![]() Join Date: Dec 2017
Rep Power: 0 ![]() Thanks: 1
(Thread Starter) | Not Ranked : 0 score So I got my bnr s4 in along with these mods ported intake manifold, xspower turbo manifold, HTP 3.5” intake, corksport injector seals, Damond motorsports rear motor mount, turbo smart dual port blowoff valve, autotech high pressure fuel pump internals, cpe catted downpipe, grimmspeed 3 Port electronic boost controller, cx racing front mount intercooler, guardian angel v3, and I think a 3bar map sensor ( came with the manifold and I forgot to ask, it is a Bosch sensor). I got it all together and when I tried to start it nothing happens, all my interior lights turn on and everything but I’m not getting anything to the starter. So I jumped the starter and once I get it started it dies in about 2-3 seconds. I even have a mechanic helping me with this and he doesn’t know. All the fuses tested ok. He has almost run out of ideas. Just looking for some helpful ideas as to why it is doing this. I also have no throttle response, I can’t just press the gas to keep it running. Last edited by Clay46; 08-08-2018 at 04:18 AM. |
| The Following User Says NO Thank You to Clay46 For This Un-useful Post: | MD1032 (08-08-2018) |
![]() Join Date: Apr 2013 Location: Somersworth, NH
Rep Power: 878 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,570
| Not Ranked : 0 score Do you have a tune for that 3.5" intake? If not that may be why it dies right away. Check wiring harness again. Did you take out the ground by the HPFP?
__________________ 2012 NASA Spaceship Gray MS3 BNR S3 - JBR Tru 3.0" - CP-E TMIC - Corksport catless DP - Corksport catted race pipe - Forge V2 - Autotech internals + AP v3 - Swift springs - Enkei RPF1 17x9 + 45 (5mm JBR spacers in the front) - Freektune 320/346 |
(Thread Starter) | Not Ranked : 0 score I do not have a tune yet. I was just looking to make sure it would start before I moved on to getting a tune. I did ask on one of the Mazdaspeed Facebook groups last night and they recommended to get a tune. I ordered one last night but I’m more worried about why it won’t start with the key. I have to jump the starter selonoid for it to turn over |
| The Following 4 Users Say NO Thank You to Clay46 For This Un-useful Post: |
![]() Join Date: Mar 2013 Location: North Brunswick, NJ
Rep Power: 1125 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 4,645
Groans: 143
| Not Ranked : 0 score What in the world led you to believe you could drive a car modified to this extent on a stock tune? The intake alone is going to prevent your car from running, never mind all the other stuff. Do you even understand how electronic boost control works? Next time try doing a little reading before just bolting a bunch of stuff onto your car and expecting it to work...
__________________ 2007 Mazdaspeed3 GT |
| The Following 2 Users Say Thank You to MD1032 For This Useful Post: | KiwiFlavor (08-08-2018), Vansquish (08-08-2018) |
Nowhere did I state that I planned on pulling it out of the garage and go driving around in it Last edited by Clay46; 08-08-2018 at 06:24 AM. Reason: MSF Database - Automerged Doublepost | |
| Not Ranked : 0 score Ok, you CERTAINLY need a tune. When you have bigger intake than stock, you're going to need MAF CAL or the car won't even idle. Im not sure tho if that could be the cause of your no-start issue. Try unplugging the MAF sensor and see if it starts without it.
| The Following User Says Thank You to KiwiFlavor For This Useful Post: | Vansquish (08-08-2018) |
(Thread Starter) | Not Ranked : 0 score Ok, I’ll try that after work. I understand how the MAF would not let it idle but how would it not allow it to start because it can’t read air flow if there is none. The motor won’t turn over. I can hear the fuel pump but that’s it |
![]() Join Date: Nov 2010 Location: South Haven, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,824
Groans: 75
| Neutral : +1 score wait wait wait, you put in a bigger turbo, and a bunch of mods, and then thought the car would start without a tune? wow.
__________________ Franken Turbo, built motor, meth. DIY parts: Shift Knob, Shift Plate, Shift Bushings, Battery Tray, EBCS, RSB, probably more. "Your signature should just say, I'm the shit." -LynzeC |
| The Following 4 Users Say Thank You to maisonvi For This Useful Post: | KiwiFlavor (08-08-2018), sharksinspace (08-08-2018), Thor Hammer (08-08-2018), Vansquish (08-08-2018) |
| The Following User Says NO Thank You to Clay46 For This Un-useful Post: | Vansquish (08-08-2018) |
You need a tune for the intake, the 3 port EBCS, and also your 3 bar map sensor....
__________________ 2012 NASA Spaceship Gray MS3 BNR S3 - JBR Tru 3.0" - CP-E TMIC - Corksport catless DP - Corksport catted race pipe - Forge V2 - Autotech internals + AP v3 - Swift springs - Enkei RPF1 17x9 + 45 (5mm JBR spacers in the front) - Freektune 320/346 | |
(Thread Starter) | Not Ranked : 0 score So if I get a tune then the key will work to start it? I understand that but how would that make the car not allow the key to be used for starting. I understand it would do that once it’s started and then die Last edited by Clay46; 08-08-2018 at 06:30 AM. Reason: MSF Database - Automerged Doublepost |
Groans: 143
| Not Ranked : 0 score This is a MAF-based car. Fueling, boost control, everything is calculated and driven by the MAF signal. This is why MAF calibration is the first thing we do when tuning these cars, and why your car won't run at all right now. The car is expecting a certain amount of air to be going into the engine at the MAF voltage it detects while it's cranking and starting, and right now a completely different amount is going in because you have a 3.5" intake that's flowing a lot more air at the same MAF voltage than the stock 2.5" intake. The ECU can use the primary O2 sensor to make small corrections in fueling (because MAF sensors inherently have error), but not the level we're looking at between a 2.5" and a 3.5" intake. You're literally flowing like double the amount of air at the same voltage.
| The Following 2 Users Say Thank You to KiwiFlavor For This Useful Post: | Thor Hammer (08-08-2018), Vansquish (08-08-2018) |
| Not Ranked : 0 score .... there's so much wrong here... lol
| Not Ranked : 0 score You can start there first. If not then maybe your starter is crapping out. Idk if this is relevant, but again, did you mess with any ground wire at all? EDIT: Actually nvm, ground wire will let you crank, but it won't start.
(Thread Starter) | Not Ranked : 0 score I did not touch any of the grounds but the starter seems fine because I can jump the solenoid on the starter to get it to turn over I just can’t get the key to work |
![]() Join Date: Feb 2012 Location: Australia
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 250
Groaned at 7 Times in 3 Posts
Hi, yes you're right. If the starter won't engage, there are some other problems beyond the tune. It's quite common on this platform for the car not to start after being pulled apart and put back together. Keep trying, double check all of your plugs and harnesses. Often times it's just a plug that needs a wiggle or a faulty ground. Have a look at some of the 'Car won't start' threads on here for ideas. As far as the tune goes, one of the etuners on here will be able to send you a base map that suits the larger MAF housing, hopefully this will allow it to idle once you've got it to the point where it's tuning over with the key. Best of luck to you sir.
__________________ - 2008 Gen1 MS3 Cobb AP ~ Autotech HPFP Internals ~ HTP 3" Intake ~ Custom Testpipe ~ Cobb RSB ~ Sticky Tires. Self tuned on E85 | |
| Bruh, don't report posts just because they are right. You can't go big turbo without a base tune at the least. It just won't run.
| The Following 4 Users Say Thank You to MS3Shadow For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score Ok I understand that but my problem is that I’m not getting any power from the key to the starter. Like I had stated I am not trying to drive it. I’m just trying to figure out why the key won’t work to start it |
![]() Join Date: Jun 2009
| Not Ranked : 0 score All I will say is that OP is very lucky that he has the starter problem. Not being able to start was a guardian angel looking our for his ass. Otherwise, he'd be trying to drive it, trying to find some way to keep it running while he explored his yet to be found base map from a custom tuner for his big turbo setup. He should be very thankful that the starter issue saved his ass. Now, OP, get with one of the custom e-Tuners here, line up a base map that will be a safe place to begin with your mods. Chances are high that the starter issue is probably going to be a ground wire left unconnected or a poor ground connection somewhere during the install.
Groans: 211
| Not Ranked : 0 score If you removed the HPFP you did have to remove a ground. But what do we know? We're trying to help here.....
![]() | | #24 | ![]() |
And also as I stated above I have had the car running. If the fuel pump wasn’t grounded I would have not had fuel right? But if it’s starting by jumping the solenoid then the fuel pump is good. Last edited by Clay46; 08-08-2018 at 04:11 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #25 | ![]() |
Rep Power: 3746 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,744
Given all the shit that you touched on your car, it's likely that you've got a missing ground wire. If the car won't crank without applying power directly to the starter, then the likelihood is that your starter isn't properly grounded. It's easy to knock the starter ground off while removing and/or installing an intake manifold. Moreover, if the HPFP isn't properly grounded (which also might be the case here), then even if you got the car started, it shouldn't stay running. EVEN IF you get the car started at this point, it WILL NOT MAINTAIN idle. The 3.5" ID of the intake you installed is too large for the ECU to compensate for. You absolutely 100% need a custom tune for the car to even hold an idle for more than a couple of seconds. Edit: Also, don't report posts just because you think they're offensive or insensitive due to the fact that they are telling you factual information about your car that you don't want to hear.
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! | |
| The Following 4 Users Say Thank You to Vansquish For This Useful Post: |
![]() | | #26 | ![]() |
People here have been living with these cars daily for ten years or more in many cases, having bought them new off the showroom floor. These cars are very mature platform. The technical knowledge here is deep.
| The Following 2 Users Say Thank You to MSMS3 For This Useful Post: | KiwiFlavor (08-09-2018), Thor Hammer (08-09-2018) |
| Starter turns engine extremely slowly and wont start | maritimer95gt | 2010 MS3 - Troubleshoot/Diagnostics | 0 | 03-25-2018 06:45 PM |
| Car won't start and dealership claims starter and CPE hpfp are the cause | GR4YF0X | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 14 | 08-27-2015 11:55 AM |
| Just installed Cobb AP V3, now car won't start | kbspeed3 | MazdaSpeed 3/6 - ECU Computer Tuning | 5 | 08-07-2015 03:38 PM |
| Installed HPFP and now car won't start | buckeyepost | Mazdaspeed3/6 General Discussion | 19 | 08-31-2011 07:53 AM |
| Viper 5901 w/ Remote Start Installed!! | TongMan | MazdaSpeed 3/6 - Car Audio & Electronics | 30 | 05-04-2009 07:15 AM |
