 Old 04-03-2017, 01:59 AM   #1
NRBt's Avatar
Posts: 29   (View Stats)
NRBt is a splendid one to beholdNRBt is a splendid one to beholdNRBt is a splendid one to beholdNRBt is a splendid one to beholdNRBt is a splendid one to beholdNRBt is a splendid one to beholdNRBt is a splendid one to behold
Default BNR S3 wastegate flap
I've recently noticed that from time to time i'm not building boost at all after the CHRA replacement. The first thought was the WG actuator and rod ended up seized, but then I've discovered this:
https://youtu.be/7dvK0JTSIUU
Is this nornal, that a WG flap has so much play?
Logs will be uploaded soon!
NRBt is offline   Reply With Quote
 Old 04-15-2017, 08:32 AM   #2
NRBt's Avatar
Aaaand here's the problem.
This is the second CHRA that is fucked for unknow reason plus a busted WG flapper because of tack-welding falling apart.
Отправлено с моего iPhone используя Tapatalk
 Old 06-06-2018, 07:24 PM   #3
MAZDAMARK's Avatar
Posts: 6   (View Stats)
MAZDAMARK is an unknown quantity at this point
i recently installed mine and my wastegate is the same and makes a weird chatter when boosting.
MAZDAMARK is offline   Reply With Quote
 Old 06-07-2018, 09:10 AM   #4
MazdaspeedKills's Avatar
Posts: 443   (View Stats)
MazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the worldMazdaspeedKills is the leader of the world
Groaned at 7 Times in 4 Posts
Wow. Wonder how that happened. That's way out of spec!
'06 MS6: BNR S3//CP-E FMIC//Forge V3/CP-E Nano Intake//TIP//DNP Swain Tech Coated Exhaust Mani//CP-E Catted Swain Tech Coated DP//Magnaflow CBE//CP-E RMM & TT Rear Diff Mount//PnP & Coated Intake Mani// VCTS and EGR delete//GS EBCS//3 Bar MAP//RMM//SafeSeals//PT-P FP Internals//TWM Stage II STS//SSP//Saikou Michi OCC//Snow Stage 2 WMI w/ D07 nozzle//Cobb AP V3//RICH TUNE!//Stoptech Slotted Rotors and EBC RedStuff Pads//H&R springs w/spacers//Bilsteins//SPC Balljoints//AeroForce ScanGauge & WideBand//Snow Performance WMI Failsafe & Guardian Angel//Morimoto HID Projector Upgrade//Hella HID Fogs
MazdaspeedKills is offline   Reply With Quote
 Old 06-07-2018, 12:10 PM   #5
MAZDAMARK's Avatar
I called bnr and they said that’s a common issue and I have to tighten the waste gate actuator. I don’t see why I have to do that, why don’t they do that when they ship it?
JBR Mud Flap Feedback Oni JAMES BARONE RACING 5 08-13-2015 09:49 AM
Mud flap dimmensions? armpit Exterior 9 12-06-2013 08:56 AM
Mud Flap Jfishe JAMES BARONE RACING 0 01-07-2013 02:40 PM
Tial Wastegate vs EMUSA Wastegate SleeperHatch MazdaSpeed 3/6 - Turbo Induction 6 09-12-2012 04:31 PM
How to connect the stock wastegate solenoid to an external wastegate cageyvet MazdaSpeed 3/6 - Turbo Induction 0 03-17-2010 05:02 PM
Page generated in 0.25482 seconds with 22 queries
