 Old 12-11-2009, 12:55 PM   #1
speed3po's Avatar
Posts: 5   (View Stats)
speed3po is an unknown quantity at this point
Default blow off valve
what is the preferred blow of valve for a 07 speed3?
speed3po is offline   Reply With Quote
 Old 12-11-2009, 10:56 PM   #2
cpolly69's Avatar
Posts: 2,116   (View Stats)
Groans: 27
forge bpv
txs bpv
turbo smart bpv
txs hybrid
turbo smart tybrid
hks ssqv
greddy
hell you can make anything work with the right flange
a lot of folks like the sound of hks, but it's up to you
08 CB MS3 Sport
Sold
01 MX-5 (Project)
03 P5 (DD)
The Following 2 Users Say Thank You to cpolly69 For This Useful Post:
BudUMfan (12-19-2009), skeeter149 (12-26-2009)
 Old 12-17-2009, 03:43 AM   #3
memin's Avatar
Posts: 994   (View Stats)
just pick one
 Old 12-18-2009, 12:01 PM   #4
Alpha's Avatar
Posts: 3,711   (View Stats)
Just be sure to run 100% recirculation with whichever you choose FTW.
The Following 3 Users Say Thank You to Alpha For This Useful Post:
Blackspeed (12-27-2009), NewMexican (01-09-2010), superskaterxes (12-18-2009)
 Old 12-18-2009, 12:07 PM   #5
18psiWhiteMS3
Lurkers
18psiWhiteMS3's Avatar
Posts: n/a
HKS
 Old 12-18-2009, 12:07 PM   #6
warmongoose66's Avatar
Posts: 210   (View Stats)
warmongoose66 has a reputation beyond reputewarmongoose66 has a reputation beyond reputewarmongoose66 has a reputation beyond reputewarmongoose66 has a reputation beyond reputewarmongoose66 has a reputation beyond reputewarmongoose66 has a reputation beyond reputewarmongoose66 has a reputation beyond reputewarmongoose66 has a reputation beyond reputewarmongoose66 has a reputation beyond reputewarmongoose66 has a reputation beyond reputewarmongoose66 has a reputation beyond repute
Yes Alpha is right.
2010 Liquid Silver MazdaSpeed 3
warmongoose66 is offline   Reply With Quote
 Old 12-18-2009, 12:08 PM   #7
18psiWhiteMS3
Lurkers
Posts: n/a
Just make sure u get the best one..... the HKS kit
 Old 12-24-2009, 08:20 PM   #8
mazdaspeed619sd's Avatar
Posts: 170   (View Stats)
mazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud ofmazdaspeed619sd has much to be proud of
Hahaha GREDDY! Daym you HKS lovers, i do miss my hks though =(. But greddy Type S here i come 8)
06 MS6 Black Mica
AWD BROTHERS SHALL UNITE!
Boys love straight lines.— Men love curves.— =)— Canyon/Circuit FTW!—
mazdaspeed619sd is offline   Reply With Quote
 Old 12-26-2009, 10:02 PM   #9
jayspeed3's Avatar
Posts: 356   (View Stats)
jayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond reputejayspeed3 has a reputation beyond repute
Groans: 60
Synapse Synchronic BOV FTW!!!
PITA to install, but well worth it.
Performance Mods: Cobb AP, e48 Tune (22psi), Cobb SF w/ Amsoil Filter, RPMC TIP, Synapse Synchronic BOV, Custom FMIC w/ Godspeed Type C, CP-e DP, Custom CBE, KMD v2 CDFP Internals, Denso ITV-22, MattD OCC, Castrol Edge 5w30, XT-M5-QS Gear Oil, SU RMM, Cobb STS, Cobb Stage2 Suspension Kit, Bilstein HD, RX-8 Wheels, Toyo Proxes 4 Plus (235/40/18)
jayspeed3 is offline   Reply With Quote
 Old 12-26-2009, 10:04 PM   #10
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
whatever you can afford that gets the job done if the stocker is indeed leaking.
 Old 12-26-2009, 10:12 PM   #11
Smoker6's Avatar
Posts: 984   (View Stats)
Smoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the worldSmoker6 is the leader of the world
Oddly enough I agree. After having used 4 BPVs I'm staying with the synapse. I came into it with low expectations because of people complaining, but it's a great BPV if set up correctly.
'06 Black Cherry Mica Speed6 Since 2-26-07 | 0-60: 3.87s |
CPE CAI, SU MM, Synapse BPV, Magnaflow 2.5" CBE, MDS DashHawk, TWM SS Stage 1, TT Front MM, TT Rear Diff Mount, SU StiffDiff, Whiteline RSB, BC Coilovers, mrlilguy CDFP, CPE Catted DP, HKS Twin Power Ignition System, RAYS Gram Lights 57 Maximum Time Attack, CPE TIP, Denso 2Step Colder Spark Plugs, COBB Shifter Weight, SPC Ball Joints, VTCS, BS, & EGR Delete, VentPod w/VEI Boost Guage, Saikou Michi CC, Labonte ISG-S3 (not installed), GT2871r, DNP manifold, Tial 44mm EWG, Cobb AP, TT Liquid to Air Intercooler, DMH 3" exhaust cutout.
Smoker6 is offline   Reply With Quote
The Following User Says Thank You to Smoker6 For This Useful Post:
jayspeed3 (12-27-2009)
 Old 12-26-2009, 11:07 PM   #12
ATAZ's Avatar
Posts: 314   (View Stats)
ATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond reputeATAZ has a reputation beyond repute
turboxs bpv for me
ATAZ is offline   Reply With Quote
 Old 12-27-2009, 02:58 PM   #13
214mazdaspeeder's Avatar
Posts: 39   (View Stats)
214mazdaspeeder is a splendid one to behold214mazdaspeeder is a splendid one to behold214mazdaspeeder is a splendid one to behold214mazdaspeeder is a splendid one to behold214mazdaspeeder is a splendid one to behold214mazdaspeeder is a splendid one to behold
HKS set to recirculate
DAMN COWBOYS!!!!!
214mazdaspeeder is offline   Reply With Quote
 Old 01-09-2010, 10:26 AM   #14
Posts: 2,827   (View Stats)
Nothing wrong with the stock BPV. Cobb Access Port instructions recommend its use and their maps are designed to use with it. I can't make mine leak at 28,000 miles running 13.4 quarters at 107, doing 40-120 is 12.5 seconds with my mods. It just does its job. In a recent study in a reputable magazine, it actually held boost better and at a higher level than its major competitor once the ECU nanny let the engine build full power in third gear. As you know, if you have any mods at all, we overpower the tires in first and second gear now and really can't use any more power there without drag radials, etc.
If you want an aftermarket valve, most of them work fine. Just be sure to run it in full recirc mode. Period. Any amount of vent to atmosphere in a MAF engine is takiing air already metered by the MAF and already matched with fuel and farting it to atmosphere, shooting excess fuel that was intended to have that oxygen into the engine and causing you to lose power, IMHO.
 Old 01-09-2010, 10:29 AM   #15
OMGWTFHAX's Avatar
Posts: 445   (View Stats)
OMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the worldOMGWTFHAX is the leader of the world
Groaned at 26 Times in 25 Posts
HKS on full recirculation ftw.
Flickr
Originally Posted by Andrew85 View Post
Wow kid... how about LOL @ you for being a piece of garbage without a purpose in life. For one thing, im not really bragging, just sharing an experience. Another thing is that you like men and your opinions dont count cause you take it up the poop shute.
OMGWTFHAX is offline   Reply With Quote
 Old 01-16-2010, 03:05 AM   #16
azokaei's Avatar
Posts: 75   (View Stats)
azokaei is just really niceazokaei is just really niceazokaei is just really niceazokaei is just really nice
So is it bad to have a 50/50 BOV?
azokaei is offline   Reply With Quote
 Old 01-16-2010, 10:39 AM   #17
Mistersix's Avatar
Posts: 2,585   (View Stats)
my experience is the car runs noticeably better fully recirculated.
i ran my turbosmart 50/50 for a summer and loved the sound but found the occasional backfire embarrassing. but other than that the car seemed to run fine. once i switched back to fully recirc i immediately noticed better acceleration and throttle feel was less jerky especially with cruise control.
what ever you do. do your car a favor and stay recirculated.
blow off valve suggestions nadiapopp MazdaSpeed 3/6 - Turbo Induction 37 04-18-2009 07:29 PM
Page generated in 0.34556 seconds with 34 queries
