 Old 02-07-2018, 04:33 PM   #1
jaynick1's Avatar
Posts: 6   (View Stats)
jaynick1 is an unknown quantity at this point
Default Biost signal line
Hey guys reinstalling my turbo, and BNR forgot to include the boost line that runs from the housing to the wastegate. Main question is, since running stock boost setup, does that line have to be special...i.e. A restrictor or check valve? I should be ok using a normal silicone hose. Obiviously one that is pretty thick walled.
jaynick1 is offline   Reply With Quote
 Old 02-07-2018, 05:18 PM   #2
jaynick1's Avatar
Disregard, the restrictor is built into the tubine housing, answered my own damn question.
WHere does the sub signal come from? attomica 2010 MS3 - Car Audio & Electronics 8 12-06-2014 06:16 AM
HELP: Need way to invert ground output signal to 12v output signal dale_gribble Mazdaspeed3/6 General Discussion 9 10-17-2014 01:34 PM
Driver's turn signal - flashes on alarm but doesn't work with turn signal? xcoldricex MazdaSpeed 3/6 - Troubleshoot/Diagnostics 0 03-23-2014 08:50 PM
gauge signal ? jracer Mazdaspeed3/6 General Discussion 3 04-03-2012 11:41 AM
Tach Signal kore2000 MazdaSpeed 3/6 - Car Audio & Electronics 7 07-27-2009 08:18 PM
Page generated in 0.22746 seconds with 20 queries
