![]() | | #81 | ![]() |
![]() Join Date: Oct 2011 Location: Murrieta, CA
Rep Power: 2715 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,575
| Not Ranked : 0 score |
![]() | | #82 | ![]() |
| 5000lbs of voiceless fury ![]() Join Date: May 2012 Location: San Diego, CA
Rep Power: 2530 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,855
Groans: 185
Groaned at 124 Times in 81 Posts
__________________ 2015 Telsa Model S 85D - Delivered 10/21/2015 FYEN! SOLD!!! 2007 Mazda MS6 - //AWD//BNR S3//cp-e TMIC//cp-e CDFP//Cobb AP//Cobb TIH//Cobb EBCS//Bosch 845 3 Bar//MS-CAI//Custom DP//TS Kompact BPV//Magnaflow CBE//AWR RMM//JBR Stage 3 SSP Kit//JBR EGR Delete//H&R Springs// | |
| The Following User Says Thank You to Caligula For This Useful Post: | UnknownSuperhero (05-06-2013) |
![]() | | #83 | ![]() |
![]() Join Date: Feb 2012 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,815
Groans: 255
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress | |
![]() | | #84 | ![]() |
![]() Join Date: Oct 2012 Location: Odenville, AL USA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8
| Not Ranked : 0 score If I don't hear about potential problems, I don't know how to fix them. I have been in business for 12 years doing nothing but custom turbos. I have never had issues with bolts in compressor housings stripping out. I am not saying there won't be a first . When people do boost leak test and they see some air bubbles coming from around the bolts on the compressor side, what they think is to tighten the bolt. So they tighten, and tighten and ofcourse it strips out the threads. There aren't O rings or sealant on the bolts to prevent some seapage. Now I can put longer bolts in the compressor housing to give it more bite into the housing, but the bolt end goes into the volute of the compressor housing causing a disturbance in air flow. If you have a stripped out thread on the compressor housing, you can either: A) tap the hole with M8 by 1.25 tap and use a M8 by 1.25 12mm-14mm Length bolt. B) drill out the housing for a M8 by 1.25 Heli coil C) If you don't have the knowledge or skill, I would love to help you fix the problem ![]() So if you guys have problems, call me. This type of feedback is needed to update and improve my future products. Bryan@BNR Last edited by Bryan@BNR; 05-06-2013 at 09:43 PM. |
| The Following 15 Users Say Thank You to Bryan@BNR For This Useful Post: | 08cosmic3 (07-18-2013), Caligula (05-07-2013), Code Monkey (05-07-2013), cshunter (05-07-2013), cymen (05-07-2013), Dmurray06 (05-06-2013), faeker (05-06-2013), IMASA (05-06-2013), jdmage_mx5 (05-06-2013), memin (06-07-2014), MPS_Fan (05-07-2013), mzr0818 (05-07-2013), Nliiitend1 (05-07-2013), Wilksy (06-12-2013), YABBAMZR (05-06-2013) |
![]() | | #85 | ![]() |
![]() Join Date: Feb 2011 Location: Germany
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 29
Groaned at 17 Times in 8 Posts
![]() | | #86 | ![]() |
Groans: 185
| Not Ranked : 0 score Okay my 2 cents... sorry for the late reply. I bought one of the earlier units which didn't have the retaining tabs (is this the correct term?) installed by BNR @ the shop. After putting on a few thousand miles everything seemed to be going okay until I noticed a slight noise from the engine bay that sounded like a small exhaust leak. Long story short, I was unable to find the source of said leak until one day the CHRA bolt completely backed out. At that point my car sounded like an air-cooled VW under boost. It also made the leak rather easy to pinpoint, lol. I hit up Bryan@BNR via AIM the next day, and informed him of the issue. He promptly send out a package with 6 CHRA bolts, as well as those retaining tabs to keep them from backing out again. On that note, installing said replacement bolts/retaining tabs is a major PITA if you are trying to not remove the turbo. I had to loosen/unbolt my DP, V-band adapter, oil return line, and turbo mani to get to the bottom two bolts (FML)... and this was with the aid of a lift. Of course I also have an MS6 which doesn't help at all. I've easily doubled the number of miles on my BNR (at much higher boost levels) since first noticing the issue, and I've yet to see any additional problems, so it would appear that the "fix" is legitimate. @Bryan@BNR; A. Why no lock washers on these bolts? B. Will there be any deals for customers that want to trade in an older S3 unit for the new version once it comes out?
![]() | | #87 | ![]() |
| Banned ![]() Join Date: Aug 2011 Location: Dallas, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 253
| Not Ranked : 0 score Anything we can do as preventative maintenance on this issue? |
![]() | | #88 | ![]() |
Groans: 185
| Not Ranked : 0 score Install said retaining tabs and/or tighten the bolts.
![]() | | #89 | ![]() |
![]() Join Date: Jan 2011 Location: Cranford, New Jersey
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 233
| Not Ranked : 0 score As someone installing a brand new BNR what should I be doing? I'm slightly thick so can someone point me to a link with the kind of bolts/washers I should be using?
__________________ 2007 Mazdaspeed 6 (Velocity Red) 2002 Corvette Z06 (Black) 2001 Mazda Millenia S (Brilliant Black) - GONE |
![]() | | #90 | ![]() |
![]() Join Date: Sep 2011 Location: Croatia (Europe)
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 265
| Not Ranked : 0 score It seems that after 8+ months of using my BNR, one(or more) bolts holding the exhaust housing have backed out. I can hear exhaust leak from around the turbo and I'm 99% sure that bolt near coolant line is missing (more on this tomorrow). Which bolt is ok to use? M10x1.5 but what length?
__________________ 06 MS6, Versatuner, Stratified Tuned BNR Stage 3 turbo, Eagle con. rods, HTP Full 3" intake + AEM DryFlow filter Autotech HPFP internals, Forge V1 BPV Custom 3" cat-back with stock mufflers, M2 3" catless Downpipe Grimmspeed EBCS + Stratified Boost Dial, 3BAR BOSCH MAP NGK Iridium IX one step colder plugs, CPE SafeSeals & studs Custom FMIC with 2.5" piping and Treadstone TR8 IC SnowPerfomance WMI, Stratified Guardian Angel Eibach pro kit lowering springs |
![]() | | #91 | ![]() |
| Not Ranked : 0 score Bolts are M6!! And length is 10mm!Write Bryan an email, he will send you a fix! I'm still waiting for my fix package, because it was sent to wrong country |
![]() | | #92 | ![]() |
![]() What thread pitch do I need, is 1.0mm ok? So M6 x 10mm length x 1mm pitch ?
__________________ 06 MS6, Versatuner, Stratified Tuned BNR Stage 3 turbo, Eagle con. rods, HTP Full 3" intake + AEM DryFlow filter Autotech HPFP internals, Forge V1 BPV Custom 3" cat-back with stock mufflers, M2 3" catless Downpipe Grimmspeed EBCS + Stratified Boost Dial, 3BAR BOSCH MAP NGK Iridium IX one step colder plugs, CPE SafeSeals & studs Custom FMIC with 2.5" piping and Treadstone TR8 IC SnowPerfomance WMI, Stratified Guardian Angel Eibach pro kit lowering springs | |
![]() | | #93 | ![]() |
| Not Ranked : 0 score Sorry I took a look again, bolts are M5 NOT M6!!!! Pitch is 0.8mm and thread length is 10mm!! And don't drive with that leak. It could fry your coolant hose!! |
![]() | | #94 | ![]() |
Hopefully local hardware store is carrying that kind of bolts.
![]() | | #95 | ![]() |
| Not Ranked : 0 score @Lex; here is my report Username: kish89 Mileage on BNRS3 turbo: ~15k miles What was the failure (which bolts backed out, broken, other?): Bolt which is holding exhaust housing (nearest to the coolant line) backed out completely. Boost level you are running: 20-22PSI Are you using the bottom supporting bracket bolted to the block?: Yes How is the car driven (street, hard, tracked, etc): Street, Daily Driver Did you retorque the exhaust bolts at any time prior to failure?: No Does your turbo have any locking washers on these bolts?: No How did you fix it?: As temporary fix, I bought M5x0.8x10mm bolt at local hardware store
![]() | | #96 | ![]() |
| Banned ![]() Join Date: Oct 2011 Location: Hamilton, Ohio
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 123
| Not Ranked : 0 score Dawgincustoms 6000 all bolts backed out and 2 fell out. The top firewall one and front middle engine one. 23-24lbs NO Car is drivin extremly hard Yes at 500 miles for heat cycle and again at 2000 miles No Trying to figure that out now. Motor is coming out now. |
![]() | | #97 | ![]() |
| Not Ranked : 0 score Remember, just give me a call or an email if you need some plates and bolts. Also need to know your bolts size. I changed from 6mm to 5mm a while ago and didn't document when the changeover was. The 5mm thread pitch as an 8mm head. The 6mm thread has a 10mm head. Bryan@BNR 205 640 1193 BNRsupercars@aol.com |
| The Following 3 Users Say Thank You to Bryan@BNR For This Useful Post: |
![]() | | #98 | ![]() |
| The Following User Says Thank You to Lex For This Useful Post: | breakfstincluded (07-17-2013) |
![]() | | #99 | ![]() |
Groans: 255
![]() | | #100 | ![]() |
![]() Join Date: Apr 2009 Location: Danbury, CT
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,870
| Not Ranked : 0 score New housing and wastegate.. will upload more pics later tapa tap tap
__________________ 08.5 MS3 GT - COBB AP : HPFP : DM CatchCanBack to almost stock! 99 Miata NB - Stock for now Building a EFR 6258 Kit w/ Megasquirt 2 enhanced, COPs, Methanol, 750cc Injectors |
| The Following User Says Thank You to DSIT995 For This Useful Post: | Micha (07-19-2013) |
![]() | | #101 | ![]() |
| Not Ranked : 0 score More pictures please. Exhaust housing is still the old one? Could you measure the compressor inlet size? looks like Bryan prefers now 2 port boost contro model, since wastegate has now 2 nipples. |
![]() | | #102 | ![]() |
| Not Ranked : 0 score ImageUploadedByTapatalk1374191155.671298.jpgImageUploadedByTapatalk1374191170.176807.jpgImageUploadedByTapatalk1374191182.096982.jpg Some more shots of the updated s3... Question for everyone with the newer version.. How did you plumb the wastegate to ebcs in 3 port mode? Does one of the ports need to be plugged?
| The Following User Says Thank You to DSIT995 For This Useful Post: | Lex (07-18-2013) |
![]() | | #103 | ![]() |
Groans: 255
| Not Ranked : 0 score Wow, that housing is different than the one my buddy bought in May.
![]() | | #104 | ![]() |
![]() Join Date: May 2009 Location: Tustin, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 365
| Not Ranked : 0 score Humm here is mine from April... ![]() Very interesting...
__________________ "If I can't fix it, it was meant to be broken" [SIGPIC][/SIGPIC] 2007 MazdaSPEED 6 Titanium Grey TUNED BY NISHAN POWER SpeedPerformanc3 Wiseco Pistons (88mm)::Manley Forged H-Beams::BNR S3::Bosch 3Bar Map Sensor::CP-E Ex Mani::SBC Stg 2 Clutch::JBR RMM 80a::JBR STG II SRI::JBR Boost Tubes::JBR BPV Return::JBR SSP::CS TMIC::CS DP::Stratified 3 Port EBCS::Stratified Guardian Angel::TurboXS RP::Custom 3" Catback Exhaust::KMD 2.1::Flex Innovations Ground Kit::Turbosmart BPV::MD OCC::TWM Stage 1::BC Coilovers::Hawks HPS::EGR Delete::SURE Dreadnaught::SURE Juggernaut::SURE TIG COSMETIC AND AUDIO Mori H1 Proj Retrofit::DDM 3k HID Fogs::RPM Rear LED Reflectors::RPM Side LED Reflectors::Morel Elate 6 2W 6.5" Components::Morel Maximo 5C 5.25" Coaxial::Arc Audio KS300.4::Arc Audio KS1000.1::Audison BitOne.1::Zapco ST4 |
![]() | | #105 | ![]() |
| Not Ranked : 0 score I gotta check for a restrictor pill in one of these ports... I'm a lil lost on how this would set up with a 3 port ebcs
![]() | | #106 | ![]() |
Groans: 136
| Not Ranked : 0 score Same way you do it on a K04... Cap off the bottom port on the WGA.
__________________ |
![]() | | #107 | ![]() |
![]() Join Date: Oct 2011 Location: South Charleston, WV
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,955
Groans: 228
| Not Ranked : 0 score Damn that new housing looks nice. Hopefully this issue will be fixed before I order mine.
__________________ 2010 MAZDASPEED 3 COBB ACCESSPORT V3 // COBB FMIC // AUTOTECH INTERNALS // HTP 3" GOLD INTAKE // JBR 88 DURO RMM // JBR EGR DELETE // SURE ANCHORS // SURE COUNTERSHIFT // SURE SHORTCUT // TB PERFORMANCE TRACTION BAR V 2.0 // TB PERFORMANCE CHASSIS BRACE JBR BOOST TUBES // JBR BYPASS HOSE // DDM TUNING 5k HID // GFB RESPONS BPV // PROSPORT BOOST GAUGE // CNT CATLESS DP // ZOOM ZOOM BOX // JL Audio 10w3 // HEADLIGHT ARMOR YELLOW FOGS |
![]() | | #108 | ![]() |
(Thread Starter) | Not Ranked : 0 score What about the top port of the WG? Take a look in all the ports carefully to find the restrictor because only then I can tell you how to best plumb it.
![]() | | #109 | ![]() |
![]() Join Date: Nov 2010 Location: Reading, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 23,158
Groans: 731
sent with smiles and mouth hugs
__________________ Mods: stock Eventually I'll pay for how I am....but it won't be by the hand of any of you faggot fucks here. | |
![]() | | #110 | ![]() |
![]() Join Date: Apr 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 64
| Not Ranked : 0 score Yeah I just received mine today and got the new housing. Interested to see how to hook 3 port up with this before install next week.
__________________ 2012 Black Mazda 3 MPS ![]() CP-E Stage 2 Pistons - Manley Rods - BNR S3 - HTP 3" TIP + 3" BTM - Corksport Airbox - Cobb FMIC 2XS Exhaust Manifold - Snow Performance Meth Kit - HKS SSQIV - HPFP Internals - CPE Catted Downpipe - Perm PCV Plate OBX Catback - CPE Stage 2 RMM - JBR Side Mounts - SURE AGS Shiftknob + Shortcut + Anchors Cobb Accessport V3 - Saikou Michi OCC - Damond OCC - Corksport Springs - Bilstein B8 Shocks Versus Eurolace 19 x 8 +45 - Hankook RS3 Built & Tuned by Rob Track Setup - 18 x 8.5 Lenso Spec E - Nitto NT-01 245/40/18 DBA T3 Rotors - Carbotech XP10 Brake Pads |
![]() | | #111 | ![]() |
| Not Ranked : 0 score Here's another pic- I'm not aware of any restrictor in line, it would still have to be added if using the stock EBCS Bryan's just set it up to mimic the OEM configuration and use the stock EBCS !as long as a restrictor is used between the source and the WGA!. For those doing that the path becomes source>restrictor>WGA lower>WGA>WGA upper>Stock EBCS>TIP For using an aftermarket 3 port EBCS, like Cobb's or any of the similar units, the easiest thing to do is to block the lower WGA port, then plumb it following the instructions included with the EBCS, which are, generically, Port 1 - vent - connect to TIP/TIH Port 2 - action - connect to WGA Port 3 - source - connect to full pressure boost source
__________________ Was a Mazdaspeed6 GT #3476 TiGray slicktop Now in a BMW 135i - double the turbos, double the fun! E82.N54 2009 / BSM / A/T / Drop-in / PR CP / Berk Street / MHD / xHP 340hp / 371tq Last edited by TiGraySpeed6; 07-19-2013 at 11:16 AM. |
| The Following 4 Users Say Thank You to TiGraySpeed6 For This Useful Post: |
![]() | | #112 | ![]() |
| Not Ranked : 0 score To have confirmation direct from the source I emailed Bryan and asked about resitrctors and plans regarding the 2 port WGA. He replied that there is not currently a restrictor in place, but that there will be "in the next batch" Take from that what you will...
__________________ Was a Mazdaspeed6 GT #3476 TiGray slicktop Now in a BMW 135i - double the turbos, double the fun! E82.N54 2009 / BSM / A/T / Drop-in / PR CP / Berk Street / MHD / xHP 340hp / 371tq | |
![]() | | #113 | ![]() |
(Thread Starter) | Not Ranked : 0 score It will be tricky with an added 1 size fits all restrictor - hope he does a good amount of testing. This is why I came up with the Boost Dial since different intake and exhaust setups can benefit from a tunable restrictor.
| The Following 2 Users Say Thank You to Lex For This Useful Post: | DSIT995 (07-22-2013), Nliiitend1 (07-23-2013) |
![]() | | #114 | ![]() |
| Not Ranked : 0 score I'm surprised he's adding one at all. I like Bryan, and the S3, but I doubt he's done much testing, at least not the way you think of it Lex.
| The Following User Says Thank You to TiGraySpeed6 For This Useful Post: | DSIT995 (07-22-2013) |
![]() | | #115 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Melissa, TX
Rep Power: 5339 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27,149
| Not Ranked : 0 score @Lex; Well mine finally backed out. Mileage on BNRS3 turbo: 33 months - ~30k Mi What was the failure (which bolts backed out, broken, other?): Bolt appears to be backed out. Boost level you are running: tapering up to 25psi Are you using the bottom supporting bracket bolted to the block?: Yes How is the car driven (street, hard, tracked, etc): Tracked in the first year, but not since. Some drag usage Did you retorque the exhaust bolts at any time prior to failure?: I sent out my hotside for coating and then reinstalled it and retorqued all bolts prior to installation. Torqued by feel, don't have a box end torque wrench. Does your turbo have any locking washers on these bolts?: No (lockwashers don't do shit anyway, see NASA RP-1228) How did you fix it?: Not fixed yet. Intend on pulling the turbo and then safety wiring bolts Confirmed my bolts have the 10mm head. Going to order replacements and safety wire them in with nickel\chromium wire. No more messing with it.
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk |
| The Following 4 Users Say Thank You to Ziggo For This Useful Post: |
![]() | | #116 | ![]() |
![]() Join Date: Mar 2013 Location: Huntsville, AL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,402
| Not Ranked : 0 score I don't see the crimped brackets on yours Zig that would only allow for 1/16 of a turn at most before metal on metal. Am I missing something?
__________________ Manley forged long block, secret snail, manifolds, and 2gal E85 tune running like a champ - about to dial in a lot of meth and see what we've got. 13.10@117.1 full weight DD no prep 1/4 (BNR S3 / E85) |
![]() | | #117 | ![]() |
(Thread Starter) | Not Ranked : 0 score Looks like eventually all the BNRs without the locking washers or safety wire will see the bolts backing out. This is something that someone installing a used BNR should do before putting it in.
![]() | | #118 | ![]() |
| Not Ranked : 0 score Just skimmed through that - sweet reference manual.
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. |
![]() | | #119 | ![]() |
I am not a huge fan of the crimped bracket solution. It works so the bolt can't back out completely, but I consider any rotation of the bolt a joint failure due to the loss of preload. At the end of the day, if it's a critical joint you safety wire it. The only reason not to is the time it takes, but it will take less time than if I have to pull the turbo again to fix this. Should have done it the first time round. Sent from my SAMSUNG-SGH-I747 using Tapatalk
__________________ Ask Me About My: BNR S3 Turbo \ JBR WP 3.5" Intake \ COBB FMIC \ DNP EX MANI \ COBB DP \ MSCBE \ CPE HPFP CPE Injector Seals \ JBR Thermal Intake & Throttle Body Gaskets \ BOZO EGR Delete BC Coilovers (-2.5º F, -1º R) \ Saitek Front Endlinks \ SPC Rear Camber Arms \ Hotchkis FSB & RSB JBR 88 Duro RMM TMM PMM \ COBB AP (Self Tuned) \ EGT \ Oil Pres \ Oil Temp \ DashHawk | |
| The Following User Says Thank You to Ziggo For This Useful Post: | JgamB (05-28-2014) |
![]() | | #120 | ![]() |
| Not Ranked : 0 score Its the best publicly available guide, but keep in mind it's nearly 25 years old. The plating and materials section is pretty dated. Some of the plating has been discontinued due to health concerns (mostly containing chromium or cadmium) and there are a ton of new fancy thread lubricants and bolt materials on the market now. If you can learn everything else in there though you will be better than almost every engineering student coming out. Sent from my SAMSUNG-SGH-I747 using Tapatalk
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/bnr-s3-exhaust-housing-bolts-backing-out-144177/ | ||||
| Beaner time! - Page 20 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Pingback | 06-07-2013 04:58 PM | |
| exhaust spring bolts | slashsnake | 2010 MS3 - Engine, Transmission & Driveline | 10 | 12-17-2012 11:27 AM |
| Leaking exhaust gases | mps-passion | MazdaSpeed 3 - Engine, Transmission & Driveline | 3 | 06-18-2012 10:57 PM |
| exhaust gaskets, bolts, etc. needed | greenespeed | Mazdaspeed3/6 General Discussion | 3 | 10-05-2011 12:49 PM |
| WG right off the exhaust housing | -cj- | MazdaSpeed 3/6 - Big Turbo Builds | 4 | 07-15-2010 09:22 PM |
