Like Tree12Likes
 Old 06-07-2014, 11:07 PM   #121
Ziggo's Avatar
Posts: 3,843   (View Stats)
Fixed.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Ask Me About My:
The Following 4 Users Say Thank You to Ziggo For This Useful Post:
breakfstincluded (06-07-2014), free_refil (02-18-2015), ItsNox (06-08-2014), magicka (08-23-2014)
 Old 08-22-2014, 08:18 PM   #122
tokoam's Avatar
Posts: 199   (View Stats)
tokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant future
Groaned at 17 Times in 4 Posts
I got my bnr in september of 2013 was this issue addressed by Brian or should I be worried ? No issues yet I have about 10k on my Bnr s3 v2.
tokoam is offline   Reply With Quote
 Old 10-01-2014, 05:52 PM   #123
King Scumbag's Avatar
Posts: 2,384   (View Stats)
@Lex;,
This may be late and have to do with the v1 but I have a BNR S3 V2. Received last month Brand new.
Seal between housing and compressor leaks at any amount of pressure. I can charge the system quickly to 25psi during a leak test but It leaks out of the Turbo at rate of 2-3 PSI per second. Sometimes will hit boost perfectly and sometimes won't get past 21psi. Im running 24psi on E85 and have about 1500miles on the turbo.
I talked with Matt at PG and he got in touch with Bryan. Bryan said "I wouldn't worry about it. That's not enough volume to hurt anything. If he wanted to silicone the surface that would stop the issue."
1. I beg to differ that its not enough volume. Air is dumping out of that seal..2. Why should I have to seal a brand new turbo that wasn't manipulated in any fashion but just installed. It shouldn't come down to that..
I have a video of myself spraying soapy water on the compressor and the leak it OVERWHELMINGLY visible.
07 BLACK MICA MS3
PATTY/JEFF BUILT MOTOR
STOCK BLOCK
BOSTON STRONG
The Following 2 Users Say Thank You to King Scumbag For This Useful Post:
Easter Bunny (10-01-2014), jack_hammer (10-01-2014)
 Old 10-01-2014, 06:54 PM   #124
Fuck that send it back.
 Old 10-01-2014, 08:00 PM   #125
Read my quote from Bryan. Apprently it's acceptable or I should just fix it myself..
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
 Old 10-01-2014, 08:02 PM   #126
Lacey28's Avatar
Posts: 557   (View Stats)
Lacey28 is the leader of the worldLacey28 is the leader of the worldLacey28 is the leader of the worldLacey28 is the leader of the worldLacey28 is the leader of the worldLacey28 is the leader of the worldLacey28 is the leader of the worldLacey28 is the leader of the worldLacey28 is the leader of the worldLacey28 is the leader of the worldLacey28 is the leader of the world
Lol can you tighten the bolts? And deff not a answer i would except
Lacey28 is offline   Reply With Quote
The Following User Says Thank You to Lacey28 For This Useful Post:
 Old 10-01-2014, 08:08 PM   #127
I tried to an exceptable TQ but they didn't budge. I'm not trying to strip anything in the housing only because I knew of this being a problem on the old housing.
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
 Old 10-01-2014, 08:14 PM   #128
Time to call the credit card and cancel the payment. Product is defective manufacturer refuses to warranty.
 Old 10-01-2014, 08:42 PM   #129
After two months of making the payment lol? Im lost
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
 Old 10-01-2014, 08:51 PM   #130
jack_hammer's Avatar
Posts: 6,822   (View Stats)
Groans: 549
Maybe an "acceptable" torque would work better?
Or maybe you should call the manufacturer directly.
it's fun to do bad things
The Following User Says Thank You to jack_hammer For This Useful Post:
 Old 10-01-2014, 08:59 PM   #131
I know discover would put a hold on that shit right away. Don't know how you paid but it's probably worth a phone call. Unless you have money to burn on better turbo.
 Old 10-01-2014, 09:25 PM   #132
I sent an E-mail to Bryan. I guess we will see how it goes from there.
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
 Old 10-13-2014, 11:19 PM   #133
Update: talked with Bryan on the phone today. He said I can send it back to be re-sealed or do it myself. I don't have a spear FUCKKing turbo just laying around. Took it out and sealed it myself. He said "Since you have showed me and explained to me what is going on we are starting to put a better gasket seal on the compressor" we'll see about that I guess.
Waiting for the sealent to cure and will find out of this solves my problems which I'm about 100% sure will.
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
Easter Bunny (10-14-2014)
 Old 10-13-2014, 11:47 PM   #134
Were you running really rich under boost or was the turbo not making boost with the compressor leak?
Bryan makes the compressor housing but the chra and I imagine the backing plate is Garrett. So they are made by different manufacturers and this can cause some tolerance issues.
 Old 10-14-2014, 01:23 AM   #135
See my last post here @Lex; #2651
http://www.mazdaspeedforum.org/forum/foru...ml#post2725486
Completely inconsistent on hitting boost targets. Was leaking so bad the system wouldn't even hold 10psi. It's took 4 strait logs to get to boost targets. Spots of lean in between 4-5k but nothing more then boost being unpredictable yet naming targets in all the right places. I'm assuming the thin o-ring they use must heat up and swell creating a better seal after a couple of pulls. That's just my theory.
07 BLACK MICA MS3
STOCK BLOCK
BOSTON STRONG
 Old 01-27-2015, 08:01 PM   #136
txmedic512's Avatar
Posts: 63   (View Stats)
txmedic512 has much to be proud oftxmedic512 has much to be proud oftxmedic512 has much to be proud oftxmedic512 has much to be proud oftxmedic512 has much to be proud oftxmedic512 has much to be proud oftxmedic512 has much to be proud oftxmedic512 has much to be proud oftxmedic512 has much to be proud of
Default bnr s3 bolts
I was going through this old thread and I have a feeling I am similar issues to yours. How was your bnr building boost during wot? I am currently fully bolted running reverse taper to 25 psi and building boost down low is shit until about 4100 rpms. I have been reading that I should be hitting full boost around 3300 rpms.
Himurax13
2000 miles
One of the bolt closest to the drainline/firewall backed out and the other one was loosely hanging with the plate.
Yes
20 tapering to 22.
Mostly DD, occasionaly canyons, tracked at Willow Springs, onramps with authority. several WOT logs.
No
No
Fixed by inserting cheap grade 5 stainless bolts from the bottom while still in the car. Had to use a dremmel to turn bolts into self tapping screws and then use the goodntight torque method. No leaks were detected and held for 4 months before pulling off car.
txmedic512 is offline   Reply With Quote
 Old 01-28-2015, 01:28 PM   #137
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
The boost curve was fine. However my AFR's at WOT were all over the place.
Who is tuning you?
A BNR should be able to hit 20+ lbs of boost by 3200 RPM's or so.
Do you have the newest version?
Pickles Tune in progress
 Old 01-28-2015, 03:54 PM   #138
2.0t03speed's Avatar
Posts: 1,302   (View Stats)
Who is tuning you?
i am tuning him (Ryan @ PD) his is the old bnr. literally have thrown everything at this bnr and it won't spool faster. vvt is up to 30*+, added preload, 80% wgdc and the turbo won't hit 20 psi till 4100. Afr has been fairly flat this entire time. it's just spooling really slow. All the flange bolts have been checked. No problems there. The only things left to check are the chra bolts and the exhaust housing to see if maybe the housing or the waste gate flapper is cracked. I've tuned a bunch of bnr's and this is the first time i've ever encountered one acting like this.
The Following 2 Users Say Thank You to 2.0t03speed For This Useful Post:
Easter Bunny (01-28-2015), txmedic512 (01-28-2015)
 Old 01-28-2015, 04:40 PM   #139
Has the WGA preload been checked? is the wastegate closing all the way?
 Old 01-28-2015, 06:57 PM   #140
txmedic512's Avatar
I am taking this turbo off tomorrow and gonna go to town on it. Ryan is taking real good care of me and has literally been holding my hand through this process. Last log's afrs were great as ryan stated, i stand corrected. Before I went zzb I never got the chance to run this turbo completely so I'm not sure if this is the condition I bought it in but I was told it was mint which it still appears to be to me. I'm just hoping it was just loosened bolts as I am getting ready to sell this and install my gt3071.
The Following User Says Thank You to txmedic512 For This Useful Post:
Easter Bunny (01-29-2015)
 Old 01-29-2015, 06:47 AM   #141
i've had him add preload twice on this thing proabably 4-5 full turns in total. something is definitely up. I'm thinking either the turbine wheel got messed up on his zzb or the hosing is cracked around the wastegate port.
The Following User Says Thank You to 2.0t03speed For This Useful Post:
 Old 01-29-2015, 08:01 AM   #142
Ziggo's Avatar
Does he have a catalytic converter? If it's spun or clogged it will cause slow spooling
Ask Me About My:
 Old 01-29-2015, 09:54 AM   #143
ebay catless dp
 Old 01-29-2015, 10:26 AM   #144
nvm found the problem @txmedic512;'s friend is a derp. 2 of the manifold to turbo nuts were super loose
The Following 5 Users Say Thank You to 2.0t03speed For This Useful Post:
ASHMS3 (01-29-2015), BackRoads (01-29-2015), Easter Bunny (01-29-2015), TiGraySpeed6 (01-29-2015), UnknownSuperhero (01-29-2015)
 Old 01-29-2015, 10:51 AM   #145
himurax13's Avatar
Groans: 255
Wierd, my current Beaner is a 1st gen and I am running a stock DP, NATOR Midpipe, Corksport TMIC, Modified Corksport SRI, HTP 3" TIP, with a no name mac solenoid 3 port and I can hit 25/26 lbs of boost.
 Old 01-29-2015, 10:59 AM   #146
Read what i wrote he had 2 turbo to manifold bolts SUPER loose. He sent me a video turning them by hand. With those fixed he will hit higher boost pressure and spool faster with no problem now.
 Old 01-29-2015, 11:11 AM   #147
himurax13's Avatar
Groans: 255
It should. My old Beaner wouldnt hit past 24. But then again my old motor was hurt.
 Old 01-30-2015, 02:54 AM   #148
HaXiR's Avatar
Posts: 315   (View Stats)
HaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud ofHaXiR has much to be proud of
I really hope the S4 has all the fixes and has no bs issues like these.
HaXiR is offline   Reply With Quote
 Old 03-09-2015, 07:14 PM   #149
TRQ STEER FTL's Avatar
Posts: 189   (View Stats)
TRQ STEER FTL has much to be proud ofTRQ STEER FTL has much to be proud ofTRQ STEER FTL has much to be proud ofTRQ STEER FTL has much to be proud ofTRQ STEER FTL has much to be proud ofTRQ STEER FTL has much to be proud ofTRQ STEER FTL has much to be proud ofTRQ STEER FTL has much to be proud ofTRQ STEER FTL has much to be proud ofTRQ STEER FTL has much to be proud of
Is this still a issue at all? Im going to be ordering a new bnr s3 and definitely dont want to deal with this kind of headache.
TRQ STEER FTL is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f11/bnr-s3-exhaust-housing-bolts-backing-out-144177/
Beaner time! - Page 20 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum This thread Pingback 06-07-2013 04:58 PM
exhaust spring bolts slashsnake 2010 MS3 - Engine, Transmission & Driveline 10 12-17-2012 11:27 AM
Leaking exhaust gases mps-passion MazdaSpeed 3 - Engine, Transmission & Driveline 3 06-18-2012 10:57 PM
exhaust gaskets, bolts, etc. needed greenespeed Mazdaspeed3/6 General Discussion 3 10-05-2011 12:49 PM
WG right off the exhaust housing -cj- MazdaSpeed 3/6 - Big Turbo Builds 4 07-15-2010 09:22 PM
Page generated in 0.50375 seconds with 32 queries
