![]() Join Date: Aug 2012 Location: Toronto, Ontario, Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 165
Groaned at 7 Times in 4 Posts
(Thread Starter) | Neutral : +1 score Has anyone had a similar issue with a Bnr turbo? Thanks guys
__________________ - 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 3 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress) Last edited by BuddySpeed3; 11-09-2018 at 06:12 PM. |
![]() Join Date: May 2016
Rep Power: 53 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14
| Not Ranked : 0 score I think the restrictor bolt is for the stock turbo so I wouldn't go that route. Sent from my XT1565 using Tapatalk |
| The Following User Says Thank You to tom10122 For This Useful Post: | BuddySpeed3 (10-16-2017) |
![]() Join Date: Dec 2013 Location: Plainfield, IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,712
| Not Ranked : 0 score Yea definitely put the stock banjo bolt in the s4, it's designed with that oil flow in mind. Have you done a compression or leak down test? Also, what oil are you using?
__________________ 2010 black mica speed3 The go: Depo racing: downpipe (100 cell count), custom: FMIC. HTP: 3.5" intake, under route piping. JBR: shortshifter, RSB. Autotech: HPFP internals. Go fast bits: hybrid BPV, VMR: 18x8.5 V710s, Bridgestone: potenza re760 245/40/18, KW: v3 coilovers,SPC: camber arms, freektuned, Damond Motorsports: dual OCC, PMM, PCV plate, RMM, TMM, EGR delete, FoSt mani, Corksport: battery box(fuck this thing), injector seals, Cobb: EBCS, AP v3. AEM: methanol. Seibon: carbon fiber hood. UR: catback. Bosch: 3bar. BNR: s4, DNP: EWG manifold, Tial: 38mm mvs EWG. The show: 5% tint all around, 50% tint windshield, rally armor mudflaps, Sony XAV64BT touchscreen headunit, katskin leather interior, CPE relocation plate, Maisonvi weighted shift knob, Corksport hoodscoop, black housing headlights. Soon:built motor |
| The Following 2 Users Say Thank You to Djohns For This Useful Post: | BuddySpeed3 (10-16-2017), MD1032 (12-24-2017) |
I spoke to Bryan at Bnr Supercars today and he said that there is a specific oil restrictor bolt for the Bnr S4. It is sold here: Shop Now I also asked him if it would be ok to use a JBR bolt, but he said that the hole on the JBR is slightly bigger, so he highly recommended this one with a 0.060 hole. I'll give this a shot and hope for the best Thanks, I'll report back with my findings.
__________________ - 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 3 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress) | |
| Not Ranked : 0 score There's a specific bolt that needs to be used and it's not included with the turbo? That's fucking retarded. And the JBR restrictor bolt is larger than the recommended bolt?? How tiny is that damn thing.
| The Following 2 Users Say Thank You to Djohns For This Useful Post: | 2008mazdaspeed3! (10-18-2017), MD1032 (12-24-2017) |
| Not Ranked : 0 score I get puffs of smoke on occasion. Can't see it from my seat but others have reported it to me. Heard it could be oil rings? My compression #'s are good as well.
Bryan said that the bolt is only needed if your car has smoking issues but that every car will be different, and if there are any smoking issues the 0.060 bolt is recommended because it pretty much guarantees no smoking, yet still provides sufficient oil supply. He also said that using a bolt with a slightly bigger hole may work, but that it's better to buy the recommended bolt once and forget it. It very well could be turbo seals. Are you using the stock banjo bolt? Maybe try contacting Corksport to see if they've seen any issues with their turbo's smoking?
| Not Ranked : 0 score My buddy suggested turbo seals as well, as the smoking was noticed within a week of putting that turbo on. However, I put on a catless DP too. If it was smoking before, my cat could have been masking it? Can't be certain. The Corksport turbo came with a new banjo bolt and, if i recall correctly, it's restricted. The stock bolt was wide open. Also, I'm running 2 OCC's, so I doubt crankcase pressure is an issue. The PCV OCC is VTA. During clutch swap the other weekend, we pulled the turbo and exh mani to see if there was any excessive oily residue pre and post turbo. Pre-turbo would indicate engine issue. Post-turbo oil with pre-turbo clean would indicate turbo issue. However, I guess my issue is minor enough that we didn't see anything out of the ordinary.
It was the most cost effective way to vent my setup without buying a whole new one and it claims to have the best results. I wonder how big the hole is on the corksport restriction bolt?
| Not Ranked : 0 score I have 2 OCCs. The one from the valve cover returns to the TIP, so it always sees at tiny bit of vacuum. The one from the PCV returns to the manifold with a check valve for vacuum operation and the catch can is VTA with another check valve so it breathes in boost.
![]() Join Date: Oct 2012 Location: Colorado Springs, CO
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 757
| Not Ranked : 0 score Interesting that there is a specific restrictor and you had to ask.... sounds like the seals are looser than stock by design and the alternate banjo is only for those that notice? T6 isn’t exactly a ‘light’ oil I would imagine people running lower weight would see more loss?
__________________ mods: \\// AT HPFP // AccessPort // CS S2 TIP, SRI and TMIC // CPe S2 RMM // Synapse BPV // Mazda gutted secondary cat // S-OTS+ 91S2 // HKS TP DLi II // Wilwood DP6 13” brakes // TCE 2 piece rear rotors // Maxwell SuperCap/LiFePO4 cell \\// waiting for install: \\// CPE Catted DP // CS Battery Box // Devils Own Meth kit // H&R Coilovers \\// |
![]() Join Date: Nov 2013 Location: Germantown, MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 15
| Not Ranked : 0 score Just noticed smoking at idle with my BNR s4 v2 as well. Only had it for a few days and I have a catted dp and 2 OCC setup. I did notice some oil on the vented OCC filter. @BuddySpeed3 keep us posted on the banjo bolt for the s4. I think I'm going to try that as well.
__________________ MS6/SP63 Stage 1 build/APv3/BNR S4 v2/hpfp internals/JBR full 3" intake/ATP catted dp/Magnaflow cbe/GFB bov/Damond OCC/Damond egr delete/Treadstone TR1035 FMIC kit/CPE rear diff mount/CPE safe seals/Damond rmm/H&R co/18x9 conti dws 235-40/Stoptech bbk/morimoto xb led fogs/Osram Xenarc d2s 6000K bulb/osram led parking light/Led Tails/Purple Drank Tuned |
When the engine is at operating temprature, there is barely any smoke at idle and or slight throttle in between shifts. But at WOT, there is a lot of smoke in between shifts even with the engine warm. This might be because the turbo seals and bearings expand as they warm up reducing the clearances, in turn reducing the amount of oil seeping past. I have a feeling the majority of the oil seeping past the seals is happening at WOT in between shifts and I'm not sure why. I went to the track back in October for some open lapping, and people noticed a lot of smoke from my tail pipe. They described it as a blueish blackish whitish smoke. I too would notice it between shifts in my rear view mirror (puffs or plooms of smoke only in between shifts). I kept having to top up my oil as it would drop down near the min line every 5-6 laps. That's why I did a compression test and found all cylinders to be above 180 psi, indicating that the oil must be getting past the seals. I will definitely keep this thread posted and please let us know if anyone has any thoughts or experiences on this as well. Thanks
__________________ - 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 3 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress) Last edited by BuddySpeed3; 12-02-2017 at 01:52 PM. | ||
| The Following User Says Thank You to BuddySpeed3 For This Useful Post: | afronese1 (12-17-2017) |
![]() Join Date: Jun 2013
Rep Power: 0 ![]() Thanks: 2
| Not Ranked : 0 score I am having similar issues with my S4. Just replace today the banjo bolt still smoking. Compression test is 170 and 160 in #3 . I use the car yesterday an oil go low. I have jbr occ since the car has 7xxx miles. I just need to to leak down test and make sure my pcv is not restricted. Buddyspeed3 how many miles is in your S4? |
I only noticed oil consumption about 2 months after installing the turbo when I decided to check my oil, and saw that it was a little too far below min for comfort. Ever since then I've been keeping an eye on the oil level and have noticed patterns on when it drops in relation to how I've been driving the car. Cruising around peacefully, it barely consumes any oil. It's only when boosting a lot do I see higher consumption. I don't think I have an issue with the engine as my compression results checked out at 180 psi across all cylinders. Also I've got zero oil coming out of the valve cover breather indicating that my vented OCC setup is working. I will go ahead and verify that my pcv valve and OCC check valves are in good working order when I bring the car back out in the spring and install a few more performance goodies.
Groans: 111
| Not Ranked : 0 score If you pull the downpipe it's easier to see if the turbo leaks oil in the exhaust.
(Thread Starter) | Not Ranked : 0 score So I should be able to see oil near the turbine wheel?
| The Following User Says Thank You to Yllib30 For This Useful Post: | BuddySpeed3 (12-05-2017) |
Groans: 111
| Not Ranked : 0 score Yeah, and a lot of black crap trapped by that oil around the shaft, actual wheel, and so on. You should see that the black crap I mentioned is also kind of moist and looks like snoot with dust...
__________________ MS6/SP63 Stage 1 build/APv3/BNR S4 v2/hpfp internals/JBR full 3" intake/ATP catted dp/Magnaflow cbe/GFB bov/Damond OCC/Damond egr delete/Treadstone TR1035 FMIC kit/CPE rear diff mount/CPE safe seals/Damond rmm/H&R co/18x9 conti dws 235-40/Stoptech bbk/morimoto xb led fogs/Osram Xenarc d2s 6000K bulb/osram led parking light/Led Tails/Purple Drank Tuned | |
I have an OCC with a vented check valve tee'd off the line going from the IM to OCC, but I may get rid of that check valve and am going to run a gen 2 valve cover with the SP63 breather cap. Hopefully this will pull more vacuum on the crankcase and relieve excess pressure at WOT. This video illustrates how well that setup works. I plan to keep the valve cover hose going into the turbo inlet for more vacuum: https://www.youtube.com/watch?v=T5bG_EkTHhM I've also got the JBR oil restrictor bolt installed but haven't really had enough time to monitor if it has helped. If even after all this I still get oil consumption, I will try and seek out the oil restrictor bolt that Bryan @ BNR recommended found here: Shop Now If that doesn't work then we'll go from there.
| Not Ranked : 0 score Why get rid of that check calve? It vents under pressure, which is what you want.
![]() | | #24 | ![]() |
Groans: 111
However, when I had this problem with my UR catted DP v1 (initially had a ceramic cat which i replaced wich a metallic cat) my problem was that I broke the cat, as in shattered it. Probably too muchuse of launch control. Now I have another UR catted DP (v3) with a metallic magnaflow cat and this one seems to be holding up perfectly. As for the oil level issues... since you all noticed the low oil level days after installing the S4 - well that's bad news for you. However, some people may have broken the ringlands in the process of tuning, that simply happens sometimes on tired motors which all of a sudden have to deal with even more cylinder pressure. The increase of oil consumption may be another result of installing a big turbo and running with not enough timing. the extra air and fuel in the cylinders result in even bigger flames torching the exhaust valves during the exhaust stroke. I'm not trying to draw the guilt away from the BNR turbos, I'm only trying to make a list of all possible issues that can lead to the oil consumption problem when going BT especially on relatively beaten motors. Sometimes pulling the exhaust manifold and/or the downpipe just to take a look at the turbo can be enlightening.
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI | |
![]() | | #25 | ![]() |
![]() | | #26 | ![]() |
| Not Ranked : 0 score Built motor has rebuilt head?
![]() | | #27 | ![]() |
![]() | | #28 | ![]() |
Groans: 111
| Not Ranked : 0 score I take it the weather is colder in your area as well these days, unless you're in AUS or NZ. So that "white smoke" when you first start the car cold is condensation, is normal and natural.
![]() | | #29 | ![]() |
Groans: 111
So if it's your daily and you care that much about the noise you should seriously consider staying catted. I've been in that situation as well and ended up going with catted DP and catted TP. With a 3" catback it made a huge difference and I lost like 2HP which I later gained back by upping the WGDC. I always had a catted DP, but adding this little unicorn here instead of the existing one made the cabin noise just perfect, not to loud, not too silent, just perfect. And now I can open the trunk when the car is still idling without impregnating all the luggage and clothes with burnt gas smell. Ultimate racing custom made me an unicorn Now they have this part listed on their site as well, for who wants to go silent and kick nissan GTR/porsche 911/ BMW M series fat asses.
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI Last edited by mituc; 12-20-2017 at 10:10 PM. Reason: MSF Database - Automerged Doublepost | |
![]() | | #30 | ![]() |
![]() | | #31 | ![]() |
![]() Join Date: Apr 2016 Location: Richmond, VA
| Not Ranked : 0 score I just got a new BNR S4 v2 to replace my stock K04 that blew. At first I thought I was just burning off residual oil from the blown K04. However, it smokes very heavily after 400 miles and I’m losing oil by the quart daily. As others have mentioned, the smoking seems to subside as things heat up. Cold, it’s a god damned fog machine. Checked compression and I have less than 1% variance per cylinder. I’m really lost here. Anyone figure anything out? |
| The Following User Says Thank You to Solarsurge For This Useful Post: | BuddySpeed3 (01-07-2018) |
![]() | | #32 | ![]() |
This spring I'm installing a Gen 2 valve cover with the Sp63 breather cap to ensure minimal crankcase pressure (I also have good compression). I figure since the majority of oil consumption is at WOT and not part throttle, slight crankcase pressure may be preventing proper oil drainage out of the turbo. What's annoying is that my K04 never smoked with my current PCV setup. I'm thinking there is more blow by from the increase cylinder pressures associated with the increased boost. We'll have to see this spring if the Gen 2 cover and breather cap along with the Jbr bolt solve this issue.
![]() | | #33 | ![]() |
Groans: 111
One other thing to consider: other people with similar setups but only different turbos (garrett, corksport, pte) have these oil consumption issues? Because if they don't (and they don't!) and if in your case the massive oil consumption only started right after swapping the turbo I think you should have a word with BNR.
![]() | | #34 | ![]() |
![]() | | #35 | ![]() |
Groans: 111
| Not Ranked : 0 score Well, cylinder 3 and then 2 are the Achile's heel for these motors. If you noticed anything out of the ordinary despite apparent normality then assume the abnormality.
![]() | | #36 | ![]() |
| Not Ranked : 0 score Block test and leakdown test were fine. Mechanic officially diagnosed as bad turbo seals in the brand new S4. Looks like I’ll be pursuing a warranty replacement. Sent from my iPhone using Tapatalk |
![]() | | #37 | ![]() |
| Neutral : +1 score Turned out to not be a bad new S4. Bryan from BNR Supercars quickly identified it as a crank case ventilation issue. After further investigation, it turned out the oil and coolant mixed as a result of the original blown turbo, the water in the coolant vaporized and sent steam to my catch can, which collected and froze in my catch can due to the arctic temperatures we’ve had, causing a line to clog. This made my crank case pressurize, preventing oil from draining out of the turbo. Sent from my iPhone using Tapatalk |
| The Following 2 Users Say Thank You to Solarsurge For This Useful Post: | BuddySpeed3 (06-12-2018), mituc (01-14-2018) |
![]() | | #38 | ![]() |
(Thread Starter) | Not Ranked : 0 score Ok so a little update... Smoking is still happening only at WOT but has improved a little bit. It's worse if the oil hasn't fully warmed up. Compression was checked and resulted in 180 psi across all 4 cylinders. I've removed oil return line and verified no blockage in the line, engine block, and turbo cartridge. Puffs of whitish blueish smoke occur more noticeably if I hit the throttle hard as opposed to gradually going WOT. It's also noticebly smokey if I hit the rev limiter (accidentally). It seems very much related to crankcase pressure as it only happens at WOT. If I rev the engine out to high rpm at part throttle to raise oil pressure, it doesn't smoke at all. Things that have helped but not fully cured the issue: 1. Gen 2 valve cover w/ Sp63 oil breather cap; VC breather still routed to turbo inlet for vacuum 2. DM stage 2 vented catch can with vent routed to turbo inlet for added vacuum 3. Oil restrictor bolt from BNR (smaller hole than JBR bolt) 4. Switching back to 5w30 (was running 5w40 Rotella T6) as it drains out of the turbo more efficiently as per Bryan. I really don't want to have to send it out to Bryan to get rebuilt. Has anyone had a similar issue with the S4? If so what was your solution? Thanks! Erik
__________________ - 2009 Speed 3 - Clocked BNR S4 v2 - Corksport 3.5" Intake - Cobb 3 Port Bcs - Cobb AP V2 - Guardian Angel V3 - Tr8 Fmic w/ Jbr Under Route Piping - Jbr Raiders Air Damn w/ Custom Radiator Side Ducting - Cpe Catless Dp - Cnt Catback - Cobb Xle Bpv - Corksport IM - Full Race EM - Cobb Shift Knob - Autotech Internals - Corksport HP Fuel Line - Gen 2 VC w/ Sp63 Oil Breather Cap - DM PCV Plate w/ Dual Vented Catch Cans - Jbr 88a Rmm - 88a Tmm - 80a Pmm - Corksport Injector Seals - Ngk 1 Step colder Plugs - Koni Yellow Shocks - Eibach Springs - 94 Octane w/ 3 Gallons of In Tank Methanol - Sp63 6th Port Kit (tune in progress) Last edited by BuddySpeed3; 06-12-2018 at 09:42 AM. |
![]() | | #39 | ![]() |
| Not Ranked : 0 score The S4 is SUPER sensitive to crank case pressure. It doesn't take much to blow out oil. I would STRONGLY recommend a PCV plate and using Damond's OCC routing diagram pictured here. Also, check your AFRs. If you're running rich, you might see some blue smoke. |
| The Following 2 Users Say Thank You to Solarsurge For This Useful Post: | BuddySpeed3 (06-14-2018), Thor Hammer (06-13-2018) |
![]() | | #40 | ![]() |
| Not Ranked : 0 score I like that routing, but I would have both cans VTA.
| The Following User Says Thank You to Fstrnyou For This Useful Post: | BuddySpeed3 (06-14-2018) |
| intermittent smoke | Savo1997 | Mazdaspeed3/6 General Discussion | 7 | 06-22-2015 07:51 PM |
| white smoke after e85 mix | bshotts422 | 2010 MS3 - Troubleshoot/Diagnostics | 123 | 04-20-2014 08:44 PM |
| white smoke | Dslatch4 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 19 | 11-12-2013 10:06 AM |
| White smoke | aldekei | 2010 MS3 - Troubleshoot/Diagnostics | 7 | 07-22-2013 12:26 PM |
| White smoke? PLEASE HELP | Fallenvoices | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 13 | 01-06-2010 03:39 PM |
