![]() | | #41 | ![]() |
![]() Join Date: Oct 2015 Location: South Africa
Rep Power: 0 ![]() Thanks: 0
Groaned at 6 Times in 2 Posts
| Not Ranked : 0 score For the BNR s2, did you upgrade the MAP sensor as well? Or only 3 port EBCS ? I got a bnr s2, but would like to find out on upgrading the MAP sensor as well? |
![]() | | #42 | ![]() |
Groans: 438
| Not Ranked : 0 score If you are planning on running anything above 21psi, you should upgrade the MAP sensor. It isn't NEEDED, but highly recommended. The stock one pegs out around 22.8psi, so if you were to go past that, you would never know unless you upgrade.
__________________ All good things must come to an end... |
| The Following User Says Thank You to g00s3y For This Useful Post: | Vansquish (03-07-2016) |
![]() | | #43 | ![]() |
![]() Join Date: Dec 2013 Location: Tampa, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 462
| Not Ranked : 0 score Thread is from 2010. Nobody runs a bnrs2 anymore...
__________________ The line up: 2013 G37 loaded...not stock for long 2013 MS3...stock to midturbo back to stock (traded) 2009 Nissan Frontier LE loaded...big stereo system (traded) 2009 Cadillac CTS sport package...stock (blown and traded piece of shit) 1994 Integra RS built all motor (sold) 1990 Civic EF nitrous turbo motor swapped beast (sold) 1987 Dodge pick up...jacked up (sold) |
![]() | | #44 | ![]() |
| Just a 6 year thread necro to start the day. sent from my Nexus 6P
![]() | | #45 | ![]() |
| Not Ranked : 0 score Thanks, I know this is old, sorry about this, still fresh with this turbo in South Africa, I will continue with the stock MAP first, then i will see as the tune progress. Thanks for the feedback!!! |
![]() | | #46 | ![]() |
![]() Join Date: Jun 2010 Location: The Netherlands
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3
Groaned at 3 Times in 1 Post
(Thread Starter) | Not Ranked : 0 score Just to let you guys know 2weeks ago the stage2 Died... sad story but she went up in smoke... and here comes the fail.... iam ordering a new CHRA stage2 cause FUCK the Import tax! a 1250dollar Beanerblower Stage4 turns into a 2000euro investment and i say hellll NO to that...
__________________ Dutch Mazda 3 MPS Mica Black. MODS - COBB FMIC - COBB SF Intake - COBB TurboInlet - TurboSmart BOV - NGK LTR7IX - BNR Stage2 Turbo - PG Turbo Manifold - COBB Downpipe - COBB AP V3 - COBB Swaybars - TRZ RRM - TRZ TMM - NRG Torque damper - 2x Greddy OCC - PCV Mod - Homebrew tune in the making ![]() |
![]() | | #47 | ![]() |
![]() Join Date: May 2012 Location: Virginia Beach, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 101
| Not Ranked : 0 score lol
__________________ 2012 Crystal White Pearl MazdaSpeed 3 Mods: BNR S4 V2 // XS Power Manifold V3 // JBR Tru-3.0" Aluminum Intake // Devils Own WMI D10 NOZZLE// JBR DISI Bypass Valve Hose // JBR 70duro RMM // JBR SSB // JBR SSP // JBR Coolant Bypass Kit // DM EGR Full Delete Kit // DM TMM // DM PMM // COBB AP V2 // CNT Racing Catless Downpipe // CP-E TMIC // CP-E Injector Seals // SP63 Valve Cover Breather // Custom 3" Magnaflow exhaust //One Step Colder NGK Plugs // Bosch 3bar Map sensor // Grimmspeed EBCS // MD OCC // MD PCV Plate // Stop Tech Braided Lines // Autotech Internals // Forge BPV V1 // Corksport V2 RSB // Eibach PRO-kit Stratified Tuned Stage 2 OTS+ 273whp/330wtq SnailD Tuned on Meth 316whp/359wtq Purple Drank Tuned BNR S4 V2 and 100%Meth 412whp/373wtq |
| Feedback on the Stage2+SF 93 map | speedzilla | MazdaSpeed 3/6 - ECU Computer Tuning | 5 | 04-16-2010 12:11 PM |
| Stage2+SF 93 Octane | manofhonor24 | MazdaSpeed 3/6 - ECU Computer Tuning | 13 | 10-05-2009 11:06 PM |
| Stage2+SF 93 v103 MAF Fix | evidence | MazdaSpeed 3/6 - ECU Computer Tuning | 15 | 05-12-2009 02:13 PM |
| 1.03 stage2+sr 91 -> 93 - logs | evidence | Cobb Access Port/Maps | 1 | 04-04-2009 06:53 AM |
| Stage2+SF 91 +TMIC | prspect | Cobb Access Port/Maps | 7 | 02-21-2009 11:07 AM |
