![]() Join Date: Mar 2009 Location: IE in CALI
Rep Power: 0 ![]() Thanks: 0
![]() Join Date: Nov 2008 Location: tampa, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 32
Groaned at 16 Times in 4 Posts
__________________ 2010 mazdaspeed3 (current) jbr rmm, jbr stage 2 intake, jbr shifter bushings, cpe hpfp, obx cbe, catless downpipe, cobb fmic , bosh 3 bar map , jbr 3 port ebc,jbr IM and TB thermal gaskets, jbr egr delete, HKS ssqv,jbr short shift plate . |
![]() Join Date: Mar 2008 Location: PA
Rep Power: 1819 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,082
Groaned at 39 Times in 23 Posts
| Not Ranked : 0 score the HKS SSQ is by far the best design for the MS3/MS6 IMO
__________________ 2006 Mazdaspeed 6 / 386awhp/376awtq (Aug 2008) 2008 Caliber SRT4 / 11.8 @ 120 |
![]() Join Date: Jun 2008 Location: NW Indiana
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 361
| Not Ranked : 0 score You will want a BPV and not a BOV..Alot of people like the forge bpv.Also you may want a new intake as your first mod or just do both.
__________________ Pauter rods,Cp pistons 9.5:1 @ .020 over,ARP head & main studs,DNP ceramic coated exhaust mani.,TXS Dp,TXS Tp with high flow cat,PG reworked turbo,Cobb sri,Cobb fmic,Cobb Ap,Cobb inlet,HPFP,BSD,ACT street disk with light flywheel,TWM shifter bushing,rear MM,Oil CC and 1 step colder plugs and more http://videos.streetfire.net/profile/SharkDiver.htm http://www.youtube.com/user/sharkdiverjohn |
| Not Ranked : 0 score i runing the ssqv and btv those csrt4 are the shit my buddy has one pushing around 400 to the wheels
![]() Join Date: Aug 2008
| Not Ranked : 0 score I really like my Synapse Synchronic BPV. It can hold all the boost you can through at it. I'm not sure how many other people are running this set up. If you have any questions about it let me know. Justin |
![]() Join Date: Oct 2008 Location: Orlando, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 47
| Not Ranked : 0 score I have a turbosmart dual port and really like it. It gets a lower vent sound (not like the sword fighting sound).
__________________ |
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9
| Not Ranked : 0 score HKS, I also just picked up an NGR performance valve and its great as well. It sounds just like the greddy Type S. Sound clips can be found on youtube. I would say HKS if you just wanna bolt it up and not be bothered agaiin. Its the best BPV/BOV I ever owned. |
![]() Join Date: Apr 2008 Location: Cali
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 173
| Not Ranked : 0 score LOL, why would you want a BOV for a first mod? an intake will wield you more powr, and give you the nice turbo sounds, if thats what youre looking for.
| The Following 2 Users Say Thank You to Renzokuken For This Useful Post: | martyxattack (04-09-2009), phillyb (04-16-2009) |
![]() Join Date: Oct 2008 Location: Chicago
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,083
Groans: 365
Groaned at 594 Times in 575 Posts
| Not Ranked : 0 score this is what your first mod should be CPE Xcel NANO Short Ram Intake
| The Following User Says Thank You to boostedminime For This Useful Post: | Renzokuken (04-17-2009) |
![]() Join Date: Mar 2008 Location: In a house
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 54
| Not Ranked : 0 score dual port which is like the hks, when the pressure is low there is a secondary valve that opens releasing the pressure, when go above a certain psi the main valve opens to release the larger amount of air. I have the hks and do not have complaints, no leaks no adjusting necessary. You put it on and forget about it. and if you want to rice out you can cap off the recirc hose and put in the infamous hks fin for that super rice sound you can annoy people with. i was looking at synapse valve but i think since that is a push type valve that it is better used on a high power engine. ive also heard some good things about teh forge piece but you gota fuck with sims and all this stuff to stiffne the spring which im not a big fan off and i think its really unncessary unless your gona put down some serious numbers or increase boost.install, 5 minutes max if you have the big ass o ring on already. You just bolt off the stock valve and put the gasket on the new flange then bolt the valve on the intercooler. proly one of the easiest mods to install on this car besides fuzzy dice
__________________ 7-Inch Jensen Flip Out Touch Screen, HKS SSQ, MS CAI, Prosport Premium Amber/White Boost Gauge,2nd Cat Gutted, Delrin TRZ MM,16 inch FD rims,TWM shifter Bushings,COBB Turbo Inlet, 28psi, rebuilt stock block, custom rods and piston heads/gaskets, underdrive pulleys, big cams, big oil filter, stage4 clutch, stage4 DISI injectors, Fuel Pump, 4inch Catless TBE with screamer pipe, external wastegate spring modification,Methanol direct twin port duty cycle injection. Tuned by Nator Performance |
__________________ 2010 mazdaspeed3 (current) jbr rmm, jbr stage 2 intake, jbr shifter bushings, cpe hpfp, obx cbe, catless downpipe, cobb fmic , bosh 3 bar map , jbr 3 port ebc,jbr IM and TB thermal gaskets, jbr egr delete, HKS ssqv,jbr short shift plate . | |
![]() Join Date: Sep 2008
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 145
| Not Ranked : 0 score HKS HKS HKS! Say it with me HKS. Jeff at PG
__________________ All wagon, No traction |
(Thread Starter) | Not Ranked : 0 score i have def checked out the HKS and i love the sound it makes. ive also looked a little into turbosmart. now that ive done a little more research i def think my first mod would be a exhaust. im likeing borla!! i think ill prolly put some miles on the car before i do a BOV/BPV. i assume a swithching this out would void the warranty?? |
| The Following User Says NO Thank You to nadiapopp For This Un-useful Post: |
![]() Join Date: Mar 2008 Location: Bells, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 88
__________________ [SIGPIC][/SIGPIC] | |
| Thermonuclear Skeet ![]() Join Date: Jul 2008 Location: Triad N.C.
Rep Power: 3875 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,765
Groans: 188
Groaned at 333 Times in 222 Posts
Groans: 365
| Not Ranked : 0 score Do the stanky leg
![]() Join Date: Apr 2009 Location: Saint Petersburg, Florida
| Not Ranked : 0 score i had a turbosmart dual port bov. I loved that thing. Nice whip sound. So loud. People hear it a mile down the street. |
![]() Join Date: Nov 2008 Location: Merrimack, New Hampshire
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 134
| Not Ranked : 0 score is the turbosmart dual port bov hard to keep maintained? I would keep it on 100% recirc so would I just be better off waiting for the review of the turbosmart bpv? |
| Banned ![]() Join Date: Jun 2008 Location: misery
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11,510
Groans: 1,940
| Not Ranked : 0 score listen to some of the people here op. get a fucking intake |
| The Following 4 Users Say Thank You to phillyb For This Useful Post: | Dash08 (04-18-2009), doubleflusher (04-17-2009), FantasmoNegro (04-16-2009), Renzokuken (04-17-2009) |
Groans: 188
| Not Ranked : 0 score Putting a BOV on a stock intaked car is like putting a dress on a whore. |
![]() | | #24 | ![]() |
![]() Join Date: Jun 2008 Location: Dallas, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
| Not Ranked : 0 score ok....it seems like every1 in this thread discussing the hks are saying everything went flawlessly. are any of you guys running FMICs? I posted about this a while back and the response i got was that the hks recirc line gets kinked up and u've gotta do some type of work around to fix it |
![]() | | #25 | ![]() |
![]() | | #26 | ![]() |
![]() Join Date: Mar 2008 Location: south texas
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,310
Groans: 102
| Not Ranked : 0 score I love my Forge but I also have a turboxs rfl vta and I put it back on yesterday just for fun and love it! Thats thing is LOUD! Especcially since I havent heard it in a while...
![]() | | #27 | ![]() |
![]() Join Date: May 2008 Location: Jacksonville, Florida
Rep Power: 198 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 185
| Not Ranked : 0 score Forge BPV w/ blue spring ftw!
__________________ ![]() 07'MazdaSpeed3 Stage2+SF 93 FMIC Custom Map Current Mods: COBB AP, COBB SRI, COBB Inlet, COBB Cold Air Box, COBB Shift Weight, COBB STS, COBB PCV Catch Can, COBB Rear Sway Bar, M3M FMIC, TWM Shifter Bushings, FORGE BPV, Nator Rear MM, TurboXS DP, TurboXS RP, TB BYPASS MOD, MSD Dash Hawk, Denso 2-Step Colder plugs, Eibach Springs, BSD, KMD ver2 internals, EGR delete, PTP intake cooler kit, CNT Racing CBE, PG Exhaust Manifold |
![]() | | #28 | ![]() |
![]() Join Date: Jun 2008 Location: Reading, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 70
Groaned at 6 Times in 1 Post
| Not Ranked : 0 score i have the HKS SSQV and i absolutely love it. Sounds great and is a great design! |
![]() | | #29 | ![]() |
| Not Ranked : 0 score I ran forge bpv in vta this thing is fucking loud.....and now my car is shooting huge ass flames between shifts....what is weird that my boost gauge showed 24psi and no cut |
![]() | | #30 | ![]() |
Groans: 1,940
| Not Ranked : 0 score hks + fmic = cutting the recirc hose. really any valve and fmic will require a new recirc hose |
![]() | | #31 | ![]() |
![]() Join Date: Jan 2009
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 100
| Not Ranked : 0 score Get the nano! Im running a turboXS bpv. I scored it off a buddy for a hundo. If it were my choice HKS!! |
![]() | | #32 | ![]() |
| Not Ranked : 0 score The HKS sounds like a huge bird moaning in heat, and it looks like a robotic titty.
![]() | | #33 | ![]() |
Groans: 188
![]() | | #34 | ![]() |
| I <3 your mom ![]() ![]() Join Date: Jul 2008 Location: Long Beach, CA.
Rep Power: 14358 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 18,316
Groans: 293
| Not Ranked : 0 score Original Poster: Please for the love of God, get an INTAKE first. Then get the HKS or Forge BPV. Don't even consider a catback exhaust, it'll give you about 3-4 more Hp. If your gonna do exhaust, either do a race-pipe or a full turbo back. The cat-back alone is for sound only. If you insist on having a loud car, save some cash by deleting the resonators. |
![]() | | #35 | ![]() |
| Not Ranked : 0 score Intake intake say it with me I need a intake first before a blow off job
![]() | | #36 | ![]() |
![]() Join Date: Dec 2008 Location: atlanta, ga
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 206
Groaned at 37 Times in 27 Posts
| Not Ranked : 0 score fuck givin this guy advice. first he wants a bov then catback. he obviously doesnt give a shit about performance. he wants to sound fast and thats it.
__________________ know your roll |
![]() | | #37 | ![]() |
| Not Ranked : 0 score and he also only has 2 posts lmfao
![]() | | #38 | ![]() |
| Not Ranked : 0 score If you are looking for sound and performance, get a corksport full length intake. This will let you hear that turbo whine and the stock bypass valve. Jeff at PG
| need some suggestions | FWD=WWD | MazdaSpeed 3/6 - Car Audio & Electronics | 0 | 11-12-2008 09:28 AM |
