 Old 04-10-2008, 03:09 PM   #1
speed3's Avatar
Posts: 504   (View Stats)
speed3 has a brilliant futurespeed3 has a brilliant futurespeed3 has a brilliant futurespeed3 has a brilliant futurespeed3 has a brilliant futurespeed3 has a brilliant futurespeed3 has a brilliant futurespeed3 has a brilliant futurespeed3 has a brilliant futurespeed3 has a brilliant futurespeed3 has a brilliant future
Groans: 56
Groaned at 43 Times in 21 Posts
Default Boost Controler Question
i have hallman bc and it is connected right. the thing is when i turn it down all the way i'm still hitting 17psi. what is up with this shit? It seems to be a good bc. $100 i paid. I'm positive is connect right. 100%. Anyone can help me?
2008 BM..MSCAI..8K HID..MAGNAFLOW CB..<----- SOLD
Current car: 1991 Sport 600 Z32. 487whp on 91 Octane
speed3 is offline   Reply With Quote
 Old 04-10-2008, 06:29 PM   #2
Bravnik's Avatar
Posts: 383   (View Stats)
Bravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond reputeBravnik has a reputation beyond repute
Groaned at 33 Times in 22 Posts
Did you disconnect the factory boost controller? My bet is no.
Bravnik is offline   Reply With Quote
 Old 04-10-2008, 07:59 PM   #3
speed3's Avatar
Groans: 56
you mean the boost solenoid. yes, And I Aslo put a cap on it.
 Old 04-10-2008, 09:48 PM   #4
Davidb's Avatar
Posts: 218   (View Stats)
Davidb is the leader of the worldDavidb is the leader of the worldDavidb is the leader of the worldDavidb is the leader of the worldDavidb is the leader of the worldDavidb is the leader of the worldDavidb is the leader of the worldDavidb is the leader of the worldDavidb is the leader of the worldDavidb is the leader of the worldDavidb is the leader of the world
I have the turbosmart...its a different brand but they do the same thing. When I turn mine all the way down I only hit 12-13psi...But I also see that you don't have the stock bpv....that might be something as well...
08 Cosmic Blue MS3
Autox pwns j00!!!
Davidb is offline   Reply With Quote
 Old 04-10-2008, 10:32 PM   #5
surfwagon's Avatar
Posts: 456   (View Stats)
surfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the worldsurfwagon is the leader of the world
I have a Hallman BC on my Z and I don't have that problem. I'm at 15 psi. I'm puzzled.
2012 G37S; 7 speed paddle shifters
2007 Mazdaspeed3 GT; Hypertech Tuned, MS CAI, ETS 3" TMIC, Catless CorkSport Down-Pipe, Catted Corksport Mid-Pipe, Corksport Cat-Back Exhaust, Forge II BPV, Cobb front and rear sway bars, KW V1 Coilovers, JBR Shifter Plate, TWM STS/Bushing, SU Rear Mount, GROM ipod link, Sub/Amp added to Bose - Sold
1995 Nissan 300ZX Twin Turbo; SRI - ASHSPEC ECU - MBC @ 14psi - Turbo-Back Exhaust - Larger Intercoolers - RPS Street Sport Clutch - RPS Flywheel - Megan Springs - Subframe Spacers - 51,000 original miles - Thrill Ride and Sold
surfwagon is offline   Reply With Quote
 Old 04-13-2008, 12:25 PM   #6
det_ms3's Avatar
Posts: 479   (View Stats)
det_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the worlddet_ms3 is the leader of the world
Map Claps, Boost Cut Defenders? make sure you have either one. From what I've been gathering its preference but the Clamp will fool the ECU so for my money thats what i'm gonna go with.
2008 Sunlight Silver MS3 the toy
2012 Chrysler 200 Limited 3.6l the daily driver
det_ms3 is offline   Reply With Quote
 Old 04-15-2008, 05:31 AM   #7
Fux Wit It
Darksun280's Avatar
Posts: 9,214   (View Stats)
Groans: 175
yo I've had three differnt ones and this is what i've noticed
Forge: All the way down i was still hitting 18 PSI. Not a defect others have said the same thing. Very bad spike 5-8 psi more than what its set at.
Turbosmart: Not bad spikes hihg when you step on a tall gear but only 4-5 psi more then it going to hold. Turned all the way down i was at 10-11 psi
Turboxs Hi low dual stage: So far gorgeous. all the way down 8-10 psi. spike 1-2 psi more then the hold. On the fly switching. I'm so happy my boy gave me this one for free. I'll takes pics today for the peoples.
 Old 04-15-2008, 07:06 PM   #8
TRU-BOOST's Avatar
Posts: 801   (View Stats)
TRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the worldTRU-BOOST is the leader of the world
shit if i turn my turbosmart MBC all the way down my car only hits 9 psi !! you have a problem somewhere.
TRU-BOOST is offline   Reply With Quote
 Old 04-15-2008, 07:11 PM   #9
mrlilguy157's Avatar
Posts: 606   (View Stats)
mrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the worldmrlilguy157 is the leader of the world
joeP for the win!
Black Mica '07 Mazdaspeed3
Mods:CP-E FMIC - ProtegeGarage Tubular Exhaust Manifold - TurboXS Hybrid BOV, Downpipe, and Custom Catted Racepipe - mrlilguyCDFP - ATP 3" Turbo Inlet - ATP Boost Cut Killer Module - CP-E Rear MM - WelderWerkz Short Shifter - AEM UEGO Wideband - ProSport Blue Boost/EGT/Oil Pressure Gauges - GReddy Full Auto Turbo Timer - PimpWheels Black/Red Edition - Falken Azenis RT-615 - Yakima Roof Rack w/ Fairing
Reppin' ProtegeGarage for life!
mrlilguy157 is offline   Reply With Quote
hypothetical question phailerider MazdaSpeed 3/6 - Turbo Induction 34 04-17-2008 01:06 PM
Boost Controler Question speed3 MazdaSpeed 3/6 - Turbo Induction 13 04-02-2008 06:09 PM
question for driver311? bombdotcom MazdaSpeed 3/6 - Turbo Induction 8 03-31-2008 06:13 PM
Page generated in 0.33605 seconds with 27 queries
