![]() Join Date: Apr 2016 Location: Richmond, VA
| Not Ranked : 0 score The S4 is SUPER sensitive to crank case pressure. It doesn't take much to blow out oil. I would STRONGLY recommend a PCV plate and using Damond's OCC routing diagram pictured here. Also, check your AFRs. If you're running rich, you might see some blue smoke. |
| The Following 2 Users Say Thank You to Solarsurge For This Useful Post: | BuddySpeed3 (06-14-2018), Thor Hammer (06-13-2018) |
Fstrnyou sometimes peoples don't like the oil smell when venting out.
__________________ Mazda for life...or until i can afford something better... 2007 rusted Speed6... Forged with meth and a 3076 in progress... 1993 Ford Probe KLZE 143dB 2012 Mazda3 Gs-sky 6.5l/100 when transporting speed parts 1989 GM 6.2 diesel pickup Wife drive 2010 CX7 2007 speed3 burned (i'm proud to ran 12.7s with it) ...Because French Canadian... If you check for leaks and you didn't made a test under compressor pressure, you aren't done checking for leaks.... | |
| Not Ranked : 0 score |
| Not Ranked : 0 score i know, but it get worst when venting VTA....especially if occ filter is high in the engine bay...
| intermittent smoke | Savo1997 | Mazdaspeed3/6 General Discussion | 7 | 06-22-2015 07:51 PM |
| white smoke after e85 mix | bshotts422 | 2010 MS3 - Troubleshoot/Diagnostics | 123 | 04-20-2014 08:44 PM |
| white smoke | Dslatch4 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 19 | 11-12-2013 10:06 AM |
| White smoke | aldekei | 2010 MS3 - Troubleshoot/Diagnostics | 7 | 07-22-2013 12:26 PM |
| White smoke? PLEASE HELP | Fallenvoices | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 13 | 01-06-2010 03:39 PM |
