | ![]() |
Rep Power: 3746 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
| Read . . . then donate . . . then read some more.
![]() | | #33 | ![]() |
![]() Join Date: Oct 2011
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11
| Not Ranked : 0 score My black ms3 has a .5557 w/ t-4 hotside running 17psi currently @16* timing on 93pump gas. Gonna get the meth kit working and fix the most fucked up maf cal in history and run 22-25psi and 19ish* timing. I'll get ligit dyno numbers up when I'm done with tuning. motor only has 21.5k miles currently so fingers crossed she's a strong one
__________________ White 2009 MS3: 100k mile pig HTP built gt3076r powered 6th port fueled Tuned by Nishan Black 2008 MS3: under construction #700orbust Last edited by stlskater92; 06-02-2013 at 12:37 PM. Reason: spell phail |
![]() | | #34 | ![]() |
![]() Join Date: Jun 2011 Location: Parma, OH
Rep Power: 1009 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 545
Groaned at 7 Times in 4 Posts
| Not Ranked : 0 score 6266 w/6th port 3 gal e85/ 9 gal 93 mix 26 psi at redline with only 12* advance at 6500. (tune in progress by @Realgib3 ) 99k on motor, great compression still. Was running a gt30 before this for about 10k miles on 390whp. Have about 5k on this setup.
__________________ Parting out car, 800whp motor with 4k miles on it, 6466 turbo kit... ect I also do diesel gear swaps hit me up for more info. |
| The Following 4 Users Say Thank You to Etipp98 For This Useful Post: |
![]() | | #35 | ![]() |
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) | |
| The Following User Says Thank You to cld12pk2go For This Useful Post: | Realgib3 (07-08-2013) |
![]() | | #36 | ![]() |
| Not Ranked : 0 score Yeah, I looove his turbo. I had a feeling it would be just about perfect, after seeing how my 6466 was reacting. He was knock limited on 93 at ~12*, so that's where we started with the 3gal blend. We'll work up to the ~15* range at 6500, get the tq as flat/low as possible, then see where we are. The car really moves out though already. Keepin tq low and still making good peak numbers is the toughest thing on these cars, partly because of our lack of rpm. I'd love peak numbers to be at 7500, rather than 6500, but since I've already kissed pistons from valve float on a very similar setup, we'll stick with the low rl for now. |
| The Following User Says Thank You to Realgib3 For This Useful Post: | Etipp98 (07-08-2013) |
![]() | | #37 | ![]() |
Now with a gen2 6266, JMF IM and a few other things. Ill probably try to get to the dyno soon to confirm im roughly in the ballpark of this VD.
__________________ Parting out car, 800whp motor with 4k miles on it, 6466 turbo kit... ect I also do diesel gear swaps hit me up for more info. | |
| The Following 15 Users Say Thank You to Etipp98 For This Useful Post: | 09TrueRedGTX (06-08-2015), Boost_creep (07-27-2015), cld12pk2go (06-08-2015), Code Monkey (06-08-2015), Easter Bunny (06-08-2015), ItsNox (06-08-2015), joeyspeed3 (06-08-2015), Mauro_Penguin (06-07-2015), Mazdazilla6 (10-19-2015), sho (06-08-2015), Snyeed (06-08-2015), SpeedRebirth (06-08-2015), speed_freak91 (06-09-2015), TRBLSM (06-23-2015), WetzMS3 (02-08-2016) |
![]() | | #38 | ![]() |
That is roughly 60whp more than I have ever seen on my stock block... Reverse taper FTW!
| The Following 3 Users Say Thank You to cld12pk2go For This Useful Post: |
![]() | | #39 | ![]() |
| Not Ranked : 0 score Knowing what i put my stock block through and seeing what you guys are doing, it really is a wonder how people manage to blow these things up...
| The Following 6 Users Say Thank You to Voltwings For This Useful Post: | cld12pk2go (06-08-2015), Easter Bunny (06-08-2015), ItsNox (06-08-2015), pmartz16 (06-08-2015), sho (06-08-2015), Vansquish (06-08-2015) |
![]() | | #40 | ![]() |
| Banned ![]() Join Date: Nov 2012 Location: Las Vegas NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 54
Groaned at 19 Times in 8 Posts
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/big-turbo-stock-block-thread-108396/ | ||||
| ? View topic - getting 300WHP out of a KO4 in JHB | This thread | Refback | 05-13-2013 09:59 AM | |
| HOW TO GET 400WHP FROM YOUR SPEED 3 (the practical way) | This thread | Pingback | 04-19-2012 03:02 PM | |
| Display Modes | |
| stock block big turbo dyno | kmac | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 178 | 06-24-2012 08:35 PM |
| Bad Turbo Results in New Block | batman | MazdaSpeed 3 - Engine, Transmission & Driveline | 31 | 02-22-2010 08:32 AM |
| So...Turbo/motor limits on stock block & internals? | 94jedi | MazdaSpeed 3/6 - Turbo Induction | 26 | 05-31-2008 08:01 AM |
