Like Tree12Likes
 Old 04-29-2013, 12:05 PM   #1
Default BNR S3 exhaust housing bolts backing out/breaking/leaking thread
If you've had this problem, post up the information and let's see if we can identify some trends and address the issue. All gens obviously welcome!
Username:
Mileage on BNRS3 turbo:
What was the failure (which bolts backed out, broken, other?):
Boost level you are running:
Are you using the bottom supporting bracket bolted to the block?:
How is the car driven (street, hard, tracked, etc):
Did you retorque the exhaust bolts at any time prior to failure?:
Does your turbo have any locking washers on these bolts?:
How did you fix it?:
Sloanek
4000 miles (1000 when it started to leak)
Bolts on exhaust side and compressor side backed out causing a boost leak. After retorquing all bolts w/lock washers there was still a leak on the compressor side for unknown reason. (Will be taking off turbo this weekend to inspect it)
22 psi
Car is hardly in boost other than doing logs
I did not retorque the bolts prior to failure
I added lock washers for all bolts on both sides.
Not fixed yet, but will fix after I replace it with a new gtx3071 this weekend.
Before the problems I loved this turbo so much. The only reason why I am dropping the bnr and getting the gtx3071 was the way Bryan treated me over the phone when I called. He didn't have an open mind about the bolts on the compressor side causing the boost leak and just straight out denied it being a problem that could cause my boost leak.
Himurax13
2000 miles
One of the bolt closest to the drainline/firewall backed out and the other one was loosely hanging with the plate.
Yes
20 tapering to 22.
Mostly DD, occasionaly canyons, tracked at Willow Springs, onramps with autority. several WOT logs.
No
No
Fixed by inserting cheap grade 5 stainless bolts from the bottom while still in the car. Had to use a dremmel to turn bolts into self tapping screws and then use the goodntight torque method. No leaks were detected and held for 4 months before pulling off car.
MPS_Fan
1500 miles
Bolt in direction to firewall (directly besides coolant line) fell completely out and other bolt on same braket was loose.
One bolt in direction to motor broke when i tried to remove it. Got stuck in middle of threads, when i tried to srew in again (without any force) the head just fell off
reverse tapper to 23psi (redline)
yes
street, sometimes highspeed runs for couple of minutes
No, but they are ok
No
Not fixed yet, will use high tensile bolts (8.8) and special washers:
Turbo has to get out to drill out the bolt, fuuuuuuuuuuck!
Username: Paveltol
Mileage on BNRS3 turbo: 60 000 km
What was the failure (which bolts backed out, broken, other?): one of the bolts holding the bracket and exhaust side together is backing out every ~5 000/10 000km. Once it caused the coolant line get burnt by the exhaust flame, the coolant started leaking hard. It took me 3 hours being 100 km away from the nearest town at 3 AM and -25C to try and fix the car to drive home without coolant and exhaust leak.
Boost level you are running: 1.1 Bar
Are you using the bottom supporting bracket bolted to the block?: Yes
How is the car driven (street, hard, tracked, etc): Street/Highway
Did you retorque the exhaust bolts at any time prior to failure?: No
Does your turbo have any locking washers on these bolts?:No
How did you fix it?: I disassembled the old OEM turbo, took one of its bolts, and screwed it into the bnr with very small amount of loctite on the thread. 3000 km since then.. Next time I will put put locking washer.
I contacted Bryan a couple of times regarding that issue, he promised to send me some new caps, that are supposed to solve the issue. He never did.
Username: jdw1
Mileage on BNRS3 turbo: ~15-20k
What was the failure (which bolts backed out, broken, other?): not sure, one on the bracket
Boost level you are running: ~20psi
Are you using the bottom supporting bracket bolted to the block?: Hell if I know
How is the car driven (street, hard, tracked, etc): Street DD but I beat on it some times
Did you retorque the exhaust bolts at any time prior to failure?: yes
Does your turbo have any locking washers on these bolts?: no
How did you fix it?: new bolt and thread seal
The Following 19 Users Say Thank You to Lex For This Useful Post:
06Speed6 (04-30-2013), ABolewski (04-30-2013), atvfreek (04-29-2013), boostdmazda3 (04-29-2013), breakfstincluded (04-30-2013), Code Monkey (04-29-2013), cshunter (05-03-2013), cymen (05-03-2013), fivefingerdeathpunch (04-30-2013), jack_hammer (04-30-2013), KevMS6 (05-03-2013), Mchart (04-29-2013), meicalnissyen (01-30-2015), Menace1 (05-02-2013), Micha (04-30-2013), paveltol (04-30-2013), sleepyspeed6 (05-03-2013), SLOWHATCH (04-30-2013), TiGraySpeed6 (04-29-2013)
 Old 04-29-2013, 12:32 PM   #2
sloanek's Avatar
Posts: 38   (View Stats)
sloanek is a glorious beacon of lightsloanek is a glorious beacon of lightsloanek is a glorious beacon of lightsloanek is a glorious beacon of lightsloanek is a glorious beacon of lightsloanek is a glorious beacon of light
Sloanek
22 psi
sloanek is offline   Reply With Quote
The Following 4 Users Say Thank You to sloanek For This Useful Post:
breakfstincluded (04-30-2013), Easter Bunny (04-30-2013), Lex (04-29-2013), SLOWHATCH (04-30-2013)
 Old 04-29-2013, 12:37 PM   #3
sloanek's Avatar
Oh and before anyone ask when the turbo is fixed it will probably be sold locally. Unless you want to pay way more for it HAHA.
 Old 04-29-2013, 12:41 PM   #4
Was the bottom bracket bolted to the turbo during this time?
 Old 04-29-2013, 12:38 PM   #5
boostdmazda3's Avatar
Posts: 1,177   (View Stats)
boostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the worldboostdmazda3 is the leader of the world
very curious to see how many more people chime in.
Bnr s3/Act 6 puck/sure full 3inch intake/cobb fmic/cobb downpipe/grimmspeed ebc/3 bar map/hks catback/autotech hpfp internals/turbosmart bpv/bc coilovers/jbr trilogy mounts/ngk one step colder plugs/ms6 rims on nt-01 tires. 24 psi E85 freektuned.
Freektuned e85 Focus st as the daily.
boostdmazda3 is offline   Reply With Quote
 Old 04-29-2013, 12:42 PM   #6
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Himurax13
2000 miles
Yes
20 tapering to 22.
Mostly DD, occasionaly canyons, tracked at Willow Springs, onramps with authority. several WOT logs.
No
No
Pickles Tune in progress
The Following 3 Users Say Thank You to himurax13 For This Useful Post:
atvfreek (04-29-2013), Easter Bunny (04-30-2013), Lex (04-29-2013)
 Old 04-29-2013, 12:56 PM   #7
Himurax13
2000 miles
20 tapering to 22.
No
No
Bracket to block used?
 Old 04-29-2013, 01:04 PM   #8
himurax13's Avatar
Groans: 255
Whoops, updated post to yes. I believe I was the lucky one to experience this first. I believe it happened on the way to the NATOR pool party last year (my car sounded like an mid 80's Mercedes Turbo diesel).
It only took us 3 months to find it (I replaced every gasket from the block to the catback).
Lex (04-29-2013)
 Old 01-27-2015, 08:01 PM   #9
txmedic512's Avatar
Posts: 63   (View Stats)
txmedic512 has much to be proud oftxmedic512 has much to be proud oftxmedic512 has much to be proud oftxmedic512 has much to be proud oftxmedic512 has much to be proud oftxmedic512 has much to be proud oftxmedic512 has much to be proud oftxmedic512 has much to be proud oftxmedic512 has much to be proud of
Default bnr s3 bolts
I was going through this old thread and I have a feeling I am similar issues to yours. How was your bnr building boost during wot? I am currently fully bolted running reverse taper to 25 psi and building boost down low is shit until about 4100 rpms. I have been reading that I should be hitting full boost around 3300 rpms.
Himurax13
2000 miles
Yes
20 tapering to 22.
No
No
txmedic512 is offline   Reply With Quote
 Old 01-28-2015, 01:28 PM   #10
himurax13's Avatar
Groans: 255
The boost curve was fine. However my AFR's at WOT were all over the place.
Who is tuning you?
A BNR should be able to hit 20+ lbs of boost by 3200 RPM's or so.
Do you have the newest version?
 Old 01-28-2015, 03:54 PM   #11
2.0t03speed's Avatar
Posts: 1,302   (View Stats)
Who is tuning you?
i am tuning him (Ryan @ PD) his is the old bnr. literally have thrown everything at this bnr and it won't spool faster. vvt is up to 30*+, added preload, 80% wgdc and the turbo won't hit 20 psi till 4100. Afr has been fairly flat this entire time. it's just spooling really slow. All the flange bolts have been checked. No problems there. The only things left to check are the chra bolts and the exhaust housing to see if maybe the housing or the waste gate flapper is cracked. I've tuned a bunch of bnr's and this is the first time i've ever encountered one acting like this.
The Following 2 Users Say Thank You to 2.0t03speed For This Useful Post:
Easter Bunny (01-28-2015), txmedic512 (01-28-2015)
 Old 04-29-2013, 12:57 PM   #12
MPS_Fan's Avatar
Posts: 436   (View Stats)
MPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the worldMPS_Fan is the leader of the world
Groaned at 17 Times in 8 Posts
MPS_Fan
1500 miles
yes
No, but they are ok
No
MPS_Fan is offline   Reply With Quote
 Old 04-29-2013, 01:02 PM   #13
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
How about safety wiring the bolts?
Nator is what it does.
 Old 04-30-2013, 07:17 AM   #14
paveltol's Avatar
Posts: 520   (View Stats)
Hello Alex! I have the same issue.
Username: Paveltol
paveltol is offline   Reply With Quote
The Following User Says Thank You to paveltol For This Useful Post:
 Old 04-30-2013, 07:54 AM   #15
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
what a bummer to hear!
it's fun to do bad things
 Old 04-30-2013, 08:35 AM   #16
MPS_Fan's Avatar
@paveltol
+1 for awesome customer service, i even didn't got an answer.
Why only 1.1 bar? Isn't running such low boost on bnr wasted money?
 Old 04-30-2013, 10:46 AM   #17
paveltol's Avatar
Originally Posted by MPS_Fan View Post
@paveltol
I am running a very conservative tune on a RON95 gas with that boost pressure. The tuner managed to make just 279 hp last time I took my car to the dyno tuning, saying that I had a bad VVT actuator. I was quite disappointed with those numbers, because before that he made 301 hp with stock turbo and with no supporting mods. I totally replaced the VVT and haven't done any new tune since then. Still, even with that boost the car pulls well.
The graphs:
Stock car without a tune made 271hp on RON95 with only an inlet pipe and an ignition aplifier.
After the tune on RON95 it made 301 hp.
After adding BNRS3+FMIC+3"catless dp+hpfp+sri it made 279hp)) With same RON95 in tank)
Now I have an AP and willing to do the e-tuning with Lex @ Stratified Auto. When finished, I'll post the figures & impressions.
The Following 2 Users Say Thank You to paveltol For This Useful Post:
Lex (04-30-2013), SLOWHATCH (04-30-2013)
 Old 04-30-2013, 11:01 AM   #18
The graphs:
If the fuel can support it, we will definitely be making a lot more power on your setup
Op updated. It appears that this is a common issue. Keep posting!
Last edited by Lex; 04-30-2013 at 11:01 AM. Reason: MSF Database - Automerged Doublepost
 Old 04-30-2013, 11:05 AM   #19
kish89's Avatar
Posts: 292   (View Stats)
kish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the worldkish89 is the leader of the world
The graphs:
I don't get it, almost stock MPS 6 dynoed 271WHP ?
It seems that you got factory freak lol, because I'm currently at those power levels with all mods I have.
Ok, I'm still in the middle of tuning, but I'm not expecting more than 290WHP on pump gas tune, we will see what gains I'll get with meth.
06 MS6, Versatuner, Stratified Tuned
BNR Stage 3 turbo, Eagle con. rods, HTP Full 3" intake + AEM DryFlow filter
Autotech HPFP internals, Forge V1 BPV
Custom 3" cat-back with stock mufflers, M2 3" catless Downpipe
Grimmspeed EBCS + Stratified Boost Dial, 3BAR BOSCH MAP
NGK Iridium IX one step colder plugs, CPE SafeSeals & studs
Custom FMIC with 2.5" piping and Treadstone TR8 IC
SnowPerfomance WMI, Stratified Guardian Angel
Eibach pro kit lowering springs
kish89 is offline   Reply With Quote
 Old 04-30-2013, 11:04 AM   #20
paveltol's Avatar
I believe we will!
 Old 04-30-2013, 11:11 AM   #21
paveltol's Avatar
The hp i have written about are definitely not whp!)
kish89 (04-30-2013)
 Old 04-30-2013, 12:19 PM   #22
MPS_Fan's Avatar
@paveltol
You have chosen the right way. I was just in mid tune process when I lost my bolt now I have to fix this first. But I can tell you, tune is not finished and the car is a beast!!! Are you using Toyota seals?
Oh and my coolant line was also little bit toasted. But I drove only 50km with this leak and always out of boost. Seems that we are loosing the same bolt!?!?
So btt
@lex
What do you think about using standard high tensile bolts with washers like on the picture instead of stainless steel? I mean the exhaust studs also just made of high tensile material wich takes the expansion much better. I know that they will rust, but the threads should stay intact (maybe use anti-size paste) and in this area there's absolutely no water and its dry, so that the bolts should last a very long time.
I could also use stainless steel bolts coated with silver (have them at work), that should prevent the bolt from getting stuck. We use them for stainless steel to stainless steel connection. Because screwing stainless steel bolt a few times in and out eats up the threads. This is a common issue and the material is still not good for this stressed area (high temperature, lot of expansion).
 Old 04-30-2013, 01:14 PM   #23
paveltol's Avatar
@paveltol
Yes, it seems like we are losing the same bolt, which is hard to get back in place with a coolant line connected to the turbo - nearly no space for tools..
I am using stock seals. So far they are holding fine. Don't know which seals to put in when doing the engine rebuild.. CP-E/Toyota??
 Old 04-30-2013, 03:15 PM   #24
@paveltol
So btt
@lex
Here's a good reference:
Carpenter Products - Selecting High Temperature Alloys for Fasteners in Automotive Exhaust Systems - Carpenter 286-LNi
 Old 04-30-2013, 12:22 PM   #25
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
good thread idea!
 Old 04-30-2013, 02:56 PM   #26
MPS_Fan's Avatar
I removed the cooling line and heat shieldings, it was impossible to get it back with the line attached.
 Old 04-30-2013, 03:25 PM   #27
himurax13's Avatar
Groans: 255
It helps to have small, angry, asian hands. Big, manly, German hands will not work..
I believe I removed the coolant line and the oil drain line to gain access. Even with those out of the way, the amount of room to work is extremely small. I had to do most of the work by feel. I ended up shaving off the first few threads of the bolt so I could finger it in then tighten with an open end wrench. This took me a few hours, most of which was spent cursing.
 Old 04-30-2013, 04:11 PM   #28
dereeek's Avatar
Posts: 2,053   (View Stats)
Groans: 386
Just went and checked out my BNR3 the only bolt I'm missing is on the bottom where the turbo bracket and hot side connect. installed at 21,400k & now 28k miles
My one year with the BNR is coming up in July. I remember when I got it I went to the local screw-nut store(no idea what the name is) and had them match stud and nuts that I bought from SU(OEM replacement). I believe they were stainless steel with lock washers.
BNR3-FREEK-PU-398HP
 Old 04-30-2013, 07:30 PM   #29
kritz's Avatar
Groans: 95
How about these?
http://www.stage8.com/perfauto.html
Sent from fastest ko4 Pu!
 Old 05-03-2013, 12:34 AM   #30
sidekick's Avatar
Posts: 3,093   (View Stats)
Groans: 47
How about these?
Performance Auto | Locking Fasteners
I wasn't involved with it myself, but a couple years ago I remember reading about a lot of VW guys that were having issues with nuts/bolts backing out on the 1.8t and their solution was to use these. They seemed to work out very well for those that tried them, but then again, how can they not? Lol. They literally lock the nut against a solid object so it has nowhere to go.
 Old 05-03-2013, 02:46 AM   #31
MPS_Fan's Avatar
This bolts would be fine. But you find them only in M8 or M10 :-(
What we need is M5
sidekick likes this.
The Following User Says Thank You to MPS_Fan For This Useful Post:
kritz (05-03-2013)
 Old 04-30-2013, 09:11 PM   #32
Speeeeeed
06Speed6's Avatar
Posts: 6,530   (View Stats)
Stage 8 is good, or an oem turbo stud/nut. Ide never reused a turbo nut and I always use a oem stud nut combo and ive never had one back out. The 1700+* temps dont play around and HD nuts and bolts just arent rated to those temps, all oems that I am aware of use special materials in their studs and nuts so that they stay tight through the heat cycles. I think there are several cars that use inconel studs, I think Porsche and the new GTR both do, they generally are way cheaper than aftermarket options.
2006 Mazdaspeed 6
 Old 04-30-2013, 09:20 PM   #33
Ur moms boyfriend
forcedinduktion's Avatar
Posts: 2,719   (View Stats)
Groans: 70
Aircraft Quality Turbo Lock Nut, M10 x 1.5 (SET OF 4 NUTS) - NEW LOWER PRICE - 034Motorsport | Performance Parts for Audi, Porsche, and Volkswagen
 Old 05-02-2013, 10:29 AM   #34
MPS_Fan's Avatar
I trie to decide wich route i should go:
1.Use silver coated A2-70 bolts with lock washers like on my picture with low torque and wiring them
2.Use 8.8 Bolts with special lock washer but more torque.
At the moment i tend to nr. 1 because wiring the bolts seems to be quite efficient and i don´t risk that the bolts get sized because A2 + silver coating.
 Old 05-02-2013, 10:44 AM   #35
Let's see if we can get a stud and nut combo. That way if the nut backs out you still don't have a leak.
 Old 05-02-2013, 11:27 AM   #36
paveltol's Avatar
I think we need custom coolant line with heat shield and a stud as a kit.ImageUploadedByTapatalk1367515457.193654.jpg
 Old 05-02-2013, 09:55 PM   #37
razorscs's Avatar
Posts: 391   (View Stats)
razorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the worldrazorscs is the leader of the world
So everyone having problems is using the bracket... Does that mean that since I don't have it I'm definitely screwed?? Haha
2007 MS6- BNR S3, HTP 3" Intake, 3 Bar MAP, DO Meth, CP-E Catted DP, Autotech Internals, SRI, ETS TMIC, Sure Sidewinder, Sure Charge Tubes, Lex tuned, BC Coils, Sure RMM, JBR SSP, Dreadnaught, Whiteline RSB
2008 Mazdaspeed3- Totalled!
razorscs is offline   Reply With Quote
 Old 05-02-2013, 10:52 PM   #38
himurax13's Avatar
Groans: 255
Actually, mine was pre bracket. He probably designed the bracket because of my frustration. I tokd him I spent a lot of money and a great deal of time to locate the leak. I was rather upset. My temporary fix held up the rest if the time I had the turbo. I sent it in when I stocked out to have him rebalance the wheel and upgrade it.
Sent via stockish Black Mica Pu
 Old 05-02-2013, 11:41 PM   #39
razorscs's Avatar
Wait are we not talking about the stock Turbo Support Bracket here?
 Old 05-03-2013, 12:13 AM   #40
When I installed mine I snugged up the bolts. A few were loose and the turbo was used. I have about 3k hard miles on it and I haven't seen any of the heads break or any of them back out.
I had a similar issue on a previous turbo car. Bolt fell out but once I replaced it and tightened it down, it never came out for the many years I owned the car.
I have a feeling they come too loosely attached from BNR.
Easter Bunny (05-03-2013), JDW1 (05-03-2013)
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/bnr-s3-exhaust-housing-bolts-backing-out-144177/
Beaner time! - Page 20 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 06-07-2013 04:58 PM
exhaust spring bolts slashsnake 2010 MS3 - Engine, Transmission & Driveline 10 12-17-2012 11:27 AM
Leaking exhaust gases mps-passion MazdaSpeed 3 - Engine, Transmission & Driveline 3 06-18-2012 10:57 PM
exhaust gaskets, bolts, etc. needed greenespeed Mazdaspeed3/6 General Discussion 3 10-05-2011 12:49 PM
WG right off the exhaust housing -cj- MazdaSpeed 3/6 - Big Turbo Builds 4 07-15-2010 09:22 PM
Page generated in 0.68646 seconds with 37 queries
