 Old 07-07-2009, 05:43 AM   #1
tburton101's Avatar
Posts: 201   (View Stats)
tburton101 is just really nicetburton101 is just really nicetburton101 is just really nicetburton101 is just really nice
Default Bnoon Banjo turbo restrictor bolt
Okay, So earlie this morning around 5:30am I wake up for work and say hmmm, i'm calling out of work. Okay anyways to the point. I got a bnoon banjo bolt that he made into a oil restrictor. I had to work on my cp-e fmic anyways because my turbo hot side had my coupler so oily that my hot pipe kept blowing off. But i fixed that and installed the banjo bolt tightened her all the way down until completely tight. Anyways I went for a hard ride and no smoke at idle! I then went for another ride i couldnt believe it no smoke at idle. Only smoke I had was once after a back fire after wot it was blue smoke, which I am going to order a Oil catch can. I think the oil catch can will fix that issue.
car was sold.
tburton101 is offline   Reply With Quote
 Old 07-07-2009, 06:14 AM   #2
Addikted To Boost's Avatar
Posts: 1,837   (View Stats)
Yea I was pretty fucking happy that mine quite smoking using his bolt too. I cant believe no one thought of this shit a long time ago. But i think with so many cars blowing up people have stopped caring about their cars smoking as much or something. Im using a bnoon bolt with a saikou michi catch can and no smoke at all.
09 MGM MS3
 Old 07-07-2009, 07:19 AM   #3
tburton101's Avatar
Hell yeah man it's deffentely awesome like I said I get smoke after wot sometimes. So I will buy a occ also what oil catch is that where you get it from and how well does it work??
car was sold.
 Old 07-07-2009, 07:48 AM   #4
Just search for saikou michi on google and you will find their website, you have to email the guy and he will let you know if they have any in stock and give you his paypal. They were recommended to me by some people on here and the quality is excellent. The stage 2 catch can is the one you want. It works great and keeps your oil from getting fucked up so fast.
09 MGM MS3
 Old 07-07-2009, 10:18 AM   #5
bnoon's Avatar
Posts: 1,770   (View Stats)
Glad it worked out for you guys.
Saikou Michi is the shit! I need to post pics of where I mounted mine. I don't have to pop the hood or lift up the car to drain it either!!! Just put a drain pan (or butter tub) under it and drain... takes less than 5 mins total.
2008.5 MS3 GT - Sold!
2013 Ford Focus SE - Sold!
2002 BMW M3 - Sold!
 Old 07-07-2009, 10:39 AM   #6
i wish you would because mine is a pain in the ass to drain.
09 MGM MS3
 Old 07-07-2009, 11:50 AM   #7
bnoon's Avatar
Well, until I get pics, I can describe how it's done...
Passenger's side of the radiator support, down at the bottom, there are two hard lines (I didn't look to see if they are AC or power steering lines or something else). There's a bracket where those two hard lines are bolted to the side of a radiator support area. I used heavy duty ty-wraps and tied it right to that bracket. Then, I used a 3" hole saw and cut through the plastic undertray right below the catch can to let the petcock stick through.
That's it! All I have to do is lay down and drain it into a butter tub or something like that.
2002 BMW M3 - Sold!
 Old 07-07-2009, 11:54 AM   #8
ugh wtf!!! i wish this worked for me =(
 Old 07-07-2009, 12:02 PM   #9
eddelgado's Avatar
Posts: 84   (View Stats)
eddelgado will become famous soon enougheddelgado will become famous soon enough
How often are your draining you Saikou Michi can?
I installed and drained after 1000 miles and had maybe 2-3 oz. I am running for 2500 miles this time to see if that is ok.
Ed.
eddelgado is offline   Reply With Quote
 Old 07-07-2009, 04:42 PM   #10
bnoon's Avatar
Ed.
I've had maybe 2-3 oz after about the same miles as you. First time using this one though, so I'm still experimenting.
2002 BMW M3 - Sold!
 Old 07-07-2009, 04:54 PM   #11
flyrevs2's Avatar
Posts: 1,235   (View Stats)
flyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the worldflyrevs2 is the leader of the world
Did this, and you will get group buy pricing $85 delivered for a stage 2 5/8" CC everything you need except hose.
Now the hose is a problem - you can't use heater hose it will collapse under vacuum. Try to find vacuum resistant hose - good luck I can't find any. What are you guys using for hose on the CC setup ??????
Thanks!
2013 Mazdaspeed3 Gen2
Mods: Cobb SRI, Tip, Turbosmart BPV, Cobb AP, Cp-e DP, CPE HPFP, CPE RMM, PTP Kicker Mount
flyrevs2 is offline   Reply With Quote
 Old 07-07-2009, 06:21 PM   #12
bnoon's Avatar
Thanks!
You CAN use heater hose, it just has to be the HEAVY DUTY heater hose that doesn't collapse under vacuum. Here's some online http://www.ebasicpower.com/pc/MPI132...r%20Foot).html
Also recommended if you're going the catch can route is a SECOND PCV!!!!!!
2002 BMW M3 - Sold!
 Old 07-07-2009, 07:04 PM   #13
eddelgado's Avatar
I used a marine grade gasohol rated fuel line in 5/8". I purchased it off some marine supplier from e-bay.
Ed
 Old 07-07-2009, 07:35 PM   #14
flyrevs2's Avatar
Originally Posted by bnoon View Post
You CAN use heater hose, it just has to be the HEAVY DUTY heater hose that doesn't collapse under vacuum. Here's some online Heavy Duty, Water Heater Hose 0.625" (Per Foot): eBasicPower Marine Engine Parts & Fishing Tackle
Thanks!!!!!! How many feet do I need - 10 feet ???
 Old 07-07-2009, 09:00 PM   #15
failure's Avatar
Posts: 77   (View Stats)
failure has a brilliant futurefailure has a brilliant futurefailure has a brilliant futurefailure has a brilliant futurefailure has a brilliant futurefailure has a brilliant futurefailure has a brilliant futurefailure has a brilliant futurefailure has a brilliant futurefailure has a brilliant futurefailure has a brilliant future
Groaned at 3 Times in 1 Post
Bnoon, are you going to make another set of bolts or no?
failure is offline   Reply With Quote
 Old 07-08-2009, 10:58 AM   #16
bnoon's Avatar
Yeah, I think I did mine with 10 feet and had about 2 feet left over.
Don't know, haven't worked out the details yet.
2002 BMW M3 - Sold!
 Old 07-09-2009, 12:45 AM   #17
Yahdy Ras's Avatar
Posts: 221   (View Stats)
Yahdy Ras is a splendid one to beholdYahdy Ras is a splendid one to beholdYahdy Ras is a splendid one to beholdYahdy Ras is a splendid one to beholdYahdy Ras is a splendid one to beholdYahdy Ras is a splendid one to beholdYahdy Ras is a splendid one to behold
Groaned at 14 Times in 7 Posts
so you cant just get a hose from home depot or something?
Yahdy Ras is offline   Reply With Quote
 Old 07-09-2009, 06:27 AM   #18
eddelgado's Avatar
The problem with most hoses from a home depot type store is that they are not fuel/oil resistant and will collapse under vacuum. You may have the same problem with standard heater hose.
Ed.
 Old 07-09-2009, 07:21 AM   #19
bnoon's Avatar
Ed.
Actually, I just got some heavy duty hose from Home Depot last night that is automotive grade heavy duty hose. I had to get some more because I want to relocate the PCV and reroute the hoses a bit... The odd thing was, the Oriely's (however you spell that) auto parts store only had the wussy single layer wrapped stuff and no heavy duty hose in 5/8".
2002 BMW M3 - Sold!
 Old 07-10-2009, 09:09 PM   #20
jlocurto's Avatar
Posts: 388   (View Stats)
jlocurto is the leader of the worldjlocurto is the leader of the worldjlocurto is the leader of the worldjlocurto is the leader of the worldjlocurto is the leader of the worldjlocurto is the leader of the worldjlocurto is the leader of the worldjlocurto is the leader of the worldjlocurto is the leader of the worldjlocurto is the leader of the worldjlocurto is the leader of the world
bnoon you'd probably make good money making more of the bolts, i know i want one lol
08.5 BM MS3 GT; CPE Nano; Forge BPV; CPE Catless TBE; CPE 60 RMM: ITV22; Cobb AP Stage 2 +SF 93; PTP HPFP; CPE Front Mount Intercooler
jlocurto is offline   Reply With Quote
 Old 07-11-2009, 02:45 PM   #21
bnoon's Avatar
I'm actually down money from the first run after shipping/site donations and drill bits (broken or dulled). The tiny bits don't last long at all and cost nearly $4 each. Not doing any more. Unless you guys can afford a price jump. But after Mazda comes out with their revised PCV, we'll see if that is worth a damn, then see if it's still worth it to make more.
2002 BMW M3 - Sold!
 Old 07-11-2009, 04:35 PM   #22
failure's Avatar
How much were they going for? Shipping should also be on the buyer.
 Old 07-12-2009, 04:29 PM   #23
bnoon's Avatar
FYI, I'm doing another run of 20 bolts. Few bucks more than the first run and I'll give you shipping options if you want tracking/etc. The updates are in my "Quest to cure..." thread.
2002 BMW M3 - Sold!
 Old 07-12-2009, 04:59 PM   #24
red07's Avatar
Posts: 290   (View Stats)
red07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant futurered07 has a brilliant future
Got the bolt in today. Easy install. I took the TMIC all the way off, and had a factory fail, the rubber TMIC bracket grommets were torn, so I have to get some new ones.
Install is literally remove TMIC/shroud, remove heatshield, remove bolt, install bnoon bolt, reinstall heatshield/TMIC/shroud, and done.
No smoke so far, I'll run it harder this week as the temps will break 100, and I'll see how things are.
Brad, your bolt was longer than the factory bolt. Is that normal?
Larry
red07 is offline   Reply With Quote
 Old 07-13-2009, 10:06 AM   #25
bnoon's Avatar
Larry
Yes, it's normal. It's maybe 1/8 longer or so... There are enough threads to engage in the stock turbo and the extra length does not block the oil from feeding both sides of the center section, so we're OK.
2002 BMW M3 - Sold!
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/bnoon-banjo-turbo-restrictor-bolt-31861/
Oil banjo bolt - K04 - Page 2 This thread Refback 01-15-2013 11:15 AM
Oil banjo bolt - K04 This thread Pingback 07-28-2010 06:35 AM
Oil restrictor bolt install bnoon MazdaSpeed 3 - How-To's 250 03-19-2014 06:47 PM
New turbo option, bolt on for MS3/6/CX7 wassup61 MazdaSpeed 3/6 - Turbo Induction 35 06-29-2009 08:09 PM
2871 really bolt on? Speedie6 Mazdaspeed3/6 General Discussion 15 10-03-2008 01:03 PM
Page generated in 0.42787 seconds with 29 queries
