![]() | | #81 | ![]() |
| Not Ranked : 0 score He was knock limited on 93 at ~12*, so that's where we started with the 3gal blend. We'll work up to the ~15* range at 6500, get the tq as flat/low as possible, then see where we are. The car really moves out though already. Keepin tq low and still making good peak numbers is the toughest thing on these cars, partly because of our lack of rpm. I'd love peak numbers to be at 7500, rather than 6500, but since I've already kissed pistons from valve float on a very similar setup, we'll stick with the low rl for now. |
| The Following User Says Thank You to Realgib3 For This Useful Post: | Etipp98 (07-08-2013) |
![]() | | #82 | ![]() |
| Not Ranked : 0 score GT2871R in progress Actually running 21-22 psi at 12-13 deg RL 330cc W/m with 50/50 blend Waiting for next maf housing to increase boost a little more and install 3bar map sensor also... I'm surprise to see your high boost and timing level on stock internals i will probably remain more conservative...
![]() | | #83 | ![]() |
| Hide Yo Kids-No really, Hide them! ![]() Join Date: Oct 2011 Location: PMITA Jail until 12/2015
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,515
Groans: 77
| Not Ranked : 0 score T3 3076r .82 hotside 28psi 93 octane w 100% meth single d10 Tapered timing to 19.5* Bt since 22k. 49xxx now. |
| The Following 4 Users Say Thank You to Voltron For This Useful Post: |
![]() | | #84 | ![]() |
![]() Join Date: Jun 2011 Location: Parma, OH
Rep Power: 1009 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 545
Groaned at 7 Times in 4 Posts
Now with a gen2 6266, JMF IM and a few other things. Ill probably try to get to the dyno soon to confirm im roughly in the ballpark of this VD.
__________________ Parting out car, 800whp motor with 4k miles on it, 6466 turbo kit... ect I also do diesel gear swaps hit me up for more info. | |
| The Following 15 Users Say Thank You to Etipp98 For This Useful Post: | 09TrueRedGTX (06-08-2015), Boost_creep (07-27-2015), cld12pk2go (06-08-2015), Code Monkey (06-08-2015), Easter Bunny (06-08-2015), ItsNox (06-08-2015), joeyspeed3 (06-08-2015), Mauro_Penguin (06-07-2015), Mazdazilla6 (10-19-2015), sho (06-08-2015), Snyeed (06-08-2015), SpeedRebirth (06-08-2015), speed_freak91 (06-09-2015), TRBLSM (06-23-2015), WetzMS3 (02-08-2016) |
![]() | | #85 | ![]() |
![]() Join Date: Jan 2015
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 0
Groaned at 30 Times in 8 Posts
| Not Ranked : 0 score Still on stock block? Putting in Corksport turbo tomorrow on stock block, how do you recommend it be tuned? I see your torque delivery is a nice smooth up and then flat rather than the k04's jump to maximum at low rpms.
__________________ 2010 Gen 2 - "SPOOOL" (VIC/AU) - Fully bolted COBB AP3 | CORKSPORT TURBO | COBB DOWNPIPE | COBB REM | AUTOTECH HPFP | CORKSPORT TRUE 3" BIG MAF INTAKE | CPE TMIC | CUSTOM HEADERS | COBB 3 PORT EBCS | 3 BAR MAP| PEDDERS COILOVERS | DBA T4 SLOTTED ROTORS | CORKSPORT EYELIDS| FORGE V1 BPV| | MAGNAFLOW | VELOCITY RED | PEARL WHITE 2PAC STOCK RIMS | TUNED BY HP-F |
![]() | | #86 | ![]() |
That is roughly 60whp more than I have ever seen on my stock block... Reverse taper FTW!
__________________ 08 MS3: ATP GTX3071 at 26PSI , AEM Dryflow 21-2147DK, CP-E 3.25'' MAF, CP-E Nviscid TIP, PG FMIC piping with Treadstone TR11 core, Cobb BPV, Ported IM, PG v1 manifold, CP-E catted DP, CNT CBE, KMD v2, Grimspeed EBCS, Alkycontrol Meth injection (M10 with 100% meth), E40 fuel, Cobb AP (ATR= WIN), ACT ZX4-HDSS, 3-Bar MAP, JBR RSB, and CP-E 60 Duro Engine Mount Set. (297.3WHP/366.9WTQ - on K04, 469.2WHP/420.7WTQ - on GTX3071) | |
| The Following 3 Users Say Thank You to cld12pk2go For This Useful Post: |
![]() | | #87 | ![]() |
![]() Join Date: Nov 2010 Location: Houston, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,489
| Not Ranked : 0 score Knowing what i put my stock block through and seeing what you guys are doing, it really is a wonder how people manage to blow these things up...
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. |
| The Following 6 Users Say Thank You to Voltwings For This Useful Post: | cld12pk2go (06-08-2015), Easter Bunny (06-08-2015), ItsNox (06-08-2015), pmartz16 (06-08-2015), sho (06-08-2015), Vansquish (06-08-2015) |
![]() | | #88 | ![]() |
![]() Join Date: Oct 2013 Location: Lehigh Acres, Fl
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29
| Not Ranked : 0 score @Etipp98; That's some serious power man, never knew that was even posible good stuff
__________________ 2013 CWP Mazdaspeed3 Bnr S3 v2//Cobb AP//Autotech internals//3 BAR MAP sensor//3 port EBCS//CNT catback//Ebay catless DP//Tr8 core with cxracing piping kit//Hks bpv//Jbr True 3.5" intake//Jbr ssp//Jbr shift knob//Jbr Trilogy//XXR 527 habanero 18x8.75 +35//H&R springs//385/370 AWD mustang dyno |
| The Following User Says Thank You to joeyspeed3 For This Useful Post: | ItsNox (06-08-2015) |
![]() | | #89 | ![]() |
| Not Ranked : 0 score The CS turbo is going to give you a curve much more similar to a k04, but can definitely still be tuned to be safe on stock block. |
![]() | | #90 | ![]() |
| Not Ranked : 0 score Wouldn't be posting in here if it wasn't. Good luck with the turbo, you should hit up an e-tuner on here.
![]() | | #91 | ![]() |
![]() Join Date: Apr 2013 Location: Atlanta, Georgia
Rep Power: 1578 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,584
@ms6mil; You see this bro? I thought your 470+ was pushing it. Time to turn that shit up yo. I should have gotten a bigger terbow.
__________________ '06 Mazdaspeed 6 GT Power & Drivetrain BNR S3v2 / AP V3 + 100% Meth / Autotechs / JBR Tru 3.5" SRI w/ 51R Battery / ETS TMIC / DO Meth D07 @ 100% / ACT6 Puck w/ Streetlight FW / 80mm CorkSport Exhaust / SLS Test Pipe / Turbosmart BPV / Techna-Fit SS CL / AP Shift Hammer / Bosch 3Bar / Grimspeed EBCS / NGK 1 Step Colder / JBR Boost Tubes / ProSport Sammich Plate / Rotella Suspension & Mounts KWv2 Fronts & Bilstein Rears / AIDS Rear Diff Mounts / Whiteline RSB / Prothane Lowpro Bushings / Steeda Endlinks / JBR 88RMM / JBR Solid Bushings Brakes & Wheels StopTech Slotted Rotors & Pads / Technafit SS Brake Lines / Evo X Wheels / 245/40/18 Potenza RE760s Misc Redline & Unicorn Jizz (XTM5QS) / Sharkfin Antenna / Kuda Mount of Sweetness / Full TRS Mini-H1 Retrofit w/ Demon Eyes / TRS Xb LED Fogs / Hardwired Valentine 1 w/ Bluetooth / AuxMod w/Bluetooth - Miltuned On order/To be installed: E-btec Built Motor , BNR S4, CPe EWG Exhaust Mani, Precision 46mm WG, Kozmic 6th Port, CS FSB, RDMotorsportz Crash Bar, CS Injector Seals.![]() | |
![]() | | #92 | ![]() |
![]() | | #93 | ![]() |
| Not Ranked : 0 score "Spirited" 150+mph runs with the man transmission lol. http://www.mazdaspeedforum.org/forum/foru...ti-e85-172531/ |
| The Following User Says Thank You to Realgib3 For This Useful Post: | ItsNox (06-08-2015) |
![]() | | #94 | ![]() |
| Banned ![]() Join Date: Nov 2012 Location: Las Vegas NV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 54
Groaned at 19 Times in 8 Posts
| Not Ranked : 0 score |
![]() | | #95 | ![]() |
![]() Join Date: Jun 2015
![]() | | #96 | ![]() |
Rep Power: 0 ![]() ![]() ![]() ![]() Thanks: 3
Groaned at 9 Times in 5 Posts
| Neutral : -1 score 100% e85 21 psi 12* up top stock k04 turbo 320ish HP 54k miles and still tuning for more power I still have injector head room ![]() MODS: corksport race pipe auto tech hpfp internal cobb short ram intake cobb inlet pipe custom straight pipes no cats access port v3 100% e85 pro tune jbr 88 duro rmm soon fmic |
![]() | | #97 | ![]() |
![]() Join Date: Jul 2009 Location: Key West, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,273
Groans: 143
__________________ 2016 BMW M235i [Dead] 2006 MS6 #367 Liquid Platinum 73,000 miles Engine - Killah built -L19 Headstuds - Steedspeed T3 Twin Scroll top mount goodness - Twin Scroll .83 A/R hotside GTX3071R - JMF V1 IM - Perm 6th Port - CP-E FMIC - SURE 3.25 MAF housing - customized EBay DP - Magnaflow CBE - Autotech HPFP internals Electrical - GS EBC - Cobb AP Richtune in progress Drive train - Techna-fit Stainless Steel clutch and brake lines - stoptech rotors - CorkSport RMM - Corksport Trans inserts - SURE Juggernaught & Dreadnaught - E4 heavy knob & Jbarone's Short Shift plate - Tenzo DC-5 Bronze +45 wrapped in ExtremeContact DWS 235/40-18's Fluids Transmission - Motorcraft synthetic. PTO and Rear diff - Conklin Gold Guard Plus synthetic 75W-90. Engine Oil - Rotella T6 5W-40. | |
![]() | | #98 | ![]() |
![]() Join Date: Jan 2014 Location: Harco MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
| Not Ranked : 0 score 10GPH Methanol above 12psi 15.5deg timing @ 7000 25psi at around 6000 Vdyno from before upgraded exhaust manifold Oh and 141XXX miles and climbing daily. I have a dyno appt later this month so we will see how vdyno compares.
__________________ 2008.5 CWP MazdaSpeed3 Purple Drank Tuned ATP GT3076R @ 26 psi 369.5whp & 348wtq.. yawn |
| The Following User Says Thank You to alexwlwsn For This Useful Post: | Boost_creep (02-08-2016) |
![]() | | #99 | ![]() |
![]() Join Date: Nov 2010 Location: Riverhead, NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,457
| Not Ranked : 0 score 2009 MS3 with 92,xxx miles Gtx3071r Snow Performance 625ml/min nozzle 93 octane Ported intake mani/cpe exhaust mani/catted downpipe |
![]() | | #100 | ![]() |
![]() Join Date: Apr 2015 Location: Central Coast, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
| Not Ranked : 0 score 167K Freek Dynotuned 4 gal E85 / 91 OCT 379WHP/380TQ GTX3076R 21LBS @ 6000RPM
__________________ 2008 MS3 GT, Fully Bolted, Cobb AP V3, TR8 FMIC, JBR Piping, JBR 3.5 Wide Path, Autotech Internals, CPE Stage 2 Rear Motor Mount, CNT Catless DP, CNT Cat Back, 51R Battery Box, Cobb Short Shifter, Enkei RPF1's, Koni Yellows, GTX3076R, Freektuned. |
![]() | | #101 | ![]() |
![]() Join Date: Oct 2013 Location: FL -IN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 43
| Not Ranked : 0 score Gtx2867r .86 Tial ar. 25psi 15.5*@6k 400whp/ 370 wtq 100% meth do7 nozzle |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/big-turbo-stock-block-thread-108396/ | ||||
| ? View topic - getting 300WHP out of a KO4 in JHB | This thread | Refback | 05-13-2013 09:59 AM | |
| HOW TO GET 400WHP FROM YOUR SPEED 3 (the practical way) | This thread | Pingback | 04-19-2012 03:02 PM | |
| stock block big turbo dyno | kmac | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 178 | 06-24-2012 08:35 PM |
| Bad Turbo Results in New Block | batman | MazdaSpeed 3 - Engine, Transmission & Driveline | 31 | 02-22-2010 08:32 AM |
| So...Turbo/motor limits on stock block & internals? | 94jedi | MazdaSpeed 3/6 - Turbo Induction | 26 | 05-31-2008 08:01 AM |
