Like Tree4Likes
 Old 08-01-2013, 03:42 PM   #41
timjustindodd's Avatar
Posts: 45   (View Stats)
timjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the worldtimjustindodd is the leader of the world
With the boost dial you are still controlling boost from the ECU but doing it using the solenoid in 2 port mode.
The reason why it wins in my testing is that you can keep the load dynamics closer to OEM. The less neutering you do of the load control system, the better the car will drive.
You can control boost using either solution and the BNR is very forgiving when it comes to 3 port control. However when trying both, the driveability is better using a 2 port setup versus a 3 port and the boost dial allows you to use the OEM 2 port on non OEM turbos.
Yo LEX. What specific MBC do you recommend? I'm ordering one up now. How the hell do you tune with one of those? Drive, pull over dial back, drive test?!? Seems silly... but I'll trust you if you think it's the best.
2006 Mazdaspeed6 | SNR S3 | Stratified Tune | Corksport DP | Corksport TP | Cobb AP | SU TMIC | HTP 3" intake | HTP battery tray | 3 bar MAP | HPFP | Whiteline rear sway bar | SU Rear engine mount | SU rear diff mount | Forge BPV
timjustindodd is offline   Reply With Quote
 Old 08-01-2013, 04:10 PM   #42
LilGator's Avatar
Posts: 136   (View Stats)
LilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond reputeLilGator has a reputation beyond repute
Groaned at 6 Times in 3 Posts
You quoted the answer to your question right there: "With the boost dial you are still controlling boost from the ECU but doing it using the solenoid in 2 port mode."
This is what you want: Stratified Boost Dial [BOOST DIAL (0100-0004.1)] - $70.00CAD : Stratified Automotive Controls
2007 Speed6 GT - LPM
RMM 88 | JBR SSP, SSB & Heavy Knob | NGK Iridiums | Cobb AP
SURE Full3 3" Aeros | M2 Downpipe | Autotech Internals | Forge BPV
MagnaFlow CBE | SURE Dreadnaught / Juggernaught | Whiteline RSB | H&R Sports
E85 Stratified
LilGator is offline   Reply With Quote
The Following User Says Thank You to LilGator For This Useful Post:
timjustindodd (08-01-2013)
 Old 08-01-2013, 11:23 PM   #43
Thanks LilGATOR!
TMIC > FMIC > back to TMIC - my journey dale_gribble Mazdaspeed3/6 General Discussion 95 12-14-2012 04:58 AM
upgrade TMIC or FMIC without tune punisherB273 2010 MS3 - Turbo Induction 14 12-06-2011 07:27 PM
TMIC/BPV Upgrade Tune Airman3454 2010 MS3 - ECU Computer Tuning 15 12-02-2011 02:09 PM
HP Gains- fully bolted w/stock TMIC vs. FMIC/bigger TMIC Chimmike MazdaSpeed 3/6 - Turbo Induction 6 07-04-2011 03:18 PM
Page generated in 0.24290 seconds with 21 queries
