Bnr s4 installed now my car won’t start without jumping the starter So I got my bnr s4 in along with these mods ported intake manifold, xspower turbo manifold, HTP 3.5” intake, corksport injector seals, Damond motorsports rear motor mount, turbo smart dual port blowoff valve, autotech high pressure fuel pump internals, cpe catted downpipe, grimmspeed 3 Port electronic boost controller, cx racing front mount intercooler, guardian angel v3, and I think a 3bar map sensor ( came with the manifold and I forgot to ask, it is a Bosch sensor). I got it all together and when I tried to start it nothing happens, all my interior lights turn on and everything but I’m not getting anything to the starter. So I jumped the starter and once I get it started it dies in about 2-3 seconds. I even have a mechanic helping me with this and he doesn’t know. All the fuses tested ok. He has almost run out of ideas. Just looking for some helpful ideas as to why it is doing this. I also have no throttle response, I can’t just press the gas to keep it running. |
Do you have a tune for that 3.5" intake? If not that may be why it dies right away. Check wiring harness again. Did you take out the ground by the HPFP? |
Quote:
Ok, you CERTAINLY need a tune. When you have bigger intake than stock, you're going to need MAF CAL or the car won't even idle. Im not sure tho if that could be the cause of your no-start issue. Try unplugging the MAF sensor and see if it starts without it. |
wait wait wait, you put in a bigger turbo, and a bunch of mods, and then thought the car would start without a tune? wow. |
Quote:
Quote:
Quote:
Nowhere did I state that I planned on pulling it out of the garage and go driving around in it |
.... there's so much wrong here... lol |
Quote:
Quote:
You need a tune for the intake, the 3 port EBCS, and also your 3 bar map sensor.... |
So if I get a tune then the key will work to start it? Quote:
You can start there first. If not then maybe your starter is crapping out. Idk if this is relevant, but again, did you mess with any ground wire at all? EDIT: Actually nvm, ground wire will let you crank, but it won't start. |
Quote:
Quote:
Quote:
Quote:
Hi, yes you're right. If the starter won't engage, there are some other problems beyond the tune. It's quite common on this platform for the car not to start after being pulled apart and put back together. Keep trying, double check all of your plugs and harnesses. Often times it's just a plug that needs a wiggle or a faulty ground. Have a look at some of the 'Car won't start' threads on here for ideas. As far as the tune goes, one of the etuners on here will be able to send you a base map that suits the larger MAF housing, hopefully this will allow it to idle once you've got it to the point where it's tuning over with the key. Best of luck to you sir. |
Quote:
Sounds to me like the clutch switch on the pedal or you left a connector off somewhere. Ensure that all wires and grounds are G2G. Good luck!! You'll be loving it once its tuned. |
Bruh, don't report posts just because they are right. You can't go big turbo without a base tune at the least. It just won't run. |
Quote:
All I will say is that OP is very lucky that he has the starter problem. Not being able to start was a guardian angel looking our for his ass. Otherwise, he'd be trying to drive it, trying to find some way to keep it running while he explored his yet to be found base map from a custom tuner for his big turbo setup. He should be very thankful that the starter issue saved his ass. Now, OP, get with one of the custom e-Tuners here, line up a base map that will be a safe place to begin with your mods. Chances are high that the starter issue is probably going to be a ground wire left unconnected or a poor ground connection somewhere during the install. |
Quote:
Quote:
Quote:
Quote:
Quote:
Given all the shit that you touched on your car, it's likely that you've got a missing ground wire. If the car won't crank without applying power directly to the starter, then the likelihood is that your starter isn't properly grounded. It's easy to knock the starter ground off while removing and/or installing an intake manifold. Moreover, if the HPFP isn't properly grounded (which also might be the case here), then even if you got the car started, it shouldn't stay running. EVEN IF you get the car started at this point, it WILL NOT MAINTAIN idle. The 3.5" ID of the intake you installed is too large for the ECU to compensate for. You absolutely 100% need a custom tune for the car to even hold an idle for more than a couple of seconds. Edit: Also, don't report posts just because you think they're offensive or insensitive due to the fact that they are telling you factual information about your car that you don't want to hear. |
Quote:
People here have been living with these cars daily for ten years or more in many cases, having bought them new off the showroom floor. These cars are very mature platform. The technical knowledge here is deep. |
Quote:
Quote:
Now tune that bitch and get your roll on! Post back here with your impressions with the new setup. |
| All times are GMT -7. The time now is 01:58 PM. |
