 Old 10-03-2013, 06:00 PM   #1
tokoam's Avatar
Posts: 199   (View Stats)
tokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant futuretokoam has a brilliant future
Groaned at 17 Times in 4 Posts
Default BNR S3 return line leak
shortly after maybe a few weeks later my car started to smell of burning oil and exhaust gases after shutting off the car and exiting the vehicle. So putting it on the lift I saw the issue the return line started to leak.So I used silicon gasket sealer along with a new gasket and that was the end of the leak this is just a post to keep those informed of this happening as I am still using the turbo brace I guess it happened with the rocking of the motor ? I dunno But it was properly torqued and did not leak after install this started to happen over time .
tokoam is offline   Reply With Quote
The Following User Says Thank You to tokoam For This Useful Post:
breakfstincluded (10-03-2013)
 Old 10-03-2013, 07:45 PM   #2
2012FailWheelDrive's Avatar
Posts: 327   (View Stats)
2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world2012FailWheelDrive is the leader of the world
Mine leaked a little after my turbo went in. I just bought a new gasket for like $3 and it fixed it. The stock one really sucked.
"under construction"
2012FailWheelDrive is offline   Reply With Quote
 Old 10-03-2013, 08:11 PM   #3
Always replace these crush metal gaskets when they are disturbed/removed. This goes for intake, exhaust, etc.
 Old 10-03-2013, 08:16 PM   #4
tokoam's Avatar
Lex I will get those logs to you ASAP Florida rain has been killing us . seems I still get over boost though not as much in 4th but 5th and 6th its there access port says 22.5 also I calibrate my pro sport Guage so it reads correctly now.
 Old 10-03-2013, 09:10 PM   #5
breakfstincluded's Avatar
Posts: 3,588   (View Stats)
Yay I'm not the only one who's hard line is rusted all over
 Old 11-04-2013, 08:00 PM   #6
tokoam's Avatar
looks like this bloody return line started leaking again do you happen to know the part# for both crush washers along with gaskets ? gonna have to fix this once and for all dose apt or anyone else make a more sturdy aftermarket one ?
 Old 11-04-2013, 08:10 PM   #7
2008 Mazda 3/M Parts - Online Mazda Parts
taf0422 (11-04-2013)
 Old 11-05-2013, 04:36 PM   #8
tokoam's Avatar
in the link you sent item #9 and #10 ? dose this include the metal gaskets as well ?
 Old 11-05-2013, 04:39 PM   #9
those ARE the metal gaskets unless I'm incorrect?
 Old 11-05-2013, 05:17 PM   #10
tokoam's Avatar
problem is there is no real description or OEM part# to verify plus i also need the carbon/non metallic based gasket as well.
 Old 11-05-2013, 05:22 PM   #11
alphasaur's Avatar
Posts: 2,847   (View Stats)
Groans: 235
lolwut, there's only 9 and 10. What ceramic/nonmetallic gasket?
/Turbo ep3 BWAAAAA PSH
/speed 3- bye
/lol nator.
 Old 11-05-2013, 06:00 PM   #12
tokoam's Avatar
yes this lol whats the part number for ceramic/nonmetallic gasket or dose it come with the metallic one .
 Old 11-05-2013, 06:13 PM   #13
where did you hear this from?
just get 9 and 10
Oil return line options? btstarcher MazdaSpeed 3/6 - Turbo Induction 15 10-31-2016 08:52 PM
Page generated in 0.32619 seconds with 25 queries
